Traeyu Posted April 29, 2015 Posted April 29, 2015 Up until recently I have had Xpadder working perfectly with Hyperspin/Hyperlaunch and emulators. But now when I start up a game it closes, cant find profiles, and doesn't open back up. I don't remember touching anything that would effect this but I can't find any answers online. I also have a batch file to load 4 profiles on the load of Hyperspin using "Startup Program". This is what the log shows: Keymapper - Loading xpadder RunKeymapper - Started, using method "load" GetJoystickArray - Started GetJoystickArray - Joysticks Detected: 0000000000000000 GetJoystickArray - Ended RunKeymapper - Looping through controllers to find xpadder profiles for each one RunXpadder - Started Process - Exist JoyToKey.exe RunXpadder - Closing xpadder to refresh controllers seen by xpadder Run - Running: F:\HyperSpin\Utilities\Xpadder\Xpadder.exe /C Run - "Xpadder.exe /C" Process ID: 4892 RunXpadder - Creating an array of connected controllers and profiles to arrange according to the order found in F:\HyperSpin\Utilities\Xpadder\xpadder.ini Process - WaitClose Xpadder.exe 2 RunXpadder - Reading the order in F:\HyperSpin\Utilities\Xpadder\xpadder.ini and arranging profiles found to match that order RunXpadder - No more controllers to be found RunXpadder - No profiles found and nothing to tell Xpadder to load RunXpadder - Ended RunKeymapper - Ended Heres the full log: [code] 12:30:47:395 | HL | INFO | +N/A | Main - HyperLaunch v3.1.0.5b BETA (www.hyperlaunch.net) 12:30:47:395 | HL | WARNING | +0 | Main - You have "Logging_Log_Command_Window" enabled. This is only for logging errors being dumped to the command window from an executable. This may cause issues with running some executables and needs to be turned off when you are done. 12:30:47:623 | HL | INFO | +218 | Main - System Specs: HyperLaunch Dir: F:\HyperSpin\HyperLaunch HyperLaunch is: 32-bit OS: Microsoft Windows 7 Home Premium SKU: Total Memory: 12172.60 MB Free Memory: 8151.11 MB Used Memory: 4021.488 MB SystemType: 64-bit Physical Processors: See Logical in XP Logical Processors: 1 GPU 1 Name: NVIDIA GeForce GTX 770 GPU 1 RAM: -2048.00 MB GPU 1 Driver Version: 9.18.13.5012 GPU 2 Name: Intel(R) HD Graphics 4000 GPU 2 RAM: -1984.00 MB GPU 2 Driver Version: 10.18.10.4061 Sound 1 Device: Microsoft LifeCam HD-6000. Sound 1 Status: Enabled Sound 2 Device: NVIDIA High Definition Audio Sound 2 Status: Enabled Sound 3 Device: NVIDIA Virtual Audio Device (Wave Extensible) (WDM) Sound 3 Status: Enabled Sound 4 Device: Realtek High Definition Audio Sound 4 Status: Enabled Sound 5 Device: Intel(R) Display Audio Sound 5 Status: Enabled OS Language: English_United_States OS Admin Status: Yes Monitor #1 (\\.\DISPLAY1): 3840x1080 (3840x1080 work) Monitor #2 (\\.\DISPLAY2): 1920x1080 (1920x1040 work) Monitor #1 Orientation: Landscape Current AHK Desktop Width: 1920 Current AHK Desktop Height: 1080 AutoHotkey Path: C:\Program Files (x86)\AutoHotkey\AutoHotkey.exe AHK Version: 1.1.09.04 Unicode: No 12:30:47:623 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\HyperLaunch.exe exists 12:30:47:623 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription Your favorite Front End companion! Visit us @ www.hyperlaunch.net FileVersion 3.1.0.5 LegalCopyright ©2014 HyperLaunch ProductName djvj's one swell guy! ProductVersion 1.1.9.4 CompanyName HyperLaunch BETA File Size: 971264 bytes Created: 3/20/2015 - 11:06:10 PM Modified: 3/17/2015 - 10:23:59 PM 12:30:47:623 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Module Extensions\dxwnd\dxwnd.ini exists 12:30:47:630 | HL | DEBUG1 | +16 | CheckFile - Attributes: File Size: 409 bytes Created: 3/20/2015 - 11:06:17 PM Modified: 2/25/2015 - 11:48:52 AM 12:30:47:633 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Module Extensions\dxwnd\dxwnd.exe exists 12:30:47:650 | HL | DEBUG1 | +15 | CheckFile - Attributes: FileDescription DxWnd MFC application FileVersion 1, 0, 0, 1 InternalName DxWnd LegalCopyright Copyright (C) 