ScummVM 1.7 and HyperLaunch 3.1.0.5b Beta
annomatik
Hi Guys!
Currently trying to run ScummVM from HyperSpin. I already have a couple of other Systems running fine, but I'm not sure on how to set up ScummVM.
What I did:
1) ScummVM is running fine standalone, I have currently one game in it (samnmax is the short name, it's Sam N Max hit the road)
2) I downloaded the corresponding XML and deleted everything except samnmax from it. I've also downloaded the corresponding Default theme and wheel images, the wheel of Sam N Max shows up fine in HyperSpin.
3) As HyperLaunch shows 7z as the default extension, I zipped Sam N Max to samnmax.7z, set the extension in HyperspinHQ to 7z and set the rom path to the directory containing the file.
4) As HyperLauch complained that 7z support was disabled, I've enabled it.
Now comes the part where I'm stuck. When I try to run samnmax, HyperLaunch tells me:
"You did not supply any valid rom extensions to search for in your compressed roms. Please turn off 7z support or add at least one rom extension to Rom_Extension: "7z". If this archive has no roms with a standard romName inside, you may need to set Skip Checks to "Rom Extension."".
What should I do? And where do I do that?
Thanks!
Yay, it launches! Thanks.
The problem now remaining is, when I quit a game in ScummVM, it messes up how HyperSpin looks.
Before running the game:
After running the game:
Help?
