Hypermarquee Tutorial Setup
Hello,
I've been using HS since the early days but can't get my head around the HyperMarquee/ESD combo, has anyone a default working tutorial setup to get it working and go from there?
tnx!
Erik
  • 1 month later...
Try SevenSeal's artwork setup tutorial for HM on this page  http://www.hyperspin-fe.com/topic/9012-hypermarquee-040/page-24
For EDS follow instructions on post 188 on this page http://www.hyperspin-fe.com/topic/9006-hyperspin-event-dispatch-system-eds-071/page-10?hl=%20event%20%20dispatch%20%20system
If you are running the new HS Beta 1.4 then you don't need to install/run HSFilewatcher.
Maybe this will help explain a little.
Normally HyperHQ has the option to enable the use of LedBlinky in HS.  If you follow the instructions above then you will rename the EDS program to LedBlinky and you will give HyperHQ the file location of this "fake" LedBlinky. This gets EDS running in HS. Then EDS runs the true LedBlinky program (along with Hypermarquee).
Hope this makes sense and helps.
Junky
just got HM to work with my global settings... EDS works on the basic startup settings
all i did was change to Pipe_ID to match the name of the HM desired settings file
for some reason  though,,, it's not working for the main wheel !?!
any advice?!?
HM wont load settings when HS opens...
HM also wont close with HS
am missing some params... suggestions?!?
  • 5 months later...
I'm having a problem setting this up....I followed the tuitorials and vids to set it up but I have this weird thing happening where my mouse keeps going to the top left corner of my screen as well as nothing being displayed for the hypermarquee....when I run hyperspin....iedblinky.exe has stopped working error.....any idea what I should do guys...I would really like to have this running on my cab.
I'm lovin my arcade
maybe you should be seeking help on the main thread of the program, and ask your question there? you will get much better support for Q and A that way than avoiding that area?
  • 4 weeks later...
Sevenseal has been very helpful in setting up hypermarquee and event dispatch system, I want to thank him for giving me such great 1 on 1 support...thank you!
