Q button not working (player 2 button 3)
nolancraw
Thx again i got it working...FINALLY!
I didn't know there was another version of hyperspin. When you go to the download section the only version mentioned is 1.0. Must have missed that...
Will updating affect my games/art/movies as they excist now?
Glad you got it working. No new Hyperspin... yet. Only Hyperlaunch 2 at the moment. HL is what launches your games, it's separate from HS, but they work together. Your artwork and vids will be unaffected. But now you will need to download new modules for each system you add to your wheel. It's all explained in that link, but let us know if you run into any issues or just post in that thread. Good luck!
  • 1 year later...
Are you sure you aren't using Hyperlaunch? Try going to Settings.ini and change:
exit_script_key=q & s
to:
exit_script_key=~q & ~s
By default you can't use q because the exit script key is q&s so making this change fixes it.
i have suddenly run into this issue, worked fine then all of asudden had this bug... i tried the above, but was already set as exit_script_key=~q & ~s
so dont know what to do.... people say they have fixed there problem but dont detail what they actually did... someone please help :( only affects MAME emulator when run in hyperspin, every other game and emulator works
