SpoilerDwarf Posted 17 hours ago Posted 17 hours ago Hi, After opening HyperHQ today, it installed/updated something called HyperSpin Core Essentials. Since then, I can launch HyperSpin from HyperHQ and the main system wheel appears normally. However, when I select a system, HyperSpin does not enter that system’s game wheel. It briefly acts like it is going to open the selected system, but then immediately returns me back to the main system wheel. At first I noticed this with Xbox 360, but the issue is not limited to Xbox 360. Most of my systems are affected. Important details: - HyperHQ version: 2.0.302 - HyperHQ path: H:\HS\HyperHQ\HyperHQ.exe - HyperSpin is launched from inside HyperHQ - Games are visible correctly inside HyperHQ - The issue happens even when using only the keyboard, so it does not appear to be a controller/input mapping problem - I tried clearing cache from HyperHQ - I also tried renaming/restoring cache.hsdata.bak, but the problem still continues Expected behavior: When selecting a system from the main wheel, HyperSpin should enter that system and show the games wheel. Actual behavior: Selecting most systems sends me back to the main system wheel instead of opening the games wheel. This started after the HyperSpin Core Essentials update.
SpoilerDwarf Posted 3 hours ago Author Posted 3 hours ago I found the cause of the issue. In the menu section inside HyperSpin, under the wheel settings, I had turned the “Hide” options ON. It turns out that this was the reason for the problem. I honestly did not expect those settings to have such a significant effect. Thank you for your help. Best regards.
