Hyperpause delays
dsnyd22
I Recently Added Some Game Guides and Maps to Hyperpause. Since this I have noticed long delays when going into Hyperpause and sometimes it even freezes. Has anyone had issues with this. Is it best to remove all large pdfs so it doesnt attempt to load the images. Sorry for new thread but curious if anyone has had same issues?
HyperPause has two ways of handling the pdf files.
The first one is to load them at startup and the second one is to load each page when you select to see the guide.
If you don't like the starting wait, just change the HyperLaunchHQ option to do not load pdf files at startup.
Next HL version will have some improvements also on the pdf handling, so if the problem persists, just wait a little bit to test with the next version.
By the way, please provide a hyperlaunch log when asking for help on these kind of things. Also, try to take a look at the log time stamps, and see where the HyperPause load is getting stuck. That helps a lot on fixing any possible issue that could happen.
When asking for help for RocketLauncher, POST ON THE RLAUNCHER.NET FORUMS!
Also, please post your RocketLauncher.log with logging level set to troubleshooting in pastebin (set the log level in RocketLauncherUI, global system > General Settings -> RocketLauncher).
Ass. Bleasby - RocketLauncher Development Team.
Thanks Bleasby. Fixed my problem for the most part. Now is just need to figure out how to hide the mouse cursor when going into hyperpause.......
