KMHamel Posted September 24, 2012 Posted September 24, 2012 I was setting up NullDC and found a workaround for getting the second controller to work in NullDC. I'm using two rotary U360's. Of course, you need to setup both port A and port B in maple to the purupuru input (for pads). Set controller 1 as usual. Exit out of nulldc and edit the Nulldc cfg file in you nulldc folder. Scroll down to PuruPuru_pad_2 and find joyid=0 and change it to 1. Start nulldc again and setup port b in maple using your second player joystick. When you click on ok, nulldc will save all your changes but it will change back the joyid to 0 in purupuru_pad_2. Go back and edit the nulldc cfg file again and change back joyid to 1. You are now ready to play with two players. As long as you don't setup your controls in maple again the joyid will stay as 1. If you do enter the maple setup, just edit the cfg file again. Have fun.....no more joy to key. This should work for player 3 and 4 also....I don't have 4 joysticks but I don't see why it wouldn't work.
Yuguru Posted December 27, 2014 Posted December 27, 2014 This should work for player 3 and 4 also....I don't have 4 joysticks but I don't see why it wouldn't work. This helped me tremendously when setting up four controllers. Thank you very much.
