Is there any way I can get Fade to start faster?
esoteric
Fade is part of RocketLauncher, rlauncher.com would probably be the best place to ask this question.
BTW - I didn't realize that we had a HyperSpin sub-reddit. Just sub'd.
Fade is also part of HL2 thats the main reason i never moved away from HL2 works flawless, also with button setup images, you can set it to fade into the image and after a keypress it will fade into the game, otherwise it will just fade in and out
I probably should switch back over to HL2, I just worry it's going to be a headache reconfiguring everything especially since I have the new beta running smoothly now. I'll look and see if what you're talking about is applicable to rocketlauncher/HL3beta Sub-Zero, thanks. Also thanks for subscribing Dazz!
