daanmuller Posted February 25, 2015 Posted February 25, 2015 Hi, I got Daphne all set-up using the guide. No problems. But when I run Dragon's Lair from Hyperspin or HyperlaunchHQ I have a black screen between a lot of scene changes. When I run Lair from the Daphneloader I dont have these black screens. Anyone an idea what to change to get rid of these black screens? cheers, Daan
rfancella Posted February 25, 2015 Posted February 25, 2015 Hi,I got Daphne all set-up using the guide. No problems. But when I run Dragon's Lair from Hyperspin or HyperlaunchHQ I have a black screen between a lot of scene changes. When I run Lair from the Daphneloader I dont have these black screens. Anyone an idea what to change to get rid of these black screens? cheers, Daan I believe that is from the LD seek. That's the way the original machine booted up. Sounds like it's not passing all the values it needs to. Please launch the game with your Logging level set to Troubleshooting and post your HyperLaunch.log file here. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
daanmuller Posted February 26, 2015 Author Posted February 26, 2015 Hi, yes it looks like a seek thing to me too, the black screen always occurs when the scene jumps, like when you die. [code] 09:06:20:320 | HL | INFO | +N/A | Main - HyperLaunch v3.1.0.3 BETA (www.hyperlaunch.net) 09:06:20:452 | HL | INFO | +140 | Main - System Specs: HyperLaunch Dir: S:\Hyperspin\HyperLaunch HyperLaunch is: 32-bit OS: Microsoft Windows 7 Home Premium SKU: Home Premium Total Memory: 3316.93 MB Free Memory: 2034.68 MB Used Memory: 1282.254 MB SystemType: 32-bit Physical Processors: 1 Logical Processors: 4 GPU 1 Name: AMD RADEON HD 6350 GPU 1 RAM: 512.00 MB GPU 1 Driver Version: 8.783.2.2000 Sound 1 Device: High Definition Audio-apparaat Sound 1 Status: Enabled OS Language: Dutch_Standard OS Admin Status: No Monitor #1 (\\.\DISPLAY1): 1920x1200 (1920x1160 work) Monitor #1 Orientation: Landscape Current AHK Desktop Width: 1920 Current AHK Desktop Height: 1200 AutoHotkey Path: AHK Version: 1.1.09.04 Unicode: No 09:06:20:452 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\HyperLaunch.exe exists 09:06:20:453 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription Your favorite Front End companion! Visit us @ www.hyperlaunch.net FileVersion 3.1.0.3 LegalCopyright ©2014 HyperLaunch ProductName djvj's one swell guy! ProductVersion 1.1.9.4 CompanyName HyperLaunch BETA File Size: 981504 bytes Created: 2/24/2015 - 5:00:58 Modified: 2/12/2015 - 3:16:35 09:06:20:453 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Module Extensions\dxwnd\dxwnd.ini exists 09:06:20:454 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 409 bytes Created: 2/24/2015 - 5:01:39 Modified: 2/12/2015 - 3:16:13 09:06:20:454 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Module Extensions\dxwnd\dxwnd.exe exists 09:06:20:455 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription DxWnd MFC application FileVersion 1, 0, 0, 1 InternalName DxWnd LegalCopyright Copyright (C) 2004/2012 OriginalFilename DxWnd.exe ProductName DxWnd application ProductVersion 1, 0, 0, 1 File Size: 539136 bytes Created: 2/24/2015 - 5:01:39 Modified: 2/12/2015 - 3:16:13 09:06:20:455 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Module Extensions\BinHexRW.ahk exists 09:06:20:460 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 09:06:20:461 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 4961 bytes Created: 2/24/2015 - 5:01:38 Modified: 2/12/2015 - 3:16:07 09:06:20:461 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Module Extensions\BlockInput.exe exists 09:06:20:503 | HL | DEBUG1 | +47 | CheckFile - Attributes: FileDescription FileVersion 1.1.09.04 InternalName OriginalFilename ProductName ProductVersion 1.1.09.04 File Size: 657920 bytes Created: 2/24/2015 - 5:01:38 Modified: 2/12/2015 - 3:16:07 09:06:20:504 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Module Extensions\CLR.ahk exists 09:06:20:505 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 09:06:20:506 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 10586 bytes Created: 2/24/2015 - 5:01:38 Modified: 2/12/2015 - 3:16:07 09:06:20:506 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Module Extensions\COM.ahk exists 09:06:20:507 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 09:06:20:508 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 26342 bytes Created: 2/24/2015 - 5:01:38 Modified: 2/12/2015 - 3:16:07 09:06:20:509 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Module Extensions\Control_AniGif.ahk exists 09:06:20:510 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 09:06:20:510 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 5716 bytes Created: 2/24/2015 - 5:01:38 Modified: 2/12/2015 - 3:16:07 09:06:20:510 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Module Extensions\dxwnd\dxwnd.ini exists 09:06:20:511 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 409 bytes Created: 2/24/2015 - 5:01:39 Modified: 2/12/2015 - 3:16:13 09:06:20:511 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Module Extensions\dxwnd\dxwnd.exe exists 09:06:20:512 | HL | DEBUG1 | +16 | CheckFile - Attributes: FileDescription DxWnd MFC application FileVersion 1, 0, 0, 1 InternalName DxWnd LegalCopyright Copyright (C) 2004/2012 OriginalFilename DxWnd.exe ProductName DxWnd application ProductVersion 1, 0, 0, 1 File Size: 539136 bytes Created: 2/24/2015 - 5:01:39 Modified: 2/12/2015 - 3:16:13 09:06:20:513 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Module Extensions\gdip.ahk exists 09:06:20:516 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 09:06:20:517 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 88789 bytes Created: 2/24/2015 - 5:01:38 Modified: 2/12/2015 - 3:16:08 09:06:20:517 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Module Extensions\gdip_alt.ahk exists 09:06:20:518 | HL | ERROR | +0 | CRC Check - No CRC defined on the header for: S:\Hyperspin\HyperLaunch\Module Extensions\gdip_alt.ahk 09:06:20:519 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 3156 bytes Created: 2/24/2015 - 5:01:38 Modified: 2/12/2015 - 3:16:08 09:06:20:519 | HL | DEBUG1 | +0 | gdip_alt.ahk Version: rotation 09:06:20:520 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Module Extensions\gsdll32.dll exists 09:06:20:538 | HL | DEBUG1 | +15 | CheckFile - Attributes: File Size: 13090816 bytes Created: 2/24/2015 - 5:01:38 Modified: 2/12/2015 - 3:16:10 09:06:20:538 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Module Extensions\itextsharp.dll exists 09:06:20:559 | HL | DEBUG1 | +32 | CheckFile - Attributes: FileDescription iTextSharp FileVersion 5.4.2.0 InternalName itextsharp.dll LegalCopyright Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved. OriginalFilename itextsharp.dll ProductName iTextSharp ProductVersion 5.4.2.0 CompanyName 1T3XT BVBA File Size: 3743744 bytes Created: 2/24/2015 - 5:01:39 Modified: 2/12/2015 - 3:16:11 09:06:20:560 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Module Extensions\Java.ahk exists 09:06:20:562 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 09:06:20:564 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 7841 bytes Created: 2/24/2015 - 5:01:39 Modified: 2/12/2015 - 3:16:11 09:06:20:564 | HL | DEBUG1 | +0 | Java.ahk Version: 1.0.0 09:06:20:565 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Module Extensions\JSON.ahk exists 09:06:20:568 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 09:06:20:569 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 9203 bytes Created: 2/24/2015 - 5:01:39 Modified: 2/12/2015 - 3:16:11 09:06:20:570 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Module Extensions\Origin.ahk exists 09:06:20:572 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 09:06:20:573 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 4897 bytes Created: 2/24/2015 - 5:01:39 Modified: 2/12/2015 - 3:16:11 09:06:20:574 | HL | DEBUG1 | +0 | Origin.ahk Version: 1.0.0 09:06:20:574 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Module Extensions\PacDrive32.dll exists 09:06:20:584 | HL | DEBUG1 | +15 | CheckFile - Attributes: File Size: 69120 bytes Created: 2/24/2015 - 5:01:39 Modified: 2/12/2015 - 3:16:11 09:06:20:585 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Module Extensions\RegRW64.ahk exists 09:06:20:587 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 09:06:20:588 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 6915 bytes Created: 2/24/2015 - 5:01:39 Modified: 2/12/2015 - 3:16:11 09:06:20:589 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Module Extensions\RIni.ahk exists 09:06:20:596 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Extension. 