record mame inp when launched through Hyperspin
ideacipher
I pretty much want to add -rec rec.inp to the command line that Hyperspin uses to launch mame when I select a rom. This may be very easy to do and I'm just missing something. The mame config file has the inp path set and works by manually launching.
Also another quick question is there an easy way to execute a bat file on mame exit (esc) while using Hyperspin? If I can get the -rec to work I'm interested in archiving mame sessions for highscores without having to bring out the wireless keyboard and stop play every time a file needs to be saved.
Thanks
In HyperLaunchHQ: Select MAME on left, modules tab, mame.ahk, edit global module settings button. Select MAME tab, and in parameters type: -record rec.inp
Not sure on 2nd thing, but if you find a way please share it as I'd like to know about that as well. Right now when I get a good score I have to grab the keyboard and exit out of HS, then move the inp file for safe keeping before I run another game or I lose it. Perhaps there's a way to name the inp file with a date/time stamp or something in the filename?
That worked perfectly! Thanks
Managing on rom exit is another story. I'll let you know if I hear or find anything on the moving/renaming inp files on rom change/mame exit.
boohiss I created a fairly good solution tonight for moving and renaming the inp files on rom switch and exit while using Hyperspin.
First I had to brush up on my AHK skills for just a bit and made the following change to \HyperSpin Install v1.3.2.0\Modules\MAME\MAME (MAME .148 djvj 2.0).ahk
CloseProcess:
FadeOutStart()
WinClose("MAME ahk_class MAME")
Run, C:\Users\ideacipher\Downloads\mame64\inp\move.bat %romName%
Return
I started by running all the commands in line in the module ahk file but I would rather just run the batch file and pass the romname as a variable
My move.bat file looks like this:
move C:\Users\ideacipher\Downloads\mame64\inp\rec.inp C:\Users\ideacipher\Downloads\mame64\inp\holding
set filename=%date:~-10,2%-%date:~-7,2%-%date:~-4,4%_%time:~-11,2%%time:~-8,2%%time:~-5,2%
set filename=%filename: =%
rename C:\Users\ideacipher\Downloads\mame64\inp\holding\rec.inp %1-%filename%.inp
So once the module is closing it will move your inp file to a location of your choice and then rename with 'romname'-month-day-year_HourMinuteSecond.inp . I just tried it out with Donkey Kong and the file was moved and renamed to dkong-10-23-2014_05255.inp it was 12:52am
There are many ways this could have been done but this way works and made the most since to me while I was working on it. Now I'll be able to archive every game. I know I'll need to add a clean up job down the road but that should be easy and pretty much the same principle.
Thanks again for helping with that first step I was stumped.
I found an issue on playback and will look into it further in the next couple days. until then I would not use this solution on your inp files.
This will help a ton. I need to figure out how to fire the batch file prior to recording. After is easy we can just call that before the move line or even in the same batch file. About 95% there it seems.
I did some further testing today even without moving the nvram, hi, and cfg files and most recordings played back fine (not sure what was going on last night but it was late probably a ID10t error). I remember hearing stuff especially about hi causing some crazy stuff to happen because of the random numbers a while back but couldn't remember if it screwed up the highscore tracking or the recording itself.
If you find a way to run the batch file prior to recording we should be all set. I'll look into it as well and keep everyone posted if I find anything.
Many games will work fine without moving anything, but I know Tapper is one such game that won't play back correctly. Since it didn't work, I did an avi MAME record to save my gameplay when I played it for a competition here. It takes up a ton of space for just 10 minutes of play time though rather than a small inp file.
I really like keeping my configs and love the highscore support so I needed to find a way to auto record while supporting playback while keeping the other settings and files intact.
I've added a backup of the current cfg, hi and nvram contents on launch. This was done by adding the following two lines to the MAME
module MAME (MAME .148 djvj 2.0).ahk:
; Added to backup current cfg, hi and nvram files for the present rom
Run, C:\Users\softice10001\Downloads\mame64\inp\backup.bat %romName%
Run(executable . A_Space . romName . A_Space . fullscreen . A_Space . cheatEnabled . A_Space . videomode . A_Space . useBezels . A_Space . useOverlays . A_Space . useBackdrops . A_Space . mameRomPaths . A_Space . sysParams . A_Space . romParams, emuPath, winstate)
The new backup.bat file looks like this (non standard install but a quick adjustment in paths will make it work):
mkdir C:\Users\ideacipher\Downloads\mame64\inp\holding\%1
copy C:\Users\ideacipher\Downloads\mame64\cfg\%1.cfg C:\Users\ideacipher\Downloads\mame64\inp\holding\%1
copy C:\Users\ideacipher\Downloads\mame64\hi\%1.hi C:\Users\ideacipher\Downloads\mame64\inp\holding\%1
copy C:\Users\ideacipher\Downloads\mame64\nvram\%1\* C:\Users\ideacipher\Downloads\mame64\inp\holding\%1
I kept the end of MAME (MAME .148 djvj 2.0).ahk pretty much the same just added a comment:
CloseProcess:
FadeOutStart()
; added to archive recorded inp, nvram, cfg and hi files
Run, C:\Users\softice10001\Downloads\mame64\inp\move.bat %romName%
Return
The move file needed to be reworked and I changed the way the renaming and structure was handled a bit:
set dirname=%date:~-10,2%-%date:~-7,2%-%date:~-4,4%_%time:~-11,2%%time:~-8,2%%time:~-5,2%
set dirname=%dirname: =%
mkdir C:\Users\ideacipher\Downloads\mame64\inp\archive\%1
move C:\Users\ideacipher\Downloads\mame64\inp\rec.inp C:\Users\ideacipher\Downloads\mame64\inp\holding\%1
rename C:\Users\ideacipher\Downloads\mame64\inp\holding\%1\rec.inp %1.inp
rename C:\Users\ideacipher\Downloads\mame64\inp\holding\%1 %dirname%
move C:\Users\ideacipher\Downloads\mame64\inp\holding\%dirname% C:\Users\ideacipher\Downloads\mame64\inp\archive\%1\%dirname%
So what you end up with is an archived recording automated using Hyperspin that will playback properly if the backed up files are put back into place (cfg, nvram and hi). Always backup the current files prior to doing this until an automated process is in place. I'm probably going to work on a playback.bat that will do something similar to what is being done here http://replay.marpirc.net/playback.htm only instead of running with no files at all I'll use the ones backed up before the recording was created and revert back to current after playback. This is a good enough for me I think to put this one on the back burner for a while.
Let me know what you all think and if any issues are found
Thanks
Don't edit the modules, the User Functions.ahk lib is where you should be adding any custom code.
In this case inside the StopGlobalUserFeatures function.
  • 10 months later...
Wow Brolly very polite there bud. Don't get pissed I moved the code to user space if you read I was starting to figure this stuff out. Ends up very simple and I have made some other changes that were not offered as well. Let me guess the option will be put in production when MAME grows flippers and has a steal ball as the main character LOL
Almost a year later and it's running like a top - one of the best extra features of hyperspin for me compared to other front ends.
