newoski Posted April 28, 2015 Posted April 28, 2015 Hi Guys, I'm pulling my hair out trying to compile HBMAMEUI with nonag/whitebox removal. I grabbed the source from github, but everytime I try to apply the hi_160.diff I get the following errors: C:\buildtools\src>cmd.exe Microsoft Windows [Version 6.1.7601] Copyright © 2009 Microsoft Corporation. All rights reserved. C:\buildtools\src>patchmame hi_160 C:\buildtools\src>set path=c:\mingw\mingw64-w64\bin C:\buildtools\src>patch -p0 -E 0<hi_160.diff can't find file to patch at input line 4 Perhaps you used the wrong -p or --strip option? The text leading up to this was: -------------------------- |diff -Nru old/emu/emu.mak src/emu/emu.mak |--- old/emu/emu.mak 2015-03-25 08:16:52.000000000 -0500 |+++ src/emu/emu.mak 2015-03-25 11:50:02.000000000 -0500 -------------------------- File to patch: Any help would be extremely appreciated!
justice999 Posted April 28, 2015 Posted April 28, 2015 hello newoski. I had the same problem, I dont know how to compile it correctly. I asked to the creator of HBMame on PD forum to release proper source, and he answered: why you want nonag? He can't understand that people want to use this system without boring messages. I'm using MAMEUIFX 0.160 with the last HBMAME set and it works well but I haven't tried all games. You should try it. Otherwise i'm using custom wheels (check my folder), did you manage to rename MAME wheels for this set? Thanks.
newoski Posted April 28, 2015 Author Posted April 28, 2015 MAMEUIFX doesn't work. It supports the games it knows -- which is why some work -- but for example, abortman does not work
justice999 Posted April 28, 2015 Posted April 28, 2015 MAMEUIFX doesn't work. It supports the games it knows -- which is why some work -- but for example, abortman does not work Ok thanks. So we need help