09:06:20:598 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 67561 bytes Created: 2/24/2015 - 5:01:39 Modified: 2/12/2015 - 3:16:11 09:06:20:598 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Module Extensions\SevenZipSharp.dll exists 09:06:20:615 | HL | DEBUG1 | +15 | CheckFile - Attributes: FileDescription SevenZipSharp FileVersion 0.64.4841.31212 InternalName SevenZipSharp.dll LegalCopyright Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3 OriginalFilename SevenZipSharp.dll ProductName SevenZipSharp ProductVersion 0.64.4841.31212 CompanyName Markovtsev Vadim File Size: 165888 bytes Created: 2/24/2015 - 5:01:39 Modified: 2/12/2015 - 3:16:12 09:06:20:615 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Module Extensions\Steam.ahk exists 09:06:20:617 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 09:06:20:619 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 5326 bytes Created: 2/24/2015 - 5:01:39 Modified: 2/12/2015 - 3:16:12 09:06:20:619 | HL | DEBUG1 | +0 | Steam.ahk Version: 1.0.0 09:06:20:620 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Module Extensions\VA.ahk exists 09:06:20:623 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Extension. 09:06:20:625 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 34688 bytes Created: 2/24/2015 - 5:01:39 Modified: 2/12/2015 - 3:16:12 09:06:20:625 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Module Extensions\VA_Extension.ahk exists 09:06:20:627 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 09:06:20:629 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 3741 bytes Created: 2/24/2015 - 5:01:39 Modified: 2/12/2015 - 3:16:12 09:06:20:629 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Lib\Bezel.ahk exists 09:06:20:651 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 09:06:20:653 | HL | DEBUG1 | +15 | CheckFile - Attributes: File Size: 95272 bytes Created: 2/24/2015 - 5:01:04 Modified: 2/12/2015 - 3:15:48 09:06:20:653 | HL | DEBUG1 | +0 | Bezel.ahk Version: 1.0.7 09:06:20:654 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Lib\Fade.ahk exists 09:06:20:657 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 09:06:20:659 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 35101 bytes Created: 2/24/2015 - 5:01:04 Modified: 2/12/2015 - 3:15:49 09:06:20:659 | HL | DEBUG1 | +0 | Fade.ahk Version: 1.0.8 09:06:20:660 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Lib\Fade Init.ahk exists 09:06:20:661 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 09:06:20:663 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 999 bytes Created: 2/24/2015 - 5:01:04 Modified: 2/12/2015 - 3:15:49 09:06:20:663 | HL | DEBUG1 | +0 | Fade Init.ahk Version: 1.0.1 09:06:20:664 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Lib\Fade Animations.ahk exists 09:06:20:668 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 09:06:20:669 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 70787 bytes Created: 2/24/2015 - 5:01:04 Modified: 2/16/2015 - 6:50:57 09:06:20:669 | HL | DEBUG1 | +0 | Fade Animations.ahk Version: 1.1.0 09:06:20:669 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Lib\HyperPause.ahk exists 09:06:20:688 | HL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library. 09:06:20:689 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 388770 bytes Created: 2/24/2015 - 5:01:04 Modified: 2/12/2015 - 3:15:49 09:06:20:689 | HL | DEBUG1 | +0 | HyperPause.ahk Version: 1.0.6 09:06:20:690 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Lib\HyperPause Init.ahk exists 09:06:20:690 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 09:06:20:691 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 537 bytes Created: 2/24/2015 - 5:01:04 Modified: 2/12/2015 - 3:15:49 09:06:20:692 | HL | DEBUG1 | +0 | HyperPause Init.ahk Version: 1.0.1 09:06:20:692 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Lib\Keymapper.ahk exists 09:06:20:695 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 09:06:20:696 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 32953 bytes Created: 2/24/2015 - 5:01:04 Modified: 2/12/2015 - 3:15:49 09:06:20:696 | HL | DEBUG1 | +0 | Keymapper.ahk Version: 1.0.9 09:06:20:696 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Lib\Keymapper Init.ahk exists 09:06:20:697 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 09:06:20:698 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 3435 bytes Created: 2/24/2015 - 5:01:04 Modified: 2/12/2015 - 3:15:49 09:06:20:698 | HL | DEBUG1 | +0 | Keymapper Init.ahk Version: 1.0.2 09:06:20:698 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Lib\MultiGame.ahk exists 09:06:20:701 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 09:06:20:702 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 40582 bytes Created: 2/24/2015 - 5:01:04 Modified: 2/12/2015 - 3:15:49 09:06:20:702 | HL | DEBUG1 | +0 | MultiGame.ahk Version: 1.0.5 09:06:20:702 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Lib\MultiGame Init.ahk exists 09:06:20:703 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 09:06:20:704 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 161 bytes Created: 2/24/2015 - 5:01:04 Modified: 2/12/2015 - 3:15:49 09:06:20:704 | HL | DEBUG1 | +0 | MultiGame Init.ahk Version: 1.0.0 09:06:20:704 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Lib\MultiPlayer.ahk exists 09:06:20:706 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 09:06:20:707 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 55606 bytes Created: 2/24/2015 - 5:01:04 Modified: 2/12/2015 - 3:15:49 09:06:20:707 | HL | DEBUG1 | +0 | MultiPlayer.ahk Version: 1.0.1 09:06:20:708 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Lib\Password.ahk exists 09:06:20:709 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 09:06:20:709 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 10035 bytes Created: 2/24/2015 - 5:01:04 Modified: 2/12/2015 - 3:15:49 09:06:20:710 | HL | DEBUG1 | +0 | Password.ahk Version: 1.0.0 09:06:20:710 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Lib\Rom Mapping Launch Menu.ahk exists 09:06:20:714 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 09:06:20:715 | HL | DEBUG1 | +16 | CheckFile - Attributes: File Size: 73560 bytes Created: 2/24/2015 - 5:01:04 Modified: 2/12/2015 - 3:15:49 09:06:20:715 | HL | DEBUG1 | +0 | Rom Mapping Launch Menu.ahk Version: 1.0.3 09:06:20:715 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Lib\Shared.ahk exists 09:06:20:720 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 09:06:20:721 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 140133 bytes Created: 2/24/2015 - 5:01:04 Modified: 2/12/2015 - 3:15:49 09:06:20:721 | HL | DEBUG1 | +0 | Shared.ahk Version: 1.2.1 09:06:20:721 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Lib\Statistics.ahk exists 09:06:20:722 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 09:06:20:723 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 26170 bytes Created: 2/24/2015 - 5:01:04 Modified: 2/12/2015 - 3:15:49 09:06:20:724 | HL | DEBUG1 | +0 | Statistics.ahk Version: 1.0.2 09:06:20:724 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Lib\Statistics Init.ahk exists 09:06:20:724 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 09:06:20:725 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 33 bytes Created: 2/24/2015 - 5:01:04 Modified: 2/12/2015 - 3:15:49 09:06:20:725 | HL | DEBUG1 | +0 | Statistics Init.ahk Version: 1.0.1 09:06:20:726 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Lib\XHotkey.ahk exists 09:06:20:727 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 09:06:20:728 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 29623 bytes Created: 2/24/2015 - 5:01:04 Modified: 2/12/2015 - 3:15:49 09:06:20:728 | HL | DEBUG1 | +0 | XHotkey.ahk Version: 1.0.2 09:06:20:728 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Lib\XHotkey Init.ahk exists 09:06:20:729 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 09:06:20:730 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 1236 bytes Created: 2/24/2015 - 5:01:04 Modified: 2/12/2015 - 3:15:49 09:06:20:730 | HL | DEBUG1 | +0 | XHotkey Init.ahk Version: 1.0.0 09:06:20:730 | HL | DEBUG1 | +0 | Main - Raw CLI received: "-s Daphne -r lair -f S:\Hyperspin\HyperSpin.exe -p HyperSpin" 09:06:20:731 | HL | DEBUG1 | +15 | Main - Received this dbName with no path via CLI: "lair" 09:06:20:731 | HL | DEBUG1 | +0 | Main - dbName: lair 09:06:20:732 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Plugins\HyperSpin.plugin exists 09:06:20:733 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 7998 bytes Created: 2/24/2015 - 5:01:43 Modified: 2/12/2015 - 3:16:34 09:06:20:733 | HL | INFO | +0 | Main - Loading Front End Plugin: "HyperSpin" 09:06:20:733 | HL | INFO | +0 | Main - HyperLaunch received "Daphne" and "lair" 09:06:20:738 | HL | INFO | +0 | Main - lair is using the default emulator: Daphne 09:06:20:739 | HL | INFO | +0 | Main - Checking for a [Daphne] section in S:\Hyperspin\HyperLaunch\Settings\Daphne\Emulators.ini 09:06:20:739 | HL | INFO | +0 | Main - Checking for a [Daphne] section in S:\Hyperspin\HyperLaunch\Settings\Global Emulators.ini 09:06:20:739 | HL | INFO | +0 | Main - Found [Daphne] in S:\Hyperspin\HyperLaunch\Settings\Global Emulators.ini 09:06:20:740 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Modules\Daphne\Daphne.ahk exists 09:06:20:740 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 6621 bytes Created: 2/24/2015 - 5:01:40 Modified: 2/16/2015 - 12:40:49 09:06:20:741 | HL | INFO | +0 | Main - CRC Check - CRC matches, this is an official unedited module. 