NES - Nestopia error opening rom? Anyone know why?
barakawins
Recently made an XML file which for seems to work well. Issue I'm having is that upon opening some of the roms I get an error once the video is starting to open up.
any way to correct this issue? See below log. It seems to not want to open but real errors
Nestopia log file version 1.40
Language: loaded "english.nlg" version 1.40.0.01
Direct3D: initializing..
Direct3D: enumerating device - name: Intel® HD Graphics, GUID: D7B78E66-4306-11CF-247E-5001A2C2C535
Direct3D: dynamic textures: supported
Direct3D: texture bilinear filtering: supported
Direct3D: max texture dimensions: 8192x8192
Direct3D: scanline effect: supported
Direct3D: vsync on every second refresh: supported
Direct3D: vsync on every third refresh: supported
Direct3D: found 30 display modes
Direct3D: supported monitor frequencies: 50hz, 60hz
Direct3D: creating HAL device #0
Direct3D: entering 1440x900x32 50hz window mode
DirectSound: initializing..
DirectSound: enumerating device - name: Primary Sound Driver, GUID: unspecified
DirectSound: enumerating device - name: Speakers (Conexant 20585 SmartAudio HD), GUID: 224EE72C-0180-4CE7-8345-76BDFC878988
DirectSound: creating device #0
DirectInput: initializing..
DirectInput: found 0 attached joystick(s)
Timer: performance counter present (2337998 hz)
Kaillera: found "kailleraclient.dll" version 0.9
Launcher: database file "launcher.xml" not present
Database: 2894 items imported from internal DB
Emulator: loading "C:\HyperSpin\Roms\Nintendo Entertainment System\Elevator Action (USA).zip <Rad Racer (USA).nes>"
Ines: 128k PRG-ROM set
Ines: horizontal mirroring set
Ines: NTSC set
Ines: mapper 1 set
Direct3D: entering 640x480x16 60hz full-screen mode
Wait... it tried to load elevator action which has a different game inside of it?
Line:
Hope your entire rom set isn't like that. You might be best off grabbing a new set instead of fixing the entire thing.
