Wow Action Max
stillcore
I'm running into an issue with trying to run Action Max and hopefully someone can give me some input on what's wrong. I've read Ron's walkthrough, and set it up step-by-step and have it working properly in HyperLaunchHQ, however, when I try running it in Hyperspin it starts to load, goe to a green screen, then jumps back to the wheel. (Probably lasts about 2-3 seconds before jumping back)
I'm not seeing any errors in the log which would result in it resetting.... it's almost like Hyperspin isn't giving it enough time to fully boot before it resets.
Here's the last log:
04:56:21 PM |  HyperSpin Started
04:56:21 PM |  Going windowed mode
04:56:21 PM |  Checking for updates
04:56:21 PM |  Update Check Complete
04:56:21 PM |  Startup program unavailable
04:56:21 PM |  Playing intro video
04:56:23 PM |  Error intializing joysticks
04:56:23 PM |  Menu Mode is multi
04:56:23 PM |  Loading Main Menu.xml
04:56:23 PM |  Main Menu.xml successfully loaded
04:56:23 PM |  Main Menu wheel loaded successfully
04:56:34 PM |  Loading WoW Action Max.xml
04:56:35 PM |  Main Menu.xml successfully loaded
04:56:35 PM |  WoW Action Max wheel loaded successfully
04:56:40 PM |  Launching Game
04:56:40 PM |  Using HyperLaunch
04:56:40 PM |  Getting HyperLaunch path
04:56:40 PM |  HyperLaunch located at C:\HyperLaunch\HyperLaunch.exe
04:56:40 PM |  Running HyperLaunch.exe
04:56:40 PM |  HyperLaunch Command Line is: C:\HyperLaunch\HyperLaunch.exe "WoW Action Max" "PopsGhostly"
04:56:59 PM |  Loading Main Menu.xml
04:56:59 PM |  Main Menu.xml successfully loaded
04:56:59 PM |  Main Menu wheel loaded successfully
04:57:00 PM |  Exit program unavailable
04:57:00 PM |  Quiting Hyperspin
04:57:00 PM |  Bye!
Can someone help me with this? Thanks!!
I'm not actually using bat files. I renamed the txt files to correspond with the singe files. Weird how they run perfectly through HyperLaunchHQ...
So I still haven't resolved this issue. It seems like Hyperlaunch isn't giving Daphne enough time to load before quitting back (like it thinks the program isn't responding)? Is there a way to extend the load time so I can test this theory?
Or does this sound absolutely ridiculous?
