MAME 0.146 high score?
SCUTTER BLASTER
Hello,
I am finished making my mame arcade on an old dell 3100 windows 7 32bit. I used mame 0.146 and was wondering is there an easy way to have it save high scores? I'm looking for the simplest way to do this. I have read a bunch of forums and tried a few compiling methods but it is coming up with errors (I've never compiled anything before so I'm failing at that). Starting off fresh, give me a step by step if it's possible for mame 0.146. If you have cmd suggestions I would appreciate if you could have them so I can copy/paste. My directory is c:\hyperspin\emulators\mame
I would very much appreciate some friendly advice and how-to on this :beer:
I have the hiscore.dat file in my folder (same place as mame.exe) and I made a sub folder called "hi"
The only options for mame 0.146 is to press Tab and my only options are: User Interface, controls for different players, others controls. Nothing about miscellaneous or high score support.
Nothing in the mame.ini file either. I went to "Hyperspin\settings\settings.ini and it says [high score] enabled. Thats Hyperspin settings but nothing in the mame stuff
Thanks for the suggestions. I tried making a dat folder and placing it different places but still nothing. I'm guessing it will be a more complicated task. Hopefully someone knows how
If the version of MAME you have doesn't have the hiscore patch baked into the build you're using, it's not going to work no matter what you try.
Try upgrading to another build that has HiScore baked in. There are many in my folder on the FTP.
- J*
How to rebuild your MAME ROM set using CLRMAMEPRO - Walkthrough HERE!
