aloner187 Posted September 2, 2014 Posted September 2, 2014 man im at a loss with this system, i have it working great outside hyperspin...i'm trying to setup microsoft msx. ive watched the coleco video explaining set up but still cant get it to launch with hyperlaunch, it just starts the script and sit in tray but wont open the actual emulator...everything is up to date, module and emulator, any help would really be appreciated cause this is driving me up the walls...is there a mess script for msx, got the emulator working fine, but comes back with an error saying this isnt a supported system with this module My Cab Project http://www.hyperspin-fe.com/forum/showthread.php?t=7541
rfancella Posted September 2, 2014 Posted September 2, 2014 man im at a loss with this system, i have it working great outside hyperspin...i'm trying to setup microsoft msx. ive watched the coleco video explaining set up but still cant get it to launch with hyperlaunch, it just starts the script and sit in tray but wont open the actual emulator...everything is up to date, module and emulator, any help would really be appreciated cause this is driving me up the walls...is there a mess script for msx, got the emulator working fine, but comes back with an error saying this isnt a supported system with this module Please post your HyperLaunch.log file as per this post: http://www.hyperspin-fe.com/forum/showthread.php?31072-The-HyperNoobie-Guide-For-Posting-To-The-Fourm Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
aloner187 Posted September 3, 2014 Author Posted September 3, 2014 here is the log 13:38:18:154 | HL | INFO | +N/A | Main - HyperLaunch v3.0.0.9 13:38:18:154 | HL | INFO | +0 | Main - System Specs: HyperLaunch Dir: X:\Hyperspin\HyperLaunch OS: WIN_7 Architecture: 64-bit (might not be accurate) OS Language: English_United_States OS Admin Status: No Monitor #1 (\\.\DISPLAY1): 1600x900 (1600x860 work) AutoHotkey Path: C:\Program Files (x86)\AutoHotkey\AutoHotkey.exe AHK Version: 1.1.09.04 Unicode: No 13:38:18:154 | HL | INFO | +0 | Main - HyperSpin.exe coordinates are x y w h 13:38:18:154 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\HyperLaunch.exe exists 13:38:18:154 | HL | INFO | +0 | Main - HyperLaunch received "Microsoft MSX" and "10 Yard Fight (1986) (Irem)" 13:38:18:164 | HL | INFO | +16 | Main - 10 Yard Fight (1986) (Irem) is using the default emulator: BlueMSX 13:38:18:164 | HL | INFO | +0 | Main - Checking for a [blueMSX] section in X:\Hyperspin\HyperLaunch\Settings\Microsoft MSX\Emulators.ini 13:38:18:164 | HL | INFO | +0 | Main - Checking for a [blueMSX] section in X:\Hyperspin\HyperLaunch\Settings\Global Emulators.ini 13:38:18:164 | HL | INFO | +0 | Main - Found [blueMSX] in X:\Hyperspin\HyperLaunch\Settings\Global Emulators.ini 13:38:18:164 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Modules\BlueMSX\BlueMSX.ahk exists 13:38:18:164 | HL | INFO | +0 | Main - CRC Check - CRC matches, this is an official unedited module. 13:38:18:164 | HL | INFO | +0 | Main - 10 Yard Fight (1986) (Irem) will use module: X:\Hyperspin\HyperLaunch\Modules\BlueMSX\BlueMSX.ahk 13:38:18:184 | HL | INFO | +15 | Main - Using standard method with "Rom Extensions" SkipChecks or without any SkipChecks. 13:38:18:184 | HL | INFO | +0 | Main - INI Keys read 13:38:18:184 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Module Extensions\7z.exe exists 13:38:18:184 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Module Extensions\7z.dll exists 13:38:18:184 | HL | INFO | +0 | CheckPaths - Started 13:38:18:214 | HL | INFO | +31 | CheckPaths - Found rom: X:\Hyperspin\Emulators\Microsoft MSX 1 & 2\MSX1 Romset\10 Yard Fight (1986) (Irem).7z 13:38:18:214 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\Emulators\Microsoft MSX 1 & 2\BlueMSX\blueMSX.exe exists 13:38:18:234 | HL | INFO | +16 | CheckPaths - Ended 13:38:18:244 | HL | INFO | +16 | BuildScript - User Variables: ;---------------------------------------------------------------------------- ; INJECTED VARIABLES ;---------------------------------------------------------------------------- #NoTrayIcon #InstallKeybdHook DetectHiddenWindows, ON SetTitleMatchMode, 2 SendMode, Event 0 = 2 frontendPID = 0 frontendPath = X:\Hyperspin frontendExe = HyperSpin.exe frontendExt = exe frontendName = HyperSpin frontendDrive = X: exitEmulatorKey = ~Esc exitEmulatorKeyWait = 0 forceHoldKey = ~Esc restoreFE = false exitScriptKey = ~q & ~s emuFullPath = X:\Hyperspin\Emulators\Microsoft MSX 1 & 2\BlueMSX\blueMSX.exe emuPath = X:\Hyperspin\Emulators\Microsoft MSX 1 & 2\BlueMSX emuName = BlueMSX emuExt = exe romPath = X:\Hyperspin\Emulators\Microsoft MSX 1 & 2\MSX1 Romset romPathFromIni = X:\Hyperspin\Emulators\Microsoft MSX 1 & 2\MSX1 Romset romExtension = .7z romExtensionOrig = .7z romExtensions = 7z|zip|col|rom executable = blueMSX.exe systemName = Microsoft MSX dbName = 10 Yard Fight (1986) (Irem) romName = romMapPath = romMappingEnabled = false romMappingLaunchMenuEnabled = false romMappingFirstMatchingExt = false romMappingShowAllRomsInArchive = true romMappingNumberOfWheelsByScreen = 7 romMappingMenuWidth = 300 romMappingMenuMargin = 50 romMappingTextFont = Bebas Neue romMappingTextOptions = cFFFFFFFF r4 s40 Bold romMappingDisabledTextColor = ff888888 romMappingTextSizeDifference = 5 romMappingTextMargin = 10 romMappingTitleTextFont = Bebas Neue romMappingTitleTextOptions = cFFFFFFFF r4 s60 Bold romMappingTitle2TextFont = Bebas Neue romMappingTitle2TextOptions = cFFFFFFFF r4 s15 Bold romMappingGameInfoTextFont = Bebas Neue romMappingGameInfoTextOptions = cFFFFFFFF r4 s15 Regular romMappingBackgroundBrush = aa000000 romMappingColumnBrush = 33000000 romMappingButtonBrush1 = 6f000000 romMappingButtonBrush2 = 33000000 romMappingBackgroundAlign = Stretch and Lose Aspect romMappingMenuFlagWidth = 40 romMappingMenuFlagSeparation = 5 romMappingDefaultMenuList = FullList romMappingSingleFilteredRomAutomaticLaunch = false skipchecks = false romMatchExt = true logFile = X:\Hyperspin\HyperLaunch\HyperLaunch.log logLabel := [" INFO"," WARNING"," ERROR"," DEBUG1"," DEBUG2"] logLevel = 3 logIncludeModule = true logIncludeFileProperties = true logShowCommandWindow = false logCommandWindow = false navUpKey = Up navDownKey = Down navLeftKey = Left navRightKey = Right navSelectKey = Enter navP2UpKey = Numpad8 navP2DownKey = Numpad2 navP2LeftKey = Numpad4 navP2RightKey = Numpad6 navP2SelectKey = NumpadEnter originalWidth = 1600 originalHeight = 900 dtEnabled = true dtPath = X:\Hyperspin\Programs\DTLite\DAEMON Tools Lite\DTLite.exe dtUseSCSI = true dtAddDrive = true emuIdleShutdown = 0 hideEmu = false hideFE = false fadeIn = false fadeInDuration = 500 fadeInTransitionAnimation = DefaultAnimateFadeIn fadeInDelay = 0 fadeInExitDelay = 0 fadeOutExitDelay = 0 fadeOut = false fadeOutDuration = 500 fadeOutTransitionAnimation = DefaultAnimateFadeOut fadeOutDelay = 0 fadeLyrInterpolation = 7 fadeLyr1Color = FF000000 fadeLyr1AlignImage = Align to Top Left fadeLyr2Pos = Bottom Right Corner fadeLyr2X = 300 fadeLyr2Y = 300 fadeLyr2Adjust = 1 fadeLyr2PicPad = 0 fadeLyr3Pos = Center fadeLyr3X = 300 fadeLyr3Y = 300 fadeLyr3Adjust = 0.75 fadeLyr3Speed = 750 fadeLyr3Animation = DefaultFadeAnimation fadeLyr37zAnimation = DefaultFadeAnimation fadeLyr3Type = imageandbar fadeLyr3ImgFollow7zProgress = true fadeLyr3Repeat = 1 fadeLyr3PicPad = 0 fadeLyr4Adjust = 0.75 fadeLyr4X = 100 fadeLyr4Y = 100 fadeLyr4Pos = Above Layer 3 - Left fadeLyr4FPS = 10 fadeLyr4PicPad = 0 fadeTranspGifColor = FFFFFF fadeBarWindow = false fadeBarWindowX = fadeBarWindowY = fadeBarWindowW = 600 fadeBarWindowH = 120 fadeBarWindowR = 20 fadeBarWindowM = 20 fadeBarWindowHatchStyle = 8 fadeBarBack = true fadeBarBackColor = FF555555 fadeBarH = 20 fadeBarR = 5 fadeBarColor = DD00BFFF fadeBarHatchStyle = 3 fadeBarPercentageText = true fadeBarInfoText = true fadeBarXOffset = 0 fadeBarYOffset = 100 fadeRomInfoDescription = text fadeRomInfoSystemName = text fadeRomInfoYear = text fadeRomInfoManufacturer = text fadeRomInfoGenre = text fadeRomInfoRating = text fadeRomInfoOrder = Description|SystemName|Year|Manufacturer|Genre|Rating fadeRomInfoTextPlacement = topRight fadeRomInfoTextMargin = 5 fadeRomInfoText1Options = cFF555555 r4 s20 Bold fadeRomInfoText2Options = cFF555555 r4 s20 Bold fadeRomInfoText3Options = cFF555555 r4 s20 Bold fadeRomInfoText4Options = cFF555555 r4 s20 Bold fadeRomInfoText5Options = cFF555555 r4 s20 Bold fadeRomInfoText6Options = cFF555555 r4 s20 Bold fadeStats_Number_of_Times_Played = text with label fadeStats_Last_Time_Played = text with label fadeStats_Average_Time_Played = text with label fadeStats_Total_Time_Played = text with label fadeStats_System_Total_Played_Time = text with label fadeStats_Total_Global_Played_Time = text with label fadeStatsInfoOrder = Number_of_Times_Played|Last_Time_Played|Average_Time_Played|Total_Time_Played|System_Total_Played_Time|Total_Global_Played_Time fadeStatsInfoTextPlacement = topLeft fadeStatsInfoTextMargin = 5 fadeStatsInfoText1Options = cFF555555 r4 s20 Bold fadeStatsInfoText2Options = cFF555555 r4 s20 Bold fadeStatsInfoText3Options = cFF555555 r4 s20 Bold fadeStatsInfoText4Options = cFF555555 r4 s20 Bold fadeStatsInfoText5Options = cFF555555 r4 s20 Bold fadeStatsInfoText6Options = cFF555555 r4 s20 Bold fadeText1X = 0 fadeText1Y = 0 fadeText1Options = cFFFFFFFF r4 s20 Right Bold fadeText1 = Loading Game fadeText2X = 0 fadeText2Y = 0 fadeText2Options = cFFFFFFFF r4 s20 Right Bold fadeText2 = Extraction Complete fadeFont = Arial fadeSystemAndRomLayersOnly = false fadeInterruptKey = detectFadeErrorEnabled = true fadeImgPath = X:\Hyperspin\HyperLaunch\Media\Fade HLDataPath = X:\Hyperspin\HyperLaunch\Data HLMediaPath = X:\Hyperspin\HyperLaunch\Media HLErrSoundPath = X:\Hyperspin\HyperLaunch\Media\Sounds\Error modulesPath = X:\Hyperspin\HyperLaunch\Modules moduleFullName = X:\Hyperspin\HyperLaunch\Modules\BlueMSX\BlueMSX.ahk moduleName = BlueMSX modulePath = X:\Hyperspin\HyperLaunch\Modules\BlueMSX moduleExtension = ahk moduleExtensionsPath = X:\Hyperspin\HyperLaunch\Module Extensions libPath = X:\Hyperspin\HyperLaunch\Lib 7zEnabled = false 7zPath = X:\Hyperspin\HyperLaunch\Module Extensions\7z.exe 7zDllPath = X:\Hyperspin\HyperLaunch\Module Extensions\7z.dll 7zExtractPath = C:\Users\shaun\AppData\Local\Temp\HS 7zExtractPathOrig = 7zAttachSystemName = false 7zDelTemp = true 7zSounds = true 7zFormats = .zip,.rar,.7z,.lzh,.gzip,.tar 7zFormatsNoP = zip,rar,7z,lzh,gzip,tar mgEnabled = false mgKey = ~NumpadSub mgBackgroundColor = FF000000 mgSidePadding = 0.2 mgYOffset = 500 mgImageAdjust = 0 mgFont = Arial mgText1Options = x10p y30p w80p Center cBBFFFFFF r4 s100 BoldItalic mgText1Text = Please select a game mgText2Options = w96p cFFFFFFFF r4 s50 Center BoldItalic mgText2Offset = 70 mgUseSound = true mgSoundfreq = 300 mgExitEffect = none mgSelectedEffect = rotate mgUseGameArt = false mgArtworkDir = Artwork1 hpEnabled = false hpKey = ~NumpadAdd hpBackToMenuBarKey = X hpZoomInKey = C hpZoomOutKey = V hpScreenshotKey = ~PrintScreen hpHiToTextPath = X:\Hyperspin\HyperLaunch\Module Extensions\HiToText.exe hpSaveStateKeyCodes = {F8 down}{F8 up} hpLoadStateKeyCodes = {F7 down}{F7 up} keymapperEnabled = false keymapper = xpadderFullPath = X:\Hyperspin\Programs\Xpadder_v5.6\Xpadder.exe joyToKeyFullPath = X:\Hyperspin\Programs\JoyToKey_en\JoyToKey.exe keymapperProfilePath = X:\Hyperspin\HyperLaunch\Profiles\ keymapperFrontEndProfileName = HyperSpin keymapperHyperLaunchProfileEnabled = false JoyIDsEnabled = false JoyIDsPreferredControllersSystem = use_global JoyIDsPreferredControllersGlobal = use_global CustomJoyNamesEnabled = false CustomJoyNames = FEProfile = X:\Hyperspin\HyperLaunch\Profiles\\HyperSpin defaultProfile = X:\Hyperspin\HyperLaunch\Profiles\\_Default systemProfile = X:\Hyperspin\HyperLaunch\Profiles\\Microsoft MSX xPadderSystemProfile = X:\Hyperspin\HyperLaunch\Profiles\\Microsoft MSX\_Default emuProfile = X:\Hyperspin\HyperLaunch\Profiles\\Microsoft MSX\BlueMSX romProfile = X:\Hyperspin\HyperLaunch\Profiles\\Microsoft MSX\10 Yard Fight (1986) (Irem) blankProfile = X:\Hyperspin\HyperLaunch\Profiles\\blank HyperLaunchProfile = X:\Hyperspin\HyperLaunch\Profiles\\HyperLaunch bezelEnabled = true statisticsEnabled = true 13:38:18:244 | HL | INFO | +0 | BuildScript - Loaded XHotkey Init.ahk scripts 13:38:18:244 | HL | INFO | +0 | BuildScript - Loaded Statistics Init.ahk scripts 13:38:18:244 | HL | INFO | +0 | BuildScript - Loaded User Functions Init.ahk script 13:38:18:244 | HL | INFO | +0 | BuildScript - Module: MEmu = BlueMSX MEmuV = v2.8.2 MURL = [url]http://www.bluemsx.com/[/url] MAuthor = djvj MVersion = 2.0.1 MCRC = BAB8048F iCRC = 6DC9C5DF MID = 635038268875990669 MSystem = "ColecoVision","Microsoft MSX","Microsoft MSX2" ;---------------------------------------------------------------------------- ; Notes: ; Set your fullscreen res manually in the emu by clicking Options->Performance->Fullscreen Resolution ;---------------------------------------------------------------------------- StartModule() FadeInStart() settingsFile := modulePath . "\" . moduleName . ".ini" Fullscreen := IniReadCheck(settingsFile, "settings", "Fullscreen","true",,1) Stretch := IniReadCheck(settingsFile, "settings", "Stretch","false",,1) bluemsxINI := CheckFile(emuPath . "\bluemsx.ini") IniRead, currentFullscreen, %bluemsxINI%, config, video.windowSize IniRead, currentStretch, %bluemsxINI%, config, video.horizontalStretch ; Setting Fullscreen setting in ini if it doesn't match what user wants above If ( Fullscreen != "true" And currentFullScreen = "fullscreen" ) IniWrite, normal, %bluemsxINI%, config, video.windowSize Else If ( Fullscreen = "true" And currentFullScreen = "normal" ) IniWrite, fullscreen, %bluemsxINI%, config, video.windowSize ; Setting Stretch setting in ini if it doesn't match what user wants above If ( Stretch != "true" And currentStretch = "yes" ) IniWrite, no, %bluemsxINI%, config, video.horizontalStretch Else If ( Stretch = "true" And currentStretch = "no" ) IniWrite, yes, %bluemsxINI%, config, video.horizontalStretch 7z(romPath, romName, romExtension, 7zExtractPath) Run(executable . " """ . romPath . "\" . romName . romExtension . """", emuPath) WinWait("blueMSX ahk_class blueMSX") WinWaitActive("blueMSX ahk_class blueMSX") Sleep, 2000 ; need this otherwise Hyperspin flashes back in during fade FadeInExit() Process("WaitClose", executable) 7zCleanUp() FadeOutExit() ExitModule() HaltEmu: disableSuspendEmu := true PostMessage, 0x111, 40025,,,blueMSX ahk_class blueMSX ; Pause Return RestoreEmu: PostMessage, 0x111, 40025,,,blueMSX ahk_class blueMSX ; Pause Return CloseProcess: FadeOutStart() WinClose("blueMSX ahk_class blueMSX") Return 13:38:18:254 | HL | INFO | +15 | BuildScript - Loaded Statistics.ahk script 13:38:18:254 | HL | INFO | +0 | BuildScript - Loaded User Functions.ahk script 13:38:18:254 | HL | INFO | +0 | BuildScript - Finished injecting functions into module 13:38:18:254 | HL | INFO | +0 | Main - Module is built 13:38:18:254 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\AutoHotkey.dll exists 13:38:18:254 | HL | INFO | +0 | Main - Running module My Cab Project http://www.hyperspin-fe.com/forum/showthread.php?t=7541
rfancella Posted September 3, 2014 Posted September 3, 2014 here is the log Thank you for your reply. Please set your logging level to Troubleshooting and post a new log. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
aloner187 Posted September 3, 2014 Author Posted September 3, 2014 13:54:14:785 | HL | INFO | +N/A | Main - HyperLaunch v3.0.0.9 13:54:14:800 | HL | INFO | +16 | Main - System Specs: HyperLaunch Dir: X:\Hyperspin\HyperLaunch OS: WIN_7 Architecture: 64-bit (might not be accurate) OS Language: English_United_States OS Admin Status: No Monitor #1 (\\.\DISPLAY1): 1600x900 (1600x860 work) AutoHotkey Path: C:\Program Files (x86)\AutoHotkey\AutoHotkey.exe AHK Version: 1.1.09.04 Unicode: No 13:54:14:802 | HL | INFO | +0 | Main - HyperSpin.exe coordinates are x y w h 13:54:14:804 | HL | INFO | +16 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\HyperLaunch.exe exists 13:54:14:807 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription Your favorite Front End companion! FileVersion 3.0.0.9 LegalCopyright ©2013 HL squad ProductName djvj's one swell guy! ProductVersion 1.1.9.4 CompanyName djvj's one swell guy! File Size: 899072 bytes Created: 9/1/2014 - 4:51:55 PM Modified: 8/28/2014 - 8:18:26 AM 13:54:14:809 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Module Extensions\gdip.ahk exists 13:54:14:839 | HL | DEBUG1 | +31 | CRC Check - CRC matches, this is an official unedited Extension. 13:54:14:848 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 88789 bytes Created: 9/1/2014 - 4:53:41 PM Modified: 8/28/2014 - 8:18:23 AM 13:54:14:851 | HL | INFO | +15 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Module Extensions\RIni.ahk exists 13:54:14:857 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 13:54:14:860 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 67561 bytes Created: 9/1/2014 - 4:53:43 PM Modified: 8/28/2014 - 8:18:24 AM 13:54:14:861 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Module Extensions\CLR.ahk exists 13:54:14:865 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Extension. 13:54:14:867 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 10586 bytes Created: 9/1/2014 - 4:53:41 PM Modified: 8/28/2014 - 8:18:22 AM 13:54:14:870 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Module Extensions\COM.ahk exists 13:54:14:875 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 13:54:14:878 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 26342 bytes Created: 9/1/2014 - 4:53:41 PM Modified: 8/28/2014 - 8:18:22 AM 13:54:14:879 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Module Extensions\JSON.ahk exists 13:54:14:900 | HL | DEBUG1 | +31 | CRC Check - CRC matches, this is an official unedited Extension. 