Fusion screen flickering and changing resolution
sonicboom88
Hi Guys having problems with fusion if it goes to full screen it keeps flickering and changing resolutions. It Was working fine until yesterday I am on windows 8.1 disabled UAC.
Hyper Helper Ready To Help
15:05:10:659 | HL |     INFO  | +N/A   | Main - HyperLaunch v3.0.1.1c
15:05:10:792 | HL |     INFO  | +140   | Main - System Specs:
				HyperLaunch Dir: G:\Hyperspin\HyperLaunch
				OS: Microsoft Windows 8.1 Pro
				SKU: Professional
				Total Memory: 16342.88 MB
				Free Memory: 12832.42 MB
				Used Memory: 3510.461 MB
				SystemType: x64-based PC
				Physical Processors: 1
				Logical Processors: 4
				GPU 1 Name: AMD Radeon HD 6670
				GPU 1 RAM: -2048.00 MB
				GPU 1 Driver Version: 13.251.9001.1001
				Sound 1 Device: USB Audio Device
				Sound 1 Status: Enabled
				Sound 2 Device: Sound Blaster X-Fi Xtreme Audio
				Sound 2 Status: Enabled
				Sound 3 Device: AVerMedia TV Tuner Card, M156 (PCI, PAL/SECAM/FM)
				Sound 3 Status: Enabled
				Sound 4 Device: High Definition Audio Device
				Sound 4 Status: Enabled
				Sound 5 Device: AMD High Definition Audio Device
				Sound 5 Status: Enabled
				OS Language: English_United_Kingdom
				OS Admin Status: No
				Monitor #1 (\\.\DISPLAY4): 1440x900 (1440x860 work)
				AutoHotkey Path: C:\Program Files (x86)\AutoHotkey\AutoHotkey.exe
				AHK Version: 1.1.09.04
				Unicode: No
15:05:10:794 | HL |     INFO  | +0     | Main - HyperSpin.exe coordinates are x y w h
15:05:10:795 | HL |     INFO  | +0     | CheckFile - Checking if G:\Hyperspin\HyperLaunch\HyperLaunch.exe exists
15:05:10:798 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				FileVersion             	3.0.1.1
				File Size:			910336 bytes
				Created:			7/28/2013 - 3:35:52 PM
				Modified:			8/5/2014 - 8:06:21 PM
15:05:10:799 | HL |     INFO  | +0     | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Module Extensions\itextsharp.dll exists
15:05:10:802 | HL |   DEBUG1  | +16    | CheckFile - Attributes:
				FileDescription         	iTextSharp
				FileVersion             	5.4.2.0
				InternalName            	itextsharp.dll
				LegalCopyright          	Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved.
				OriginalFilename        	itextsharp.dll
				ProductName             	iTextSharp
				ProductVersion          	5.4.2.0
				CompanyName             	1T3XT BVBA
				File Size:			3743744 bytes
				Created:			8/16/2014 - 12:55:26 AM
				Modified:			8/5/2014 - 8:06:23 PM
15:05:10:804 | HL |     INFO  | +0     | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Module Extensions\SevenZipSharp.dll exists
15:05:10:807 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				FileDescription         	SevenZipSharp
				FileVersion             	0.64.4841.31212
				InternalName            	SevenZipSharp.dll
				LegalCopyright          	Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3
				OriginalFilename        	SevenZipSharp.dll
				ProductName             	SevenZipSharp
				ProductVersion          	0.64.4841.31212
				CompanyName             	Markovtsev Vadim
				File Size:			165888 bytes
15:05:10:809 | HL |     INFO  | +0     | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Module Extensions\gsdll32.dll exists
15:05:10:812 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			8818688 bytes
15:05:10:813 | HL |     INFO  | +0     | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Module Extensions\BlockInput.exe exists
15:05:10:817 | HL |   DEBUG1  | +15    | CheckFile - Attributes:
				FileDescription
				InternalName
				OriginalFilename
				ProductName
				File Size:			657920 bytes
15:05:10:819 | HL |     INFO  | +0     | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Module Extensions\gdip.ahk exists
15:05:10:829 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
15:05:10:832 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			88789 bytes
15:05:10:834 | HL |     INFO  | +16    | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Module Extensions\RIni.ahk exists
15:05:10:840 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
15:05:10:843 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			67561 bytes
15:05:10:846 | HL |     INFO  | +0     | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Module Extensions\CLR.ahk exists
15:05:10:849 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
15:05:10:852 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			10586 bytes
15:05:10:854 | HL |     INFO  | +0     | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Module Extensions\COM.ahk exists
15:05:10:858 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
15:05:10:861 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			26342 bytes
15:05:10:864 | HL |     INFO  | +15    | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Module Extensions\JSON.ahk exists
15:05:10:867 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
15:05:10:870 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			9203 bytes
15:05:10:872 | HL |     INFO  | +0     | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Lib\Fade Init.ahk exists
15:05:10:875 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:05:10:878 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			1145 bytes
				Created:			8/16/2014 - 12:55:25 AM
				Modified:			8/5/2014 - 8:06:22 PM
15:05:10:881 | HL |     INFO  | +16    | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Lib\HyperPause Init.ahk exists
15:05:10:884 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:05:10:887 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			691 bytes
15:05:10:889 | HL |     INFO  | +0     | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Lib\Keymapper Init.ahk exists
15:05:10:893 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:05:10:896 | HL |   DEBUG1  | +16    | CheckFile - Attributes:
				File Size:			3435 bytes
15:05:10:898 | HL |     INFO  | +0     | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Lib\MultiGame Init.ahk exists
15:05:10:901 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:05:10:904 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			161 bytes
15:05:10:906 | HL |     INFO  | +0     | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Lib\Statistics Init.ahk exists
15:05:10:909 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:05:10:913 | HL |   DEBUG1  | +15    | CheckFile - Attributes:
				File Size:			167 bytes
15:05:10:915 | HL |     INFO  | +0     | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Lib\Fade.ahk exists
15:05:10:918 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:05:10:922 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			25516 bytes
15:05:10:924 | HL |     INFO  | +0     | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Lib\HyperPause.ahk exists
15:05:10:938 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
15:05:10:941 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			360180 bytes
15:05:10:944 | HL |     INFO  | +15    | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Lib\Keymapper.ahk exists
15:05:10:948 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:05:10:951 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			30775 bytes
15:05:10:953 | HL |     INFO  | +0     | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Lib\MultiGame.ahk exists
15:05:10:958 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
15:05:10:961 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			36816 bytes
15:05:10:963 | HL |     INFO  | +0     | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Lib\Bezel.ahk exists
15:05:10:970 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:05:10:974 | HL |   DEBUG1  | +16    | CheckFile - Attributes:
				File Size:			83008 bytes
15:05:10:976 | HL |     INFO  | +0     | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Lib\Statistics.ahk exists
15:05:10:980 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:05:10:983 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			26153 bytes
15:05:10:985 | HL |     INFO  | +0     | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Lib\Rom Mapping Launch Menu.ahk exists
15:05:10:990 | HL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
15:05:10:994 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			63798 bytes
15:05:10:996 | HL |     INFO  | +0     | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Lib\Shared.ahk exists
15:05:10:001 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:05:11:005 | HL |   DEBUG1  | +16    | CheckFile - Attributes:
				File Size:			81966 bytes
15:05:11:007 | HL |     INFO  | +0     | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Lib\XHotkey.ahk exists
15:05:11:011 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:05:11:014 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			28374 bytes
15:05:11:016 | HL |     INFO  | +0     | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Lib\Fade Animations.ahk exists
15:05:11:021 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
15:05:11:025 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			49050 bytes
15:05:11:027 | HL |     INFO  | +0     | Main - HyperLaunch received "Sega Genesis" and "6-Pak (USA)"
15:05:11:036 | HL |     INFO  | +15    | Main - 6-Pak (USA) is using the default emulator: Fusion
15:05:11:039 | HL |     INFO  | +0     | Main - Checking for a [Fusion] section in G:\Hyperspin\HyperLaunch\Settings\Sega Genesis\Emulators.ini
15:05:11:041 | HL |     INFO  | +0     | Main - Checking for a [Fusion] section in G:\Hyperspin\HyperLaunch\Settings\Global Emulators.ini
15:05:11:044 | HL |     INFO  | +0     | Main - Found [Fusion] in G:\Hyperspin\HyperLaunch\Settings\Global Emulators.ini
15:05:11:047 | HL |     INFO  | +0     | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Modules\Fusion\Fusion.ahk exists
15:05:11:050 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			17044 bytes
				Modified:			8/5/2014 - 8:06:24 PM
15:05:11:054 | HL |     INFO  | +16    | Main - CRC Check - CRC matches, this is an official unedited module.
