CD32/WinUAE Error Call to nonexitent function
tonycrew
If i drop to HL 2.25c then i get can't find rom with provided extension..? on ALL games..!
And on HyperLaunch v3.1.0.5 Beta it runs..? But i dont want to use Rocketlaunch so what can i do..?
Ok got it working by editing the winuae.ahk file although not recomended until i can find v2.0 this will have to do, it's only for CD32 games anyway so i don't need WHLoad paths etc...
MEmu = WinUAE
MEmuV = v2.6.0
MURL = http://www.winuae.net/
MAuthor = brolly
MVersion = 2.1.3
MCRC = 64CDF688
iCRC = 387DD74B
mId = 635138307631183750
MSystem = "Commodore Amiga","Commodore Amiga CD32","Commodore CDTV","Commodore Amiga CD","Commodore Amiga Demos"
; Notes:
; You can have specific configuration files inside a Configurations folder on WinUAE main dir.
; Just name them the same as the game name on the XML file.
; Make sure you create a host config files with these names:
; CD32 : cd32host.uae and cd32mousehost.uae;
; CDTV : cdtvhost.uae and cdtvmousehost.uae;
; Amiga : amigahost.uae;
; Amiga CD : amigacdhost.uae;
; cd32mouse and cdtvmouse are for mouse controlled games on these systems, you should configure
; Windows Mouse on Port1 and a CD32 pad on Port2. For Amiga and Amiga CD make sure you set both
; a joystick and a mouse on Port1 and only a joystick on Port2.
; Set all your other preferences like video display settings. And make sure you are saving a HOST
; configuration file and not a general configuration file.
; If you want to configure an exit key through WinUAE:
; Host-Input-Configuration #1-RAW Keyboard and then remap the desired key to Quit Emulator.
; If you want to configure a key to toggle fullscreen/windowed mode:
; Host-Input-Configuration #1-RAW Keyboard and then remap the desired key to Toggle windowed/fullscreen.
; CD32 and CDTV:
; A settings file called System_Name.ini should be placed on your module dir. on that file you can define if a
; game uses mouse or if it needs the special delay hack loading method amongst other things. Example of such a file:
; [Lemmings (Europe)]
; UseMouse=true
; [Project-X & F17 Challenge (Europe)]
; DelayHack=true
; Amiga:
; For MultiGame support make sure you don't change the default WinUAE diskswapper keys which are:
; END+1-0 (not numeric keypad) = insert image from swapper slot 1-10
; END+SHIFT+1-0 = insert image from swapper slot 11-20
; END+CTRL+1-4 = select drive
; To do that follow the same procedure as above for the exit
; key, but on F11 set it to Toggle windowed/fullscreen. Make sure you save your configuration afterwards.
; Note : If you want to use Send commands to WinUAE for any keys that you configured through Input-Configuration panel make sure you
; set those keys for Null Keyboard! This is a virtual keyboard that collects all input events that don't come from physical
; keyboards. This applies to the exit or windowed/fullscreen keys mentioned above.
; If you are using WHDLoad games, but want to keep your default user-startup file after exiting then make a copy of it in the
; WHDFolder\S (Set in PathToWHDFolder) and name it default-user-startup. This file will then be copied over S\user-startup on exit.
StartModule()
FadeInStart()
settingsFile := modulePath . "\" . systemName . ".ini"
PathToWHDFolder := IniReadCheck(settingsFile, "Settings", "PathToWHDFolder", EmuPath . "\HDD\WHD",,1)
PathToWorkBenchBase := IniReadCheck(settingsFile, "Settings", "PathToWorkBenchBase", EmuPath . "\HDD\Workbench31_Lite.vhd",,1)
;Bezel settings
bezelTopOffset := IniReadCheck(settingsFile, "Settings", "Bezel_Top_Offset","0",,1)
bezelBottomOffset := IniReadCheck(settingsFile, "Settings", "Bezel_Bottom_Offset","0",,1)
bezelRightOffset := IniReadCheck(settingsFile, "Settings", "Bezel_Right_Offset", "0",,1)
bezelLeftOffset := IniReadCheck(settingsFile, "Settings", "Bezel_Left_Offset", "0",,1)
; This object controls how the module reacts to different systems. MESS can play a lot of systems, but needs to know what system you want to run, so this module has to adapt.