2004/2012 OriginalFilename DxWnd.exe ProductName DxWnd application ProductVersion 1, 0, 0, 1 File Size: 539136 bytes Created: 3/20/2015 - 11:06:17 PM Modified: 2/25/2015 - 11:48:52 AM 12:30:47:650 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Module Extensions\BinHexRW.ahk exists 12:30:47:668 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 12:30:47:668 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 4961 bytes Created: 3/20/2015 - 11:06:16 PM Modified: 2/25/2015 - 11:48:52 AM 12:30:47:670 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Module Extensions\BlockInput.exe exists 12:30:47:688 | HL | DEBUG1 | +15 | CheckFile - Attributes: FileDescription FileVersion 1.1.09.04 InternalName OriginalFilename ProductName ProductVersion 1.1.09.04 File Size: 657920 bytes Created: 3/20/2015 - 11:06:16 PM Modified: 2/25/2015 - 11:48:52 AM 12:30:47:688 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Module Extensions\CLR.ahk exists 12:30:47:705 | HL | DEBUG1 | +32 | CRC Check - CRC matches, this is an official unedited Extension. 12:30:47:705 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 10586 bytes Created: 3/20/2015 - 11:06:16 PM Modified: 2/25/2015 - 11:48:52 AM 12:30:47:705 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Module Extensions\COM.ahk exists 12:30:47:713 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 12:30:47:715 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 26342 bytes Created: 3/20/2015 - 11:06:16 PM Modified: 2/25/2015 - 11:48:52 AM 12:30:47:715 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Module Extensions\Control_AniGif.ahk exists 12:30:47:725 | HL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Extension. 12:30:47:728 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 5716 bytes Created: 3/20/2015 - 11:06:16 PM Modified: 2/25/2015 - 11:48:52 AM 12:30:47:728 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Module Extensions\dxwnd\dxwnd.ini exists 12:30:47:728 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 409 bytes Created: 3/20/2015 - 11:06:17 PM Modified: 2/25/2015 - 11:48:52 AM 12:30:47:728 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Module Extensions\dxwnd\dxwnd.exe exists 12:30:47:728 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription DxWnd MFC application FileVersion 1, 0, 0, 1 InternalName DxWnd LegalCopyright Copyright (C) 2004/2012 OriginalFilename DxWnd.exe ProductName DxWnd application ProductVersion 1, 0, 0, 1 File Size: 539136 bytes Created: 3/20/2015 - 11:06:17 PM Modified: 2/25/2015 - 11:48:52 AM 12:30:47:728 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Module Extensions\gdip.ahk exists 12:30:47:745 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Extension. 12:30:47:745 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 88789 bytes Created: 3/20/2015 - 11:06:16 PM Modified: 2/25/2015 - 11:48:52 AM 12:30:47:745 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Module Extensions\gdip_alt.ahk exists 12:30:47:763 | HL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library. 12:30:47:763 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 3394 bytes Created: 3/20/2015 - 11:06:16 PM Modified: 2/25/2015 - 11:48:52 AM 12:30:47:765 | HL | DEBUG1 | +0 | gdip_alt.ahk Version: 1.0.1 12:30:47:765 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Module Extensions\gsdll32.dll exists 12:30:47:793 | HL | DEBUG1 | +32 | CheckFile - Attributes: File Size: 13090816 bytes Created: 3/20/2015 - 11:06:16 PM Modified: 2/25/2015 - 11:48:52 AM 12:30:47:793 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Module Extensions\itextsharp.dll exists 12:30:47:810 | HL | DEBUG1 | +15 | CheckFile - Attributes: FileDescription iTextSharp FileVersion 5.4.2.0 InternalName itextsharp.dll LegalCopyright Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved. OriginalFilename itextsharp.dll ProductName iTextSharp ProductVersion 5.4.2.0 CompanyName 1T3XT BVBA File Size: 3743744 bytes Created: 3/20/2015 - 11:06:16 PM Modified: 