Capcom setup
shitoken
I would like to setup capcom system how should I go with it? Front main wheel with all CP1,2,3 or with subwheels of capcom1,2,3 inside main wheel?
Can someone point me to guide I tried but not able to find. Thanks
I know that MAME contain all the games of CAPCOM, but I would really want to learn to setup individually which will help me to learn more in setting up in HS as a new user.
Hope some one can point me to right direction Sorry.
Thanks for your reply Jeremy.
I want to setup CP1, CP2 & CP3 in my wheel, I noticed can only add One system name under global setting as Capcom Play System and only have one icon in folder with same name. This small icon will appear next to it under global systems . I have seen on youtube many have cp1,cp2 setup individually, how can I do that and do I need copy paste icon into 3 copies and rename them as cp1,2,3 as I need will this be possible?
Also I have set the path of roms but the default global emu is empty nothing to select?
Go into HLHQ and uncheck the ticked box which says Valid emulator/Modules only. Then go into emulator for the Capcom CPS I,II,III separate systems and point them all to the MAME emulator as the default and the MAME roms folder.
If you have MAME set up in HS already these will all work.