mType := Object("Commodore Amiga","a500","Commodore Amiga CD32","cd32","Commodore CDTV","cdtv","Commodore Amiga CD","amigacd","Commodore Amiga Demos","a500")
ident := mType[systemName] ; search object for the systemName identifier MESS uses
If !ident
ScriptError("Your systemName is: " . systemName . "`nIt is not one of the known supported systems for this WinUAE module: " . moduleName)
specialcfg = %emuPath%\Configurations\%romName%.uae
If romExtension in .hdf,.vhd
DefaultRequireWB := "true"
Else
DefaultRequireWB := "false"
If romExtension in .zip,.lha,.rar,.7z
SlaveFile := COM_Invoke(HLObject, "findByExtension", romPath . "\" . romName . romExtension, "slave")
If (SlaveFile) {
If romName contains (AGA)
defaultCycleExact := "false"
defaultCpuSpeed := "max"
} Else {
defaultCycleExact := "true"
defaultCpuSpeed := "real"
defaultImmediateBlittler = "false"
defaultCpuCompatible := "false"
defaultCacheSize := "0" ;8192
usemouse := IniReadCheck(settingsFile, romName, "UseMouse","false",,1)
delayhack := IniReadCheck(settingsFile, romName, "DelayHack","false",,1)
floppyspeed := IniReadCheck(settingsFile, romName, "FloppySpeed","turbo",,1)
quickstartmode := IniReadCheck(settingsFile, romName, "QuickStartMode",A_Space,,1)
options := IniReadCheck(settingsFile, romName, "Options","",,1)
requireswb := IniReadCheck(settingsFile, romName, "RequiresWB",DefaultRequireWB,,1)
customwb := IniReadCheck(settingsFile, romName, "CustomWB",A_Space,,1)
;Chipset settings
videomode := IniReadCheck(settingsFile, romName, "VideoMode","PAL",,1)
immediateblitter := IniReadCheck(settingsFile, romName, "ImmediateBlitter",defaultImmediateBlittler,,1)
collisionlevel := IniReadCheck(settingsFile, romName, "CollisionLevel","",,1)
;CPU settings
cycleexact := IniReadCheck(settingsFile, romName, "CycleExact",defaultCycleExact,,1)
cpucycleexact := IniReadCheck(settingsFile, romName, "CpuCycleExact","",,1)
blittercycleexact := IniReadCheck(settingsFile, romName, "BlitterCycleExact","",,1)
cpucompatible := IniReadCheck(settingsFile, romName, "CpuCompatible",defaultCpuCompatible,,1)
cpuspeed := IniReadCheck(settingsFile, romName, "CpuSpeed",defaultCpuSpeed,,1)
cachesize := IniReadCheck(settingsFile, romName, "CacheSize",defaultCacheSize,,1)
cpu := IniReadCheck(settingsFile, romName, "CPU","",,1)
fpu := IniReadCheck(settingsFile, romName, "FPU","",,1)
;RAM settings
chipmemory := IniReadCheck(settingsFile, romName, "ChipMemory","",,1)
fastmemory := IniReadCheck(settingsFile, romName, "FastMemory","",,1)
autoconfigfastmemory := IniReadCheck(settingsFile, romName, "AutoConfigFastMemory","",,1)
slowmemory := IniReadCheck(settingsFile, romName, "SlowMemory","",,1)
z3fastmemory := IniReadCheck(settingsFile, romName, "Z3FastMemory","",,1)
megachipmemory := IniReadCheck(settingsFile, romName, "MegaChipMemory","",,1)
;WHDLoad settings
whdloadoptions := IniReadCheck(settingsFile, romName, "WHDLoadOptions","PRELOAD",,1)
neverextract := IniReadCheck(settingsFile, romName, "NeverExtract","false",,1)
BezelStart()
windowClass = PCsuxRox ;Class name is different depending on if the game is being run windowed or fullscreen
If ( Fullscreen = "true" )
windowClass = AmigaPowah
If (cpucycleexact and blittercycleexact)
cycleexact := "" ;No need to set cycle exact if both cpu and blitter are set as it could lead to inconsistent states
;Fill both z3 slots when amount of RAM requires it
