Please help me with OpenBor
gamesmame
Please help me with OpenBor...
Hello friends, I 'm in trouble, to run OpenBor someone can help me? where to start? hyperspin downloaded a module in the ...
; OpenBOR
; PCLauncher.exe
; by djvj
; 1.2
and the folder with the game theme etc ... I do not know how to get things in the emulators folder! Thanks!! :congrats:
:tee:
Please read anything djvj has included in the module pertaining to setup.
In your HyperSpin\Games\ folder create an OpenBor folder. ----> HyperSpin\Games\OpenBor\
Inside the OpenBor folder create an empty AutoHotkey Script name it OpenBor.ahk and compile it. ----> HyperSpin\Games\OpenBor\OpenBor.ahk ----> HyperSpin\Games\OpenBor\OpenBor.exe
Each game should have it's own folder inside the OpenBor folder. ----> HyperSpin\Games\OpenBor\GameName\
Inside each folder you need the OpenBor files and dirs. ----> 4 Folders - Logs, Paks, Saves, and ScreenShots -- 4 files -borpak.exe, packer.bat, paxplode.bat, and OpenBOR.exe
The actual game or PAK file should go into the Paks folder. ----> HyperSpin\Games\OpenBor\GameName\Paks\GameName.pak
Inside the OpenBor folder create a blank txt file for each game. ----> HyperSpin\Games\OpenBor\GameName.txt -- If you have all the wheels this can be skipped
Point HyperHQ emulator to the empty compiled OpenBor.exe
Point to the txt files for your roms or to the wheel images (if you have all of them for the games you have) be sure to set your extension accordingly
Edit the settings.ini according to the instructions in the module
Hope this helps at least a little bit
  • 1 year later...
sorry dustind900,
it's a full day i'm trying to set openbor to start in hyperlaunch but i didn't try.
it's too much if i ask you if you could upload into the ftp the structure of your openbor with all files except .pak ?
thank you also if you can't
EDIT1 --> i made everything like you described
this is the structure:
C:\Hyperspin\Emulators\OpenBOR --> here's only the dummy.exe, an ahk empty of 1kb, pointed by hyperhq and hyperlaunch
C:\Hyperspin\Emulators\OpenBOR\A Tale Of Vengeance --> there are the 4 folders and the 4 files, inside paks folders there's the tale of vengeance.pak
everythings looks correct... but hyperlaunch can't find anything... look the image .. damn
no ones could help?
  • 3 months later...
I've tried the same as the poster above, with no luck. But I pointed HyperlaunchHQ to the dummy OpenBor.exe in the OpenBor folder. Are we missing something?
  • 4 months later...
I have a wierd problem with this too, i followed the steps above but HL cannot find any of the games. However if i double up on the folders in my game path, it works....
For example BLAH:\Hyperspin\Emulators\RomFiles\OpenBOR\A Tale of Vengeance\OpenBor.exe does not work
But... BLAH:\Hyperspin\Emulators\RomFiles\OpenBOR\A Tale of Vengeance\Paks\A Tale of Vengeance\OpenBor.exe does
Can anyone explain why this is happening? Id rather not double up if i really dont have to :)
It seems its looking inside the Paks folder for the exe instead of the "GameName" folder, i am using the default module and ini the comes with the latest updated HL.
The instructions above seem to be the way to do it with the old hyperspin. I have tried to get OpenBOR to work within hyperspin following the module instructions exactly without any luck. I have been working on it for hours, I normally try not to ask for help until I have exhausted all options. Does someone have a small mini tutorial on getting OpenBOR to work with Hyperspin newest version? Thanks in advance!
EDIT: Figured it out
How did you get it working? Mine still will not work properly, still having the problem i described above :(
In the OpenBor Games folder you must have:
- One empty txt file for each game with the game name as in the xml
- One subfolder for each game. The name of the dir must be the same as in the xlm and as the above txt
----Inside each game subfolder there must be a "Paks" sub-subfolder where you place the pak file, no matter the name of the pak.
----Inside each game subfolder there must be openbor.exe
Emulator:
As emulator point to one of the openbor.exe, no matter which (you will have as many exe as many game subfolders)
Rom extension:
As roms extension choose txt.
That's all.
  • 1 month later...
i am having a hell of a time trying to figure out how to put a Openbor wheel on my Hyperspin, ive tried everything, could you please help me via PM or something with a step by step or a download or something... the above steps do not work !
  • 5 months later...
  • 1 year later...