09:06:20:741 | HL | INFO | +0 | Main - lair will use module: S:\Hyperspin\HyperLaunch\Modules\Daphne\Daphne.ahk 09:06:20:752 | HL | INFO | +16 | Main - Did not find a "S:\Hyperspin\HyperLaunch\Settings\Daphne\Game Options.ini" file, skipping any game-specific options. 09:06:20:752 | HL | INFO | +0 | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks. 09:06:20:753 | HL | INFO | +0 | Main - INI Keys read 09:06:20:753 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Module Extensions\7z.exe exists 09:06:20:754 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription 7-Zip Console FileVersion 9.20 InternalName 7z LegalCopyright Copyright (c) 1999-2010 Igor Pavlov OriginalFilename 7z.exe ProductName 7-Zip ProductVersion 9.20 CompanyName Igor Pavlov File Size: 163840 bytes Created: 2/24/2015 - 5:01:38 Modified: 2/12/2015 - 3:16:06 09:06:20:754 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Module Extensions\7z.dll exists 09:06:20:755 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription 7z Standalone Plugin FileVersion 9.20 InternalName 7za LegalCopyright Copyright (c) 1999-2010 Igor Pavlov OriginalFilename 7za.dll ProductName 7-Zip ProductVersion 9.20 CompanyName Igor Pavlov File Size: 914432 bytes Created: 2/24/2015 - 5:01:38 Modified: 2/12/2015 - 3:16:06 09:06:20:755 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\Module Extensions\FontReg.exe exists 09:06:20:756 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription Font Registration Utility (x86-32) FileVersion 2.1.3.0 OriginalFilename FontReg.exe File Size: 6144 bytes Created: 2/24/2015 - 5:01:38 Modified: 2/12/2015 - 3:16:08 09:06:20:758 | HL | INFO | +0 | Main - "lair" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side 09:06:20:758 | HL | INFO | +0 | CheckPaths - Started 09:06:20:759 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom: S:\Hyperspin\Emulators\Daphne\framefile\lair.txt 09:06:20:759 | HL | INFO | +0 | CheckPaths - Found rom: S:\Hyperspin\Emulators\Daphne\framefile\lair.txt 09:06:20:759 | HL | DEBUG1 | +0 | CheckPaths - Current romName: lair 09:06:20:759 | HL | DEBUG1 | +0 | CheckPaths - Current romPath: S:\Hyperspin\Emulators\Daphne\framefile 09:06:20:759 | HL | DEBUG1 | +0 | CheckPaths - Current romExtension: .txt 09:06:20:759 | HL | INFO | +0 | CheckPaths - Ended 09:06:20:760 | HL | INFO | +0 | BuildScript - User Variables: ;---------------------------------------------------------------------------- ; INJECTED VARIABLES ;---------------------------------------------------------------------------- #NoTrayIcon #InstallKeybdHook DetectHiddenWindows, ON SetTitleMatchMode, 2 SendMode, Event 0 = 8 pluginPath = S:\Hyperspin\HyperLaunch\Plugins pluginName = HyperSpin pluginExt = .plugin hlMode = hlTitle = HyperLaunch hlVersion = 3.1.0.3 BETA hlAuthor = djvj hlURL = www.hyperlaunch.net langFile = S:\Hyperspin\HyperLaunch\Data\Language\Localization.ini frontendPID = 0 frontendPath = S:\Hyperspin frontendExe = HyperSpin.exe frontendExt = exe frontendName = HyperSpin frontendDrive = S: exitEmulatorKey = ~Esc exitEmulatorKeyWait = 0 forceHoldKey = ~Esc restoreFE = false exitScriptKey = ~q & ~s toggleCursorKey = ~e & ~t emuFullPath = S:\Hyperspin\Emulators\Daphne\daphne.exe emuPath = S:\Hyperspin\Emulators\Daphne emuName = Daphne emuExt = exe romPath = S:\Hyperspin\Emulators\Daphne\framefile romPathFromIni = S:\Hyperspin\Emulators\Daphne\framefile romExtension = .txt romExtensionOrig = .txt romExtensions = txt executable = daphne.exe systemName = Daphne dbPath = dbName = lair dbExt = romName = lair romMapPath = romMappingEnabled = false romMappingLaunchMenuEnabled = false romMappingFirstMatchingExt = false romMappingShowAllRomsInArchive = true romMappingNumberOfGamesByScreen = 7 romMappingMenuWidth = 400 romMappingMenuMargin = 65 romMappingTextFont = Bebas Neue romMappingTextOptions = cFFFFFFFF r4 s60 Bold romMappingDisabledTextColor = ff888888 romMappingTextSizeDifference = 7 romMappingTextMargin = 15 romMappingTitleTextFont = Bebas Neue romMappingTitleTextOptions = cFFFFFFFF r4 s90 Bold romMappingTitle2TextFont = Bebas Neue romMappingTitle2TextOptions = cFFFFFFFF r4 s22 Bold romMappingGameInfoTextFont = Bebas Neue romMappingGameInfoTextOptions = cFFFFFFFF r4 s22 Regular romMappingBackgroundBrush = aa000000 romMappingColumnBrush = 33000000 romMappingButtonBrush1 = 6f000000 romMappingButtonBrush2 = 33000000 romMappingBackgroundAlign = Stretch and Lose Aspect romMappingMenuFlagWidth = 55 romMappingMenuFlagSeparation = 7 romMappingDefaultMenuList = FullList romMappingSingleFilteredRomAutomaticLaunch = false altArchiveNameOnly = altRomNameOnly = altArchiveAndRomName = altArchiveAndManyRomNames = altRomNamesOnly = romMapScenario = skipchecks = false romMatchExt = false blockInputTime = 0 blockInputFile = S:\Hyperspin\HyperLaunch\Module Extensions\BlockInput.exe errorLevelReporting = false lockLaunch = false lockLaunchGame = screenRotationAngle = 0 screenRotationAngleGame = logFile = S:\Hyperspin\HyperLaunch\HyperLaunch.log logLabel := [" INFO"," WARNING"," ERROR"," DEBUG1"," DEBUG2"] logLevel = 10 logShowDebugConsole = false logIncludeModule = true logIncludeFileProperties = true logShowCommandWindow = false logCommandWindow = false hlDebugConsoleStdout = sysLang = Dutch_Standard sysType = 32-bit navUpKey = Up navDownKey = Down navLeftKey = Left navRightKey = Right navSelectKey = Enter navP2UpKey = Numpad8 navP2DownKey = Numpad2 navP2LeftKey = Numpad4 navP2RightKey = Numpad6 navP2SelectKey = NumpadEnter originalWidth = 1920 originalHeight = 1200 dtEnabled = false dtPath = dtUseSCSI = true dtAddDrive = true servoStikEnabled = false ledblinkyEnabled = false ledblinkyFullPath = ledblinkyProfilePath = S:\Hyperspin\HyperLaunch\Profiles\LEDBlinky ledblinkyHLProfile = S:\Hyperspin\HyperLaunch\Profiles\LEDBlinky\HyperLaunch emuIdleShutdown = 0 launchPasswordHash = UpUpDownDownLeftRightLeftRight hideCursor = true hideEmu = false hideFE = false fadeIn = true fadeInDuration = 250 fadeInTransitionAnimation = DefaultAnimateFadeIn fadeInDelay = 3500 fadeInExitDelay = 3500 fadeOutExitDelay = 0 fadeOut = true fadeOutExtraScreen = false fadeOutDuration = 10 fadeOutTransitionAnimation = DefaultAnimateFadeOut fadeOutDelay = 2500 fadeLyrInterpolation = 7 fadeMuteEmulator = false fadeUseBackgrounds = false fadeXScale = fadeYScale = fadeLyr1Color = FF000000 fadeLyr1AlignImage = Stretch and Lose Aspect fadeLyr2Pos = Center fadeLyr2X = 0 fadeLyr2Y = 0 fadeLyr2Adjust = 1 fadeLyr2PicPad = 0 fadeLyr2Prefix = Extra Layer 1 - Console fadeLyr3Pos = Center fadeLyr3X = 450 fadeLyr3Y = 450 fadeLyr3Adjust = 0.8 fadeLyr3PicPad = 0 fadeLyr3Speed = 750 fadeLyr3Animation = ZeroDreamsFade fadeLyr37zAnimation = ZeroDreamsFade fadeLyr3Type = imageandbar fadeLyr3ImgFollow7zProgress = true fadeLyr3Repeat = 1 fadeLyr3BackImageTransparency = 30 fadeLyr3StaticPos = No Alignment fadeLyr3StaticX = 0 fadeLyr3StaticY = 870|1575 fadeLyr3StaticAdjust = 1 fadeLyr3StaticPicPad = 0 fadeLyr3StaticPrefix = Info Bar fadeLyr4Adjust = 1 fadeLyr4X = 1792|952 fadeLyr4Y = 891|1596 fadeLyr4Pos = No Alignment fadeLyr4FPS = 50 fadeLyr4PicPad = 0 fadeTranspGifColor = FFFFFF fadeBarWindow = Image fadeBarWindowX = fadeBarWindowY = fadeBarWindowW = 900 fadeBarWindowH = 180 fadeBarWindowR = 30 fadeBarWindowM = 30 fadeBarWindowHatchStyle = 8 fadeBar = 7zOnly fadeBarNon7zProgressTime = 0 fadeBarBack = true fadeBarBackColor = FF555555 fadeBarH = 30 fadeBarR = 10 fadeBarColor = DD00BFFF fadeBarHatchStyle = 8 fadeBarPercentageText = true fadeBarInfoText = true fadeBarXOffset = 0 fadeBarYOffset = 150 fadeRomInfoDescription = filtered text fadeRomInfoSystemName = image fadeRomInfoYear = text with label fadeRomInfoManufacturer = text with label fadeRomInfoGenre = disabled fadeRomInfoRating = image fadeRomInfoOrder = Description|SystemName|Year|Manufacturer|Genre|Rating fadeRomInfoTextPlacement = User Defined fadeRomInfoTextMargin = 7 fadeRomInfoText1Options = w1600|787 h90 x165 y870|1575 cFFE1E1E1 r4 s90 Left Regular fadeRomInfoText2Options = w400 x8 y15 cFF555555 r4 s60 Bold fadeRomInfoText3Options = w310 x165 y960|1665 cFFE1E1E1 r4 s66 Left Regular fadeRomInfoText4Options = cFF555555 r4 s20 Bold fadeRomInfoText5Options = cFF555555 r4 s20 Bold fadeRomInfoText6Options = cFF555555 r4 s20 Bold