subzero1970 Posted February 25, 2015 Posted February 25, 2015 i have a resolution type problem with sega model 3 from inside hyperspin - when launched OUTSIDE Hs it will play full screen...when launched from INSIDE Hs it plays in a very small window, and no matter what I try it wont fix it... is there an easy solution?
Styphelus Posted February 26, 2015 Posted February 26, 2015 1. Check you module options and make sure you have it set to full screen 2. Make sure you don't have bezel enabled. 3. Chance the Model 3 ini (of cfg) file into read only and try again.
subzero1970 Posted February 27, 2015 Author Posted February 27, 2015 1. Check you module options and make sure you have it set to full screen2. Make sure you don't have bezel enabled. 3. Chance the Model 3 ini (of cfg) file into read only and try again. set to fullscreen, no bezels, ini file is read only, still displays in a tiny window