13:54:14:902 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 9203 bytes Created: 9/1/2014 - 4:53:43 PM Modified: 8/28/2014 - 8:18:23 AM 13:54:14:907 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Lib\Fade Init.ahk exists 13:54:14:909 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 13:54:14:912 | HL | DEBUG1 | +16 | CheckFile - Attributes: File Size: 1145 bytes Created: 9/1/2014 - 4:52:06 PM Modified: 8/28/2014 - 8:18:23 AM 13:54:14:914 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Lib\HyperPause Init.ahk exists 13:54:14:917 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 13:54:14:933 | HL | DEBUG1 | +15 | CheckFile - Attributes: File Size: 691 bytes Created: 9/1/2014 - 4:52:06 PM Modified: 8/28/2014 - 8:18:23 AM 13:54:14:935 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Lib\Keymapper Init.ahk exists 13:54:14:940 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 13:54:14:940 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 2485 bytes Created: 9/1/2014 - 4:52:06 PM Modified: 8/28/2014 - 8:18:23 AM 13:54:14:940 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Lib\MultiGame Init.ahk exists 13:54:14:950 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 13:54:14:950 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 161 bytes Created: 9/1/2014 - 4:52:06 PM Modified: 8/28/2014 - 8:18:23 AM 13:54:14:950 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Lib\Statistics Init.ahk exists 13:54:14:960 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 13:54:14:960 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 167 bytes Created: 9/1/2014 - 4:52:07 PM Modified: 8/28/2014 - 8:18:24 AM 13:54:14:970 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Lib\Fade.ahk exists 13:54:14:990 | HL | DEBUG1 | +31 | CRC Check - CRC matches, this is an official unedited Library. 13:54:14:990 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 26644 bytes Created: 9/1/2014 - 4:52:06 PM Modified: 8/28/2014 - 8:18:23 AM 13:54:14:000 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Lib\HyperPause.ahk exists 13:54:15:060 | HL | DEBUG1 | +62 | CRC Check - CRC matches, this is an official unedited Library. 13:54:15:060 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 326352 bytes Created: 9/1/2014 - 4:52:06 PM Modified: 8/28/2014 - 8:18:23 AM 13:54:15:060 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Lib\Keymapper.ahk exists 13:54:15:060 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 13:54:15:070 | HL | DEBUG1 | +16 | CheckFile - Attributes: File Size: 27844 bytes Created: 9/1/2014 - 4:52:06 PM Modified: 8/28/2014 - 8:18:23 AM 13:54:15:080 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Lib\MultiGame.ahk exists 13:54:15:080 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 13:54:15:090 | HL | DEBUG1 | +15 | CheckFile - Attributes: File Size: 28070 bytes Created: 9/1/2014 - 4:52:06 PM Modified: 8/28/2014 - 8:18:23 AM 13:54:15:090 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Lib\Bezel.ahk exists 13:54:15:090 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 13:54:15:100 | HL | DEBUG1 | +16 | CheckFile - Attributes: File Size: 21407 bytes Created: 9/1/2014 - 4:52:06 PM Modified: 8/28/2014 - 8:18:22 AM 13:54:15:100 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Lib\Statistics.ahk exists 13:54:15:100 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 13:54:15:110 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 26089 bytes Created: 9/1/2014 - 4:52:07 PM Modified: 8/28/2014 - 8:18:24 AM 13:54:15:110 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Lib\Rom Mapping Launch Menu.ahk exists 13:54:15:130 | HL | DEBUG1 | +31 | CRC Check - CRC matches, this is an official unedited Library. 13:54:15:140 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 63798 bytes Created: 9/1/2014 - 4:52:06 PM Modified: 8/28/2014 - 8:18:24 AM 13:54:15:140 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Lib\Shared.ahk exists 13:54:15:140 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 13:54:15:160 | HL | DEBUG1 | +16 | CheckFile - Attributes: File Size: 65137 bytes Created: 9/1/2014 - 4:52:06 PM Modified: 8/28/2014 - 8:18:24 AM 13:54:15:160 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Lib\XHotkey.ahk exists 13:54:15:170 | HL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library. 13:54:15:170 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 28659 bytes Created: 9/1/2014 - 4:52:07 PM Modified: 8/28/2014 - 8:18:25 AM 13:54:15:170 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Lib\Fade Animations.ahk exists 13:54:15:170 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 13:54:15:180 | HL | DEBUG1 | +16 | CheckFile - Attributes: File Size: 48181 bytes Created: 9/1/2014 - 4:52:06 PM Modified: 8/28/2014 - 8:18:23 AM 13:54:15:180 | HL | INFO | +0 | Main - HyperLaunch received "Microsoft MSX" and "10 Yard Fight (1986) (Irem)" 13:54:15:190 | HL | INFO | +0 | Main - 10 Yard Fight (1986) (Irem) is using the default emulator: BlueMSX 13:54:15:210 | HL | INFO | +31 | Main - Checking for a [blueMSX] section in X:\Hyperspin\HyperLaunch\Settings\Microsoft MSX\Emulators.ini 13:54:15:210 | HL | INFO | +0 | Main - Checking for a [blueMSX] section in X:\Hyperspin\HyperLaunch\Settings\Global Emulators.ini 13:54:15:210 | HL | INFO | +0 | Main - Found [blueMSX] in X:\Hyperspin\HyperLaunch\Settings\Global Emulators.ini 13:54:15:210 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Modules\BlueMSX\BlueMSX.ahk exists 13:54:15:210 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 2238 bytes Created: 9/2/2014 - 9:31:49 AM Modified: 9/2/2014 - 9:31:49 AM 13:54:15:220 | HL | INFO | +0 | Main - CRC Check - CRC matches, this is an official unedited module. 13:54:15:220 | HL | INFO | +0 | Main - 10 Yard Fight (1986) (Irem) will use module: X:\Hyperspin\HyperLaunch\Modules\BlueMSX\BlueMSX.ahk 13:54:15:230 | HL | INFO | +16 | Main - Using standard method with "Rom Extensions" SkipChecks or without any SkipChecks. 13:54:15:240 | HL | INFO | +15 | Main - INI Keys read 13:54:15:240 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Module Extensions\7z.exe exists 13:54:15:240 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription 7-Zip Console FileVersion 9.20 InternalName 7z LegalCopyright Copyright (c) 1999-2010 Igor Pavlov OriginalFilename 7z.exe ProductName 7-Zip ProductVersion 9.20 CompanyName Igor Pavlov File Size: 163840 bytes Created: 9/1/2014 - 4:53:41 PM Modified: 8/28/2014 - 8:18:26 AM 13:54:15:240 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Module Extensions\7z.dll exists 13:54:15:250 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription 7z Standalone Plugin FileVersion 9.20 InternalName 7za LegalCopyright Copyright (c) 1999-2010 Igor Pavlov OriginalFilename 7za.dll ProductName 7-Zip ProductVersion 9.20 CompanyName Igor Pavlov File Size: 914432 bytes Created: 9/1/2014 - 4:53:41 PM Modified: 8/28/2014 - 8:18:26 AM 13:54:15:250 | HL | INFO | +0 | CheckPaths - Started 13:54:15:250 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom: X:\Hyperspin\Emulators\Microsoft MSX 1 & 2\MSX1 Romset\10 Yard Fight (1986) (Irem).7z 13:54:15:250 | HL | INFO | +0 | CheckPaths - Found rom: X:\Hyperspin\Emulators\Microsoft MSX 1 & 2\MSX1 Romset\10 Yard Fight (1986) (Irem).7z 13:54:15:250 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\Emulators\Microsoft MSX 1 & 2\BlueMSX\blueMSX.exe exists 13:54:15:260 | HL | DEBUG1 | +16 | CheckFile - Attributes: File Size: 3493888 bytes Created: 8/14/2009 - 1:57:32 PM Modified: 8/14/2009 - 1:57:32 PM 13:54:15:260 | HL | INFO | +0 | CheckPaths - Ended 13:54:15:260 | HL | INFO | +0 | BuildScript - User Variables: ;---------------------------------------------------------------------------- ; INJECTED VARIABLES ;---------------------------------------------------------------------------- #NoTrayIcon #InstallKeybdHook DetectHiddenWindows, ON SetTitleMatchMode, 2 SendMode, Event 0 = 2 frontendPID = 0 frontendPath = X:\Hyperspin frontendExe = HyperSpin.exe frontendExt = exe frontendName = HyperSpin frontendDrive = X: exitEmulatorKey = ~Esc exitEmulatorKeyWait = 0 forceHoldKey = ~Esc restoreFE = false exitScriptKey = ~q & ~s emuFullPath = X:\Hyperspin\Emulators\Microsoft MSX 1 & 2\BlueMSX\blueMSX.exe emuPath = X:\Hyperspin\Emulators\Microsoft MSX 1 & 2\BlueMSX emuName = BlueMSX emuExt = exe romPath = X:\Hyperspin\Emulators\Microsoft MSX 1 & 2\MSX1 Romset romPathFromIni = X:\Hyperspin\Emulators\Microsoft MSX 1 & 2\MSX1 Romset romExtension = .7z romExtensionOrig = .7z romExtensions = 7z|zip|col|rom executable = blueMSX.exe systemName = Microsoft MSX dbName = 10 Yard Fight (1986) (Irem) romName = romMapPath = romMappingEnabled = false romMappingLaunchMenuEnabled = false romMappingFirstMatchingExt = false romMappingShowAllRomsInArchive = true romMappingNumberOfWheelsByScreen = 7 romMappingMenuWidth = 300 romMappingMenuMargin = 50 romMappingTextFont = Bebas Neue romMappingTextOptions = cFFFFFFFF r4 s40 Bold