fadeStats_Number_of_Times_Played = disabled fadeStats_Last_Time_Played = disabled fadeStats_Average_Time_Played = disabled fadeStats_Total_Time_Played = disabled fadeStats_System_Total_Played_Time = disabled fadeStats_Total_Global_Played_Time = disabled fadeStatsInfoOrder = Number_of_Times_Played|Last_Time_Played|Average_Time_Played|Total_Time_Played|System_Total_Played_Time|Total_Global_Played_Time fadeStatsInfoTextPlacement = topLeft fadeStatsInfoTextMargin = 5 fadeStatsInfoText1Options = cFF555555 r4 s20 Bold fadeStatsInfoText2Options = cFF555555 r4 s20 Bold fadeStatsInfoText3Options = cFF555555 r4 s20 Bold fadeStatsInfoText4Options = cFF555555 r4 s20 Bold fadeStatsInfoText5Options = cFF555555 r4 s20 Bold fadeStatsInfoText6Options = cFF555555 r4 s20 Bold fadeText1X = 0 fadeText1Y = 0 fadeText1Options = cFFFFFFFF r4 s20 Right Bold fadeText1 = Loading Game fadeText2X = 0 fadeText2Y = 0 fadeText2Options = cFFFFFFFF r4 s20 Right Bold fadeText2 = Extraction Complete fadeText3 = Loading Game fadeText4 = Loading Complete fadeFont = Arial fadeSystemAndRomLayersOnly = false fadeExtractionTime = disabled fadeExtractionTimeTextX = 0 fadeExtractionTimeTextY = 0 fadeExtractionTimeTextOptions = cFF555555 r4 s20 Bold fadeInterruptKey = detectFadeErrorEnabled = true fadeImgPath = S:\Hyperspin\HyperLaunch\Media\Fade HLDataPath = S:\Hyperspin\HyperLaunch\Data HLMediaPath = S:\Hyperspin\HyperLaunch\Media HLErrSoundPath = S:\Hyperspin\HyperLaunch\Media\Sounds\Error modulesPath = S:\Hyperspin\HyperLaunch\Modules moduleFullName = S:\Hyperspin\HyperLaunch\Modules\Daphne\Daphne.ahk moduleName = Daphne modulePath = S:\Hyperspin\HyperLaunch\Modules\Daphne moduleExtension = ahk moduleExtensionsPath = S:\Hyperspin\HyperLaunch\Module Extensions libPath = S:\Hyperspin\HyperLaunch\Lib 7zEnabled = false 7zPath = S:\Hyperspin\HyperLaunch\Module Extensions\7z.exe 7zDllPath = S:\Hyperspin\HyperLaunch\Module Extensions\7z.dll 7zExtractPath = C:\Users\Daan Muller\AppData\Local\Temp\HS 7zExtractPathOrig = 7zAttachSystemName = false 7zDelTemp = true 7zSounds = true 7zFormats = .zip,.rar,.7z,.lzh,.gzip,.tar 7zFormatsNoP = zip,rar,7z,lzh,gzip,tar mgEnabled = false mgKey = ~NumpadSub mgBackgroundColor = FF000000 mgSidePadding = 0.2 mgXScale = 1 mgYScale = 1 mgYOffset = 500|800 mgFont = Arial mgText1Options = x10p y250|500 w80p Center cBBFFFFFF r4 s100 BoldItalic mgText1Text = Please select a game mgText2Options = w96p cFFFFFFFF r4 s50 Center BoldItalic mgText2Offset = 100 mgUseSound = true mgSoundfreq = 300 mgExitEffect = none mgSelectedEffect = rotate mgUseGameArt = false mgArtworkDir = Artwork1 mgCandidate = mgValidTypes = (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side mgOnLaunch = false hpEnabled = false hpKey = ~NumpadAdd hpBackToMenuBarKey = X hpZoomInKey = C hpZoomOutKey = V hpScreenshotKey = ~PrintScreen hpHiToTextPath = S:\Hyperspin\HyperLaunch\Module Extensions\HiToText.exe hpSaveStateKeyCodes = hpLoadStateKeyCodes = keymapperEnabled = false keymapperAHKMethod = false keymapper = xpadder xpadderFullPath = S:\Hyperspin\Utilities\Xpadder\xpadder.exe joyToKeyFullPath = S:\Hyperspin\Utilities\JoyToKey\JoyToKey.exe keymapperProfilePath = S:\Hyperspin\HyperLaunch\Profiles\xpadder keymapperFrontEndProfileName = HyperSpin keymapperFrontEndProfile = false keymapperHyperLaunchProfileEnabled = false JoyIDsEnabled = false JoyIDsPreferredControllersSystem = use_global JoyIDsPreferredControllersGlobal = use_global CustomJoyNamesEnabled = false CustomJoyNames = rotateMethod = false FEProfile = S:\Hyperspin\HyperLaunch\Profiles\xpadder\HyperSpin defaultProfile = S:\Hyperspin\HyperLaunch\Profiles\xpadder\_Default systemProfile = S:\Hyperspin\HyperLaunch\Profiles\xpadder\Daphne xPadderSystemProfile = S:\Hyperspin\HyperLaunch\Profiles\xpadder\Daphne\_Default emuProfile = S:\Hyperspin\HyperLaunch\Profiles\xpadder\Daphne\Daphne romProfile = S:\Hyperspin\HyperLaunch\Profiles\xpadder\Daphne\lair HyperLaunchProfile = S:\Hyperspin\HyperLaunch\Profiles\xpadder\HyperLaunch blankProfile = S:\Hyperspin\HyperLaunch\Profiles\xpadder\_Default\blank ahkFEProfile = S:\Hyperspin\HyperLaunch\Profiles\AHK\HyperSpin ahkDefaultProfile = S:\Hyperspin\HyperLaunch\Profiles\AHK\_Default ahkSystemProfile = S:\Hyperspin\HyperLaunch\Profiles\AHK\Daphne ahkEmuProfile = S:\Hyperspin\HyperLaunch\Profiles\AHK\Daphne\Daphne ahkRomProfile = S:\Hyperspin\HyperLaunch\Profiles\AHK\Daphne\lair ahkHyperLaunchProfile = S:\Hyperspin\HyperLaunch\Profiles\AHK\HyperLaunch bezelEnabled = false bezelICEnabled = false statisticsEnabled = true pressDuration = -1 emuVolume = 1 dxwndIni = S:\Hyperspin\HyperLaunch\Module Extensions\dxwnd\dxwnd.ini dxwndFullPath = S:\Hyperspin\HyperLaunch\Module Extensions\dxwnd\dxwnd.exe mon1O = 0 pacDrivedllFile = S:\Hyperspin\HyperLaunch\Module Extensions\PacDrive32.dll 09:06:20:760 | HL | INFO | +0 | BuildScript - Loaded XHotkey Init.ahk scripts 09:06:20:761 | HL | INFO | +0 | BuildScript - Loaded Fade Init.ahk scripts 09:06:20:761 | HL | INFO | +0 | BuildScript - Loaded Statistics Init.ahk scripts 09:06:20:761 | HL | WARNING | +0 | BuildScript - "S:\Hyperspin\HyperLaunch\Lib\User Functions Init.ahk" not found 09:06:20:761 | HL | DEBUG1 | +0 | BuildScript - Module starts on line: 2 09:06:20:762 | HL | INFO | +15 | BuildScript - Validating module 09:06:20:762 | HL | INFO | +0 | BuildScript - Validation complete 09:06:20:763 | HL | INFO | +0 | BuildScript - Module: MEmu = Daphne MEmuV = v1.0.13 MURL = http://www.daphne-emu.com/ MAuthor = djvj MVersion = 2.0.6 MCRC = F8545233 iCRC = 7FCE1920 MID = 635038268879753802 MSystem = "Daphne","LaserDisc" ;---------------------------------------------------------------------------- ; Notes: ; Executable should be Daphne.exe NOT Daphneloader.exe ; You need the module's ini from GIT, remove the (Example) from the filename. It has settings for each game so they work properly. ; If you want to define custom controls for each game, follow this process: ; 1) Manually run DaphneLoader.exe ; 2) Select each game you want to configure and click the Configure button. Select the Input tab and define your controls and hit OK and repeat for each game. ; 3) Create a folder in your emu directory called "controls" and copy your current dapinput.ini into it. This will be your default controls used for all games that a custom one was not created. ; 4) Launch each game you defined controls for through DaphneLoader. DaphneLoader will set your custom controls in the dapinput.ini. Now exit the game. ; 5) After each game you launch, copy the dapinput.ini into the controls folder and name it after the rom name you use in your xml: Example: lair.ini ; ; First time users, please follow the guide found @ http://www.hyperspin-fe.com/forum/showthread.php?29410-Complete-Guide-for-Daphne-in-HyperSpin-and-RL ;---------------------------------------------------------------------------- StartModule() BezelGUI() FadeInStart() settingsFile := modulePath . "\" . moduleName . ".ini" globalParams := IniReadCheck(settingsFile,"settings","globalParams","vldp -blank_searches -prefer_samples -noissues -fastboot",,1) fullscreen := IniReadCheck(settingsFile, "Settings", "Fullscreen","true",,1) screenWidth := IniReadCheck(settingsFile, "Settings", "ScreenWidth",A_ScreenWidth,,1) screenHeight := IniReadCheck(settingsFile, "Settings", "ScreenHeight",A_ScreenHeight,,1) pauseOnExit := IniReadCheck(settingsFile,"settings","pauseOnExit","false",,1) hwAccel := IniReadCheck(settingsFile,"settings","hwAccel","true",,1) min_seek_delay := IniReadCheck(settingsFile,romName,"min_seek_delay",A_Space,,1) seek_frames_per_ms := IniReadCheck(settingsFile,romName,"seek_frames_per_ms",A_Space,,1) homedir := IniReadCheck(settingsFile,romName,"homedir",".",,1) bank0 := IniReadCheck(settingsFile,romName,"bank0",A_Space,,1) bank1 := IniReadCheck(settingsFile,romName,"bank1",A_Space,,1) bank2 := IniReadCheck(settingsFile,romName,"bank2",A_Space,,1) bank3 := IniReadCheck(settingsFile,romName,"bank3",A_Space,,1) sound_buffer := IniReadCheck(settingsFile,romName,"sound_buffer",A_Space,,1) params := IniReadCheck(settingsFile,romName,"params",A_Space,,1) version := IniReadCheck(settingsFile,romName,"version",romName,,1) frameFile = %romName% ; storing parent romName to send as the framefile name so we don't send wrong name when using an alternate version of a game BezelStart() fullscreen := If fullscreen = "true" ? " -fullscreen" : "" If bezelPath ; this variable is only filled if bezel is enabled and a valid bezel image is found { params:= params . " -ignore_aspect_ratio" screenWidth := " -x " . Round(bezelScreenWidth) ;bezelScreenWidth variable is defined on the BezelStart function and it gives the desired width that your game screen should have while using this bezel screenHeight := " -y " . Round(bezelScreenHeight) ;idem above } Else { screenWidth := " -x " . screenWidth screenHeight := " -y " . screenHeight } min_seek_delay := If min_seek_delay ? " -min_seek_delay " . min_seek_delay : "" seek_frames_per_ms := If seek_frames_per_ms ? " -seek_frames_per_ms " . seek_frames_per_ms : "" homedir := If homedir ? " -homedir " . homedir : "" bank0 := If bank0 ? " -bank 0 " . bank0 : "" bank1 := If bank1 ? " -bank 1 " . bank1 : "" bank2 := If bank2 ? " -bank 2 " . bank2 : "" bank3 := If bank3 ? " -bank 3 " . bank3 : "" sound_buffer := If sound_buffer ? " -sound_buffer " . sound_buffer : "" hwAccel := If hwAccel = "true" ? " -opengl" : " -nohwaccel" params := globalParams . " " . params hideEmuObj := Object("ahk_class SDL_app",1) ; Hide_Emu will hide these windows. 