hvkirov Posted March 17, 2015 Posted March 17, 2015 Hi Guys, I am new in all this Retro gaming, actually I decided to bring up some good old memories from when I was a little boy and all there was were the arcades and the good old Ataris, so lately playing on my consoles got bored and went on youtube looking at those arcade projects so got the dust of couple of old PCs and started building my HiperSpin system, But no luck with the emu side of it, it seems that I cant make the Hyperspin Front end work with retroarch. I setup retroarch and it works on its own but it wont startup from Hyperspin cand figure out how and where from to Get the correct ahk for it. So I f I could get some help here, It would be greatly appreciated
scooter1974 Posted March 17, 2015 Posted March 17, 2015 aletterfromthelostdays has made a great guide on getting RetroArch up and running. It helped me out a lot. Complete-RetroArch-Guide-For-Noobs Check out my MAME Arcade classics themes!
hvkirov Posted March 18, 2015 Author Posted March 18, 2015 Thanks for the quick reply I will give it a try today and see how it goes, but why is there so hard to find answers in this forums, seems that the search engine is not so good. and one more think: I am having troubles exiting an emulator through Hyperspin the esc buton does not work if started from the front end, and I couldnt find where to set it up in Hyperspin
hvkirov Posted March 18, 2015 Author Posted March 18, 2015 Still no luck Got Retroarch to work started by the exe, and launched through Hyper launch but from the Hyperspin Front end it wont as I dont have the correct .AHK file, witch will make it start or if someone could tell me how to compile it for each system
scooter1974 Posted March 18, 2015 Posted March 18, 2015 Still no luck Got Retroarch to work started by the exe, and launched through Hyper launch but from the Hyperspin Front end it wont as I dont have the correct .AHK file, witch will make it start or if someone could tell me how to compile it for each system It sounds like you are running an old version of HyperSpin/HyperLaunch. Updating both should fix that problem. If you want to start a fresh install, grab the first 2 files from the downloads section, then update your HyperLaunch with this guide. Gigapig also has some great guides on setting up various systems and also one on the features of Hyperlaunch, have a look here. Hopefully this will get you on your feet Check out my MAME Arcade classics themes!