15:05:11:056 | HL |     INFO  | +0     | Main - 6-Pak (USA) will use module: G:\Hyperspin\HyperLaunch\Modules\Fusion\Fusion.ahk
15:05:11:071 | HL |     INFO  | +15    | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
15:05:11:078 | HL |     INFO  | +0     | Main - INI Keys read
15:05:11:080 | HL |     INFO  | +0     | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Module Extensions\7z.exe exists
15:05:11:084 | HL |   DEBUG1  | +16    | CheckFile - Attributes:
				FileVersion             	9.20
				InternalName            	7z
				ProductVersion          	9.20
				File Size:			163840 bytes
15:05:11:087 | HL |     INFO  | +0     | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Module Extensions\7z.dll exists
15:05:11:090 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				FileVersion             	9.20
				InternalName            	7za
				ProductVersion          	9.20
				File Size:			914432 bytes
15:05:11:093 | HL |     INFO  | +0     | CheckPaths - Started
15:05:11:095 | HL |   DEBUG1  | +0     | CheckPaths - Looking for rom: G:\Hyperspin\Emulators\Fusion361\Sega Genesis\roms\6-Pak (USA).7z
15:05:11:098 | HL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: G:\Hyperspin\Emulators\Fusion361\Sega Genesis\roms\6-Pak (USA)\6-Pak (USA).7z
15:05:11:100 | HL |   DEBUG1  | +16    | CheckPaths - Rom not found
15:05:11:103 | HL |   DEBUG1  | +0     | CheckPaths - Looking for rom: G:\Hyperspin\Emulators\Fusion361\Sega Genesis\roms\6-Pak (USA).zip
15:05:11:105 | HL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: G:\Hyperspin\Emulators\Fusion361\Sega Genesis\roms\6-Pak (USA)\6-Pak (USA).zip
15:05:11:108 | HL |   DEBUG1  | +0     | CheckPaths - Rom not found
15:05:11:111 | HL |   DEBUG1  | +0     | CheckPaths - Looking for rom: G:\Hyperspin\Emulators\Fusion361\Sega Genesis\roms\6-Pak (USA).sg
15:05:11:113 | HL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: G:\Hyperspin\Emulators\Fusion361\Sega Genesis\roms\6-Pak (USA)\6-Pak (USA).sg
15:05:11:116 | HL |   DEBUG1  | +15    | CheckPaths - Rom not found
15:05:11:118 | HL |   DEBUG1  | +0     | CheckPaths - Looking for rom: G:\Hyperspin\Emulators\Fusion361\Sega Genesis\roms\6-Pak (USA).gg
15:05:11:121 | HL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: G:\Hyperspin\Emulators\Fusion361\Sega Genesis\roms\6-Pak (USA)\6-Pak (USA).gg
15:05:11:124 | HL |   DEBUG1  | +0     | CheckPaths - Rom not found
15:05:11:126 | HL |   DEBUG1  | +0     | CheckPaths - Looking for rom: G:\Hyperspin\Emulators\Fusion361\Sega Genesis\roms\6-Pak (USA).sms
15:05:11:129 | HL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: G:\Hyperspin\Emulators\Fusion361\Sega Genesis\roms\6-Pak (USA)\6-Pak (USA).sms
15:05:11:132 | HL |   DEBUG1  | +16    | CheckPaths - Rom not found
15:05:11:134 | HL |   DEBUG1  | +0     | CheckPaths - Looking for rom: G:\Hyperspin\Emulators\Fusion361\Sega Genesis\roms\6-Pak (USA).gen
15:05:11:137 | HL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: G:\Hyperspin\Emulators\Fusion361\Sega Genesis\roms\6-Pak (USA)\6-Pak (USA).gen
15:05:11:139 | HL |   DEBUG1  | +0     | CheckPaths - Rom not found
15:05:11:142 | HL |   DEBUG1  | +0     | CheckPaths - Looking for rom: G:\Hyperspin\Emulators\Fusion361\Sega Genesis\roms\6-Pak (USA).32x
15:05:11:145 | HL |   DEBUG1  | +16    | CheckPaths - Looking for rom by name in subfolder: G:\Hyperspin\Emulators\Fusion361\Sega Genesis\roms\6-Pak (USA)\6-Pak (USA).32x
15:05:11:147 | HL |   DEBUG1  | +0     | CheckPaths - Rom not found
15:05:11:150 | HL |   DEBUG1  | +0     | CheckPaths - Looking for rom: G:\Hyperspin\Emulators\Fusion361\Sega Genesis\roms\6-Pak (USA).md
15:05:11:153 | HL |     INFO  | +0     | CheckPaths - Found rom: G:\Hyperspin\Emulators\Fusion361\Sega Genesis\roms\6-Pak (USA).md
15:05:11:155 | HL |   DEBUG1  | +0     | CheckPaths - Current romName: 6-Pak (USA)
15:05:11:158 | HL |   DEBUG1  | +0     | CheckPaths - Current romPath: G:\Hyperspin\Emulators\Fusion361\Sega Genesis\roms
15:05:11:160 | HL |   DEBUG1  | +0     | CheckPaths - Current romExtension: .md
15:05:11:163 | HL |     INFO  | +15    | CheckFile - Checking if G:\Hyperspin\Emulators\Fusion361\Fusion.exe exists
15:05:11:166 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			2756608 bytes
				Created:			3/6/2010 - 7:34:58 AM
				Modified:			8/25/2014 - 2:49:27 PM
15:05:11:169 | HL |     INFO  | +0     | CheckPaths - Ended
15:05:11:172 | HL |     INFO  | +0     | BuildScript - User Variables:
				; INJECTED VARIABLES
				#NoTrayIcon
				#InstallKeybdHook
				DetectHiddenWindows, ON
				SetTitleMatchMode, 2
				SendMode, Event
				0 = 2
				hlMode =
				frontendPID = 0
				frontendPath = G:\Hyperspin
				frontendExe = HyperSpin.exe
				frontendExt = exe
				frontendName = HyperSpin
				frontendDrive = G:
				exitEmulatorKey = F1
				exitEmulatorKeyWait = 0
				forceHoldKey = ~Esc
				restoreFE = false
				exitScriptKey = ~q & ~s
				toggleCursorKey = ~e & ~t
				emuFullPath = G:\Hyperspin\Emulators\Fusion361\Fusion.exe
				emuPath = G:\Hyperspin\Emulators\Fusion361
				emuName = Fusion
				emuExt = exe
				romPath = G:\Hyperspin\Emulators\Fusion361\Sega Genesis\roms
				romPathFromIni = G:\Hyperspin\Emulators\Fusion361\Sega Genesis\roms
				romExtension = .md
				romExtensionOrig = .md
				romExtensions = 7z|zip|sg|gg|sms|gen|32x|md|cue
				executable = Fusion.exe
				systemName = Sega Genesis
				dbName = 6-Pak (USA)
				romName = 6-Pak (USA)
				romMapPath =
				romMappingEnabled = false
				romMappingMenuWidth = 300
				romMappingMenuMargin = 50
				romMappingTextMargin = 10
				romMappingMenuFlagWidth = 40
				skipchecks = false
				romMatchExt = false
				blockInputTime = 0
				blockInputFile = G:\Hyperspin\HyperLaunch\Module Extensions\BlockInput.exe
				errorLevelReporting = false
				logFile = G:\Hyperspin\HyperLaunch\HyperLaunch.log
				logLevel = 10
				logIncludeModule = true
				logShowCommandWindow = false
				logCommandWindow = false
				sysLang = English_United_Kingdom
				navUpKey = Up
				navDownKey = Down
				navLeftKey = Left