If (z3fastmemory = "384") {
z3fastmemory = "256"
z3fastmemoryb = "128"
} Else If (z3fastmemory = "768") {
z3fastmemory = "512"
z3fastmemoryb = "256"
} Else If (z3fastmemory = "1536") {
z3fastmemory = "1024"
z3fastmemoryb = "512"
fs := If (Fullscreen = "true") ? "true" : "false"
videomode := (If videomode = "NTSC" ? ("-s ntsc=true") : (""))
floppyspeed := (If floppyspeed ? ("-s floppy_speed=" . floppyspeed) : (""))
If (requireswb = "true") {
ident := "a1200"
If (customwb)
PathToWorkBenchBase := %EmuPath% . "\" . customwb
CheckFile(PathToWorkBenchBase)
wbDrive := "-s hardfile=rw,32,1,2,512," . """" . PathToWorkBenchBase . """"
ident := "a1200"
gameDrive := "-s hardfile=rw,32,1,2,512," . """" . romPath . "\" . romName . romExtension . """"
options := options . " " . videomode
If (ident = "a500" or ident = "a1200") {
If romName contains (AGA),(LW)
ident := "a1200"
If (SlaveFile) {
ident := "a1200"
;Create the user-startup file to launch the game
WHDUserStartupFile := PathToWHDFolder . "\S\user-startup"
SplitPath, SlaveFile, SlaveName, SlaveFolder
FileDelete, %WHDUserStartupFile%
FileAppend, echo "";`n, %WHDUserStartupFile%
FileAppend, echo "Running: %SlaveName%";`n, %WHDUserStartupFile%
FileAppend, cd dh1:%SlaveFolder%;`n, %WHDUserStartupFile%
FileAppend, whdload %SlaveName% %whdloadoptions%;`n, %WHDUserStartupFile%
hideEmuObj := Object("ahk_class " . windowClass,1) ; Hide_Emu will hide these windows. 0 = will never unhide, 1 = will unhide later
;--- Detecting what Configuration File to use (Or Quick Start Mode) ---
If FileExist(specialcfg) {
;Game specific configuration file exists
configFile = %romName%.uae
} Else {
;Game specific configuration file doesn't exist
If (ident = "cd32" or ident = "cdtv") {
configFile := If (usemouse = "true") ? ("host\" . ident . "mousehost.uae") : ("host\" . ident . "host.uae")
quickcfg := If (ident = "cd32") ? ("-s quickstart=" . ident . "`,0 -s chipmem_size=8") : ("-s quickstart=" . ident . "`,0")
} Else {
;Amiga or Amiga CD game
configFile := If systemName = "Commodore Amiga CD" ? "host\amigacdhost.uae" : "host\amigahost.uae"
If quickstartmode
quickcfg := "-s quickstart=" . quickstartmode
Else
quickcfg := If (ident = "a500") ? "-s quickstart=a500`,1" : "-s quickstart=a1200`,1"
;--- Setting up command line arguments to use ---
If (delayhack = "true")
options := options . " -s cdimage0=" . """" . romPath . "\" . romName . romExtension . """" . "`,delay"
Else
options := options . " -cdimage=" . """" . romPath . "\" . romName . romExtension . """"
} Else {
If immediateblitter
options := options . " -s immediate_blits=" . immediateblitter
If cycleexact
options := options . " -s cycle_exact=" . cycleexact
If cpucycleexact
options := options . " -s cpu_cycle_exact=" . cpucycleexact
If blittercycleexact
options := options . " -s blitter_cycle_exact=" . blittercycleexact
If cpucompatible
options := options . " -s cpu_compatible=" . cpucompatible
If cpuspeed
options := options . " -s cpu_speed=" . cpuspeed
If cpu
options := options . " -s cpu_model=" . cpu
If fpu
options := options . " -s fpu_model=" . fpu
If cachesize
options := options . " -s cachesize=" . cachesize
If collisionlevel
options := options . " -s collision_level=" . collisionlevel
If chipmemory
options := options . " -s chipmem_size=" . chipmemory
If fastmemory
options := options . " -s fastmem_size=" . fastmemory
If autoconfigfastmemory