2/25/2015 - 11:48:52 AM 12:30:47:810 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Module Extensions\Java.ahk exists 12:30:47:828 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 12:30:47:830 | HL | DEBUG1 | +15 | CheckFile - Attributes: File Size: 7841 bytes Created: 3/20/2015 - 11:06:16 PM Modified: 2/25/2015 - 11:48:52 AM 12:30:47:830 | HL | DEBUG1 | +0 | Java.ahk Version: 1.0.0 12:30:47:830 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Module Extensions\JSON.ahk exists 12:30:47:843 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 12:30:47:843 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 9203 bytes Created: 3/20/2015 - 11:06:16 PM Modified: 2/25/2015 - 11:48:52 AM 12:30:47:843 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Module Extensions\Origin.ahk exists 12:30:47:851 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 12:30:47:851 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 4901 bytes Created: 3/20/2015 - 11:06:16 PM Modified: 3/17/2015 - 10:23:59 PM 12:30:47:851 | HL | DEBUG1 | +0 | Origin.ahk Version: 1.0.1 12:30:47:851 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Module Extensions\PacDrive32.dll exists 12:30:47:858 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 69120 bytes Created: 3/20/2015 - 11:06:16 PM Modified: 2/25/2015 - 11:48:52 AM 12:30:47:858 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Module Extensions\RegRW64.ahk exists 12:30:47:876 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Extension. 12:30:47:876 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 6915 bytes Created: 3/20/2015 - 11:06:16 PM Modified: 2/25/2015 - 11:48:52 AM 12:30:47:876 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Module Extensions\RIni.ahk exists 12:30:47:881 | HL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Extension. 12:30:47:881 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 67561 bytes Created: 3/20/2015 - 11:06:16 PM Modified: 2/25/2015 - 11:48:52 AM 12:30:47:881 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Module Extensions\SevenZipSharp.dll exists 12:30:47:896 | HL | DEBUG1 | +16 | CheckFile - Attributes: FileDescription SevenZipSharp FileVersion 0.64.4841.31212 InternalName SevenZipSharp.dll LegalCopyright Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3 OriginalFilename SevenZipSharp.dll ProductName SevenZipSharp ProductVersion 0.64.4841.31212 CompanyName Markovtsev Vadim File Size: 165888 bytes Created: 3/20/2015 - 11:06:16 PM Modified: 2/25/2015 - 11:48:52 AM 12:30:47:896 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Module Extensions\Steam.ahk exists 12:30:47:903 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 12:30:47:906 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 5344 bytes Created: 3/20/2015 - 11:06:17 PM Modified: 3/17/2015 - 10:23:59 PM 12:30:47:906 | HL | DEBUG1 | +0 | Steam.ahk Version: 1.0.1 12:30:47:906 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Module Extensions\VA.ahk exists 12:30:47:921 | HL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Extension. 12:30:47:921 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 34688 bytes Created: 3/20/2015 - 11:06:17 PM Modified: 2/25/2015 - 11:48:52 AM 12:30:47:921 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Module Extensions\VA_Extension.ahk exists 12:30:47:928 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 12:30:47:931 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 3833 bytes Created: 3/20/2015 - 11:06:17 PM Modified: 2/25/2015 - 11:48:52 AM 12:30:47:931 | HL | DEBUG1 | +0 | VA_Extension.ahk Version: 1.0.1 12:30:47:931 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Lib\Bezel.ahk exists 12:30:48:005 | HL | DEBUG1 | +78 | CRC Check - CRC matches, this is an official unedited Library. 