Help adding new system to wheel
thegh0st81
Brand new HS user here so please bear with me.  I have set up a few systems that are already on the wheel with hypersync (NES, SNES, MAME, Genesis).  I'd like to add one that isn't on there already and theme it up.  I can't quite figure it out.  I can add, for example, Atari Jaguar but there's no theme or anything.
Can somebody guide me through setting up Jaguar and setting it up with a theme and stuff with hypersync?  Once I know how to do that, I should be able to add any other ones I want on my own.
Thanks
Ok so I've been able to add it to the wheel, but when I go into hypersync and select Jaguar on the left and press set, when I go to sync it doesn't show up in the systems.  Suggestions?
Do you see at the game list, game names?
did you select under, sync on?
dit you select on the tab where you can set box art and others to the richt(check if its blue)
sorry for my very bad english.
On the left of Hypersync configuration window, you have a list of systems Hypersync supports.
In HyperHQ use the wizard to add a new wheel and name it, for instance "Jaguar".
In Hypersync select Atari Jaguar on the left, and then clic on the Jaguar wheel to link it and click on "set", and then "Update database" in the lower left corner of the window. It'll populate the database with games. Make sure "sync" is on, and also that  in the different tabs, you'rve set videos, artworks etc to "on" as well.