				navRightKey = Right
				navSelectKey = Enter
				navP2UpKey = Numpad8
				navP2DownKey = Numpad2
				navP2LeftKey = Numpad4
				navP2RightKey = Numpad6
				navP2SelectKey = NumpadEnter
				originalWidth = 1440
				originalHeight = 900
				dtEnabled = false
				dtPath = C:\Program Files (x86)\DAEMON Tools Lite\DTLite.exe
				dtUseSCSI = true
				dtAddDrive = true
				emuIdleShutdown = 0
				hideCursor = false
				hideEmu = false
				hideFE = false
				fadeIn = false
				fadeInDuration = 500
				fadeInDelay = 0
				fadeInExitDelay = 0
				fadeOutExitDelay = 0
				fadeOut = false
				fadeOutExtraScreen = false
				fadeOutDuration = 500
				fadeOutDelay = 0
				fadeLyrInterpolation = 7
				fadeLyr1Color = FF000000
				fadeLyr2X = 300
				fadeLyr2Y = 300
				fadeLyr2Adjust = 1
				fadeLyr2PicPad = 0
				fadeLyr3Pos = Center
				fadeLyr3X = 300
				fadeLyr3Y = 300
				fadeLyr3Adjust = 0.75
				fadeLyr3Speed = 750
				fadeLyr3Type = imageandbar
				fadeLyr3Repeat = 1
				fadeLyr3PicPad = 0
				fadeLyr4Adjust = 0.75
				fadeLyr4X = 100
				fadeLyr4Y = 100
				fadeLyr4FPS = 10
				fadeLyr4PicPad = 0
				fadeTranspGifColor = FFFFFF
				fadeBarWindow = false
				fadeBarWindowX =
				fadeBarWindowY =
				fadeBarWindowW = 600
				fadeBarWindowH = 120
				fadeBarWindowR = 20
				fadeBarWindowM = 20
				fadeBarWindowHatchStyle = 8
				fadeBarBack = true
				fadeBarBackColor = FF555555
				fadeBarH = 20
				fadeBarR = 5
				fadeBarColor = DD00BFFF
				fadeBarHatchStyle = 3
				fadeBarPercentageText = true
				fadeBarInfoText = true
				fadeBarXOffset = 0
				fadeBarYOffset = 100
				fadeRomInfoDescription = text
				fadeRomInfoSystemName = text
				fadeRomInfoYear = text
				fadeRomInfoGenre = text
				fadeRomInfoRating = text
				fadeRomInfoTextMargin = 5
				fadeStatsInfoTextMargin = 5
				fadeText1X = 0
				fadeText1Y = 0
				fadeText1 = Loading Game
				fadeText2X = 0
				fadeText2Y = 0
				fadeFont = Arial
				fadeInterruptKey =
				detectFadeErrorEnabled = true
				fadeImgPath = G:\Hyperspin\HyperLaunch\Media\Fade
				HLDataPath = G:\Hyperspin\HyperLaunch\Data
				HLMediaPath = G:\Hyperspin\HyperLaunch\Media
				HLErrSoundPath = G:\Hyperspin\HyperLaunch\Media\Sounds\Error
				modulesPath = G:\Hyperspin\HyperLaunch\Modules
				moduleFullName = G:\Hyperspin\HyperLaunch\Modules\Fusion\Fusion.ahk
				moduleName = Fusion
				modulePath = G:\Hyperspin\HyperLaunch\Modules\Fusion
				moduleExtension = ahk
				moduleExtensionsPath = G:\Hyperspin\HyperLaunch\Module Extensions
				libPath = G:\Hyperspin\HyperLaunch\Lib
				7zEnabled = false
				7zPath = G:\Hyperspin\HyperLaunch\Module Extensions\7z.exe
				7zDllPath = G:\Hyperspin\HyperLaunch\Module Extensions\7z.dll
				7zExtractPath = C:\Users\jade\AppData\Local\Temp\hsperfdata_jade
				7zExtractPathOrig =
				7zAttachSystemName = false
				7zDelTemp = true
				7zSounds = true
				mgEnabled = false
				mgKey = ~NumpadSub
				mgBackgroundColor = FF000000
				mgSidePadding = 0.2
				mgYOffset = 500
				mgImageAdjust = 1
				mgFont = Arial
				mgText2Offset = 70
				mgUseSound = true
				mgSoundfreq = 300
				mgExitEffect = none
				mgSelectedEffect = rotate
				mgUseGameArt = false
				mgArtworkDir = Artwork1
				hpEnabled = false
				hpKey = ~NumpadAdd
				hpBackToMenuBarKey = X
				hpZoomInKey = C
				hpZoomOutKey = V
				hpHiToTextPath = G:\Hyperspin\HyperLaunch\Module Extensions\HiToText.exe
				hpSaveStateKeyCodes = {F5 down}{F5 up}
				hpLoadStateKeyCodes = {F5 down}{F5 up}
				keymapperEnabled = true
				keymapperAHKMethod = false
				keymapper = xpadder
				xpadderFullPath = G:\Hyperspin\Utilities\Xpadder 2013.07.18.exe
				joyToKeyFullPath = G:\Hyperspin\Utilities\JoyToKey\JoyToKey.exe
				keymapperProfilePath = G:\Hyperspin\HyperLaunch\Profiles\xpadder
				keymapperFrontEndProfile = xpadder
				JoyIDsEnabled = true
				JoyIDsPreferredControllersSystem = Controller (XBOX 360 For Windows)
				CustomJoyNamesEnabled = false
				CustomJoyNames =
				FEProfile = G:\Hyperspin\HyperLaunch\Profiles\xpadder\HyperSpin
				defaultProfile = G:\Hyperspin\HyperLaunch\Profiles\xpadder\_Default
				systemProfile = G:\Hyperspin\HyperLaunch\Profiles\xpadder\Sega Genesis
				xPadderSystemProfile = G:\Hyperspin\HyperLaunch\Profiles\xpadder\Sega Genesis\_Default
				emuProfile = G:\Hyperspin\HyperLaunch\Profiles\xpadder\Sega Genesis\Fusion
				romProfile = G:\Hyperspin\HyperLaunch\Profiles\xpadder\Sega Genesis\6-Pak (USA)
				HyperLaunchProfile = G:\Hyperspin\HyperLaunch\Profiles\xpadder\HyperLaunch
				blankProfile = G:\Hyperspin\HyperLaunch\Profiles\xpadder\_Default\blank
				ahkFEProfile = G:\Hyperspin\HyperLaunch\Profiles\AHK\HyperSpin
				ahkDefaultProfile = G:\Hyperspin\HyperLaunch\Profiles\AHK\_Default
				ahkSystemProfile = G:\Hyperspin\HyperLaunch\Profiles\AHK\Sega Genesis
				ahkEmuProfile = G:\Hyperspin\HyperLaunch\Profiles\AHK\Sega Genesis\Fusion
				ahkRomProfile = G:\Hyperspin\HyperLaunch\Profiles\AHK\Sega Genesis\6-Pak (USA)
				ahkHyperLaunchProfile = G:\Hyperspin\HyperLaunch\Profiles\AHK\HyperLaunch
				bezelEnabled = false
				statisticsEnabled = true
15:05:11:175 | HL |     INFO  | +0     | BuildScript - Loaded XHotkey Init.ahk scripts
15:05:11:179 | HL |     INFO  | +16    | BuildScript - Loaded Keymapper Init.ahk scripts
15:05:11:182 | HL |     INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
15:05:11:185 | HL |     INFO  | +0     | BuildScript - Loaded User Functions Init.ahk script
15:05:11:188 | HL |   DEBUG1  | +0     | BuildScript - Module starts on line: 2
15:05:11:193 | HL |     INFO  | +15    | BuildScript - Module:
				MEmu = Fusion
				MEmuV =  v3.64
				MURL = http://www.eidolons-inn.net/tiki-index.php?page=Kega
				MAuthor = djvj
				MVersion = 2.0.8
				MCRC = 792D6332
				iCRC = 3B62A7B7
				MID = 635038268893895568
				MSystem = "Samsung Gam Boy","Sega 32X","Sega CD","Sega Game Gear","Sega Genesis","Sega Master System","Sega Mega Drive","Sega Mega-CD","Sega Pico","Sega SC-3000","Sega SG-1000"
				; Notes:
				; Don't forget to setup your bios or you might just get a black screen.