12:30:48:007 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 101738 bytes Created: 3/20/2015 - 11:06:12 PM Modified: 2/25/2015 - 11:48:51 AM 12:30:48:007 | HL | DEBUG1 | +0 | Bezel.ahk Version: 1.0.9 12:30:48:007 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Lib\Fade.ahk exists 12:30:48:015 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 12:30:48:015 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 36402 bytes Created: 3/20/2015 - 11:06:12 PM Modified: 2/25/2015 - 11:48:51 AM 12:30:48:015 | HL | DEBUG1 | +0 | Fade.ahk Version: 1.0.9 12:30:48:015 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Lib\Fade Init.ahk exists 12:30:48:035 | HL | DEBUG1 | +31 | CRC Check - CRC matches, this is an official unedited Library. 12:30:48:037 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 999 bytes Created: 3/20/2015 - 11:06:12 PM Modified: 2/25/2015 - 11:48:51 AM 12:30:48:037 | HL | DEBUG1 | +0 | Fade Init.ahk Version: 1.0.1 12:30:48:037 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Lib\Fade Animations.ahk exists 12:30:48:040 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 12:30:48:040 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 67602 bytes Created: 3/20/2015 - 11:06:12 PM Modified: 2/25/2015 - 11:48:51 AM 12:30:48:040 | HL | DEBUG1 | +0 | Fade Animations.ahk Version: 1.1.1 12:30:48:040 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Lib\HyperPause.ahk exists 12:30:48:067 | HL | DEBUG1 | +31 | CRC Check - CRC matches, this is an official unedited Library. 12:30:48:067 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 392193 bytes Created: 3/20/2015 - 11:06:12 PM Modified: 2/25/2015 - 11:48:51 AM 12:30:48:067 | HL | DEBUG1 | +0 | HyperPause.ahk Version: 1.0.8 12:30:48:070 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Lib\HyperPause Init.ahk exists 12:30:48:070 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 12:30:48:070 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 537 bytes Created: 3/20/2015 - 11:06:12 PM Modified: 2/25/2015 - 11:48:51 AM 12:30:48:070 | HL | DEBUG1 | +0 | HyperPause Init.ahk Version: 1.0.1 12:30:48:070 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Lib\Keymapper.ahk exists 12:30:48:080 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 12:30:48:080 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 32953 bytes Created: 3/20/2015 - 11:06:12 PM Modified: 2/25/2015 - 11:48:51 AM 12:30:48:080 | HL | DEBUG1 | +0 | Keymapper.ahk Version: 1.0.9 12:30:48:082 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Lib\Keymapper Init.ahk exists 12:30:48:098 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 12:30:48:099 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 3435 bytes Created: 3/20/2015 - 11:06:12 PM Modified: 2/25/2015 - 11:48:51 AM 12:30:48:099 | HL | DEBUG1 | +0 | Keymapper Init.ahk Version: 1.0.2 12:30:48:099 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Lib\MultiGame.ahk exists 12:30:48:113 | HL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library. 12:30:48:116 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 40584 bytes Created: 3/20/2015 - 11:06:12 PM Modified: 2/25/2015 - 11:48:51 AM 12:30:48:116 | HL | DEBUG1 | +0 | MultiGame.ahk Version: 1.0.6 12:30:48:116 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Lib\MultiGame Init.ahk exists 12:30:48:116 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 12:30:48:116 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 161 bytes Created: 3/20/2015 - 11:06:12 PM Modified: 2/25/2015 - 11:48:51 AM 12:30:48:116 | HL | DEBUG1 | +0 | MultiGame Init.ahk Version: 1.0.0 12:30:48:118 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Lib\MultiPlayer.ahk exists 12:30:48:118 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 12:30:48:121 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 58605 bytes Created: 3/20/2015 - 11:06:12 PM Modified: 2/25/2015 - 11:48:51 AM 12:30:48:121 | HL | DEBUG1 | +0 | MultiPlayer.ahk Version: 1.0.4 12:30:48:121 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Lib\Password.ahk exists 12:30:48:128 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 12:30:48:131 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 10035 bytes Created: 