boomerps2 Posted December 28, 2014 Posted December 28, 2014 Installed RocketLauncher.1.0.0 Hyperspin boots up fine, games run perfect. Just can't open the Hyperlaunch.exe in the HyperLaunch folder without getting the error: Cannot find C:\Users\Arcade\Desktop\Hyerspin\HyperLaunch\HyperLaunchHQ\Databases\Systems.xml There is not database folder in my HyperLaunchHQ folder. Hyperlaunch.exe opens fine in my previous Hyperlaunch build. Just having issues with the BETA. BTW...I've already added Hyperspin as my Default and Active frontend in HyperLaunchHQ under the HyperLaunchHQ tab. Thanks in advance
klizine Posted December 28, 2014 Posted December 28, 2014 I had to manually make the folder, then just used my main menu.xml renamed.
boomerps2 Posted December 28, 2014 Author Posted December 28, 2014 klizine said: I had to manually make the folder, then just used my main menu.xml renamed. That did it. I thought I screwed something up. Thank you for the fast reply.
dmxwyrw Posted December 28, 2014 Posted December 28, 2014 Just incase you didn't see... http://www.hyperspin-fe.com/forum/showthread.php?38247-HyperLaunch-v3-1-0-0-Beta