				; Set your fullscreen resolution by going to Video->Full Screen Resolution
				; Fusion only supports 4 different windowed resolutions. If you don't use fullscreen, set the one you want by going to Video->Window Size
				; Esc is Fusion's default key to go Fullscreen/Windowed mode. This cannot be changed, but this module will still close if you use Esc to exit. You may see the emu leave fullscreen first though.
				; Esc can also cause Fusion to change its fullscreen mode on exit, causing it to lockup for 5-10 seconds. The only fix for this is to not use Esc as your exit key.
				; For Sega CD, make sure your cues are correctly pointing to all the tracks or else you will not get sound. Also turn off auto-play for CDs
				; Sega CD
				; Configure your Sega CD bios first by going to Options -> Set Config -> Sega CD
				; Set the scsi drive you want to use manually by going to Options -> CD Drive and seleting the one that corresponds to your scsi drive in DT. A dt drive is not supported by the emu, it must be scsi.
				; Defining per-game controller types:
				; In the module ini, set Controller_Reassigning_Enabled to true
				; Default_P1_Controller and Default_P2_Controller should be set to the controller type you normally use for games not listed in the ini
				; Make a new ini section with the name of your rom in your database, for example [super Scope 6 (USA)]
				; Under this section you can have 2 keys, P1_Controller and P2_Controller
				; For P1_Controller - 0=None, 1=Gamepad, 2=Multitap, 3=Mouse, 4=Serial USART
				; For P2_Controller - 0=None, 1=Gamepad, 2=Multitap, 3=Mouse, 4=Super Scope, 5=Justifier, 6=Dual Justifiers, 7=Serial USART
				; Some games will not work if you have Teamplayer or 4way play active all the time, so you can set the MultiTapType for those problematic games in the module settings for each of these games.
				; Windows 8 and 8.1 users:
				; You may experience an issue with Fusion never getting higher than 33.5fps. Use Ctrl+F to bring up the FPS counter in Fusion to check if you are affected. This is caused by some compatibility changes Microsoft made for DirectDraw applications. There are two ways of fixing this issue:
				; 1) Apply a compatibility patch for the Fusion executable using the Microsoft Application Compatibility Toolkit
				; 2) Copy a prepatched ddraw.dll into the Fusion directory.
				; Using the Microsoft Application Compatibility Toolkit is a cleaner fix but takes a few minutes to go through the steps to apply. Using the prepatched ddraw.dll file is quick and simple but may break the right-click menus when in full-screen mode, requiring you to make all configuration changes with the emulator windowed.
				; Both methods are fully detailed with downloads, instructions and screenshots at http://www.blitzbasic.com/Community/post.php?topic=99477&post=1202630
				StartModule()
				BezelGUI()
				FadeInStart()
				; The object controls how the module reacts to different systems. Fusion can play a lot of systems, but changes itself slightly so this module has to adapt
				mType := Object("Samsung Gam Boy","sms","Sega 32X","32X","Sega CD","scd","Sega Mega-CD","scd","Sega Game Gear","gg","Sega Genesis","gen","Sega Mega Drive","gen","Sega Master System","sms","Sega Pico","gen","Sega SC-3000","sms","Sega SG-1000","sms")
				ident := mType[systemName]	; search 1st array for the systemName identifier mednafen uses
				If !ident
					ScriptError("Your systemName is: " . systemName . "`nIt is not one of the known supported systems for this Fusion module: " . moduleName)
				Log("Module - Started reading module ini")
				forceFullScreen32 := IniReadCheck(settingsFile, "Settings", "ForceFullScreen32","true",,1)
				hideTitleBar := IniReadCheck(settingsFile, "Settings", "hideTitleBar","true",,1)	; Removes the border, titlebar, menubar, and centers the emu on your screen. Only need this if fullscreen is false
				useRamCarts := IniReadCheck(settingsFile, "Settings", "UseRamCarts","true",,1)
				fluxAudioCD := IniReadCheck(settingsFile, "Settings", "FluxAudioCD",,,1)	; audio CD for use when Flux is ran
				fluxAudioCD := GetFullName(fluxAudioCD)	; convert relative path to absolute
				DTWaitTime := IniReadCheck(settingsFile, systemName, "DTWaitTime","0",,1)
				controllerReassigningEnabled := IniReadCheck(settingsFile, systemName, "Controller_Reassigning_Enabled","false",,1)
				perfectSync := IniReadCheck(settingsFile, romName, "PerfectSync","false",,1)
				multiTapType := IniReadCheck(settingsFile, systemName . "|" . romName, "MultiTapType",0,,1)
				genP1Controller := IniReadCheck(settingsFile, systemName . "|" . romName, "Genesis_P1_Controller",2,,1)
				genP1bController := IniReadCheck(settingsFile, systemName . "|" . romName, "Genesis_P1b_Controller",2,,1)
				genP1cController := IniReadCheck(settingsFile, systemName . "|" . romName, "Genesis_P1c_Controller",2,,1)
				genP1dController := IniReadCheck(settingsFile, systemName . "|" . romName, "Genesis_P1d_Controller",2,,1)
				genP2Controller := IniReadCheck(settingsFile, systemName . "|" . romName, "Genesis_P2_Controller",2,,1)
				genP2bController := IniReadCheck(settingsFile, systemName . "|" . romName, "Genesis_P2b_Controller",2,,1)
				genP2cController := IniReadCheck(settingsFile, systemName . "|" . romName, "Genesis_P2c_Controller",2,,1)
				genP2dController := IniReadCheck(settingsFile, systemName . "|" . romName, "Genesis_P2d_Controller",2,,1)
				smsP1Controller := IniReadCheck(settingsFile, systemName . "|" . romName, "SMS_P1_Controller",1,,1)
				smsP2Controller := IniReadCheck(settingsFile, systemName . "|" . romName, "SMS_P2_Controller",1,,1)
				genP1Use := IniReadCheck(settingsFile, systemName . "|" . romName, "Genesis_P1_Use",1,,1)
				genP1bUse := IniReadCheck(settingsFile, systemName . "|" . romName, "Genesis_P1b_Use",1,,1)
				genP1cUse := IniReadCheck(settingsFile, systemName . "|" . romName, "Genesis_P1c_Use",1,,1)
				genP1dUse := IniReadCheck(settingsFile, systemName . "|" . romName, "Genesis_P1d_Use",1,,1)
				genP2Use := IniReadCheck(settingsFile, systemName . "|" . romName, "Genesis_P2_Use",1,,1)
				genP2bUse := IniReadCheck(settingsFile, systemName . "|" . romName, "Genesis_P2b_Use",1,,1)
				genP2cUse := IniReadCheck(settingsFile, systemName . "|" . romName, "Genesis_P2c_Use",1,,1)
				genP2dUse := IniReadCheck(settingsFile, systemName . "|" . romName, "Genesis_P2d_Use",1,,1)
				smsP1Use := IniReadCheck(settingsFile, systemName . "|" . romName, "SMS_P1_Use",1,,1)