3/20/2015 - 11:06:12 PM Modified: 2/25/2015 - 11:48:51 AM 12:30:48:131 | HL | DEBUG1 | +0 | Password.ahk Version: 1.0.0 12:30:48:131 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Lib\Rom Mapping Launch Menu.ahk exists 12:30:48:133 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 12:30:48:136 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 73560 bytes Created: 3/20/2015 - 11:06:12 PM Modified: 2/25/2015 - 11:48:51 AM 12:30:48:136 | HL | DEBUG1 | +0 | Rom Mapping Launch Menu.ahk Version: 1.0.3 12:30:48:136 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Lib\Shared.ahk exists 12:30:48:148 | HL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library. 12:30:48:148 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 145962 bytes Created: 3/20/2015 - 11:06:12 PM Modified: 3/17/2015 - 10:23:59 PM 12:30:48:148 | HL | DEBUG1 | +0 | Shared.ahk Version: 1.2.3 12:30:48:151 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Lib\Statistics.ahk exists 12:30:48:163 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 12:30:48:163 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 26170 bytes Created: 3/20/2015 - 11:06:12 PM Modified: 2/25/2015 - 11:48:51 AM 12:30:48:163 | HL | DEBUG1 | +0 | Statistics.ahk Version: 1.0.2 12:30:48:163 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Lib\Statistics Init.ahk exists 12:30:48:166 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 12:30:48:166 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 33 bytes Created: 3/20/2015 - 11:06:12 PM Modified: 2/25/2015 - 11:48:51 AM 12:30:48:166 | HL | DEBUG1 | +0 | Statistics Init.ahk Version: 1.0.1 12:30:48:166 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Lib\XHotkey.ahk exists 12:30:48:168 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 12:30:48:168 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 29623 bytes Created: 3/20/2015 - 11:06:12 PM Modified: 2/25/2015 - 11:48:51 AM 12:30:48:168 | HL | DEBUG1 | +0 | XHotkey.ahk Version: 1.0.2 12:30:48:168 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Lib\XHotkey Init.ahk exists 12:30:48:181 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 12:30:48:183 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 1236 bytes Created: 3/20/2015 - 11:06:12 PM Modified: 2/25/2015 - 11:48:51 AM 12:30:48:183 | HL | DEBUG1 | +0 | XHotkey Init.ahk Version: 1.0.0 12:30:48:183 | HL | DEBUG1 | +0 | Main - Raw CLI received: "Super Nintendo Entertainment System ActRaiser 2 (USA)" 12:30:48:183 | HL | DEBUG1 | +0 | Main - Received this dbName with no path via CLI: "ActRaiser 2 (USA)" 12:30:48:183 | HL | DEBUG1 | +0 | Main - dbName: ActRaiser 2 (USA) 12:30:48:183 | HL | WARNING | +0 | Main - No frontendPath was sent via CLI. Defaulting to use HyperSpin in "..\HyperSpin.exe". If you want to use a different FE Path, please make sure you set up your Front End so it sends this parameter to HyperLaunch: "-f <PATH_TO_MY_FE\FRONTEND.exe>" 12:30:48:188 | HL | INFO | +0 | Main - HyperSpin.exe coordinates are x0 y0 w1920 h1080 12:30:48:188 | HL | WARNING | +0 | Main - Front End plugin was not sent via CLI. Defaulting to the "HyperSpin" Plugin. If you want to load a different Front End Plugin, please make sure you set up your Front End so it sends this parameter to HyperLaunch: "-p <PLUGINTYPE>" 12:30:48:188 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Plugins\HyperSpin.plugin exists 12:30:48:213 | HL | DEBUG1 | +31 | CheckFile - Attributes: File Size: 8999 bytes Created: 3/20/2015 - 11:06:19 PM Modified: 2/25/2015 - 11:48:52 AM 12:30:48:213 | HL | INFO | +0 | Main - HyperLaunch received "Super Nintendo Entertainment System" and "ActRaiser 2 (USA)" 12:30:48:307 | HL | INFO | +93 | Main - ActRaiser 2 (USA) is using the default emulator: Snes9x 12:30:48:307 | HL | INFO | +0 | Main - Checking for a [Snes9x] section in F:\HyperSpin\HyperLaunch\Settings\Super Nintendo Entertainment System\Emulators.ini 12:30:48:308 | HL | INFO | +0 | Main - Checking for a [Snes9x] section in F:\HyperSpin\HyperLaunch\Settings\Global Emulators.ini 12:30:48:309 | HL | INFO | +0 | Main - Found [Snes9x] in F:\HyperSpin\HyperLaunch\Settings\Global Emulators.ini 12:30:48:319 | HL | INFO | +16 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Modules\Snes9x\Snes9x.ahk exists 12:30:48:346 | HL | DEBUG1 | +31 | CheckFile - Attributes: File Size: 2834 bytes Created: 3/20/2015 - 11:06:19 PM Modified: 2/25/2015 - 11:48:52 AM 12:30:48:347 | HL | INFO | +0 | Main - CRC Check - CRC matches, this is an official unedited module. 