D-Fend Launch Issues
Tron0091
Hi all,
I have successfully got D-Fend smoothly running DosBox and all the games. I am now attempting to run through Hyperspin. I have tried to follow some of the similar related posts with no luck.:banghead:
Here is my .ini file and my ahk file which I have adopted from previous posts:
I have tried a few alternatives all with no luck:
- placing a blank text file in the rompath with the subfolder game name
- changing extension from lnk to zip and ziping the subfolder games
- hyperlaunch to false
I am sure there is something simple I am missing.
ini file
[exe info]
path=C:\Program Files (x86)\D-Fend Reloaded\
rompath=C:\Users\michael\D-Fend Reloaded\VirtualHD\
userompath=true
exe=DFend.exe
romextension=lnk
parameters=
searchsubfolders=true
pcgame=true
winstate=normal
hyperlaunch=true
Per_Game_Modules=false
ahk file
; DosBox
; by Neil Kalman
; Based on MAME .143 by BBB & djvj
; Notes:
GUI_ID := FadeInStart()
txtPath := romPath . romName . ".txt" ; get the full path for the .txt file
realPath :=
configPath := 1
FileReadLine, realPath, %txtPath%, 1 ; get the full path of the game executable
FileReadLine, configPath, %txtPath%, 2 ; get the full path of the game dosbox config file if exists
if configPath = 1 ; if there isn't a config file
Run, %executable% %realPath% -exit -noconsole, %emuPath%, Hide UseErrorLevel
else ; if there is :-)
Run, %executable% %realPath% -exit -noconsole -conf %configPath%, %emuPath%, Hide UseErrorLevel
If(ErrorLevel != 0){
If (ErrorLevel = 1){
Error = Failed Validity
}Else If(ErrorLevel = 2){
Error = Missing Files
}Else If(ErrorLevel = 3){
Error = Fatal Error
}Else If(ErrorLevel = 4){
Error = Device Error
}Else If(ErrorLevel = 5){
Error = Game Does Not Exist
}Else If(ErrorLevel = 6){
Error = Invalid Config
}Else If(ErrorLevel = 7 || ErrorLevel = 8 || ErrorLevel = 9){
Error = Identification Error
}Else{
Error = Mame Error
MsgBox Mame Error - %Error%
WinWait, DOSBox
WinWaitActive, DOSBox
GUI_ID2 := FadeInExit()
Process, WaitClose, %executable%
GUI_ID4 := FadeOutExit()
WinActivate, Hyperspin
ExitApp
CloseProcess:
GUI_ID3 := FadeOutStart()
WinClose, DOSBox
Return
I have a Dfend.ahk that was with hyperlaunch. Set up all the stuff in hyperlaunch, saved all the dfend conf and prof files into the Dfend subfolder of Confs, and did the text file and .zip file like you have in my MS-DOS folder within my hyperspin ROMS directory; voila, everything works. Hopefully you just need to use the dfend module/emulator in hyperlaunch?