				smsP2Use := IniReadCheck(settingsFile, systemName . "|" . romName, "SMS_P2_Use",1,,1)
				Log("Module - Finished reading module ini")
				BezelStart()
				fusionFile := CheckFile(emuPath . "\fusion.ini")
				fusionIni := LoadProperties(fusionFile)	; load the config into memory
				currentFullScreen := ReadProperty(fusionIni,"FullScreen")	; read current fullscreen state
				currentForceFullScreen32 := ReadProperty(fusionIni,"forceFullScreen32")	; read current ForceFullScreen32 state
				currentPerfectSync := ReadProperty(fusionIni,"PerfectSync")	; read current PerfectSync state
				If romExtension in .7z,.rar
					ScriptError(MEmu . " only supports uncompressed or zip compressed roms. Please enable 7z support in HLHQ to use this module/emu for this extension: """ . romExtension . """")
				If ( Fullscreen != "true" And currentFullScreen = "1" ) {
					WriteProperty(fusionIni,"FullScreen", 0)
					If controllerReassigningEnabled != true	; no need to save file if it's going to be written later
						SaveProperties(fusionFile,fusionIni)	; save fusionFile to disk
				} Else If ( Fullscreen = "true" And currentFullScreen = "0" ) {
					WriteProperty(fusionIni,"FullScreen", 1)
				If ( forceFullScreen32 != "true" And currentForceFullScreen32 = "1" ) {
					WriteProperty(fusionIni,"ForceFullScreen32", 0)
				} Else If ( forceFullScreen32 = "true" And currentForceFullScreen32 = "0" ) {
					WriteProperty(fusionIni,"ForceFullScreen32", 1)
				If ( perfectSync != "true" And currentPerfectSync = "1" ) {
					WriteProperty(fusionIni,"PerfectSync", 0)
				} Else If ( perfectSync = "true" And currentPerfectSync = "0" ) {
					WriteProperty(fusionIni,"PerfectSync", 1)
				hideEmu := (If Fullscreen = "true" ? ("Hide") : (""))
				fullscreen := (If Fullscreen = "true" ? ("-fullscreen") : (""))
				If bezelPath ; Setting windowed mode resolution
				{	WriteProperty(fusionIni,"GameGearZoom", 1) ; disabling emulator default bezel
				 ; Allows you to set on a per-rom basis the controller type plugged into controller ports 1 and 2
				If controllerReassigningEnabled = true
				{	Log("Module - Started reassigning Fusion's ini controls")
					WriteProperty(fusionIni,"MultiTapType", multiTapType)	; sets MultiTap
					WriteProperty(fusionIni,"Joystick1Type", genP1Controller)	; sets controls for P1
					WriteProperty(fusionIni,"Joystick1bType", genP1bController)	; sets controls for P1b
					WriteProperty(fusionIni,"Joystick1cType", genP1cController)	; sets controls for P1c
					WriteProperty(fusionIni,"Joystick1dType", genP1dController)	; sets controls for P1d
					WriteProperty(fusionIni,"Joystick2Type", genP2Controller)	; sets controls for P2
					WriteProperty(fusionIni,"Joystick2bType", genP2bController)	; sets controls for P2b
					WriteProperty(fusionIni,"Joystick2cType", genP2cController)	; sets controls for P2c
					WriteProperty(fusionIni,"Joystick2dType", genP2dController)	; sets controls for P2d
					WriteProperty(fusionIni,"Joystick1MSType", smsP1Controller)	; sets controls for sms P1
					WriteProperty(fusionIni,"Joystick2MSType", smsP2Controller)	; sets controls for sms P2
					WriteProperty(fusionIni,"Joystick1Using", genP1Use)	; sets controls for P1
					WriteProperty(fusionIni,"Joystick1bUsing", genP1bUse)	; sets controls for P1b
					WriteProperty(fusionIni,"Joystick1cUsing", genP1cUse)	; sets controls for P1c
					WriteProperty(fusionIni,"Joystick1dUsing", genP1dUse)	; sets controls for P1d
					WriteProperty(fusionIni,"Joystick2Using", genP2Use)	; sets controls for P2
					WriteProperty(fusionIni,"Joystick2bUsing", genP2bUse)	; sets controls for P2b
					WriteProperty(fusionIni,"Joystick2cUsing", genP2cUse)	; sets controls for P2c
					WriteProperty(fusionIni,"Joystick2dUsing", genP2dUse)	; sets controls for P2d
					WriteProperty(fusionIni,"Joystick1MSUsing", smsP1Use)	; sets controls for sms P1
					WriteProperty(fusionIni,"Joystick2MSUsing", smsP2Use)	; sets controls for sms P2
					Log("Module - Finished reassigning Fusion's ini controls")
				fluxRom := InStr(romName, "flux")	; test if this game is Flux, a special case game that requires an Audio CD to be mounted
				If fluxRom {
					Log("Module - Mounting the Audio CD because """ . romName . """ requires one to function.")
					ident := "gen"	; change ident to gen because Flux has to be mounted as a Genesis rom
					DaemonTools("mount", fluxAudioCD)	; mount the Audio CD the user has set in the module settings
				scdExtension := InStr(".ccd|.cue|.bin|.iso", romExtension)	; the sega cd extensions supported by fusion
				If (ident = "scd" && dtEnabled = "true" && scdExtension) {
					If dtUseSCSI = false
						Log("Module - Daemon Tools drive type is set to ""dt"" but only ""scsi"" is supported for Fusion. Forcing scsi drive.", 2)
					DaemonTools("mount", romPath . "\" . romName . romExtension, (If dtUseSCSI = "false" ? "scsi" : ""))
					Sleep, DTWaitTime
					Run(executable . " -auto -" . ident . " " . fullscreen, emuPath, hideEmu)
				} Else {
					If (ident = "scd" && dtEnabled = "true" && !scdExtension)
						Log("Module - " . romExtension . " is not a supported cd image extension for Fusion. Launching Fusion without DT support.", 2)
					Run(executable . " -auto -" . ident . " " . fullscreen . " """ . romPath . "\" . romName . romExtension . """", emuPath, hideEmu)
				WinWait("Fusion ahk_class KegaClass")
				WinWaitActive("Fusion ahk_class KegaClass")
				If fluxRom
					PostMessage, 0x111, 40009,,,ahk_class KegaClass	; Runs the Boot Sega-CD command to load the Audio CD that should be mounted in DT already
				If (ident = "scd" && useRamCarts = "true")	; Sega CD or Mega CD only
				{	brmPath := ReadProperty(fusionIni,"BRMFiles")		; read BRM path
					IfNotExist, %brmPath%
						FileCreateDir, %brmPath%	; create brmPath if it does not exist
					selectRamWin := "Select RAM Cart Size ahk_class #32770"
					createRamWin := "Create RAM Cart ahk_class #32770"
					loadRamWin := "Load RAM Cart ahk_class #32770"
					; Create New Ram Cart if it doesn't exist already
					IfNotExist, %brmPath%\%romName%.crm
					{	PostMessage, 0x111, 40036,,,ahk_class KegaClass	; Open Create New Ram Cart Window
						WinWait, %selectRamWin%
						WinSet, Transparent, On, %selectRamWin%
						Control, Check,, Button7, %selectRamWin%
						ControlSend, Button1, {Enter}, %selectRamWin%
						WinWait, %createRamWin%
						WinSet, Transparent, On, %createRamWin%
						WinWaitActive, %createRamWin%
						Loop {
							ControlGetText, edit1Text, Edit1, %createRamWin%
							If ( edit1Text = brmPath . "\" . romName . ".crm" )