options := options . " -s fastmem_autoconfig=" . autoconfigfastmemory
If slowmemory
options := options . " -s bogomem_size=" . slowmemory
If z3fastmemory
options := options . " -s z3mem_size=" . z3fastmemory
If z3fastmemoryb
options := options . " -s z3mem2_size=" . z3fastmemoryb
If megachipmemory
options := options . " -s megachipmem_size=" . megachipmemory
If (SlaveFile) {
;WHDLoad Game
options := options . " -s filesystem=rw,WHD:" . """" . PathToWHDFolder . """" . " -s filesystem=ro,Games:" . """" . romPath . "\" . romName . romExtension . """"
Else If (gameDrive) {
;HDD Game
options := options . " " . wbDrive . " " . gameDrive
} Else If romExtension in .cue,.iso
;Amiga CD game
options := options . " " . wbDrive . " -cdimage=" . """" . romPath . "\" . romName . romExtension . """" . " -s win32.map_cd_drives=true -s scsi=true"
} Else {
;Floppy Game
;MultiDisk loading, this will load the first 2 disks into drives 0 and 1 since some games can read from both drives and therefore
;the user won't need to change disks through the MG menu. We can have up to 4 drives, but most of the games will only support 2 drives
;so disks are only loaded into the first 2 for better compatibility. Remaining drives will be loaded into quick disk slots.
romCount = % romTable.MaxIndex()
If romName contains (Disk 1)
;If the user boots any disk rather than the first one, multi disk support must be done through HyperLaunch MG menu
If romCount > 1
options := options . " -s nr_floppies=2"
mgoptions := " -s floppy1=" . """" . romTable[2,1] . """"
options := options . " " . floppyspeed . " -s floppy0=" . """" . romPath . "\" . romName . romExtension . """" . mgoptions
If romCount > 1
;DiskSwapper
;diskswapper := " -diskswapper "
Loop % romTable.MaxIndex() ; loop each item in our array
;diskswapper := diskswapper . """" . romTable[A_Index,1] . ""","
diskswapper := diskswapper . " -s diskimage" . (A_Index-1) . "=" . """" . romTable[A_Index,1] . """"
options := options . diskswapper
param1 := "-f " . """" . EmuPath . "\Configurations\" . configFile . """" . " " . quickcfg
param2 := "-s use_gui=no -s gfx_fullscreen_amiga=" . fs
param3 := options
;MsgBox, %param1% %param2% %param3%
;ExitApp
;disableActivateBlackScreen = true
HideEmuStart()
Run(Executable . A_Space . param1 . A_Space . param2 . A_Space . param3 . A_Space . " -portable", emuPath)
WinWait("ahk_class " . windowClass)
WinWaitActive("ahk_class " . windowClass)
If bezelPath
Control, Hide, , ahk_class msctls_statusbar32, ahk_class %windowClass% ;Hide status bar (Doesn't seem to work...)
BezelDraw()
HideEmuEnd()
FadeInExit()
Process("WaitClose",executable)
7zCleanUp()
BezelExit()
FadeOutExit()
ExitModule()
MultiGame:
If currentButton = 10
diskslot = 0
Else If currentButton > 10
diskslot := currentButton - 10
Else
Send, {End Down}{Shift Down}%diskslot%{Shift Up}{End Up}
Else
Send, {End Down}%diskslot%{End Up}
Return
CloseProcess:
If (SlaveFile) {
;Copy default-user-startup to user-startup if file exists
IfExist, %PathToWHDFolder%\S\default-user-startup
FileCopy,%PathToWHDFolder%\S\default-user-startup, %PathToWHDFolder%\S\user-startup, 1
FadeOutStart()
WinClose, ahk_class %windowClass%
Return
Hi,
That error is because you did not have the most up to date HyperLaunch.
The bezel function is in the newer versions.
Check the RLauncher.com site for instructions how to update.
Thanks,
Ron
