How to remove Rom name from Hyperspin
magus90
Go into HyperHQ, select the wheel for whatever system, then click on navigation/themes tab. On the left side it says remove wheel info...that's the one. Textfield info is all the stuff after the rom name, ex. (USA) etc. Check out Simply Austin on YouTube, his vids will help you a lot!
Try going into your settings folder and right click on system of your choice and select edit. When this opens, look down under [navigation] and where it says remove_info_wheel= you want it to be true.
