wisker Posted February 23, 2015 Posted February 23, 2015 Im assuming the path has changed, I had a hard drive going bad, copied and transferred to new drive, Hyperspin starts up ok but whenever i choose a game on any system it comes up with a error: CANNOT FIND HYPERLAUNCH EXE I read to change the settings for path location but cant find the Hyperspin settings???
rfancella Posted February 23, 2015 Posted February 23, 2015 Im assuming the path has changed, I had a hard drive going bad, copied and transferred to new drive, Hyperspin starts up ok but whenever i choose a game on any system it comes up with a error: CANNOT FIND HYPERLAUNCH EXE I read to change the settings for path location but cant find the Hyperspin settings??? Hi Wisker, This is a very solvable issue. Means your Hyperlaunch_Path is either wrong or not there. Navigate to ...\HyperSpin\Settings Open up the Settings.ini in there. Either correct or add the following line (in bold below): [Main] Menu_Mode=multi Single_Mode_Name=MAME Enable_Exit_Menu=true Enable_Exit=true Exit_Default=yes Exit_Action=exit Version=1.0.0.0 Last_System=AAE [b]Hyperlaunch_Path=H:\HyperLaunch\[/b] Only use your path to the HyperLaunch folder. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