romMappingDisabledTextColor = ff888888 romMappingTextSizeDifference = 5 romMappingTextMargin = 10 romMappingTitleTextFont = Bebas Neue romMappingTitleTextOptions = cFFFFFFFF r4 s60 Bold romMappingTitle2TextFont = Bebas Neue romMappingTitle2TextOptions = cFFFFFFFF r4 s15 Bold romMappingGameInfoTextFont = Bebas Neue romMappingGameInfoTextOptions = cFFFFFFFF r4 s15 Regular romMappingBackgroundBrush = aa000000 romMappingColumnBrush = 33000000 romMappingButtonBrush1 = 6f000000 romMappingButtonBrush2 = 33000000 romMappingBackgroundAlign = Stretch and Lose Aspect romMappingMenuFlagWidth = 40 romMappingMenuFlagSeparation = 5 romMappingDefaultMenuList = FullList romMappingSingleFilteredRomAutomaticLaunch = false skipchecks = false romMatchExt = true logFile = X:\Hyperspin\HyperLaunch\HyperLaunch.log logLabel := [" INFO"," WARNING"," ERROR"," DEBUG1"," DEBUG2"] logLevel = 10 logIncludeModule = true logIncludeFileProperties = true logShowCommandWindow = false logCommandWindow = false navUpKey = Up navDownKey = Down navLeftKey = Left navRightKey = Right navSelectKey = Enter navP2UpKey = Numpad8 navP2DownKey = Numpad2 navP2LeftKey = Numpad4 navP2RightKey = Numpad6 navP2SelectKey = NumpadEnter originalWidth = 1600 originalHeight = 900 dtEnabled = true dtPath = X:\Hyperspin\Programs\DTLite\DAEMON Tools Lite\DTLite.exe dtUseSCSI = true dtAddDrive = true emuIdleShutdown = 0 hideEmu = false hideFE = false fadeIn = false fadeInDuration = 500 fadeInTransitionAnimation = DefaultAnimateFadeIn fadeInDelay = 0 fadeInExitDelay = 0 fadeOutExitDelay = 0 fadeOut = false fadeOutDuration = 500 fadeOutTransitionAnimation = DefaultAnimateFadeOut fadeOutDelay = 0 fadeLyrInterpolation = 7 fadeLyr1Color = FF000000 fadeLyr1AlignImage = Align to Top Left fadeLyr2Pos = Bottom Right Corner fadeLyr2X = 300 fadeLyr2Y = 300 fadeLyr2Adjust = 1 fadeLyr2PicPad = 0 fadeLyr3Pos = Center fadeLyr3X = 300 fadeLyr3Y = 300 fadeLyr3Adjust = 0.75 fadeLyr3Speed = 750 fadeLyr3Animation = DefaultFadeAnimation fadeLyr37zAnimation = DefaultFadeAnimation fadeLyr3Type = imageandbar fadeLyr3ImgFollow7zProgress = true fadeLyr3Repeat = 1 fadeLyr3PicPad = 0 fadeLyr4Adjust = 0.75 fadeLyr4X = 100 fadeLyr4Y = 100 fadeLyr4Pos = Above Layer 3 - Left fadeLyr4FPS = 10 fadeLyr4PicPad = 0 fadeTranspGifColor = FFFFFF fadeBarWindow = false fadeBarWindowX = fadeBarWindowY = fadeBarWindowW = 600 fadeBarWindowH = 120 fadeBarWindowR = 20 fadeBarWindowM = 20 fadeBarWindowHatchStyle = 8 fadeBarBack = true fadeBarBackColor = FF555555 fadeBarH = 20 fadeBarR = 5 fadeBarColor = DD00BFFF fadeBarHatchStyle = 3 fadeBarPercentageText = true fadeBarInfoText = true fadeBarXOffset = 0 fadeBarYOffset = 100 fadeRomInfoDescription = text fadeRomInfoSystemName = text fadeRomInfoYear = text fadeRomInfoManufacturer = text fadeRomInfoGenre = text fadeRomInfoRating = text fadeRomInfoOrder = Description|SystemName|Year|Manufacturer|Genre|Rating fadeRomInfoTextPlacement = topRight fadeRomInfoTextMargin = 5 fadeRomInfoText1Options = cFF555555 r4 s20 Bold fadeRomInfoText2Options = cFF555555 r4 s20 Bold fadeRomInfoText3Options = cFF555555 r4 s20 Bold fadeRomInfoText4Options = cFF555555 r4 s20 Bold fadeRomInfoText5Options = cFF555555 r4 s20 Bold fadeRomInfoText6Options = cFF555555 r4 s20 Bold fadeStats_Number_of_Times_Played = text with label fadeStats_Last_Time_Played = text with label fadeStats_Average_Time_Played = text with label fadeStats_Total_Time_Played = text with label fadeStats_System_Total_Played_Time = text with label fadeStats_Total_Global_Played_Time = text with label fadeStatsInfoOrder = Number_of_Times_Played|Last_Time_Played|Average_Time_Played|Total_Time_Played|System_Total_Played_Time|Total_Global_Played_Time fadeStatsInfoTextPlacement = topLeft fadeStatsInfoTextMargin = 5 fadeStatsInfoText1Options = cFF555555 r4 s20 Bold fadeStatsInfoText2Options = cFF555555 r4 s20 Bold fadeStatsInfoText3Options = cFF555555 r4 s20 Bold fadeStatsInfoText4Options = cFF555555 r4 s20 Bold fadeStatsInfoText5Options = cFF555555 r4 s20 Bold fadeStatsInfoText6Options = cFF555555 r4 s20 Bold fadeText1X = 0 fadeText1Y = 0 fadeText1Options = cFFFFFFFF r4 s20 Right Bold fadeText1 = Loading Game fadeText2X = 0 fadeText2Y = 0 fadeText2Options = cFFFFFFFF r4 s20 Right Bold fadeText2 = Extraction Complete fadeFont = Arial fadeSystemAndRomLayersOnly = false fadeInterruptKey = detectFadeErrorEnabled = true fadeImgPath = X:\Hyperspin\HyperLaunch\Media\Fade HLDataPath = X:\Hyperspin\HyperLaunch\Data HLMediaPath = X:\Hyperspin\HyperLaunch\Media HLErrSoundPath = X:\Hyperspin\HyperLaunch\Media\Sounds\Error modulesPath = X:\Hyperspin\HyperLaunch\Modules moduleFullName = X:\Hyperspin\HyperLaunch\Modules\BlueMSX\BlueMSX.ahk moduleName = BlueMSX modulePath = X:\Hyperspin\HyperLaunch\Modules\BlueMSX moduleExtension = ahk moduleExtensionsPath = X:\Hyperspin\HyperLaunch\Module Extensions libPath = X:\Hyperspin\HyperLaunch\Lib 7zEnabled = false 7zPath = X:\Hyperspin\HyperLaunch\Module Extensions\7z.exe 7zDllPath = X:\Hyperspin\HyperLaunch\Module Extensions\7z.dll 7zExtractPath = C:\Users\shaun\AppData\Local\Temp\HS 7zExtractPathOrig = 7zAttachSystemName = false 7zDelTemp = true 7zSounds = true 7zFormats = .zip,.rar,.7z,.lzh,.gzip,.tar 7zFormatsNoP = zip,rar,7z,lzh,gzip,tar mgEnabled = false mgKey = ~NumpadSub mgBackgroundColor = FF000000 mgSidePadding = 0.2 mgYOffset = 500 mgImageAdjust = 0 mgFont = Arial mgText1Options = x10p y30p w80p Center cBBFFFFFF r4 s100 BoldItalic mgText1Text = Please select a game mgText2Options = w96p cFFFFFFFF r4 s50 Center BoldItalic mgText2Offset = 70 mgUseSound = true mgSoundfreq = 300 mgExitEffect = none mgSelectedEffect = rotate mgUseGameArt = false mgArtworkDir = Artwork1 hpEnabled = false hpKey = ~NumpadAdd hpBackToMenuBarKey = X hpZoomInKey = C hpZoomOutKey = V hpScreenshotKey = ~PrintScreen hpHiToTextPath = X:\Hyperspin\HyperLaunch\Module Extensions\HiToText.exe hpSaveStateKeyCodes = {F8 down}{F8 up} hpLoadStateKeyCodes = {F7 down}{F7 up} keymapperEnabled = false keymapper = xpadderFullPath = X:\Hyperspin\Programs\Xpadder_v5.6\Xpadder.exe joyToKeyFullPath = X:\Hyperspin\Programs\JoyToKey_en\JoyToKey.exe keymapperProfilePath = X:\Hyperspin\HyperLaunch\Profiles\ keymapperFrontEndProfileName = HyperSpin keymapperHyperLaunchProfileEnabled = false JoyIDsEnabled = false JoyIDsPreferredControllersSystem = use_global JoyIDsPreferredControllersGlobal = use_global CustomJoyNamesEnabled = false CustomJoyNames = FEProfile = X:\Hyperspin\HyperLaunch\Profiles\\HyperSpin defaultProfile = X:\Hyperspin\HyperLaunch\Profiles\\_Default systemProfile = X:\Hyperspin\HyperLaunch\Profiles\\Microsoft MSX xPadderSystemProfile = X:\Hyperspin\HyperLaunch\Profiles\\Microsoft MSX\_Default emuProfile = X:\Hyperspin\HyperLaunch\Profiles\\Microsoft MSX\BlueMSX romProfile = X:\Hyperspin\HyperLaunch\Profiles\\Microsoft MSX\10 Yard Fight (1986) (Irem) blankProfile = X:\Hyperspin\HyperLaunch\Profiles\\blank HyperLaunchProfile = X:\Hyperspin\HyperLaunch\Profiles\\HyperLaunch bezelEnabled = true statisticsEnabled = true 13:54:15:260 | HL | INFO | +0 | BuildScript - Loaded XHotkey Init.ahk scripts 13:54:15:260 | HL | INFO | +0 | BuildScript - Loaded Statistics Init.ahk scripts 13:54:15:270 | HL | INFO | +0 | BuildScript - Loaded User Functions Init.ahk script 13:54:15:270 | HL | DEBUG1 | +0 | BuildScript - Module starts on line: 285 13:54:15:270 | HL | INFO | +0 | BuildScript - Module: MEmu = BlueMSX MEmuV = v2.8.2 MURL = http://www.bluemsx.com/ MAuthor = djvj MVersion = 2.0.1 MCRC = BAB8048F iCRC = 6DC9C5DF MID = 635038268875990669 MSystem = "ColecoVision","Microsoft MSX","Microsoft MSX2" ;---------------------------------------------------------------------------- ; Notes: ; Set your fullscreen res manually in the emu by clicking Options->Performance->Fullscreen Resolution ;---------------------------------------------------------------------------- StartModule() FadeInStart() settingsFile := modulePath . "\" . moduleName . ".ini" Fullscreen := IniReadCheck(settingsFile, "settings", "Fullscreen","true",,1) Stretch := IniReadCheck(settingsFile, "settings", "Stretch","false",,1) bluemsxINI := CheckFile(emuPath . "\bluemsx.ini") IniRead, currentFullscreen, %bluemsxINI%, config, video.windowSize IniRead, currentStretch, %bluemsxINI%, config, video.horizontalStretch ; Setting Fullscreen setting in ini if it doesn't match what user wants above If ( Fullscreen != "true" And currentFullScreen = "fullscreen" ) IniWrite, normal, %bluemsxINI%, config, video.windowSize Else If ( Fullscreen = "true" And currentFullScreen = "normal" ) IniWrite, fullscreen, %bluemsxINI%, config, video.windowSize ; Setting Stretch setting in ini if it doesn't match what user wants above If ( Stretch != "true" And currentStretch = "yes" ) IniWrite, no, %bluemsxINI%, config, video.horizontalStretch Else If ( Stretch = "true" And currentStretch = "no" ) IniWrite, yes, %bluemsxINI%, config, video.horizontalStretch 7z(romPath, romName, romExtension, 7zExtractPath) Run(executable . " """ . romPath . "\" . romName . romExtension . """", emuPath) WinWait("blueMSX ahk_class blueMSX") WinWaitActive("blueMSX ahk_class blueMSX") Sleep, 2000 ; need this otherwise Hyperspin flashes back in during fade FadeInExit() Process("WaitClose", executable) 7zCleanUp() FadeOutExit() ExitModule() HaltEmu: disableSuspendEmu := true PostMessage, 0x111, 40025,,,blueMSX ahk_class blueMSX ; Pause Return RestoreEmu: PostMessage, 0x111, 40025,,,blueMSX ahk_class blueMSX ; Pause Return CloseProcess: FadeOutStart() WinClose("blueMSX ahk_class blueMSX") Return 13:54:15:270 | HL | INFO | +0 | BuildScript - Loaded Statistics.ahk script 13:54:15:280 | HL | INFO | +16 | BuildScript - Loaded User Functions.ahk script 13:54:15:280 | HL | INFO | +0 | BuildScript - Finished injecting functions into module 13:54:15:280 | HL | INFO | +0 | Main - Module is built 13:54:15:280 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\AutoHotkey.dll exists 13:54:15:280 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription AutoHotkey_H ANSI 32-bit FileVersion 1.1.09.04 InternalName AutoHotkey_H LegalCopyright Copyright (C) 2012 OriginalFilename AutoHotkey.exe ProductName AutoHotkey_H ProductVersion 1.1.09.04 File Size: 785408 bytes Created: 9/1/2014 - 4:51:55 PM Modified: 8/28/2014 - 8:18:26 AM 13:54:15:290 | HL | INFO | +15 | Main - Running module 13:54:15:290 | HL | INFO | +0 | Main - Starting timer to watch if Front End gets displaced and restore it if it does. 13:54:15:390 | MD | INFO | +N/A | Module initialized 13:54:15:390 | MD | INFO | +0 | StartModule - Started 13:54:15:390 | MD | INFO | +0 | StartModule - MEmu: BlueMSX MEmuV: v2.8.2 MURL: http://www.bluemsx.com/ MAuthor: djvj MVersion: 2.0.1 MCRC: BAB8048F iCRC: 6DC9C5DF MID: MSystem: "ColecoVision","Microsoft MSX","Microsoft MSX2" 13:54:15:410 | MD | INFO | +15 | StartModule - You have a supported System Name for this module: "Microsoft MSX" 13:54:15:410 | MD | DEBUG1 | +0 | StartModule - Setting romName to the dbName sent to HyperLaunch: 13:54:15:410 | MD | INFO | +0 | StartModule - Ended 13:54:15:410 | MD | INFO | +0 | StartGlobalUserFeatures - Starting 13:54:15:410 | MD | INFO | +0 | StartGlobalUserFeatures - Ending 13:54:15:410 | MD | INFO | +0 | Module Setting - Fullscreen: true 13:54:15:420 | MD | INFO | +16 | Module Setting - Stretch: false 13:54:15:420 | MD | INFO | +0 | CheckFile - Checking if X:\Hyperspin\Emulators\Microsoft MSX 1 & 2\BlueMSX\bluemsx.ini exists 13:54:15:420 | MD | DEBUG1 | +0 | CheckFile - Attributes: File Size: 3973 bytes Created: 9/2/2014 - 2:23:07 PM Modified: 9/2/2014 - 2:57:32 PM 13:54:15:420 | MD | INFO | +0 | Module Run - Running: X:\Hyperspin\Emulators\Microsoft MSX 1 & 2\BlueMSX\blueMSX.exe "X:\Hyperspin\Emulators\Microsoft MSX 1 & 2\MSX1 Romset\10 Yard Fight (1986) (Irem).7z" 13:54:15:470 | MD | DEBUG1 | +47 | Module Run - "blueMSX.exe "X:\Hyperspin\Emulators\Microsoft MSX 1 & 2\MSX1 Romset\10 Yard Fight (1986) (Irem).7z"" Process ID: 1600 13:54:15:470 | MD | DEBUG1 | +0 | GetActiveWindowStatus - Title: HyperLaunch HQ v1.0.13.0 | Class: HwndWrapper[HyperLaunchHQ.exe;;dba8d510-ead5-461f-a2ae-357d416aa2f0] | State: 0 | X: 1 | Y: 1 | Width: 1598 | Height: 858 | Window HWND: 0x7903d6 | Process ID: 7276 | Process Path: X:\Hyperspin\HyperLaunch\HyperLaunchHQ\HyperLaunchHQ.exe 13:54:15:480 | MD | INFO | +15 | Module WinWait - Waiting for blueMSX ahk_class blueMSX 13:54:16:082 | MD | DEBUG1 | +609 | GetActiveWindowStatus - Title: | Class: #32770 | State: 0 | X: 363 | Y: 164 | Width: 274 | Height: 71 | Window HWND: 0x310018 | Process ID: 1600 | Process Path: X:\Hyperspin\Emulators\Microsoft MSX 1 & 2\BlueMSX\blueMSX.exe 13:54:16:094 | MD | DEBUG1 | +0 | GetActiveWindowStatus - Title: blueMSX | Class: blueMSX | State: 0 | X: 100 | Y: 100 | Width: 132 | Height: 38 | Window HWND: 0x6f03b8 | Process ID: 1600 | Process Path: X:\Hyperspin\Emulators\Microsoft MSX 1 & 2\BlueMSX\blueMSX.exe 13:54:16:102 | MD | INFO | +15 | Module WinWaitActive - Waiting for "blueMSX ahk_class blueMSX" 13:54:16:208 | MD | DEBUG1 | +110 | GetActiveWindowStatus - Title: HyperLaunch HQ v1.0.13.0 | Class: HwndWrapper[HyperLaunchHQ.exe;;dba8d510-ead5-461f-a2ae-357d416aa2f0] | State: 0 | X: 1 | Y: 1 | Width: 1598 | Height: 858 | Window HWND: 0x7903d6 | Process ID: 7276 | Process Path: X:\Hyperspin\HyperLaunch\HyperLaunchHQ\HyperLaunchHQ.exe 13:54:18:206 | MD | INFO | +1996 | Module Process - WaitClose blueMSX.exe 13:54:18:206 | MD | INFO | +0 | StopGlobalUserFeatures - Starting 13:54:18:206 | MD | INFO | +0 | StopGlobalUserFeatures - Ending 13:54:18:206 | MD | INFO | +0 | ExitModule - Started 13:54:18:206 | MD | INFO | +0 | Starting Updating Statistics: 13:54:18:216 | MD | DEBUG2 | +0 | Total Elapsed Time in Pause in seconds: 0 13:54:18:216 | MD | DEBUG2 | +0 | gameSectionStartTime:37901924 13:54:18:216 | MD | DEBUG2 | +0 | ElapsedTime:2 13:54:18:216 | MD | INFO | +0 | CreateRomTable - Started 13:54:18:226 | MD | DEBUG1 | +16 | CreateRomTable - Checking for match: "10 Yard Fight (1986) (Irem)" and "(Disc" 13:54:18:226 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "10 Yard Fight (1986) (Irem)" and "(Disk" 13:54:18:226 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "10 Yard Fight (1986) (Irem)" and "(Cart" 13:54:18:226 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "10 Yard Fight (1986) (Irem)" and "(Tape" 13:54:18:236 | MD | DEBUG1 | +16 | CreateRomTable - Checking for match: "10 Yard Fight (1986) (Irem)" and "(Cassette" 13:54:18:236 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "10 Yard Fight (1986) (Irem)" and "(Part" 13:54:18:236 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "10 Yard Fight (1986) (Irem)" and "(Side" 13:54:18:236 | MD | INFO | +0 | CreateRomTable - Ended, 7 Loops to create table. 13:54:18:246 | MD | DEBUG2 | +0 | Statistics cleared game name: 10 Yard Fight 13:54:18:306 | MD | DEBUG2 | +62 | Loaded game statistics from ini files: Number_of_Times_Played: 7 Last_Time_Played: Tuesday September 2, 2014 02:37:58 PM Average_Time_Played: 2 Total_Time_Played: 14 System_Total_Played_Time: 21 Total_Global_Played_Time: 3381 13:54:18:316 | MD | DEBUG2 | +16 | Updated Statistics: Number_of_Times_Played: 8 Last_Time_Played: Wednesday September 3, 2014 01:54:18 PM Average_Time_Played: 2 Total_Time_Played: 16 System_Total_Played_Time: 23 Total_Global_Played_Time: 3383 13:54:18:356 | MD | INFO | +31 | Game section statistics updated. 13:54:18:356 | MD | INFO | +0 | ExitModule - Ended 13:54:18:356 | MD | INFO | +0 | End of Module Logs 13:54:18:446 | HL | INFO | +3151 | Main - Module ended, exiting HyperLaunch normally 13:54:18:446 | HL | INFO | +0 | ExitScript - Started 13:54:18:466 | HL | DEBUG1 | +16 | ExitScript - Putting HyperSpin.exe back in focus 13:54:18:506 | HL | INFO | +47 | SystemCursor - Restoring mouse cursor 13:54:18:526 | HL | INFO | +15 | ExitScript - Ended My Cab Project http://www.hyperspin-fe.com/forum/showthread.php?t=7541
rfancella Posted September 3, 2014 Posted September 3, 2014 13:54:14:785 | HL | INFO | +N/A | Main - HyperLaunch v3.0.0.9 13:54:14:800 | HL | INFO | +16 | Main - System Specs: HyperLaunch Dir: X:\Hyperspin\HyperLaunch OS: WIN_7 Architecture: 64-bit (might not be accurate) OS Language: English_United_States OS Admin Status: No Monitor #1 (\\.\DISPLAY1): 1600x900 (1600x860 work) AutoHotkey Path: C:\Program Files (x86)\AutoHotkey\AutoHotkey.exe AHK Version: 1.1.09.04 Unicode: No 13:54:14:802 | HL | INFO | +0 | Main - HyperSpin.exe coordinates are x y w h 13:54:14:804 | HL | INFO | +16 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\HyperLaunch.exe exists 13:54:14:807 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription Your favorite Front End companion! FileVersion 3.0.0.9 LegalCopyright ©2013 HL squad ProductName djvj's one swell guy! ProductVersion 1.1.9.4 CompanyName djvj's one swell guy! File Size: 899072 bytes Created: 9/1/2014 - 4:51:55 PM Modified: 8/28/2014 - 8:18:26 AM 13:54:14:809 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Module Extensions\gdip.ahk exists 13:54:14:839 | HL | DEBUG1 | +31 | CRC Check - CRC matches, this is an official unedited Extension. 13:54:14:848 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 88789 bytes Created: 9/1/2014 - 4:53:41 PM Modified: 8/28/2014 - 8:18:23 AM 13:54:14:851 | HL | INFO | +15 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Module Extensions\RIni.ahk exists 13:54:14:857 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 13:54:14:860 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 67561 bytes Created: 9/1/2014 - 4:53:43 PM Modified: 8/28/2014 - 8:18:24 AM 13:54:14:861 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Module Extensions\CLR.ahk exists 13:54:14:865 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Extension. 