Atari St and Steem tos files memory test
spudgunjake
I have everything setup with Hyerpsin and Steem, works a treat, but When I run Steem it want to do a memory test, which takes ages I have tos206uk.img and tos206US.img.
From reading on some forums I need to patch the .img files, to get past the memory test, Is this true and if so, can any one help.
Best regards John.
I was/am having problems with the ST too. It was doing my head in so much that I took it out of the database. I did however get it running well in the RA version of ST. I also found that although it seemed to have problems with the TOS. It was in fact the rom format which was the problem
when you say its the rom format are you talking about the game or the tos, if its the game what should it be all my roms are .st I do have stx version as well as some HD Version spare.
thanks John
Your right get 1943 to work and some other just display E.g Disk A and you have to click on the game to run.
So its a case of hit and miss which game work with out doing anything. Lets hope theres a way around this,
Any way thanks for the heads up on this.
Best regards John.