								Break
							Sleep, 100
							ControlSetText, Edit1, %brmPath%\%romName%.crm, %createRamWin%
						ControlSend, Button1, {Enter}, %createRamWin% ; Select Save
					; Now load the Ram Cart
					PostMessage, 0x111, 40035,,,ahk_class KegaClass	; Open Load Ram Cart Window
					WinWait, %loadRamWin%
					WinSet, Transparent, On, %loadRamWin%
					WinWaitActive, %loadRamWin%
					Loop {
						ControlGetText, edit1Text, Edit1, %loadRamWin%
							Break
						Sleep, 100
						ControlSetText, Edit1, %brmPath%\%romName%.crm, %loadRamWin%
					ControlSend, Button1, {Enter}, %loadRamWin% ; Select Open
				Loop { ; looping until Fusion is done loading game
					Sleep, 200
					WinGetTitle, winTitle, Fusion ahk_class KegaClass
					StringSplit, T, winTitle, %A_Space%
					If ( T3 = "-" )
						Break
				If hideTitleBar = true
				{	WinSet, Style, -0x40000, Fusion ahk_class KegaClass ; Removes the border of the game window
					WinSet, Style, -0xC00000, Fusion ahk_class KegaClass ; Removes the TitleBar
					DllCall("SetMenu", uint, WinActive( "A" ), uint, 0) ; Removes the MenuBar
					If bezelEnabled != true
						Center(Fusion ahk_class KegaClass)
				BezelDraw()
				FadeInExit()
				If InStr(systemName, "Pico")
					PostMessage, 0x111, 40183,,,ahk_class KegaClass	; tell Kega Fusion to capture mouse input
				If (fluxRom || (ident = "scd" && dtEnabled = "true" && scdExtension))
					DaemonTools("unmount")
				7zCleanUp()
				BezelExit()
				FadeOutExit()
				ExitModule()
				Center(title) {
					WinGetPos, X, Y, width, height, %title%
					x := ( A_ScreenWidth / 2 ) - ( width / 2 )
					y := ( A_ScreenHeight / 2 ) - ( height / 2 )
					WinMove, %title%, , x, y
				MultiGame:
					; msgbox % "selectedRom = " . selectedRom . "`nselected game = " . currentButton . "`nmgRomPath = " . mgRomPath . "`nmgRomExt = " . mgRomExt . "`nmgRomName = "  . mgRomName
					; Unmount the CD from DaemonTools
					If ( scdExtension && dtEnabled = "true" )
					Sleep, 500	; Required to prevent  DT from bugging
					; Mount the CD using DaemonTools
						DaemonTools("mount", selectedRom)
				Return
				CloseProcess:
					FadeOutStart()
					WinClose("Fusion ahk_class KegaClass")
					; PostMessage, 0x111, 40039,,,ahk_class KegaClass	; Tells Fusion to Power Off
					; Sleep, 100	; giving time for Fusion to unload rom
					; PostMessage, 0x111, 40005,,,ahk_class KegaClass	; Tells Fusion to exit
				Return
15:05:11:197 | HL |     INFO  | +0     | BuildScript - Loaded Statistics.ahk script
15:05:11:200 | HL |     INFO  | +0     | BuildScript - Loaded User Functions.ahk script
15:05:11:204 | HL |     INFO  | +0     | BuildScript - Finished injecting functions into module
15:05:11:207 | HL |     INFO  | +0     | Main - Module is built
15:05:11:211 | HL |     INFO  | +16    | CheckFile - Checking if G:\Hyperspin\HyperLaunch\AutoHotkey.dll exists
15:05:11:215 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			785408 bytes
				Created:			7/24/2014 - 12:54:44 AM
15:05:11:221 | HL |     INFO  | +0     | Main - Running module
15:05:11:225 | HL |     INFO  | +16    | Main - Starting timer to watch if Front End gets displaced and restore it if it does.
15:05:11:338 | MD |     INFO  | +N/A   | Module initialized
15:05:11:344 | MD |   DEBUG2  | +0     | Keymapper - Checking for the JoyIDs_Preferred_Controllers key  in G:\Hyperspin\HyperLaunch\Settings\Sega Genesis\Games JoyIDs.ini under section [6-Pak (USA)]
15:05:11:348 | MD |   DEBUG2  | +0     | Keymapper - JoyIDsPreferredControllers = Controller (XBOX 360 For Windows)
15:05:11:372 | MD |   DEBUG2  | +31    | Keymapper - Creating a list of currently connected joysticks
15:05:11:416 | MD |   DEBUG2  | +47    | Keymapper - Joysticks Detected: 1000000000000000
15:05:11:422 | MD |   DEBUG2  | +0     | Keymapper - Preferred Order Sorting List -> 1.01|045e|028e|90E2BB001BE4E3118001444553540000
15:05:11:425 | MD |     INFO  | +0     | Keymapper - Sorting Currently Connected joysticks List to match the order of the Preferred Controller List
15:05:11:442 | MD |     INFO  | +31    | Keymapper - Assigning the New Joystick IDs according to the preferred list for the active controllers
15:05:11:447 | MD |   DEBUG2  | +0     | Keymapper - Swapping Joystick ID: 00000000 to the New Joystick ID: 00000000, for the Joystick VID_045e&PID_028e&GUID_90E2BB001BE4E3118001444553540000
15:05:11:450 | MD |     INFO  | +0     | CheckFile - Checking if G:\Hyperspin\Utilities\Xpadder 2013.07.18.exe exists
15:05:11:455 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			1169408 bytes
				Created:			8/18/2014 - 6:15:55 PM
				Modified:			8/18/2014 - 6:15:39 PM
15:05:11:477 | MD |     INFO  | +32    | Keymapper - Loading xpadder
15:05:11:509 | MD |   DEBUG2  | +31    | Keymapper - Joysticks Detected: 1000000000000000
15:05:11:515 | MD |   DEBUG2  | +0     | Keymapper - Searching -> G:\Hyperspin\HyperLaunch\Profiles\xpadder\Sega Genesis\6-Pak (USA)\Controller (XBOX 360 For Windows)\p1.xpadderprofile
15:05:11:518 | MD |   DEBUG2  | +0     | Keymapper - Searching -> G:\Hyperspin\HyperLaunch\Profiles\xpadder\Sega Genesis\6-Pak (USA)\p1.xpadderprofile
15:05:11:541 | MD |   DEBUG2  | +31    | Keymapper - Searching -> G:\Hyperspin\HyperLaunch\Profiles\xpadder\Sega Genesis\Fusion\Controller (XBOX 360 For Windows)\p1.xpadderprofile
15:05:11:544 | MD |   DEBUG2  | +0     | Keymapper - Searching -> G:\Hyperspin\HyperLaunch\Profiles\xpadder\Sega Genesis\Fusion\p1.xpadderprofile
15:05:11:548 | MD |     INFO  | +0     | Keymapper - Loading Profile -> G:\Hyperspin\HyperLaunch\Profiles\xpadder\Sega Genesis\Fusion\p1.xpadderprofile
15:05:11:551 | MD |   DEBUG2  | +0     | Keymapper - Closing xpadder to refresh controllers seen by xpadder
15:05:11:693 | MD |   DEBUG2  | +156   | Keymapper - Creating an array of connected controllers and profiles to arrange according to the order found in G:\Hyperspin\Utilities\xpadder.ini
15:05:12:028 | MD |   DEBUG2  | +329   | Keymapper - Reading the order in G:\Hyperspin\Utilities\xpadder.ini and arranging profiles found to match that order
15:05:12:034 | MD |     INFO  | +0     | Keymapper - Run,Xpadder 2013.07.18.exe "G:\Hyperspin\HyperLaunch\Profiles\xpadder\Sega Genesis\Fusion\p1.xpadderprofile" /M, G:\Hyperspin\Utilities, Hide
15:05:12:085 | MD |     INFO  | +62    | StartModule - Started
15:05:12:089 | MD |     INFO  | +0     | StartModule - MEmu: Fusion
				MEmuV: v3.64
				MURL: http://www.eidolons-inn.net/tiki-index.php?page=Kega
				MAuthor: djvj
				MVersion: 2.0.8