0 = will never unhide, 1 = will unhide later 7z(romPath, romName, romExtension, 7zExtractPath) ; If you have alternate controls for a specific game, this will overwrite the current dapinput.ini with your custom one romControlIni := emuPath . "\controls\" . romName . ".ini" defaultControlIni := emuPath . "\controls\dapinput.ini" daphneControlIni := emuPath . "\dapinput.ini" If FileExist(romControlIni) { ; if a romName control ini exists Log("Module - Found a romName input ini and will overwrite the existing dapinput.ini: " . romControlIni) FileCopy, %romControlIni%, %daphneControlIni%, 1 ; copy rom dapinput, overwriting working one } Else If FileExist(defaultControlIni) { ; if a default control ini exists Log("Module - No romName input ini found, overwriting the current dapinput.ini with a default one: " . defaultControlIni) FileCopy, %defaultControlIni%, %daphneControlIni%, 1 ; copy default dapinput, overwriting working one in case a rom one was set from previous launch } Else Log("Module - No romName or default inis found, leaving the current dapinput.ini alone") ; If launched game is an alternate version of a parent, this will send the alternate's name to daphne. romName = %version% HideEmuStart() ; This fully ensures windows are completely hidden even faster than winwait ; This allows us to send variables, that when empty, are not sent to the Run command ; msgbox % executable . A_Space . romName . A_Space . params . fullscreen . screenWidth . screenHeight . min_seek_delay . seek_frames_per_ms . homedir . bank0 . bank1 . bank2 . bank3 . sound_buffer . " -framefile """ . romPath . "\" . frameFile . romExtension . """" Run(executable . A_Space . romName . A_Space . params . hwAccel . fullscreen . screenWidth . screenHeight . min_seek_delay . seek_frames_per_ms . homedir . bank0 . bank1 . bank2 . bank3 . sound_buffer . " -framefile """ . romPath . "\" . frameFile . romExtension . """", emuPath) WinWait("ahk_class SDL_app") WinWaitActive("ahk_class SDL_app") BezelDraw() HideEmuEnd() FadeInExit() Process("WaitClose", executable) 7zCleanUp() FadeOutExit() ExitModule() HaltEmu: Send, {P} Return RestoreEmu: Winrestore, AHK_class %EmulatorClass% Send, {P} Return CloseProcess: FadeOutStart() BezelExit() If pauseOnExit = true { Send, {P} Sleep, 100 } WinClose("ahk_class SDL_app") Return 09:06:20:770 | HL | INFO | +0 | BuildScript - Loaded Multi-Player scripts 09:06:20:771 | HL | INFO | +0 | BuildScript - Loaded Statistics.ahk script 09:06:20:771 | HL | WARNING | +0 | BuildScript - "S:\Hyperspin\HyperLaunch\Lib\User Functions.ahk" not found 09:06:20:772 | HL | INFO | +0 | BuildScript - Finished injecting functions into module 09:06:20:773 | HL | INFO | +0 | Main - Module is built 09:06:20:773 | HL | INFO | +0 | CheckFile - Checking if S:\Hyperspin\HyperLaunch\AutoHotkey.dll exists 09:06:20:774 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription AutoHotkey_H ANSI 32-bit FileVersion 1.1.09.04 InternalName AutoHotkey_H LegalCopyright Copyright (C) 2012 OriginalFilename AutoHotkey.exe ProductName AutoHotkey_H ProductVersion 1.1.09.04 File Size: 785408 bytes Created: 2/24/2015 - 5:00:58 Modified: 2/12/2015 - 3:16:35 09:06:20:821 | HL | INFO | +47 | Main - Hiding taskbar 09:06:21:046 | HL | INFO | +234 | Main - Running module 09:06:21:046 | HL | INFO | +0 | Main - Starting timer to watch if Front End gets displaced and restore it if it does. 09:06:21:167 | MD | INFO | +N/A | Module initialized 09:06:21:167 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess" 09:06:21:169 | MD | DEBUG1 | +0 | fadeInTransitionAnimation: DefaultAnimateFadeIn 09:06:21:170 | MD | DEBUG1 | +0 | fadeOutTransitionAnimation: DefaultAnimateFadeOut 09:06:21:170 | MD | DEBUG1 | +0 | fadeLyr3Animation: ZeroDreamsFade 09:06:21:170 | MD | DEBUG1 | +0 | fadeLyr37zAnimation: ZeroDreamsFade 09:06:21:170 | MD | INFO | +0 | StartModule - Started 09:06:21:170 | MD | INFO | +0 | StartModule - MEmu: Daphne MEmuV: v1.0.13 MURL: http://www.daphne-emu.com/ MAuthor: djvj MVersion: 2.0.6 MCRC: F8545233 iCRC: 7FCE1920 MID: MSystem: "Daphne","LaserDisc" 09:06:21:170 | MD | INFO | +0 | StartModule - You have a supported System Name for this module: "Daphne" 09:06:21:171 | MD | INFO | +0 | PluginInit - Started 09:06:21:172 | MD | DEBUG1 | +0 | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo 09:06:21:172 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for: S:\Hyperspin\Media\Daphne\Images\Wheel\lair.png 09:06:21:215 | MD | DEBUG1 | +47 | BuildAssetsTable - Searching for: S:\Hyperspin\Media\Main Menu\Images\Wheel\Daphne.png 09:06:21:215 | MD | DEBUG2 | +0 | BuildAssetsTable - Media assets found: Asset Label: Game Logo | Asset Path1: S:\Hyperspin\Media\Daphne\Images\Wheel\lair.png | Asset Extension1: png | Asset Type1: game Asset Label: System Logo | Asset Path1: S:\Hyperspin\Media\Main Menu\Images\Wheel\Daphne.png | Asset Extension1: png | Asset Type1: system 09:06:21:216 | MD | DEBUG1 | +0 | BuildAssetsTable - Ended 09:06:21:216 | MD | DEBUG1 | +0 | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other 09:06:21:216 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for: S:\Hyperspin\Media\Daphne\Images\Artwork1\lair.png 09:06:21:217 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for: S:\Hyperspin\Media\Daphne\Images\Artwork2\lair.png 09:06:21:217 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for: S:\Hyperspin\Media\Daphne\Images\Artwork3\lair.png 09:06:21:218 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for: S:\Hyperspin\Media\Daphne\Images\Artwork4\lair.png 09:06:21:218 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for: S:\Hyperspin\Media\Daphne\Images\Letters 09:06:21:376 | MD | DEBUG1 | +156 | BuildAssetsTable - Searching for: S:\Hyperspin\Media\Daphne\Images\Other 09:06:21:380 | MD | DEBUG2 | +0 | BuildAssetsTable - Media assets found: Asset Label: Letters | Asset Path1: S:\Hyperspin\Media\Daphne\Images\Letters\!.png | Asset Extension1: png | Asset Type1: system Asset Label: Letters | Asset Path2: S:\Hyperspin\Media\Daphne\Images\Letters\'.png | Asset Extension2: png | Asset Type2: system Asset Label: Letters | Asset Path3: S:\Hyperspin\Media\Daphne\Images\Letters\(.png | Asset Extension3: png | Asset Type3: system Asset Label: Letters | Asset Path4: S:\Hyperspin\Media\Daphne\Images\Letters\0.png | Asset Extension4: png | Asset Type4: system Asset Label: Letters | Asset Path5: S:\Hyperspin\Media\Daphne\Images\Letters\1.png | Asset Extension5: png | Asset Type5: system Asset Label: Letters | Asset Path6: S:\Hyperspin\Media\Daphne\Images\Letters\2.png | Asset Extension6: png | Asset Type6: system Asset Label: Letters | Asset Path7: S:\Hyperspin\Media\Daphne\Images\Letters\3.png | Asset Extension7: png | Asset Type7: system Asset Label: Letters | Asset Path8: S:\Hyperspin\Media\Daphne\Images\Letters\4.png | Asset Extension8: png | Asset Type8: system Asset Label: Letters | Asset Path9: S:\Hyperspin\Media\Daphne\Images\Letters\5.png | Asset Extension9: png | Asset Type9: system Asset Label: Letters | Asset Path10: S:\Hyperspin\Media\Daphne\Images\Letters\6.png | Asset Extension10: png | Asset Type10: system Asset Label: Letters | Asset Path11: S:\Hyperspin\Media\Daphne\Images\Letters\7.png | Asset Extension11: png | Asset Type11: system Asset Label: Letters | Asset Path12: S:\Hyperspin\Media\Daphne\Images\Letters\8.png | Asset Extension12: png | Asset Type12: system Asset Label: Letters | Asset Path13: S:\Hyperspin\Media\Daphne\Images\Letters\9.png | Asset Extension13: png | Asset Type13: system Asset Label: Letters | Asset Path14: S:\Hyperspin\Media\Daphne\Images\Letters\a.png | Asset Extension14: png | Asset Type14: system Asset Label: Letters | Asset Path15: S:\Hyperspin\Media\Daphne\Images\Letters\b.png | Asset Extension15: png | Asset Type15: system Asset Label: Letters | Asset Path16: S:\Hyperspin\Media\Daphne\Images\Letters\c.png | Asset Extension16: png | Asset Type16: system Asset Label: Letters | Asset Path17: S:\Hyperspin\Media\Daphne\Images\Letters\d.png | Asset Extension17: png | Asset Type17: system Asset Label: Letters | Asset Path18: S:\Hyperspin\Media\Daphne\Images\Letters\e.png | Asset Extension18: png | Asset Type18: system Asset Label: Letters | Asset Path19: