Had All Setup and working Now nothing Plz Help
jordandparker
Hi guys I have had a ll my emus and roms and everthing setup and working great then I decided I would give retroark a go and used this guide:
http://www.hyperspin-fe.com/forum/showthread.php?36930-Complete-RetroArch-Guide-For-Noobs
Now When I use hyperlaunchHQ to test that the games and emulaters load and work all is goo they just wont load from hyperspin I press enter and nothing happens.
Note I havent setup completely retroark and I went back to other emulators.
Hypespin Log:
12:08:35 PM | HyperSpin Started
12:08:35 PM | Going FullScreen
12:08:35 PM | Checking for updates
12:08:35 PM | Update Check Complete
12:08:35 PM | Startup program unavailable
12:08:35 PM | Playing intro video
12:08:37 PM | Error intializing joysticks
12:08:37 PM | Menu Mode is multi
12:08:37 PM | Loading Main Menu.xml
12:08:38 PM | Main Menu.xml successfully loaded
12:08:38 PM | Main Menu wheel loaded successfully
12:08:41 PM | Loading Super Nintendo Entertainment System.xml
12:08:41 PM | Main Menu.xml successfully loaded
12:08:42 PM | Super Nintendo Entertainment System wheel loaded successfully
12:08:43 PM | Launching Game
12:08:43 PM | Using HyperLaunch
12:08:43 PM | Getting HyperLaunch path
12:08:43 PM | HyperLaunch located at V:\Hyperspin\HyperLaunch.exe
12:08:43 PM | Running HyperLaunch.exe
12:08:43 PM | HyperLaunch Command Line is: V:\Hyperspin\HyperLaunch.exe "Super Nintendo Entertainment System" "2020 Super Baseball (USA)"
12:08:45 PM | Launching Game
12:08:45 PM | Using HyperLaunch
12:08:45 PM | Getting HyperLaunch path
12:08:45 PM | HyperLaunch located at V:\Hyperspin\HyperLaunch.exe
12:08:45 PM | Running HyperLaunch.exe
12:08:45 PM | HyperLaunch Command Line is: V:\Hyperspin\HyperLaunch.exe "Super Nintendo Entertainment System" "2020 Super Baseball (USA)"
12:08:46 PM | Getting HyperLaunch path
12:08:46 PM | HyperLaunch located at V:\Hyperspin\HyperLaunch.exe
12:08:46 PM | Running HyperLaunch.exe
12:08:46 PM | HyperLaunch Command Line is: V:\Hyperspin\HyperLaunch.exe "Super Nintendo Entertainment System" "2020 Super Baseball (USA)"
12:08:46 PM | Launching Game
12:08:46 PM | Using HyperLaunch
12:08:47 PM | Launching Game
12:08:47 PM | Using HyperLaunch
12:08:47 PM | Getting HyperLaunch path
12:08:47 PM | HyperLaunch located at V:\Hyperspin\HyperLaunch.exe
12:08:47 PM | Running HyperLaunch.exe
12:08:47 PM | HyperLaunch Command Line is: V:\Hyperspin\HyperLaunch.exe "Super Nintendo Entertainment System" "2020 Super Baseball (USA)"
12:08:48 PM | Loading Main Menu.xml
12:08:48 PM | Main Menu.xml successfully loaded
12:08:49 PM | Main Menu wheel loaded successfully
12:08:52 PM | Exit program unavailable
12:08:52 PM | Quiting Hyperspin
12:08:52 PM | Bye!
Hyperlaunch Log:
12:08:47 PM | HyperLaunch v2.25c
12:08:47 PM | System Specs:
HyperSpin Dir: V:\Hyperspin
OS: WIN_7
OS Language: 0409
OS Admin Status: Yes
Monitor #1 (\\.\DISPLAY1): 1360x768 (1360x728 work)
HyperSpin Res: 1360x768
AHK Version: 1.1.07.03
12:08:47 PM | HyperLaunch received "Super Nintendo Entertainment System" and "2020 Super Baseball (USA)"
12:08:47 PM | INI Keys read
12:08:47 PM | Possible duplicate launch. is already running, closing HyperLaunch
I have checked that there are no other proccess running there is nothing.
Any help would be great thanks
Looks like one time you launched a game, Hyperlaunch failed to close all the way. Open up your task manager find the hyperlaunch and any emulator processes and make sure they are closed.
Walter:beerglass:
No there is no open process and I have restarted Pc and still issues.
I think it must be hyperlaunch not launching or something is there anyway to check that?
All Good I checked my settings.ini and it had change the hyperlaunch path back to c:
Thanks Heaps aletterfromthelostdays I really appreciate the quick reply
  • 2 months later...
"All Good I checked my settings.ini and it had change the hyperlaunch path back to c:
Thanks Heaps aletterfromthelostdays I really appreciate the quick reply "
I'm having the exact same issue, where is this ".ini file?
Thanks
Thanks
The file is in your HyperSpin folder. "HyperSpin\Settings\Settings.ini" You are looking for "Hyperlaunch_Path= path to your HyperLaunch folder\" If you use RocketLauncher,  it would be "Hyperlaunch_Path= path to your HyperLaunch folder\RocketLauncher\RocketLauncher.exe"
Check out my MAME Arcade classics themes