				MCRC: 792D6332
				iCRC: 3B62A7B7
				MID:
				MSystem: "Samsung Gam Boy","Sega 32X","Sega CD","Sega Game Gear","Sega Genesis","Sega Master System","Sega Mega Drive","Sega Mega-CD","Sega Pico","Sega SC-3000","Sega SG-1000"
15:05:12:092 | MD |     INFO  | +0     | StartModule - You have a supported System Name for this module: "Sega Genesis"
15:05:12:095 | MD |   DEBUG1  | +0     | StartModule - Leaving romName as is because Rom Mapping filled it with an Alternate_Rom_Name: 6-Pak (USA)
15:05:12:099 | MD |     INFO  | +16    | StartModule - Ended
15:05:12:102 | MD |     INFO  | +0     | StartGlobalUserFeatures - Starting
15:05:12:106 | MD |     INFO  | +0     | StartGlobalUserFeatures - Ending
15:05:12:109 | MD |     INFO  | +0     | Module - Started reading module ini
15:05:12:113 | MD |     INFO  | +0     | Module Setting - [settings] - Fullscreen: true
15:05:12:116 | MD |     INFO  | +15    | Module Setting - [settings] - ForceFullScreen32: true
15:05:12:120 | MD |     INFO  | +0     | Module Setting - [settings] - hideTitleBar: true
15:05:12:124 | MD |     INFO  | +0     | Module Setting - [settings] - UseRamCarts: true
15:05:12:127 | MD |     INFO  | +0     | Module Setting - [settings] - FluxAudioCD:
15:05:12:130 | MD |     INFO  | +16    | Module Setting - [sega Genesis] - DTWaitTime: 0
15:05:12:134 | MD |     INFO  | +0     | Module Setting - [sega Genesis] - Controller_Reassigning_Enabled: false
15:05:12:137 | MD |     INFO  | +0     | Module Setting - [6-Pak (USA)] - PerfectSync: false
15:05:12:141 | MD |     INFO  | +0     | Module Setting - [sega Genesis] - MultiTapType: 0
15:05:12:145 | MD |     INFO  | +16    | Module Setting - [6-Pak (USA)] - MultiTapType: 0
15:05:12:149 | MD |     INFO  | +0     | Module Setting - [sega Genesis] - Genesis_P1_Controller: 2
15:05:12:153 | MD |     INFO  | +0     | Module Setting - [6-Pak (USA)] - Genesis_P1_Controller: 2
15:05:12:156 | MD |     INFO  | +0     | Module Setting - [sega Genesis] - Genesis_P1b_Controller: 2
15:05:12:160 | MD |     INFO  | +0     | Module Setting - [6-Pak (USA)] - Genesis_P1b_Controller: 2
15:05:12:163 | MD |     INFO  | +15    | Module Setting - [sega Genesis] - Genesis_P1c_Controller: 2
15:05:12:167 | MD |     INFO  | +0     | Module Setting - [6-Pak (USA)] - Genesis_P1c_Controller: 2
15:05:12:171 | MD |     INFO  | +0     | Module Setting - [sega Genesis] - Genesis_P1d_Controller: 2
15:05:12:175 | MD |     INFO  | +0     | Module Setting - [6-Pak (USA)] - Genesis_P1d_Controller: 2
15:05:12:179 | MD |     INFO  | +16    | Module Setting - [sega Genesis] - Genesis_P2_Controller: 2
15:05:12:182 | MD |     INFO  | +0     | Module Setting - [6-Pak (USA)] - Genesis_P2_Controller: 2
15:05:12:186 | MD |     INFO  | +0     | Module Setting - [sega Genesis] - Genesis_P2b_Controller: 2
15:05:12:189 | MD |     INFO  | +0     | Module Setting - [6-Pak (USA)] - Genesis_P2b_Controller: 2
15:05:12:193 | MD |     INFO  | +15    | Module Setting - [sega Genesis] - Genesis_P2c_Controller: 2
15:05:12:196 | MD |     INFO  | +0     | Module Setting - [6-Pak (USA)] - Genesis_P2c_Controller: 2
15:05:12:200 | MD |     INFO  | +0     | Module Setting - [sega Genesis] - Genesis_P2d_Controller: 2
15:05:12:204 | MD |     INFO  | +0     | Module Setting - [6-Pak (USA)] - Genesis_P2d_Controller: 2
15:05:12:208 | MD |     INFO  | +16    | Module Setting - [sega Genesis] - SMS_P1_Controller: 1
15:05:12:211 | MD |     INFO  | +0     | Module Setting - [6-Pak (USA)] - SMS_P1_Controller: 1
15:05:12:215 | MD |     INFO  | +0     | Module Setting - [sega Genesis] - SMS_P2_Controller: 1
15:05:12:221 | MD |     INFO  | +0     | Module Setting - [6-Pak (USA)] - SMS_P2_Controller: 1
15:05:12:226 | MD |     INFO  | +16    | Module Setting - [sega Genesis] - Genesis_P1_Use: 1
15:05:12:229 | MD |     INFO  | +0     | Module Setting - [6-Pak (USA)] - Genesis_P1_Use: 1
15:05:12:234 | MD |     INFO  | +0     | Module Setting - [sega Genesis] - Genesis_P1b_Use: 1
15:05:12:238 | MD |     INFO  | +0     | Module Setting - [6-Pak (USA)] - Genesis_P1b_Use: 1
15:05:12:243 | MD |     INFO  | +15    | Module Setting - [sega Genesis] - Genesis_P1c_Use: 1
15:05:12:253 | MD |     INFO  | +0     | Module Setting - [6-Pak (USA)] - Genesis_P1c_Use: 1
15:05:12:257 | MD |     INFO  | +16    | Module Setting - [sega Genesis] - Genesis_P1d_Use: 1
15:05:12:260 | MD |     INFO  | +0     | Module Setting - [6-Pak (USA)] - Genesis_P1d_Use: 1
15:05:12:263 | MD |     INFO  | +0     | Module Setting - [sega Genesis] - Genesis_P2_Use: 1
15:05:12:273 | MD |     INFO  | +16    | Module Setting - [6-Pak (USA)] - Genesis_P2_Use: 1
15:05:12:278 | MD |     INFO  | +0     | Module Setting - [sega Genesis] - Genesis_P2b_Use: 1
15:05:12:283 | MD |     INFO  | +0     | Module Setting - [6-Pak (USA)] - Genesis_P2b_Use: 1
15:05:12:287 | MD |     INFO  | +15    | Module Setting - [sega Genesis] - Genesis_P2c_Use: 1
15:05:12:292 | MD |     INFO  | +0     | Module Setting - [6-Pak (USA)] - Genesis_P2c_Use: 1
15:05:12:296 | MD |     INFO  | +0     | Module Setting - [sega Genesis] - Genesis_P2d_Use: 1
15:05:12:300 | MD |     INFO  | +0     | Module Setting - [6-Pak (USA)] - Genesis_P2d_Use: 1
15:05:12:304 | MD |     INFO  | +16    | Module Setting - [sega Genesis] - SMS_P1_Use: 1
15:05:12:308 | MD |     INFO  | +0     | Module Setting - [6-Pak (USA)] - SMS_P1_Use: 1
15:05:12:311 | MD |     INFO  | +0     | Module Setting - [sega Genesis] - SMS_P2_Use: 1
15:05:12:316 | MD |     INFO  | +0     | Module Setting - [6-Pak (USA)] - SMS_P2_Use: 1
15:05:12:320 | MD |     INFO  | +15    | Module - Finished reading module ini
15:05:12:324 | MD |     INFO  | +0     | CheckFile - Checking if G:\Hyperspin\Emulators\Fusion361\fusion.ini exists
15:05:12:328 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			5896 bytes
				Created:			8/25/2014 - 3:01:42 PM
				Modified:			8/25/2014 - 3:04:53 PM
15:05:12:331 | MD |   DEBUG1  | +0     | LoadProperties - Started and loading this cfg into memory: G:\Hyperspin\Emulators\Fusion361\fusion.ini
15:05:12:335 | MD |   DEBUG1  | +16    | LoadProperties - Ended
15:05:12:340 | MD |   DEBUG1  | +0     | ReadProperty - Started
15:05:12:345 | MD |   DEBUG1  | +0     | ReadProperty - Started
15:05:12:349 | MD |   DEBUG1  | +16    | ReadProperty - Started
15:05:12:354 | MD |     INFO  | +0     | Run - Running: G:\Hyperspin\Emulators\Fusion361\Fusion.exe -auto -gen -fullscreen "G:\Hyperspin\Emulators\Fusion361\Sega Genesis\roms\6-Pak (USA).md"