S:\Hyperspin\Media\Daphne\Images\Letters\f.png | Asset Extension19: png | Asset Type19: system Asset Label: Letters | Asset Path20: S:\Hyperspin\Media\Daphne\Images\Letters\g.png | Asset Extension20: png | Asset Type20: system Asset Label: Letters | Asset Path21: S:\Hyperspin\Media\Daphne\Images\Letters\h.png | Asset Extension21: png | Asset Type21: system Asset Label: Letters | Asset Path22: S:\Hyperspin\Media\Daphne\Images\Letters\i.png | Asset Extension22: png | Asset Type22: system Asset Label: Letters | Asset Path23: S:\Hyperspin\Media\Daphne\Images\Letters\j.png | Asset Extension23: png | Asset Type23: system Asset Label: Letters | Asset Path24: S:\Hyperspin\Media\Daphne\Images\Letters\k.png | Asset Extension24: png | Asset Type24: system Asset Label: Letters | Asset Path25: S:\Hyperspin\Media\Daphne\Images\Letters\l.png | Asset Extension25: png | Asset Type25: system Asset Label: Letters | Asset Path26: S:\Hyperspin\Media\Daphne\Images\Letters\m.png | Asset Extension26: png | Asset Type26: system Asset Label: Letters | Asset Path27: S:\Hyperspin\Media\Daphne\Images\Letters\n.png | Asset Extension27: png | Asset Type27: system Asset Label: Letters | Asset Path28: S:\Hyperspin\Media\Daphne\Images\Letters\o.png | Asset Extension28: png | Asset Type28: system Asset Label: Letters | Asset Path29: S:\Hyperspin\Media\Daphne\Images\Letters\p.png | Asset Extension29: png | Asset Type29: system Asset Label: Letters | Asset Path30: S:\Hyperspin\Media\Daphne\Images\Letters\q.png | Asset Extension30: png | Asset Type30: system Asset Label: Letters | Asset Path31: S:\Hyperspin\Media\Daphne\Images\Letters\r.png | Asset Extension31: png | Asset Type31: system Asset Label: Letters | Asset Path32: S:\Hyperspin\Media\Daphne\Images\Letters\s.png | Asset Extension32: png | Asset Type32: system Asset Label: Letters | Asset Path33: S:\Hyperspin\Media\Daphne\Images\Letters\t.png | Asset Extension33: png | Asset Type33: system Asset Label: Letters | Asset Path34: S:\Hyperspin\Media\Daphne\Images\Letters\u.png | Asset Extension34: png | Asset Type34: system Asset Label: Letters | Asset Path35: S:\Hyperspin\Media\Daphne\Images\Letters\v.png | Asset Extension35: png | Asset Type35: system Asset Label: Letters | Asset Path36: S:\Hyperspin\Media\Daphne\Images\Letters\w.png | Asset Extension36: png | Asset Type36: system Asset Label: Letters | Asset Path37: S:\Hyperspin\Media\Daphne\Images\Letters\x.png | Asset Extension37: png | Asset Type37: system Asset Label: Letters | Asset Path38: S:\Hyperspin\Media\Daphne\Images\Letters\y.png | Asset Extension38: png | Asset Type38: system Asset Label: Letters | Asset Path39: S:\Hyperspin\Media\Daphne\Images\Letters\z.png | Asset Extension39: png | Asset Type39: system Asset Label: Other | Asset Path1: S:\Hyperspin\Media\Daphne\Images\Other\Pointer.png | Asset Extension1: png | Asset Type1: system 09:06:21:381 | MD | DEBUG1 | +0 | BuildAssetsTable - Ended 09:06:21:381 | MD | DEBUG1 | +0 | BuildAssetsTable - Started - Building Table for: MP4 Game Video|FLV Game Video|MP4 System Video|FLV System Video 09:06:21:382 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for: S:\Hyperspin\Media\Daphne\Video\lair.mp4 09:06:21:382 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for: S:\Hyperspin\Media\Daphne\Video\lair.flv 09:06:21:383 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for: S:\Hyperspin\Media\Main Menu\Video\Daphne.mp4 09:06:21:434 | MD | DEBUG1 | +62 | BuildAssetsTable - Searching for: S:\Hyperspin\Media\Main Menu\Video\Daphne.flv 09:06:21:434 | MD | DEBUG2 | +0 | BuildAssetsTable - Media assets found: Asset Label: MP4 Game Video | Asset Path1: S:\Hyperspin\Media\Daphne\Video\lair.mp4 | Asset Extension1: mp4 | Asset Type1: game Asset Label: MP4 System Video | Asset Path1: S:\Hyperspin\Media\Main Menu\Video\Daphne.mp4 | Asset Extension1: mp4 | Asset Type1: system 09:06:21:435 | MD | DEBUG1 | +0 | BuildAssetsTable - Ended 09:06:21:435 | MD | DEBUG1 | +0 | BuildDatabaseTable - Started - Building Table for: Name|Cloneof|Manufacturer|Year|Genre|Rating 09:06:21:435 | MD | INFO | +0 | CheckFile - Checking if S:\Hyperspin\Databases\Daphne\Daphne.xml exists 09:06:21:437 | MD | DEBUG1 | +0 | CheckFile - Attributes: File Size: 3207 bytes Created: 2/24/2015 - 4:17:26 Modified: 2/9/2015 - 3:33:35 09:06:21:438 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching for a "Game Name" in the database 09:06:21:438 | MD | DEBUG1 | +0 | BuildDatabaseTable - Found "Game Name" in the database! 09:06:21:438 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching database for: Name 09:06:21:439 | MD | DEBUG1 | +0 | BuildDatabaseTable - Found "Name" with a value: "Dragons Lair" 09:06:21:439 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching database for: Cloneof 09:06:21:439 | MD | DEBUG1 | +0 | BuildDatabaseTable - Could not find: Cloneof 09:06:21:440 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching database for: Manufacturer 09:06:21:440 | MD | DEBUG1 | +0 | BuildDatabaseTable - Found "Manufacturer" with a value: "Bally Midway" 09:06:21:440 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching database for: Year 09:06:21:441 | MD | DEBUG1 | +0 | BuildDatabaseTable - Found "Year" with a value: "1983" 09:06:21:441 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching database for: Genre 09:06:21:441 | MD | DEBUG1 | +0 | BuildDatabaseTable - Could not find: Genre 09:06:21:442 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching database for: Rating 09:06:21:442 | MD | DEBUG1 | +0 | BuildDatabaseTable - Could not find: Rating 09:06:21:442 | MD | DEBUG2 | +0 | PluginInit - GameInfo: GameInfo Label: Manufacturer | GameInfo Value: GameInfo Label: Name | GameInfo Value: GameInfo Label: Year | GameInfo Value: 09:06:21:443 | MD | DEBUG1 | +0 | BuildDatabaseTable - Ended 09:06:21:443 | MD | INFO | +0 | PluginInit - Ended 09:06:21:443 | MD | DEBUG1 | +0 | StartModule - Setting romName to the dbName sent to HyperLaunch: lair 09:06:21:445 | MD | INFO | +0 | Hiding mouse cursor 09:06:21:465 | MD | DEBUG2 | +31 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~e & ~t" to call label: "ToggleCursor" 09:06:21:466 | MD | INFO | +0 | StartModule - Ended 09:06:21:466 | MD | DEBUG1 | +0 | FadeInStart - Started 09:06:21:466 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Disabled Hotkey for: "~Esc" 09:06:21:467 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Disabling "CloseProcess" standard Hotkey method for key(s): "~Esc" 09:06:21:467 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Disabled Hotkey for: "~Esc" 09:06:21:468 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseFadeIn" 09:06:21:468 | MD | DEBUG2 | +0 | Fade screen scale factor: X=1.000000, Y= 1.111111 09:06:21:468 | MD | DEBUG1 | +0 | GetFadePicFile - Checking if any Fade Layer 1 images exist in: S:\Hyperspin\HyperLaunch\Media\Fade\Daphne\lair\Layer 1*.* 09:06:21:469 | MD | DEBUG1 | +0 | GetFadePicFile - Checking if any Fade Layer 1 images exist in: S:\Hyperspin\HyperLaunch\Media\Fade\Daphne\_Default\Layer 1*.* 09:06:21:469 | MD | DEBUG1 | +0 | GetFadePicFile - Looking for Fade Layer 1 pic: S:\Hyperspin\HyperLaunch\Media\Fade\Daphne\_Default\Layer 1*.png 09:06:21:470 | MD | DEBUG1 | +0 | GetFadePicFile - Found Fade Layer 1 pic: S:\Hyperspin\HyperLaunch\Media\Fade\Daphne\_Default\Layer 1.png 09:06:21:470 | MD | DEBUG1 | +0 | GetFadePicFile - Looking for Fade Layer 1 pic: S:\Hyperspin\HyperLaunch\Media\Fade\Daphne\_Default\Layer 1*.gif 09:06:21:471 | MD | DEBUG1 | +0 | GetFadePicFile - Looking for Fade Layer 1 pic: S:\Hyperspin\HyperLaunch\Media\Fade\Daphne\_Default\Layer 1*.tif 09:06:21:471 | MD | DEBUG1 | +0 | GetFadePicFile - Looking for Fade Layer 1 pic: S:\Hyperspin\HyperLaunch\Media\Fade\Daphne\_Default\Layer 1*.bmp 09:06:21:472 | MD | DEBUG1 | +0 | GetFadePicFile - Looking for Fade Layer 1 pic: S:\Hyperspin\HyperLaunch\Media\Fade\Daphne\_Default\Layer 1*.jpg 09:06:21:472 | MD | INFO | +0 | GetFadePicFile - Randomized images and Fade Layer 1 will use S:\Hyperspin\HyperLaunch\Media\Fade\Daphne\_Default\Layer 1.png 09:06:21:472 | MD | DEBUG1 | +0 | GetFadePicFile - Checking if any Fade Extra Layer 1 - Console images exist in: S:\Hyperspin\HyperLaunch\Media\Fade\Daphne\lair\Extra Layer 1 - Console*.* 09:06:21:473 | MD | DEBUG1 | +0 | GetFadePicFile - Checking if any Fade Extra Layer 1 - Console images exist in: S:\Hyperspin\HyperLaunch\Media\Fade\Daphne\_Default\Extra Layer 1 - Console*.* 09:06:21:473 | MD | DEBUG1 | +0 | GetFadePicFile - Checking if any Fade Extra Layer 1 - Console images exist in: S:\Hyperspin\HyperLaunch\Media\Fade\_Default\Extra Layer 1 - Console*.* 09:06:21:577 | MD | INFO | +110 | DefaultAnimateFadeIn - Started 09:06:21:577 | MD | INFO | +0 | DefaultAnimateFadeIn - Drawing First FadeIn Image. 