13:54:14:867 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 10586 bytes Created: 9/1/2014 - 4:53:41 PM Modified: 8/28/2014 - 8:18:22 AM 13:54:14:870 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Module Extensions\COM.ahk exists 13:54:14:875 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 13:54:14:878 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 26342 bytes Created: 9/1/2014 - 4:53:41 PM Modified: 8/28/2014 - 8:18:22 AM 13:54:14:879 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Module Extensions\JSON.ahk exists 13:54:14:900 | HL | DEBUG1 | +31 | CRC Check - CRC matches, this is an official unedited Extension. 13:54:14:902 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 9203 bytes Created: 9/1/2014 - 4:53:43 PM Modified: 8/28/2014 - 8:18:23 AM 13:54:14:907 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Lib\Fade Init.ahk exists 13:54:14:909 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 13:54:14:912 | HL | DEBUG1 | +16 | CheckFile - Attributes: File Size: 1145 bytes Created: 9/1/2014 - 4:52:06 PM Modified: 8/28/2014 - 8:18:23 AM 13:54:14:914 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Lib\HyperPause Init.ahk exists 13:54:14:917 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 13:54:14:933 | HL | DEBUG1 | +15 | CheckFile - Attributes: File Size: 691 bytes Created: 9/1/2014 - 4:52:06 PM Modified: 8/28/2014 - 8:18:23 AM 13:54:14:935 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Lib\Keymapper Init.ahk exists 13:54:14:940 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 13:54:14:940 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 2485 bytes Created: 9/1/2014 - 4:52:06 PM Modified: 8/28/2014 - 8:18:23 AM 13:54:14:940 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Lib\MultiGame Init.ahk exists 13:54:14:950 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 13:54:14:950 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 161 bytes Created: 9/1/2014 - 4:52:06 PM Modified: 8/28/2014 - 8:18:23 AM 13:54:14:950 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Lib\Statistics Init.ahk exists 13:54:14:960 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 13:54:14:960 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 167 bytes Created: 9/1/2014 - 4:52:07 PM Modified: 8/28/2014 - 8:18:24 AM 13:54:14:970 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Lib\Fade.ahk exists 13:54:14:990 | HL | DEBUG1 | +31 | CRC Check - CRC matches, this is an official unedited Library. 13:54:14:990 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 26644 bytes Created: 9/1/2014 - 4:52:06 PM Modified: 8/28/2014 - 8:18:23 AM 13:54:14:000 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Lib\HyperPause.ahk exists 13:54:15:060 | HL | DEBUG1 | +62 | CRC Check - CRC matches, this is an official unedited Library. 13:54:15:060 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 326352 bytes Created: 9/1/2014 - 4:52:06 PM Modified: 8/28/2014 - 8:18:23 AM 13:54:15:060 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Lib\Keymapper.ahk exists 13:54:15:060 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 13:54:15:070 | HL | DEBUG1 | +16 | CheckFile - Attributes: File Size: 27844 bytes Created: 9/1/2014 - 4:52:06 PM Modified: 8/28/2014 - 8:18:23 AM 13:54:15:080 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Lib\MultiGame.ahk exists 13:54:15:080 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 13:54:15:090 | HL | DEBUG1 | +15 | CheckFile - Attributes: File Size: 28070 bytes Created: 9/1/2014 - 4:52:06 PM Modified: 8/28/2014 - 8:18:23 AM 13:54:15:090 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Lib\Bezel.ahk exists 13:54:15:090 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 13:54:15:100 | HL | DEBUG1 | +16 | CheckFile - Attributes: File Size: 21407 bytes Created: 9/1/2014 - 4:52:06 PM Modified: 8/28/2014 - 8:18:22 AM 13:54:15:100 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Lib\Statistics.ahk exists 13:54:15:100 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 13:54:15:110 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 26089 bytes Created: 9/1/2014 - 4:52:07 PM Modified: 8/28/2014 - 8:18:24 AM 13:54:15:110 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Lib\Rom Mapping Launch Menu.ahk exists 13:54:15:130 | HL | DEBUG1 | +31 | CRC Check - CRC matches, this is an official unedited Library. 13:54:15:140 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 63798 bytes Created: 9/1/2014 - 4:52:06 PM Modified: 8/28/2014 - 8:18:24 AM 13:54:15:140 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Lib\Shared.ahk exists 13:54:15:140 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 13:54:15:160 | HL | DEBUG1 | +16 | CheckFile - Attributes: File Size: 65137 bytes Created: 9/1/2014 - 4:52:06 PM Modified: 8/28/2014 - 8:18:24 AM 13:54:15:160 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Lib\XHotkey.ahk exists 13:54:15:170 | HL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library. 13:54:15:170 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 28659 bytes Created: 9/1/2014 - 4:52:07 PM Modified: 8/28/2014 - 8:18:25 AM 13:54:15:170 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Lib\Fade Animations.ahk exists 13:54:15:170 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 13:54:15:180 | HL | DEBUG1 | +16 | CheckFile - Attributes: File Size: 48181 bytes Created: 9/1/2014 - 4:52:06 PM Modified: 8/28/2014 - 8:18:23 AM 13:54:15:180 | HL | INFO | +0 | Main - HyperLaunch received "Microsoft MSX" and "10 Yard Fight (1986) (Irem)" 13:54:15:190 | HL | INFO | +0 | Main - 10 Yard Fight (1986) (Irem) is using the default emulator: BlueMSX 13:54:15:210 | HL | INFO | +31 | Main - Checking for a [blueMSX] section in X:\Hyperspin\HyperLaunch\Settings\Microsoft MSX\Emulators.ini 13:54:15:210 | HL | INFO | +0 | Main - Checking for a [blueMSX] section in X:\Hyperspin\HyperLaunch\Settings\Global Emulators.ini 13:54:15:210 | HL | INFO | +0 | Main - Found [blueMSX] in X:\Hyperspin\HyperLaunch\Settings\Global Emulators.ini 13:54:15:210 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Modules\BlueMSX\BlueMSX.ahk exists 13:54:15:210 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 2238 bytes Created: 9/2/2014 - 9:31:49 AM Modified: 9/2/2014 - 9:31:49 AM 13:54:15:220 | HL | INFO | +0 | Main - CRC Check - CRC matches, this is an official unedited module. 13:54:15:220 | HL | INFO | +0 | Main - 10 Yard Fight (1986) (Irem) will use module: X:\Hyperspin\HyperLaunch\Modules\BlueMSX\BlueMSX.ahk 13:54:15:230 | HL | INFO | +16 | Main - Using standard method with "Rom Extensions" SkipChecks or without any SkipChecks. 13:54:15:240 | HL | INFO | +15 | Main - INI Keys read 13:54:15:240 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Module Extensions\7z.exe exists 13:54:15:240 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription 7-Zip Console FileVersion 9.20 InternalName 7z LegalCopyright Copyright (c) 1999-2010 Igor Pavlov OriginalFilename 7z.exe ProductName 7-Zip ProductVersion 9.20 CompanyName Igor Pavlov File Size: 163840 bytes Created: 9/1/2014 - 4:53:41 PM Modified: 8/28/2014 - 8:18:26 AM 13:54:15:240 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Module Extensions\7z.dll exists 13:54:15:250 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription 7z Standalone Plugin FileVersion 9.20 InternalName 7za LegalCopyright Copyright (c) 1999-2010 Igor Pavlov OriginalFilename 7za.dll ProductName 7-Zip ProductVersion 9.20 CompanyName Igor Pavlov File Size: 914432 bytes Created: 9/1/2014 - 4:53:41 PM Modified: 8/28/2014 - 8:18:26 AM 13:54:15:250 | HL | INFO | +0 | CheckPaths - Started 13:54:15:250 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom: X:\Hyperspin\Emulators\Microsoft MSX 1 & 2\MSX1 Romset\10 Yard Fight (1986) (Irem).7z 13:54:15:250 | HL | INFO | +0 | CheckPaths - Found rom: X:\Hyperspin\Emulators\Microsoft MSX 1 & 2\MSX1 Romset\10 Yard Fight (1986) (Irem).7z 13:54:15:250 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\Emulators\Microsoft MSX 1 & 2\BlueMSX\blueMSX.exe exists 13:54:15:260 | HL | DEBUG1 | +16 | CheckFile - Attributes: File Size: 3493888 bytes Created: 8/14/2009 - 1:57:32 PM Modified: 8/14/2009 - 1:57:32 PM 13:54:15:260 | HL | INFO | +0 | CheckPaths - Ended 13:54:15:260 | HL | INFO | +0 | BuildScript - User Variables: ;---------------------------------------------------------------------------- ; INJECTED VARIABLES ;---------------------------------------------------------------------------- #NoTrayIcon #InstallKeybdHook DetectHiddenWindows, ON SetTitleMatchMode, 2 SendMode, Event 0 = 2 frontendPID = 0 frontendPath = X:\Hyperspin frontendExe = HyperSpin.exe frontendExt = exe frontendName = HyperSpin frontendDrive = X: exitEmulatorKey = ~Esc exitEmulatorKeyWait = 0 forceHoldKey = ~Esc restoreFE = false exitScriptKey = ~q & ~s emuFullPath = X:\Hyperspin\Emulators\Microsoft MSX 1 & 2\BlueMSX\blueMSX.exe emuPath = X:\Hyperspin\Emulators\Microsoft MSX 1 & 2\BlueMSX emuName = BlueMSX emuExt = exe romPath = X:\Hyperspin\Emulators\Microsoft MSX 1 & 2\MSX1 Romset romPathFromIni = X:\Hyperspin\Emulators\Microsoft MSX 1 & 2\MSX1 Romset romExtension = .7z romExtensionOrig = .7z romExtensions = 7z|zip|col|rom executable = blueMSX.exe systemName = Microsoft MSX dbName = 10 Yard Fight (1986) (Irem) romName = romMapPath = romMappingEnabled = false romMappingLaunchMenuEnabled = false romMappingFirstMatchingExt = false romMappingShowAllRomsInArchive = true romMappingNumberOfWheelsByScreen = 7 romMappingMenuWidth = 300 romMappingMenuMargin = 50 romMappingTextFont = Bebas Neue romMappingTextOptions = cFFFFFFFF r4 s40 Bold romMappingDisabledTextColor = ff888888 romMappingTextSizeDifference = 5 romMappingTextMargin = 10 romMappingTitleTextFont = Bebas Neue romMappingTitleTextOptions = cFFFFFFFF r4 s60 Bold romMappingTitle2TextFont = Bebas Neue romMappingTitle2TextOptions = cFFFFFFFF r4 s15 Bold romMappingGameInfoTextFont = Bebas Neue romMappingGameInfoTextOptions = cFFFFFFFF r4 s15 Regular romMappingBackgroundBrush = aa000000 romMappingColumnBrush = 33000000 romMappingButtonBrush1 = 6f000000 romMappingButtonBrush2 = 33000000 romMappingBackgroundAlign = Stretch and Lose Aspect romMappingMenuFlagWidth = 40 romMappingMenuFlagSeparation = 5 romMappingDefaultMenuList = FullList romMappingSingleFilteredRomAutomaticLaunch = false skipchecks = false romMatchExt = true logFile = X:\Hyperspin\HyperLaunch\HyperLaunch.log logLabel := [" INFO"," WARNING"," ERROR"," DEBUG1"," DEBUG2"] logLevel = 10 logIncludeModule = true logIncludeFileProperties = true logShowCommandWindow = false logCommandWindow = false navUpKey = Up navDownKey = Down navLeftKey = Left navRightKey = Right navSelectKey = Enter navP2UpKey = Numpad8 navP2DownKey = Numpad2 navP2LeftKey = Numpad4 navP2RightKey = Numpad6 navP2SelectKey = NumpadEnter originalWidth = 1600 originalHeight = 900 dtEnabled = true dtPath = X:\Hyperspin\Programs\DTLite\DAEMON Tools Lite\DTLite.exe dtUseSCSI = true dtAddDrive = true emuIdleShutdown = 0 hideEmu = false hideFE = false fadeIn = false fadeInDuration = 500 fadeInTransitionAnimation = DefaultAnimateFadeIn fadeInDelay = 0 fadeInExitDelay = 0 fadeOutExitDelay = 0 fadeOut = false fadeOutDuration = 500 fadeOutTransitionAnimation = DefaultAnimateFadeOut fadeOutDelay = 0 fadeLyrInterpolation = 7 fadeLyr1Color = FF000000 fadeLyr1AlignImage = Align to Top Left fadeLyr2Pos = Bottom Right Corner fadeLyr2X = 300 fadeLyr2Y = 300 fadeLyr2Adjust = 1 fadeLyr2PicPad = 0 fadeLyr3Pos = Center fadeLyr3X = 300 fadeLyr3Y = 300 fadeLyr3Adjust = 0.75 fadeLyr3Speed = 750 fadeLyr3Animation = DefaultFadeAnimation fadeLyr37zAnimation = DefaultFadeAnimation fadeLyr3Type = imageandbar fadeLyr3ImgFollow7zProgress = true fadeLyr3Repeat = 1 fadeLyr3PicPad = 0 fadeLyr4Adjust = 0.75 fadeLyr4X = 100 fadeLyr4Y = 100 fadeLyr4Pos = Above Layer 3 - Left fadeLyr4FPS = 10 fadeLyr4PicPad = 0 fadeTranspGifColor = FFFFFF fadeBarWindow = false fadeBarWindowX = fadeBarWindowY = fadeBarWindowW = 600 fadeBarWindowH = 120 fadeBarWindowR = 20 fadeBarWindowM = 20 fadeBarWindowHatchStyle = 8 fadeBarBack = true fadeBarBackColor = FF555555 fadeBarH = 20 fadeBarR = 5 fadeBarColor = DD00BFFF fadeBarHatchStyle = 3 fadeBarPercentageText = true fadeBarInfoText = true fadeBarXOffset = 0 fadeBarYOffset = 100 fadeRomInfoDescription = text fadeRomInfoSystemName = text fadeRomInfoYear = text fadeRomInfoManufacturer = text fadeRomInfoGenre = text fadeRomInfoRating = text fadeRomInfoOrder = Description|SystemName|Year|Manufacturer|Genre|Rating fadeRomInfoTextPlacement = topRight fadeRomInfoTextMargin = 5 fadeRomInfoText1Options = cFF555555 r4 s20 Bold fadeRomInfoText2Options = cFF555555 r4 s20 Bold fadeRomInfoText3Options = cFF555555 r4 s20 Bold fadeRomInfoText4Options = cFF555555 r4 s20 Bold fadeRomInfoText5Options = cFF555555 r4 s20 Bold fadeRomInfoText6Options = cFF555555 r4 s20 Bold fadeStats_Number_of_Times_Played = text with label fadeStats_Last_Time_Played = text with label fadeStats_Average_Time_Played = text with label fadeStats_Total_Time_Played = text with label fadeStats_System_Total_Played_Time = text with label fadeStats_Total_Global_Played_Time = text with label fadeStatsInfoOrder = Number_of_Times_Played|Last_Time_Played|Average_Time_Played|Total_Time_Played|System_Total_Played_Time|Total_Global_Played_Time fadeStatsInfoTextPlacement = topLeft fadeStatsInfoTextMargin = 5 fadeStatsInfoText1Options = cFF555555 r4 s20 Bold fadeStatsInfoText2Options = cFF555555 r4 s20 Bold fadeStatsInfoText3Options = cFF555555 r4 s20 Bold fadeStatsInfoText4Options = cFF555555 r4 s20 Bold fadeStatsInfoText5Options = cFF555555 r4 s20 Bold fadeStatsInfoText6Options = cFF555555 r4 s20 Bold fadeText1X = 0 fadeText1Y = 0 fadeText1Options = cFFFFFFFF r4 s20 Right Bold fadeText1 = Loading Game fadeText2X = 0 fadeText2Y = 0 fadeText2Options = cFFFFFFFF r4 s20 Right Bold fadeText2 = Extraction Complete fadeFont = Arial fadeSystemAndRomLayersOnly = false fadeInterruptKey = detectFadeErrorEnabled = true fadeImgPath = X:\Hyperspin\HyperLaunch\Media\Fade HLDataPath = X:\Hyperspin\HyperLaunch\Data HLMediaPath = X:\Hyperspin\HyperLaunch\Media HLErrSoundPath = X:\Hyperspin\HyperLaunch\Media\Sounds\Error modulesPath = X:\Hyperspin\HyperLaunch\Modules moduleFullName = X:\Hyperspin\HyperLaunch\Modules\BlueMSX\BlueMSX.ahk moduleName = BlueMSX modulePath = X:\Hyperspin\HyperLaunch\Modules\BlueMSX moduleExtension = ahk moduleExtensionsPath = X:\Hyperspin\HyperLaunch\Module Extensions libPath = X:\Hyperspin\HyperLaunch\Lib 7zEnabled = false 7zPath = X:\Hyperspin\HyperLaunch\Module Extensions\7z.exe 7zDllPath = X:\Hyperspin\HyperLaunch\Module Extensions\7z.dll 7zExtractPath = C:\Users\shaun\AppData\Local\Temp\HS 7zExtractPathOrig = 7zAttachSystemName = false 7zDelTemp = true 7zSounds = true 7zFormats = .zip,.rar,.7z,.lzh,.gzip,.tar 7zFormatsNoP = zip,rar,7z,lzh,gzip,tar mgEnabled = false mgKey = ~NumpadSub mgBackgroundColor = FF000000 mgSidePadding = 0.2 mgYOffset = 500 mgImageAdjust = 0 mgFont = Arial mgText1Options = x10p y30p w80p Center cBBFFFFFF r4 s100 BoldItalic mgText1Text = Please select a game mgText2Options = w96p cFFFFFFFF r4 s50 Center BoldItalic mgText2Offset = 70 mgUseSound = true mgSoundfreq = 300 mgExitEffect = none mgSelectedEffect = rotate mgUseGameArt = false mgArtworkDir = Artwork1 hpEnabled = false hpKey = ~NumpadAdd hpBackToMenuBarKey = X hpZoomInKey = C hpZoomOutKey = V hpScreenshotKey = ~PrintScreen hpHiToTextPath = X:\Hyperspin\HyperLaunch\Module Extensions\HiToText.exe hpSaveStateKeyCodes = {F8 down}{F8 up} hpLoadStateKeyCodes = {F7 down}{F7 up} keymapperEnabled = false keymapper = xpadderFullPath = X:\Hyperspin\Programs\Xpadder_v5.6\Xpadder.exe joyToKeyFullPath = X:\Hyperspin\Programs\JoyToKey_en\JoyToKey.exe keymapperProfilePath = X:\Hyperspin\HyperLaunch\Profiles\ keymapperFrontEndProfileName = HyperSpin keymapperHyperLaunchProfileEnabled = false JoyIDsEnabled = false JoyIDsPreferredControllersSystem = use_global JoyIDsPreferredControllersGlobal = use_global CustomJoyNamesEnabled = false CustomJoyNames = FEProfile = X:\Hyperspin\HyperLaunch\Profiles\\HyperSpin defaultProfile = X:\Hyperspin\HyperLaunch\Profiles\\_Default systemProfile = X:\Hyperspin\HyperLaunch\Profiles\\Microsoft MSX xPadderSystemProfile = X:\Hyperspin\HyperLaunch\Profiles\\Microsoft MSX\_Default emuProfile = X:\Hyperspin\HyperLaunch\Profiles\\Microsoft MSX\BlueMSX romProfile = X:\Hyperspin\HyperLaunch\Profiles\\Microsoft MSX\10 Yard Fight (1986) (Irem) blankProfile = X:\Hyperspin\HyperLaunch\Profiles\\blank HyperLaunchProfile = X:\Hyperspin\HyperLaunch\Profiles\\HyperLaunch bezelEnabled = true statisticsEnabled = true 13:54:15:260 | HL | INFO | +0 | BuildScript - Loaded XHotkey Init.ahk scripts 13:54:15:260 | HL | INFO | +0 | BuildScript - Loaded Statistics Init.ahk scripts 13:54:15:270 | HL | INFO | +0 | BuildScript - Loaded User Functions Init.ahk script 13:54:15:270 | HL | DEBUG1 | +0 | BuildScript - Module starts on line: 285 13:54:15:270 | HL | INFO | +0 | BuildScript - Module: MEmu = BlueMSX MEmuV = v2.8.2 MURL = http://www.bluemsx.com/ MAuthor = djvj MVersion = 2.0.1 MCRC = BAB8048F iCRC = 6DC9C5DF MID = 635038268875990669 MSystem = "ColecoVision","Microsoft MSX","Microsoft MSX2" ;---------------------------------------------------------------------------- ; Notes: ; Set your fullscreen res manually in the emu by clicking Options->Performance->Fullscreen Resolution ;---------------------------------------------------------------------------- StartModule() FadeInStart() settingsFile := modulePath . "\" . moduleName . ".ini" Fullscreen := IniReadCheck(settingsFile, "settings", "Fullscreen","true",,1) Stretch := IniReadCheck(settingsFile, "settings", "Stretch","false",,1) bluemsxINI := CheckFile(emuPath . "\bluemsx.ini") IniRead, currentFullscreen, %bluemsxINI%, config, video.windowSize IniRead, currentStretch, %bluemsxINI%, config, video.horizontalStretch ; Setting Fullscreen setting in ini if it doesn't match what user wants above If ( Fullscreen != "true" And currentFullScreen = "fullscreen" ) IniWrite, normal, %bluemsxINI%, config, video.windowSize Else If ( Fullscreen = "true" And currentFullScreen = "normal" ) IniWrite, fullscreen, %bluemsxINI%, config, video.windowSize ; Setting Stretch setting in ini if it doesn't match what user wants above If ( Stretch != "true" And currentStretch = "yes" ) IniWrite, no, %bluemsxINI%, config, video.horizontalStretch Else If ( Stretch = "true" And currentStretch = "no" ) IniWrite, yes, %bluemsxINI%, config, video.horizontalStretch 7z(romPath, romName, romExtension, 7zExtractPath) Run(executable . " """ . romPath . "\" . romName . romExtension . """", emuPath) WinWait("blueMSX ahk_class blueMSX") WinWaitActive("blueMSX ahk_class blueMSX") Sleep, 2000 ; need this otherwise Hyperspin flashes back in during fade FadeInExit() Process("WaitClose", executable) 7zCleanUp() FadeOutExit() ExitModule() HaltEmu: disableSuspendEmu := true PostMessage, 0x111, 40025,,,blueMSX ahk_class blueMSX ; Pause Return RestoreEmu: PostMessage, 0x111, 40025,,,blueMSX ahk_class blueMSX ; Pause Return CloseProcess: FadeOutStart() WinClose("blueMSX ahk_class blueMSX") Return 13:54:15:270 | HL | INFO | +0 | BuildScript - Loaded Statistics.ahk script 13:54:15:280 | HL | INFO | +16 | BuildScript - Loaded User Functions.ahk script 13:54:15:280 | HL | INFO | +0 | BuildScript - Finished injecting functions into module 13:54:15:280 | HL | INFO | +0 | Main - Module is built 13:54:15:280 | HL | INFO | +0 | CheckFile - Checking if X:\Hyperspin\HyperLaunch\AutoHotkey.dll exists 13:54:15:280 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription AutoHotkey_H ANSI 32-bit FileVersion 1.1.09.04 InternalName AutoHotkey_H LegalCopyright Copyright (C) 2012 OriginalFilename AutoHotkey.exe ProductName AutoHotkey_H ProductVersion 1.1.09.04 File Size: 785408 bytes Created: 9/1/2014 - 4:51:55 PM Modified: 8/28/2014 - 8:18:26 AM 13:54:15:290 | HL | INFO | +15 | Main - Running module 13:54:15:290 | HL | INFO | +0 | Main - Starting timer to watch if Front End gets displaced and restore it if it does. 13:54:15:390 | MD | INFO | +N/A | Module initialized 13:54:15:390 | MD | INFO | +0 | StartModule - Started 13:54:15:390 | MD | INFO | +0 | StartModule - MEmu: BlueMSX MEmuV: v2.8.2 MURL: http://www.bluemsx.com/ MAuthor: djvj MVersion: 2.0.1 MCRC: BAB8048F iCRC: 6DC9C5DF MID: MSystem: "ColecoVision","Microsoft MSX","Microsoft MSX2" 13:54:15:410 | MD | INFO | +15 | StartModule - You have a supported System Name for this module: "Microsoft MSX" 13:54:15:410 | MD | DEBUG1 | +0 | StartModule - Setting romName to the dbName sent to HyperLaunch: 13:54:15:410 | MD | INFO | +0 | StartModule - Ended 13:54:15:410 | MD | INFO | +0 | StartGlobalUserFeatures - Starting 13:54:15:410 | MD | INFO | +0 | StartGlobalUserFeatures - Ending 13:54:15:410 | MD | INFO | +0 | Module Setting - Fullscreen: true 13:54:15:420 | MD | INFO | +16 | Module Setting - Stretch: false 13:54:15:420 | MD | INFO | +0 | CheckFile - Checking if X:\Hyperspin\Emulators\Microsoft MSX 1 & 2\BlueMSX\bluemsx.ini exists 13:54:15:420 | MD | DEBUG1 | +0 | CheckFile - Attributes: File Size: 3973 bytes Created: 9/2/2014 - 2:23:07 PM Modified: 9/2/2014 - 2:57:32 PM 13:54:15:420 | MD | INFO | +0 | Module Run - Running: X:\Hyperspin\Emulators\Microsoft MSX 1 & 2\BlueMSX\blueMSX.exe "X:\Hyperspin\Emulators\Microsoft MSX 1 & 2\MSX1 Romset\10 Yard Fight (1986) (Irem).7z" 13:54:15:470 | MD | DEBUG1 | +47 | Module Run - "blueMSX.exe "X:\Hyperspin\Emulators\Microsoft MSX 1 & 2\MSX1 Romset\10 Yard Fight (1986) (Irem).7z"" Process ID: 1600 13:54:15:470 | MD | DEBUG1 | +0 | GetActiveWindowStatus - Title: HyperLaunch HQ v1.0.13.0 | Class: HwndWrapper[HyperLaunchHQ.exe;;dba8d510-ead5-461f-a2ae-357d416aa2f0] | State: 0 | X: 1 | Y: 1 | Width: 1598 | Height: 858 | Window HWND: 0x7903d6 | Process ID: 7276 | Process Path: X:\Hyperspin\HyperLaunch\HyperLaunchHQ\HyperLaunchHQ.exe 13:54:15:480 | MD | INFO | +15 | Module WinWait - Waiting for blueMSX ahk_class blueMSX 13:54:16:082 | MD | DEBUG1 | +609 | GetActiveWindowStatus - Title: | Class: #32770 | State: 0 | X: 363 | Y: 164 | Width: 274 | Height: 71 | Window HWND: 0x310018 | Process ID: 1600 | Process Path: X:\Hyperspin\Emulators\Microsoft MSX 1 & 2\BlueMSX\blueMSX.exe 13:54:16:094 | MD | DEBUG1 | +0 | GetActiveWindowStatus - Title: blueMSX | Class: blueMSX | State: 0 | X: 100 | Y: 100 | Width: 132 | Height: 38 | Window HWND: 0x6f03b8 | Process ID: 1600 | Process Path: X:\Hyperspin\Emulators\Microsoft MSX 1 & 2\BlueMSX\blueMSX.exe 13:54:16:102 | MD | INFO | +15 | Module WinWaitActive - Waiting for "blueMSX ahk_class blueMSX" 13:54:16:208 | MD | DEBUG1 | +110 | GetActiveWindowStatus - Title: HyperLaunch HQ v1.0.13.0 | Class: HwndWrapper[HyperLaunchHQ.exe;;dba8d510-ead5-461f-a2ae-357d416aa2f0] | State: 0 | X: 1 | Y: 1 | Width: 1598 | Height: 858 | Window HWND: 0x7903d6 | Process ID: 7276 | Process Path: X:\Hyperspin\HyperLaunch\HyperLaunchHQ\HyperLaunchHQ.exe 13:54:18:206 | MD | INFO | +1996 | Module Process - WaitClose blueMSX.exe 13:54:18:206 | MD | INFO | +0 | StopGlobalUserFeatures - Starting 13:54:18:206 | MD | INFO | +0 | StopGlobalUserFeatures - Ending 13:54:18:206 | MD | INFO | +0 | ExitModule - Started 13:54:18:206 | MD | INFO | +0 | Starting Updating Statistics: 13:54:18:216 | MD | DEBUG2 | +0 | Total Elapsed Time in Pause in seconds: 0 13:54:18:216 | MD | DEBUG2 | +0 | gameSectionStartTime:37901924 13:54:18:216 | MD | DEBUG2 | +0 | ElapsedTime:2 13:54:18:216 | MD | INFO | +0 | CreateRomTable - Started 13:54:18:226 | MD | DEBUG1 | +16 | CreateRomTable - Checking for match: "10 Yard Fight (1986) (Irem)" and "(Disc" 13:54:18:226 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "10 Yard Fight (1986) (Irem)" and "(Disk" 13:54:18:226 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "10 Yard Fight (1986) (Irem)" and "(Cart" 13:54:18:226 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "10 Yard Fight (1986) (Irem)" and "(Tape" 13:54:18:236 | MD | DEBUG1 | +16 | CreateRomTable - Checking for match: "10 Yard Fight (1986) (Irem)" and "(Cassette" 13:54:18:236 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "10 Yard Fight (1986) (Irem)" and "(Part" 13:54:18:236 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "10 Yard Fight (1986) (Irem)" and "(Side" 13:54:18:236 | MD | INFO | +0 | CreateRomTable - Ended, 7 Loops to create table. 13:54:18:246 | MD | DEBUG2 | +0 | Statistics cleared game name: 10 Yard Fight 13:54:18:306 | MD | DEBUG2 | +62 | Loaded game statistics from ini files: Number_of_Times_Played: 7 Last_Time_Played: Tuesday September 2, 2014 02:37:58 PM Average_Time_Played: 2 Total_Time_Played: 14 System_Total_Played_Time: 21 Total_Global_Played_Time: 3381 13:54:18:316 | MD | DEBUG2 | +16 | Updated Statistics: Number_of_Times_Played: 8 Last_Time_Played: Wednesday September 3, 2014 01:54:18 PM Average_Time_Played: 2 Total_Time_Played: 16 System_Total_Played_Time: 23 Total_Global_Played_Time: 3383 13:54:18:356 | MD | INFO | +31 | Game section statistics updated. 13:54:18:356 | MD | INFO | +0 | ExitModule - Ended 13:54:18:356 | MD | INFO | +0 | End of Module Logs 13:54:18:446 | HL | INFO | +3151 | Main - Module ended, exiting HyperLaunch normally 13:54:18:446 | HL | INFO | +0 | ExitScript - Started 13:54:18:466 | HL | DEBUG1 | +16 | ExitScript - Putting HyperSpin.exe back in focus 13:54:18:506 | HL | INFO | +47 | SystemCursor - Restoring mouse cursor 13:54:18:526 | HL | INFO | +15 | ExitScript - Ended Very cool, thank you. I see two things that jump right out. The first is the first line of the log. You are running an older version of HyperLaunch. I would recommend you update your setup. Please see this post: http://www.hyperspin-fe.com/forum/showthread.php?31472-Complete-Guide-for-Commodore-Amiga-in-HS-and-RL-Using-WinUAE-Only&p=304130&viewfull=1#post304130 Second, enable 7z support in HyperLaunchHQ and try again. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
aloner187 Posted September 3, 2014 Author Posted September 3, 2014 your the man ron, the 7z fixed it, now its working great thanks...i thought i had updated my hyperlaunch already, but then i checked again and your right, older version... so ron i have this other issue with mess here is the post http://www.hyperspin-fe.com/forum/showthread.php?36582-newest-mess-module-acting-strange My Cab Project http://www.hyperspin-fe.com/forum/showthread.php?t=7541
rfancella Posted September 3, 2014 Posted September 3, 2014 your the man ron, the 7z fixed it, now its working great thanks...i thought i had updated my hyperlaunch already, but then i checked again and your right, older version... so ron i have this other issue with mess here is the posthttp://www.hyperspin-fe.com/forum/showthread.php?36582-newest-mess-module-acting-strange Very cool!!! Congrats! I don't use MESS when there is another emu available, so I try to avoid it when I can. But I'll take a peek at that thread. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
aloner187 Posted September 3, 2014 Author Posted September 3, 2014 thanks again man My Cab Project http://www.hyperspin-fe.com/forum/showthread.php?t=7541