12:30:48:347 | HL | INFO | +0 | Main - ActRaiser 2 (USA) will use module: F:\HyperSpin\HyperLaunch\Modules\Snes9x\Snes9x.ahk 12:30:48:358 | HL | INFO | +0 | Main - Did not find a "F:\HyperSpin\HyperLaunch\Settings\Super Nintendo Entertainment System\Game Options.ini" file, skipping any game-specific options. 12:30:48:358 | HL | INFO | +0 | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks. 12:30:48:361 | HL | INFO | +16 | CheckFile - Checking if F:\HyperSpin\Emulators\Super Nintendo Entertainment System\Snes9x\snes9x-x64.exe exists 12:30:48:458 | HL | DEBUG1 | +93 | CheckFile - Attributes: FileDescription Snes9X FileVersion 1.53 InternalName Snes9X LegalCopyright Copyright 1996-2011 OriginalFilename Snes9X.exe ProductName Snes9X SNES Emulator ProductVersion 1.53 CompanyName http://www.snes9x.com File Size: 4608000 bytes Created: 4/18/2015 - 12:10:32 PM Modified: 4/2/2015 - 8:45:46 PM 12:30:48:458 | HL | INFO | +0 | Main - INI Keys read 12:30:48:458 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Module Extensions\7z.exe exists 12:30:48:471 | HL | DEBUG1 | +16 | CheckFile - Attributes: FileDescription 7-Zip Console FileVersion 9.20 InternalName 7z LegalCopyright Copyright (c) 1999-2010 Igor Pavlov OriginalFilename 7z.exe ProductName 7-Zip ProductVersion 9.20 CompanyName Igor Pavlov File Size: 163840 bytes Created: 3/20/2015 - 11:06:16 PM Modified: 2/25/2015 - 11:48:52 AM 12:30:48:471 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Module Extensions\7z.dll exists 12:30:48:488 | HL | DEBUG1 | +16 | CheckFile - Attributes: FileDescription 7z Standalone Plugin FileVersion 9.20 InternalName 7za LegalCopyright Copyright (c) 1999-2010 Igor Pavlov OriginalFilename 7za.dll ProductName 7-Zip ProductVersion 9.20 CompanyName Igor Pavlov File Size: 914432 bytes Created: 3/20/2015 - 11:06:16 PM Modified: 2/25/2015 - 11:48:52 AM 12:30:48:488 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\Module Extensions\FontReg.exe exists 12:30:48:503 | HL | DEBUG1 | +15 | CheckFile - Attributes: FileDescription Font Registration Utility (x86-32) FileVersion 2.1.3.0 OriginalFilename FontReg.exe File Size: 6144 bytes Created: 3/20/2015 - 11:06:16 PM Modified: 2/25/2015 - 11:48:52 AM 12:30:48:561 | HL | INFO | +47 | Main - "ActRaiser 2 (USA)" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side 12:30:48:561 | HL | INFO | +0 | CheckPaths - Started 12:30:48:563 | HL | DEBUG1 | +16 | CheckPaths - Looking for rom: F:\HyperSpin\Emulators\Super Nintendo Entertainment System\roms\ActRaiser 2 (USA).7z 12:30:48:613 | HL | DEBUG1 | +46 | CheckPaths - Looking for rom by name in subfolder: F:\HyperSpin\Emulators\Super Nintendo Entertainment System\roms\ActRaiser 2 (USA)\ActRaiser 2 (USA).7z 12:30:48:613 | HL | DEBUG1 | +0 | CheckPaths - Rom not found 12:30:48:613 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom: F:\HyperSpin\Emulators\Super Nintendo Entertainment System\roms\ActRaiser 2 (USA).zip 12:30:48:643 | HL | INFO | +32 | CheckPaths - Found rom: F:\HyperSpin\Emulators\Super Nintendo Entertainment System\roms\ActRaiser 2 (USA).zip 12:30:48:643 | HL | DEBUG1 | +0 | CheckPaths - Current romName: ActRaiser 2 (USA) 12:30:48:643 | HL | DEBUG1 | +0 | CheckPaths - Current romPath: F:\HyperSpin\Emulators\Super Nintendo Entertainment System\roms 12:30:48:643 | HL | DEBUG1 | +0 | CheckPaths - Current romExtension: .zip 12:30:48:643 | HL | INFO | +0 | CheckPaths - Ended 12:30:48:645 | HL | INFO | +0 | BuildScript - User Variables: ;---------------------------------------------------------------------------- ; INJECTED VARIABLES ;---------------------------------------------------------------------------- #NoTrayIcon #InstallKeybdHook DetectHiddenWindows, ON SetTitleMatchMode, 2 SendMode, Event 0 = 2 pluginPath = F:\HyperSpin\HyperLaunch\Plugins pluginName = HyperSpin pluginExt = .plugin contextOnExit = hlMode = hlTitle = HyperLaunch hlVersion = 3.1.0.5b BETA hlAuthor = djvj hlURL = www.hyperlaunch.net langFile = F:\HyperSpin\HyperLaunch\Data\Language\Localization.ini frontendPID = 5540 frontendPath = F:\HyperSpin frontendExe = HyperSpin.exe frontendExt = exe frontendName = HyperSpin frontendDrive = F: exitEmulatorKey = H1500:Esc|H1500:1joy7&1joy8|H1500:2joy7&2joy8|H1500:3joy7&3joy8|H1500:4joy7&4joy8 exitEmulatorKeyWait = forceHoldKey = restoreFE = Restore and Click exitScriptKey = ~q & ~s toggleCursorKey = ~e & ~t emuFullPath = F:\HyperSpin\Emulators\Super Nintendo Entertainment System\Snes9x\snes9x-x64.exe emuPath = F:\HyperSpin\Emulators\Super Nintendo Entertainment System\Snes9x emuName = Snes9x emuExt = exe romPath = F:\HyperSpin\Emulators\Super Nintendo Entertainment System\roms romPathFromIni = F:\HyperSpin\Emulators\Super Nintendo Entertainment System\roms romExtension = .zip romExtensionOrig = .zip romExtensions = 7z|zip|sfc|smc executable = snes9x-x64.exe systemName = Super Nintendo Entertainment System dbPath = dbName = ActRaiser 2 (USA) dbExt = romName = ActRaiser 2 (USA) romMapPath = romMappingEnabled = false romMappingLaunchMenuEnabled = false romMappingFirstMatchingExt = false romMappingShowAllRomsInArchive = true romMappingNumberOfGamesByScreen = 7 romMappingMenuWidth = 400 romMappingMenuMargin = 65 romMappingTextFont = Bebas Neue romMappingTextOptions = cFFFFFFFF r4 s60 Bold romMappingDisabledTextColor = ff888888 romMappingTextSizeDifference = 7 romMappingTextMargin = 15 romMappingTitleTextFont = Bebas Neue romMappingTitleTextOptions = cFFFFFFFF r4 s90 Bold romMappingTitle2TextFont = Bebas Neue romMappingTitle2TextOptions = cFFFFFFFF r4 s22 Bold romMappingGameInfoTextFont = Bebas Neue romMappingGameInfoTextOptions = cFFFFFFFF r4 s22 Regular romMappingBackgroundBrush = aa000000 romMappingColumnBrush = 33000000 romMappingButtonBrush1 = 6f000000 romMappingButtonBrush2 = 33000000 romMappingBackgroundAlign = Stretch and Lose Aspect romMappingMenuFlagWidth = 55 romMappingMenuFlagSeparation = 7 romMappingDefaultMenuList = FullList romMappingSingleFilteredRomAutomaticLaunch = false altArchiveNameOnly = altRomNameOnly = altArchiveAndRomName = altArchiveAndManyRomNames = altRomNamesOnly = romMapScenario = skipchecks = false romMatchExt = false blockInputTime = 0 blockInputFile = F:\HyperSpin\HyperLaunch\Module Extensions\BlockInput.exe errorLevelReporting = false lockLaunch = false lockLaunchGame = screenRotationAngle = 0 screenRotationAngleGame = logFile = F:\HyperSpin\HyperLaunch\HyperLaunch.log logLabel := [" INFO"," WARNING"," ERROR"," DEBUG1"," DEBUG2"] logLevel = 10 logShowDebugConsole = false logIncludeModule = true logIncludeFileProperties = true logShowCommandWindow = false logCommandWindow = true hlDebugConsoleStdout = sysLang = English_United_States sysType = 64-bit navUpKey = Up navDownKey = Down navLeftKey = Left navRightKey = Right navSelectKey = Enter navP2UpKey = Numpad8 navP2DownKey = Numpad2 navP2LeftKey = Numpad4 navP2RightKey = Numpad6 navP2SelectKey = NumpadEnter originalWidth = 1920 originalHeight = 1080 dtEnabled = false dtPath = dtUseSCSI = true dtAddDrive = true servoStikEnabled = false ledblinkyEnabled = false ledblinkyFullPath = ledblinkyProfilePath = F:\HyperSpin\HyperLaunch\Profiles\LEDBlinky ledblinkyHLProfile = F:\HyperSpin\HyperLaunch\Profiles\LEDBlinky\HyperLaunch emuIdleShutdown = 0 launchPasswordHash = UpUpDownDownLeftRightLeftRight hideCursor = false hideEmu = false hideFE = false fadeIn = false fadeInDuration = 500 fadeInTransitionAnimation = DefaultAnimateFadeIn fadeInDelay = 0 fadeInExitDelay = 0 fadeOutExitDelay = 0 fadeOut = false