09:06:21:859 | MD | INFO | +280 | DefaultAnimateFadeIn - Ended 09:06:21:865 | MD | DEBUG1 | +0 | GetFadePicFile - Checking if any Fade Extra Layer images exist in: S:\Hyperspin\HyperLaunch\Media\Fade\Daphne\lair\Extra Layer*.* 09:06:21:865 | MD | DEBUG1 | +0 | GetFadePicFile - Checking if any Fade Extra Layer images exist in: S:\Hyperspin\HyperLaunch\Media\Backgrounds\Daphne\lair\*.* 09:06:21:865 | MD | DEBUG1 | +0 | GetFadePicFile - Checking if any Fade Extra Layer images exist in: S:\Hyperspin\HyperLaunch\Media\Fade\Daphne\_Default\Extra Layer*.* 09:06:21:866 | MD | DEBUG1 | +0 | GetFadePicFile - Checking if any Fade Extra Layer images exist in: S:\Hyperspin\HyperLaunch\Media\Backgrounds\Daphne\_Default\*.* 09:06:21:866 | MD | DEBUG1 | +0 | GetFadePicFile - Checking if any Fade Extra Layer images exist in: S:\Hyperspin\HyperLaunch\Media\Fade\_Default\Extra Layer*.* 09:06:21:866 | MD | DEBUG1 | +0 | GetFadePicFile - Looking for Fade Extra Layer pic: S:\Hyperspin\HyperLaunch\Media\Fade\_Default\Extra Layer*.png 09:06:21:866 | MD | DEBUG1 | +0 | GetFadePicFile - Found Fade Extra Layer pic: S:\Hyperspin\HyperLaunch\Media\Fade\_Default\Extra Layer 2 - Info Bar.png 09:06:21:867 | MD | DEBUG1 | +0 | GetFadePicFile - Found Fade Extra Layer pic: S:\Hyperspin\HyperLaunch\Media\Fade\_Default\Extra Layer 2 - Progress Bar.png 09:06:21:867 | MD | DEBUG1 | +0 | GetFadePicFile - Looking for Fade Extra Layer pic: S:\Hyperspin\HyperLaunch\Media\Fade\_Default\Extra Layer*.gif 09:06:21:867 | MD | DEBUG1 | +0 | GetFadePicFile - Looking for Fade Extra Layer pic: S:\Hyperspin\HyperLaunch\Media\Fade\_Default\Extra Layer*.tif 09:06:21:867 | MD | DEBUG1 | +0 | GetFadePicFile - Looking for Fade Extra Layer pic: S:\Hyperspin\HyperLaunch\Media\Fade\_Default\Extra Layer*.bmp 09:06:21:868 | MD | DEBUG1 | +0 | GetFadePicFile - Looking for Fade Extra Layer pic: S:\Hyperspin\HyperLaunch\Media\Fade\_Default\Extra Layer*.jpg 09:06:21:868 | MD | INFO | +0 | GetFadePicFile - Randomized images and Fade Extra Layer will use S:\Hyperspin\HyperLaunch\Media\Fade\_Default\Extra Layer 2 - Progress Bar.png 09:06:21:889 | MD | DEBUG1 | +32 | GetFadePicFile - Checking if any Fade Extra Layer images exist in: S:\Hyperspin\HyperLaunch\Media\Fade\Daphne\lair\Extra Layer*.* 09:06:21:889 | MD | DEBUG1 | +0 | GetFadePicFile - Checking if any Fade Extra Layer images exist in: S:\Hyperspin\HyperLaunch\Media\Backgrounds\Daphne\lair\*.* 09:06:21:889 | MD | DEBUG1 | +0 | GetFadePicFile - Checking if any Fade Extra Layer images exist in: S:\Hyperspin\HyperLaunch\Media\Fade\Daphne\_Default\Extra Layer*.* 09:06:21:890 | MD | DEBUG1 | +0 | GetFadePicFile - Checking if any Fade Extra Layer images exist in: S:\Hyperspin\HyperLaunch\Media\Backgrounds\Daphne\_Default\*.* 09:06:21:890 | MD | DEBUG1 | +0 | GetFadePicFile - Checking if any Fade Extra Layer images exist in: S:\Hyperspin\HyperLaunch\Media\Fade\_Default\Extra Layer*.* 09:06:21:890 | MD | DEBUG1 | +0 | GetFadePicFile - Looking for Fade Extra Layer pic: S:\Hyperspin\HyperLaunch\Media\Fade\_Default\Extra Layer*.png 09:06:21:890 | MD | DEBUG1 | +0 | GetFadePicFile - Found Fade Extra Layer pic: S:\Hyperspin\HyperLaunch\Media\Fade\_Default\Extra Layer 2 - Info Bar.png 09:06:21:890 | MD | DEBUG1 | +0 | GetFadePicFile - Found Fade Extra Layer pic: S:\Hyperspin\HyperLaunch\Media\Fade\_Default\Extra Layer 2 - Progress Bar.png 09:06:21:891 | MD | DEBUG1 | +0 | GetFadePicFile - Looking for Fade Extra Layer pic: S:\Hyperspin\HyperLaunch\Media\Fade\_Default\Extra Layer*.gif 09:06:21:891 | MD | DEBUG1 | +0 | GetFadePicFile - Looking for Fade Extra Layer pic: S:\Hyperspin\HyperLaunch\Media\Fade\_Default\Extra Layer*.tif 09:06:21:891 | MD | DEBUG1 | +0 | GetFadePicFile - Looking for Fade Extra Layer pic: S:\Hyperspin\HyperLaunch\Media\Fade\_Default\Extra Layer*.bmp 09:06:21:891 | MD | DEBUG1 | +0 | GetFadePicFile - Looking for Fade Extra Layer pic: S:\Hyperspin\HyperLaunch\Media\Fade\_Default\Extra Layer*.jpg 09:06:21:892 | MD | INFO | +0 | GetFadePicFile - Randomized images and Fade Extra Layer will use S:\Hyperspin\HyperLaunch\Media\Fade\_Default\Extra Layer 2 - Info Bar.png 09:06:21:892 | MD | INFO | +0 | DefaultFadeAnimation - Started 09:06:21:892 | MD | DEBUG1 | +0 | GetFadePicFile - Checking if any Fade Info Bar images exist in: S:\Hyperspin\HyperLaunch\Media\Fade\Daphne\lair\Info Bar*.* 09:06:21:893 | MD | DEBUG1 | +0 | GetFadePicFile - Checking if any Fade Info Bar images exist in: S:\Hyperspin\HyperLaunch\Media\Fade\Daphne\_Default\Info Bar*.* 09:06:21:893 | MD | DEBUG1 | +0 | GetFadePicFile - Checking if any Fade Info Bar images exist in: S:\Hyperspin\HyperLaunch\Media\Fade\_Default\Info Bar*.* 09:06:21:893 | MD | DEBUG1 | +0 | GetFadePicFile - Checking if any Fade Layer 3 images exist in: S:\Hyperspin\HyperLaunch\Media\Fade\Daphne\lair\Layer 3*.* 09:06:21:893 | MD | DEBUG1 | +0 | GetFadePicFile - Checking if any Fade Layer 3 images exist in: S:\Hyperspin\HyperLaunch\Media\Fade\Daphne\_Default\Layer 3*.* 09:06:21:894 | MD | DEBUG1 | +0 | GetFadePicFile - Looking for Fade Layer 3 pic: S:\Hyperspin\HyperLaunch\Media\Fade\Daphne\_Default\Layer 3*.png 09:06:21:894 | MD | DEBUG1 | +0 | GetFadePicFile - Found Fade Layer 3 pic: S:\Hyperspin\HyperLaunch\Media\Fade\Daphne\_Default\Layer 3.png 09:06:21:894 | MD | DEBUG1 | +0 | GetFadePicFile - Looking for Fade Layer 3 pic: S:\Hyperspin\HyperLaunch\Media\Fade\Daphne\_Default\Layer 3*.gif 09:06:21:894 | MD | DEBUG1 | +0 | GetFadePicFile - Looking for Fade Layer 3 pic: S:\Hyperspin\HyperLaunch\Media\Fade\Daphne\_Default\Layer 3*.tif 09:06:21:894 | MD | DEBUG1 | +0 | GetFadePicFile - Looking for Fade Layer 3 pic: S:\Hyperspin\HyperLaunch\Media\Fade\Daphne\_Default\Layer 3*.bmp 09:06:21:895 | MD | DEBUG1 | +0 | GetFadePicFile - Looking for Fade Layer 3 pic: S:\Hyperspin\HyperLaunch\Media\Fade\Daphne\_Default\Layer 3*.jpg 09:06:21:895 | MD | INFO | +0 | GetFadePicFile - Randomized images and Fade Layer 3 will use S:\Hyperspin\HyperLaunch\Media\Fade\Daphne\_Default\Layer 3.png 09:06:21:993 | MD | DEBUG1 | +93 | FadeInDelay - Started 09:06:22:868 | MD | INFO | +889 | DefaultFadeAnimation - Ended 09:06:25:414 | MD | DEBUG1 | +2543 | FadeInDelay - Ended 09:06:25:414 | MD | DEBUG1 | +0 | FadeInStart - Ended 09:06:25:415 | MD | DEBUG1 | +0 | CoverFE - Started 09:06:25:418 | MD | DEBUG1 | +0 | CoverFE - Ended 09:06:25:447 | MD | INFO | +31 | Module Setting - [settings] - globalParams: vldp -blank_searches -prefer_samples -noissues -fastboot 09:06:25:447 | MD | INFO | +0 | Module Setting - [settings] - Fullscreen: true 09:06:25:448 | MD | INFO | +0 | Module Setting - [settings] - ScreenWidth: 1920 09:06:25:449 | MD | INFO | +0 | Module Setting - [settings] - ScreenHeight: 1200 09:06:25:449 | MD | INFO | +0 | Module Setting - [settings] - pauseOnExit: false 09:06:25:450 | MD | INFO | +0 | Module Setting - [settings] - hwAccel: true 09:06:25:450 | MD | INFO | +0 | Module Setting - [lair] - min_seek_delay: 1000 09:06:25:451 | MD | INFO | +0 | Module Setting - [lair] - seek_frames_per_ms: 20 09:06:25:452 | MD | INFO | +0 | Module Setting - [lair] - homedir: . 09:06:25:452 | MD | INFO | +0 | Module Setting - [lair] - bank0: 11111001 09:06:25:453 | MD | INFO | +0 | Module Setting - [lair] - bank1: 00100111 09:06:25:454 | MD | INFO | +0 | Module Setting - [lair] - bank2: 09:06:25:454 | MD | INFO | +0 | Module Setting - [lair] - bank3: 09:06:25:455 | MD | INFO | +0 | Module Setting - [lair] - sound_buffer: 1024 09:06:25:455 | MD | INFO | +0 | Module Setting - [lair] - params: -opengl 09:06:25:456 | MD | INFO | +0 | Module Setting - [lair] - version: dle21 09:06:25:500 | MD | INFO | +47 | Module - No romName or default inis found, leaving the current dapinput.ini alone 09:06:25:500 | MD | INFO | +0 | Run - Running: S:\Hyperspin\Emulators\Daphne\daphne.exe dle21 vldp -blank_searches -prefer_samples -noissues -fastboot -opengl -opengl -fullscreen -x 1920 -y 1200 -min_seek_delay 1000 -seek_frames_per_ms 20 -homedir . -bank 0 11111001 -bank 1 00100111 -sound_buffer 1024 -framefile "S:\Hyperspin\Emulators\Daphne\framefile\lair.txt" 09:06:25:711 | MD | DEBUG1 | +219 | Run - "daphne.exe dle21 vldp -blank_searches -prefer_samples -noissues -fastboot -opengl -opengl -fullscreen -x 1920 -y 1200 -min_seek_delay 1000 -seek_frames_per_ms 20 -homedir . -bank 0 11111001 -bank 1 00100111 -sound_buffer 1024 -framefile "S:\Hyperspin\Emulators\Daphne\framefile\lair.txt"" Process ID: 6120 09:06:25:711 | MD | DEBUG1 | +0 | GetActiveWindowStatus - Title: CoverFE | Class: AutoHotkeyGUI | State: 0 | X: 0 | Y: 0 | Width: 1920 | Height: 1200 | Window HWND: 0x102c2 | Process ID: 6004 | Process Path: S:\Hyperspin\HyperLaunch\HyperLaunch.exe 09:06:25:711 | MD | INFO | +0 | WinWait - Waiting for "ahk_class SDL_app" 09:06:27:621 | MD | DEBUG1 | +1903 | GetActiveWindowStatus - Title: SDL_app | Class: SDL_app | State: 0 | X: 0 | Y: 0 | Width: 1920 | Height: 1200 | Window HWND: 0x102c4 | Process ID: 6120 | Process Path: S:\Hyperspin\Emulators\Daphne\daphne.exe 09:06:27:621 | MD | DEBUG1 | +0 | GetActiveWindowStatus - Title: SDL_app | Class: SDL_app | State: 0 | X: 0 | Y: 0 | Width: 1920 | Height: 1200 | Window HWND: 0x102c4 | Process ID: 6120 | Process Path: S:\Hyperspin\Emulators\Daphne\daphne.exe 09:06:27:622 | MD | INFO | +0 | WinWaitActive - Waiting for "ahk_class SDL_app" 09:06:27:748 | MD | DEBUG1 | +125 | GetActiveWindowStatus - Title: SDL_app | Class: SDL_app | State: 0 | X: 0 | Y: 0 | Width: 1920 | Height: 1200 | Window HWND: 0x102c4 | Process ID: 6120 | Process Path: S:\Hyperspin\Emulators\Daphne\daphne.exe 09:06:27:868 | MD | DEBUG1 | +124 | FadeInExit - Started 09:06:27:868 | MD | DEBUG1 | +0 | FadeInExit - fadeInExitDelay started 09:06:31:392 | MD | DEBUG1 | +3526 | FadeInExit - fadeInExitDelay ended 09:06:31:392 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Disabled Hotkey for: "~Esc" 09:06:31:393 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Disabling "CloseFadeIn" standard Hotkey method for key(s): "~Esc" 09:06:31:393 | MD | INFO | +0 | DefaultAnimateFadeIn - Started 09:06:31:661 | MD | INFO | +265 | DefaultAnimateFadeIn - Ended 09:06:31:726 | MD | DEBUG2 | +63 | XHotkeyTableCreation - Disabled Hotkey for: "~Esc" 09:06:31:726 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess" 09:06:31:727 | MD | DEBUG1 | +0 | FadeInExit - Ended, waiting for user to close launched application 09:06:31:727 | MD | INFO | +0 | Process - WaitClose daphne.exe 09:07:50:872 | MD | DEBUG1 | +79155 | CloseProcess - Started, user requested to end launched application 09:07:50:873 | MD | DEBUG1 | +0 | FadeOutStart - Started 09:07:50:873 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Disabled Hotkey for: "~Esc" 09:07:50:874 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Disabling "CloseProcess" standard Hotkey method for key(s): "~Esc" 09:07:50:874 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Disabled Hotkey for: "~Esc" 09:07:50:875 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseFadeOut" 09:07:50:875 | MD | DEBUG1 | +0 | GetFadePicFile - Checking if any Fade Layer -1 images exist in: S:\Hyperspin\HyperLaunch\Media\Fade\Daphne\lair\Layer -1*.* 09:07:50:876 | MD | DEBUG1 | +0 | GetFadePicFile - Checking if any Fade Layer -1 images exist in: S:\Hyperspin\HyperLaunch\Media\Fade\Daphne\_Default\Layer -1*.* 09:07:50:876 | MD | DEBUG1 | +0 | GetFadePicFile - Checking if any Fade Layer -1 images exist in: S:\Hyperspin\HyperLaunch\Media\Fade\_Default\Layer -1*.* 09:07:50:877 | MD | DEBUG1 | +0 | GetFadePicFile - Looking for Fade Layer -1 pic: S:\Hyperspin\HyperLaunch\Media\Fade\_Default\Layer -1*.png 09:07:50:877 | MD | DEBUG1 | +0 | GetFadePicFile - Found Fade Layer -1 pic: S:\Hyperspin\HyperLaunch\Media\Fade\_Default\Layer -1.png 09:07:50:878 | MD | DEBUG1 | +0 | GetFadePicFile - Looking for Fade Layer -1 pic: S:\Hyperspin\HyperLaunch\Media\Fade\_Default\Layer -1*.gif 09:07:50:878 | MD | DEBUG1 | +0 | GetFadePicFile - Looking for Fade Layer -1 pic: S:\Hyperspin\HyperLaunch\Media\Fade\_Default\Layer -1*.tif 09:07:50:879 | MD | DEBUG1 | +0 | GetFadePicFile - Looking for Fade Layer -1 pic: S:\Hyperspin\HyperLaunch\Media\Fade\_Default\Layer -1*.bmp 09:07:50:879 | MD | DEBUG1 | +0 | GetFadePicFile - Looking for Fade Layer -1 pic: S:\Hyperspin\HyperLaunch\Media\Fade\_Default\Layer -1*.jpg 09:07:50:879 | MD | INFO | +0 | GetFadePicFile - Randomized images and Fade Layer -1 will use S:\Hyperspin\HyperLaunch\Media\Fade\_Default\Layer -1.png 09:07:50:978 | MD | INFO | +109 | DefaultAnimateFadeOut - Started 09:07:50:009 | MD | INFO | +31 | DefaultAnimateFadeOut - Ended 09:07:51:009 | MD | DEBUG1 | +0 | FadeOutStart - Ended 09:07:51:009 | MD | DEBUG1 | +0 | ShowFE - Started 09:07:51:010 | MD | DEBUG1 | +0 | ShowFE - Ended 09:07:51:010 | MD | INFO | +0 | WinClose - Closing: ahk_class SDL_app 09:07:52:726 | MD | DEBUG1 | +1716 | CloseProcess - Ended 09:07:52:833 | MD | DEBUG1 | +109 | FadeOutExit - Started 09:07:52:834 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Disabled Hotkey for: "~Esc" 09:07:52:834 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Disabling "CloseFadeOut" standard Hotkey method for key(s): "~Esc" 09:07:53:606 | MD | INFO | +765 | DefaultAnimateFadeOut - Started 09:07:53:634 | MD | INFO | +31 | DefaultAnimateFadeOut - Ended 09:07:53:637 | MD | DEBUG1 | +0 | FadeOutExit - Ended 09:07:53:638 | MD | INFO | +0 | ExitModule - Started 09:07:53:638 | MD | INFO | +0 | Starting Updating Statistics: 09:07:53:638 | MD | DEBUG2 | +0 | Total Elapsed Time in Pause in seconds: 0 09:07:53:638 | MD | DEBUG2 | +0 | gameSectionStartTime:209946 09:07:53:639 | MD | DEBUG2 | +0 | ElapsedTime:81 09:07:53:639 | MD | DEBUG2 | +0 | Statistics cleared game name: lair 09:07:53:701 | MD | DEBUG2 | +62 | Loaded game statistics from ini files: Number_of_Times_Played: 31 Last_Time_Played: woensdag februari 25, 2015 10:58:38 Average_Time_Played: 28 Total_Time_Played: 870 System_Total_Played_Time: 945 Total_Global_Played_Time: 5621 09:07:53:701 | MD | DEBUG2 | +0 | Updated Statistics: Number_of_Times_Played: 32 Last_Time_Played: donderdag februari 26, 2015 09:06:31 Average_Time_Played: 30 Total_Time_Played: 951 System_Total_Played_Time: 1026 Total_Global_Played_Time: 5702 09:07:53:759 | MD | INFO | +63 | Game section statistics updated. 09:07:53:766 | MD | INFO | +0 | Restoring mouse cursor 09:07:53:767 | MD | INFO | +0 | ExitModule - Ended 09:07:53:768 | MD | INFO | +0 | End of Module Logs 09:07:53:881 | HL | INFO | +92836 | Main - Module ended, exiting HyperLaunch normally 09:07:53:881 | HL | INFO | +0 | ExitScript - Started 09:07:53:887 | HL | DEBUG1 | +0 | ExitScript - Unhiding taskbar 09:07:54:132 | HL | INFO | +250 | SystemCursor - Restoring mouse cursor 09:07:54:149 | HL | INFO | +16 | ExitScript - Ended cheers, Daan
rfancella Posted February 26, 2015 Posted February 26, 2015 Hi,yes it looks like a seek thing to me too, the black screen always occurs when the scene jumps, like when you die. ...snip... 09:06:25:447 | MD | INFO | +31 | Module Setting - [settings] - globalParams: vldp -blank_searches -prefer_samples -noissues -fastboot 09:06:25:447 | MD | INFO | +0 | Module Setting - [settings] - Fullscreen: true 09:06:25:448 | MD | INFO | +0 | Module Setting - [settings] - ScreenWidth: 1920 09:06:25:449 | MD | INFO | +0 | Module Setting - [settings] - ScreenHeight: 1200 09:06:25:449 | MD | INFO | +0 | Module Setting - [settings] - pauseOnExit: false 09:06:25:450 | MD | INFO | +0 | Module Setting - [settings] - hwAccel: true 09:06:25:450 | MD | INFO | +0 | Module Setting - [lair] - min_seek_delay: 1000 09:06:25:451 | MD | INFO | +0 | Module Setting - [lair] - seek_frames_per_ms: 20 09:06:25:452 | MD | INFO | +0 | Module Setting - [lair] - homedir: . 09:06:25:452 | MD | INFO | +0 | Module Setting - [lair] - bank0: 11111001 09:06:25:453 | MD | INFO | +0 | Module Setting - [lair] - bank1: 00100111 09:06:25:454 | MD | INFO | +0 | Module Setting - [lair] - bank2: 09:06:25:454 | MD | INFO | +0 | Module Setting - [lair] - bank3: 09:06:25:455 | MD | INFO | +0 | Module Setting - [lair] - sound_buffer: 1024 09:06:25:455 | MD | INFO | +0 | Module Setting - [lair] - params: -opengl 09:06:25:456 | MD | INFO | +0 | Module Setting - [lair] - version: dle21 09:06:25:500 | MD | INFO | +47 | Module - No romName or default inis found, leaving the current dapinput.ini alone 09:06:25:500 | MD | INFO | +0 | Run - Running: S:\Hyperspin\Emulators\Daphne\daphne.exe dle21 vldp -blank_searches -prefer_samples -noissues -fastboot -opengl -opengl -fullscreen -x 1920 -y 1200 -min_seek_delay 1000 -seek_frames_per_ms 20 -homedir . -bank 0 11111001 -bank 1 00100111 -sound_buffer 1024 -framefile "S:\Hyperspin\Emulators\Daphne\framefile\lair.txt" 09:06:25:711 | MD | DEBUG1 | +219 | Run - "daphne.exe dle21 vldp -blank_searches -prefer_samples -noissues -fastboot -opengl -opengl -fullscreen -x 1920 -y 1200 -min_seek_delay 1000 -seek_frames_per_ms 20 -homedir . -bank 0 11111001 -bank 1 00100111 -sound_buffer 1024 -framefile "S:\Hyperspin\Emulators\Daphne\framefile\lair.txt"" Process ID: 6120 ...snip... cheers, Daan Ok, I think it's in your bank settings. Just for grins try these settings: Bank 0 11011001 Bank 1 00100011 Let me know. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
daanmuller Posted February 27, 2015 Author Posted February 27, 2015 No that didn't help. Maybe the commandline from daphneloader helps? With this it plays without the black screens. daphne.exe dle21 vldp -framefile S:\Hyperspin\Emulators\Daphne\framefile\lair.txt -homedir S:\Hyperspin\Emulators\Daphne -bank 0 11111000 -bank 1 00110111 -noserversend -sound_buffer 1024 -fullscreen -x 640 -y 480 -opengl cheers, Daan
daanmuller Posted March 5, 2015 Author Posted March 5, 2015 Solved it. The min_seek_delay in the lair rom in the module setting is 1500 ms, changed this to 50ms and presto. Cheers, Daan