15:05:12:378 | MD |   DEBUG1  | +15    | Run - "Fusion.exe -auto -gen -fullscreen "G:\Hyperspin\Emulators\Fusion361\Sega Genesis\roms\6-Pak (USA).md"" Process ID: 2740
15:05:12:382 | MD |   DEBUG1  | +16    | GetActiveWindowStatus - Title: HyperLaunch HQ v1.0.13.0 | Class: HwndWrapper[HyperLaunchHQ.exe;;a9616f75-975a-4754-ba45-4821e4448ea3] | State: 1 | X: -8 | Y: -8 | Width: 1456 | Height: 876 | Window HWND: 0x10027a | Process ID: 4568 | Process Path: G:\Hyperspin\HyperLaunch\HyperLaunchHQ\HyperLaunchHQ.exe
15:05:12:386 | MD |     INFO  | +0     | WinWait - Waiting for "Fusion ahk_class KegaClass"
15:05:13:255 | MD |   DEBUG1  | +875   | GetActiveWindowStatus - Title: Fusion | Class: KegaClass | State: 0 | X: 0 | Y: 0 | Width: 646 | Height: 492 | Window HWND: 0xc01306 | Process ID: 2740 | Process Path: G:\Hyperspin\Emulators\Fusion361\Fusion.exe
15:05:13:267 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: Fusion | Class: KegaClass | State: 0 | X: 0 | Y: 0 | Width: 646 | Height: 492 | Window HWND: 0xc01306 | Process ID: 2740 | Process Path: G:\Hyperspin\Emulators\Fusion361\Fusion.exe
15:05:13:274 | MD |     INFO  | +16    | WinWaitActive - Waiting for "Fusion ahk_class KegaClass"
15:05:13:391 | MD |   DEBUG1  | +109   | GetActiveWindowStatus - Title: Fusion | Class: KegaClass | State: 0 | X: 0 | Y: 0 | Width: 646 | Height: 492 | Window HWND: 0xc01306 | Process ID: 2740 | Process Path: G:\Hyperspin\Emulators\Fusion361\Fusion.exe
15:05:13:398 | MD |   DEBUG1  | +16    | GetActiveWindowStatus - Title: Fusion | Class: KegaClass | State: 0 | X: 0 | Y: 0 | Width: 646 | Height: 492 | Window HWND: 0xc01306 | Process ID: 2740 | Process Path: G:\Hyperspin\Emulators\Fusion361\Fusion.exe
15:05:13:402 | MD |     INFO  | +0     | WinWaitActive - Waiting for "Fusion ahk_class KegaClass"
15:05:13:518 | MD |   DEBUG1  | +109   | GetActiveWindowStatus - Title: Fusion 3.64 (C) Steve Snake, 2010. | Class: KegaClass | State: 0 | X: 0 | Y: 0 | Width: 646 | Height: 492 | Window HWND: 0xc01306 | Process ID: 2740 | Process Path: G:\Hyperspin\Emulators\Fusion361\Fusion.exe
15:05:14:995 | MD |     INFO  | +1484  | Process - WaitClose Fusion.exe
15:05:29:143 | MD |   DEBUG1  | +14141 | CloseProcess - Started, user requested to end launched application
15:05:29:161 | MD |     INFO  | +31    | WinClose - Closing: Fusion ahk_class KegaClass
15:05:30:826 | MD |   DEBUG1  | +1656  | CloseProcess - Ended
15:05:31:057 | MD |     INFO  | +235   | StopGlobalUserFeatures - Starting
15:05:31:060 | MD |     INFO  | +0     | StopGlobalUserFeatures - Ending
15:05:31:063 | MD |     INFO  | +0     | ExitModule - Started
15:05:31:067 | MD |     INFO  | +0     | Starting Updating Statistics:
15:05:31:070 | MD |   DEBUG2  | +15    | Total Elapsed Time in Pause in seconds: 0
15:05:31:074 | MD |   DEBUG2  | +0     | gameSectionStartTime:403246828
15:05:31:077 | MD |   DEBUG2  | +0     | ElapsedTime:18
15:05:31:080 | MD |     INFO  | +0     | CreateRomTable - Started
15:05:31:084 | MD |   DEBUG1  | +16    | CreateRomTable - Checking for match: "6-Pak (USA)" and "(Disc"
15:05:31:087 | MD |   DEBUG1  | +0     | CreateRomTable - Checking for match: "6-Pak (USA)" and "(Disk"
15:05:31:091 | MD |   DEBUG1  | +0     | CreateRomTable - Checking for match: "6-Pak (USA)" and "(Cart"
15:05:31:094 | MD |   DEBUG1  | +0     | CreateRomTable - Checking for match: "6-Pak (USA)" and "(Tape"
15:05:31:097 | MD |   DEBUG1  | +0     | CreateRomTable - Checking for match: "6-Pak (USA)" and "(Cassette"
15:05:31:101 | MD |   DEBUG1  | +16    | CreateRomTable - Checking for match: "6-Pak (USA)" and "(Part"
15:05:31:104 | MD |   DEBUG1  | +0     | CreateRomTable - Checking for match: "6-Pak (USA)" and "(Side"
15:05:31:107 | MD |     INFO  | +0     | CreateRomTable - Ended, 7 Loops to create table.
15:05:31:111 | MD |   DEBUG2  | +0     | Statistics cleared game name: 6-Pak
15:05:31:145 | MD |   DEBUG2  | +31    | Loaded game statistics from ini files:
				Number_of_Times_Played: 10
				Last_Time_Played: Monday August 25, 2014 03:04:15 PM
				Average_Time_Played: 25
				Total_Time_Played: 253
				System_Total_Played_Time: 631
				Total_Global_Played_Time: 9078
15:05:31:148 | MD |   DEBUG2  | +16    | Updated Statistics: Number_of_Times_Played: 11
				Last_Time_Played: Monday August 25, 2014 03:05:12 PM
				Total_Time_Played: 271
				System_Total_Played_Time: 649
				Total_Global_Played_Time: 9096
15:05:31:187 | MD |     INFO  | +31    | Game section statistics updated.
15:05:31:205 | MD |   DEBUG2  | +15    | Keymapper - Joysticks Detected: 1000000000000000
15:05:31:211 | MD |   DEBUG2  | +16    | Keymapper - Searching -> G:\Hyperspin\HyperLaunch\Profiles\xpadder\HyperSpin\Controller (XBOX 360 For Windows)\p1.xpadderprofile
15:05:31:215 | MD |   DEBUG2  | +0     | Keymapper - Searching -> G:\Hyperspin\HyperLaunch\Profiles\xpadder\HyperSpin\p1.xpadderprofile
15:05:31:218 | MD |   DEBUG2  | +0     | Keymapper - Searching -> G:\Hyperspin\HyperLaunch\Profiles\xpadder\_Default\blank.xpadderprofile
15:05:31:221 | MD |     INFO  | +0     | Keymapper - Loading Profile -> G:\Hyperspin\HyperLaunch\Profiles\xpadder\_Default\blank.xpadderprofile
15:05:31:225 | MD |   DEBUG2  | +16    | Keymapper - Closing xpadder to refresh controllers seen by xpadder
15:05:31:252 | MD |   DEBUG2  | +15    | Keymapper - Creating an array of connected controllers and profiles to arrange according to the order found in G:\Hyperspin\Utilities\xpadder.ini
15:05:31:483 | MD |   DEBUG2  | +235   | Keymapper - Reading the order in G:\Hyperspin\Utilities\xpadder.ini and arranging profiles found to match that order
15:05:31:489 | MD |     INFO  | +0     | Keymapper - Run,Xpadder 2013.07.18.exe "G:\Hyperspin\HyperLaunch\Profiles\xpadder\_Default\blank.xpadderprofile" /M, G:\Hyperspin\Utilities, Hide
15:05:31:520 | MD |     INFO  | +31    | ExitModule - Ended
15:05:31:524 | MD |     INFO  | +16    | End of Module Logs
15:05:31:603 | HL |     INFO  | +20375 | Main - Module ended, exiting HyperLaunch normally
15:05:31:606 | HL |     INFO  | +0     | ExitScript - Started
15:05:31:662 | HL |     INFO  | +62    | SystemCursor - Restoring mouse cursor
15:05:31:759 | HL |     INFO  | +94    | ExitScript - Ended
The resolution change is because of an emulator setting in fusion. Look for something like fullscreen screen width and height. I'll investigate if fullscreen resolution can be added to module settings. I found my flickering was caused by background windows opened behind the fusion emulator. Try minimizing all windows before using hyperspin and see if it helps.
