AshuraX Posted August 15, 2014 Posted August 15, 2014 Hello, I come to you because I intended on launching Ultra Street Fighter 4 on PC. I just bought it via steam, and suddenly not having my cabinet connect to nternet,si i crack the file steam.api etc ... The game starts by executing perfectly SSFIV.exe. After adding in my Steam Database and have set on hyperlaunch HQ, the game does not start, and I have an error message concerning the fadetitle. After some research, I use windows active log to see which games actually use the command to start the games. I retrieves the command "FadeTitle = SSFIVAE ahk_class SSFIVAE" I added to my files and PCGames.ini PClauncher.ini in the folder of my module. But here is the game still does not launch. Could someone enlighten me? I apparently the same concern about KOF13 PC. thank you Ash My WIP Projects :Bezel Project Mame Horizontal : https://imageshack.com/a/auM4/1 Mame Vertical : https://imageshack.com/a/jEM4/1 Cave full pack : https://imageshack.com/a/7eJ4/1 Capcom : https://imageshack.com/a/eIM4/1 Themes Neo Geo Full Theme Pack : https://imageshack.com/a/oeJ4/1Mega CD Boxart : new thread will come....My First Cab Build : http://www.hyperspin-fe.com/topic/1221-ashurax-mon-projet-ghouls-ghost-arcade-cab/
AshuraX Posted August 15, 2014 Author Posted August 15, 2014 ok,i found alone the solution. My WIP Projects :Bezel Project Mame Horizontal : https://imageshack.com/a/auM4/1 Mame Vertical : https://imageshack.com/a/jEM4/1 Cave full pack : https://imageshack.com/a/7eJ4/1 Capcom : https://imageshack.com/a/eIM4/1 Themes Neo Geo Full Theme Pack : https://imageshack.com/a/oeJ4/1Mega CD Boxart : new thread will come....My First Cab Build : http://www.hyperspin-fe.com/topic/1221-ashurax-mon-projet-ghouls-ghost-arcade-cab/
FaithLes Posted August 16, 2014 Posted August 16, 2014 Hallo. Im having the same issue but, this is with steam games in general. to make MKKE launch via steam i had to crack it meaning no online. i dont want that for USF4. Any help is greatly aprisiated.
boomerps2 Posted August 17, 2014 Posted August 17, 2014 ok,i found alone the solution. What is the solution?
owlnonymous Posted September 17, 2014 Posted September 17, 2014 What is the solution? +1 Having the same issue, but my copy says "steam must be running to play this game" when trying to start the game via the SSFIV.exe The shortcut that the game creates is a steam:// (game name) url, which I was able to launch from a .bat file that I wrote using a web browser, but since the launch bat and .exe names are different, the game will not close.