fadeOutExtraScreen = false fadeOutDuration = 500 fadeOutTransitionAnimation = DefaultAnimateFadeOut fadeOutDelay = 0 fadeLyrInterpolation = 7 fadeMuteEmulator = false fadeUseBackgrounds = false fadeWidthBaseRes = 1920 fadeHeightBaseRes = 1080 fadeLyr1Color = FF000000 fadeLyr1AlignImage = Stretch and Lose Aspect fadeLyr2Pos = Stretch and Lose Aspect fadeLyr2X = 0 fadeLyr2Y = 0 fadeLyr2W = fadeLyr2H = fadeLyr2Adjust = 1 fadeLyr2PicPad = 0 fadeLyr2Prefix = Extra Layer 1 - Console fadeLyr3Pos = Center fadeLyr3X = 450 fadeLyr3Y = 450 fadeLyr3W = fadeLyr3H = fadeLyr3Adjust = 1 fadeLyr3PicPad = 0 fadeLyr3Speed = 750 fadeLyr3Animation = DefaultFadeAnimation fadeLyr37zAnimation = DefaultFadeAnimation fadeLyr3Type = imageandbar fadeLyr3ImgFollow7zProgress = true fadeLyr3Repeat = 1 fadeLyr3BackImageTransparency = 30 fadeLyr3StaticPos = No Alignment fadeLyr3StaticX = 0 fadeLyr3StaticY = 870|1575 fadeLyr3StaticW = fadeLyr3StaticH = fadeLyr3StaticAdjust = 1 fadeLyr3StaticPicPad = 0 fadeLyr3StaticPrefix = Info Bar fadeLyr4Adjust = 1 fadeLyr4X = 1792|952 fadeLyr4Y = 891|1596 fadeLyr4W = 128 fadeLyr4H = fadeLyr4Pos = No Alignment fadeLyr4FPS = 50 fadeLyr4PicPad = 0 fadeTranspGifColor = FFFFFF fadeBarWindow = Image fadeBarWindowX = fadeBarWindowY = fadeBarWindowW = 900 fadeBarWindowH = fadeBarWindowR = 30 fadeBarWindowM = 30 fadeBarWindowHatchStyle = 8 fadeBar = 7zOnly fadeBarNon7zProgressTime = 0 fadeBarBack = true fadeBarBackColor = FF555555 fadeBarH = 30 fadeBarR = 10 fadeBarColor = DD00BFFF fadeBarHatchStyle = 8 fadeBarPercentageText = true fadeBarInfoText = true fadeBarXOffset = 0 fadeBarYOffset = 150 fadeRomInfoDescription = filtered text fadeRomInfoSystemName = image fadeRomInfoYear = text with label fadeRomInfoManufacturer = text with label fadeRomInfoGenre = disabled fadeRomInfoRating = image fadeRomInfoOrder = Description|SystemName|Year|Manufacturer|Genre|Rating fadeRomInfoTextPlacement = User Defined fadeRomInfoTextMargin = 7 fadeRomInfoText1Options = w1600|787 h90 x165 y870|1575 cFFE1E1E1 r4 s90 Left Regular fadeRomInfoText2Options = w400 x8 y15 cFF555555 r4 s60 Bold fadeRomInfoText3Options = w310 x165 y960|1665 cFFE1E1E1 r4 s66 Left Regular fadeRomInfoText4Options = w1305|492 h66 x460 y960|1665 cFFE1E1E1 r4 s66 Left Regular fadeRomInfoText5Options = cFF555555 r4 s42 Bold fadeRomInfoText6Options = h135 x15 y885|1590 cFFCFCFCA r4 s120 Regular fadeStats_Number_of_Times_Played = text with label fadeStats_Last_Time_Played = text with label fadeStats_Average_Time_Played = text with label fadeStats_Total_Time_Played = text with label fadeStats_System_Total_Played_Time = text with label fadeStats_Total_Global_Played_Time = text with label fadeStatsInfoOrder = Number_of_Times_Played|Last_Time_Played|Average_Time_Played|Total_Time_Played|System_Total_Played_Time|Total_Global_Played_Time fadeStatsInfoTextPlacement = topRight fadeStatsInfoTextMargin = 7 fadeStatsInfoText1Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText2Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText3Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText4Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText5Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText6Options = cFFB4B4B4 r4 s22 Bold fadeText1X = 0 fadeText1Y = 0 fadeText1Options = cFFB4B4B4 r4 s30 Right Bold fadeText1 = Loading Game fadeText2X = 0 fadeText2Y = 0 fadeText2Options = cFFB4B4B4 r4 s30 Right Bold fadeText2 = Extraction Complete, Ready fadeText3 = Loading Game fadeText4 = Loading Complete fadeFont = Bebas Neue fadeSystemAndRomLayersOnly = false fadeExtractionTime = disabled fadeExtractionTimeTextX = 0 fadeExtractionTimeTextY = 0 fadeExtractionTimeTextOptions = cFF555555 r4 s20 Bold fadeInterruptKey = detectFadeErrorEnabled = true fadeImgPath = F:\HyperSpin\HyperLaunch\Media\Fade HLDataPath = F:\HyperSpin\HyperLaunch\Data HLMediaPath = F:\HyperSpin\HyperLaunch\Media HLErrSoundPath = F:\HyperSpin\HyperLaunch\Media\Sounds\Error modulesPath = F:\HyperSpin\HyperLaunch\Modules moduleFullName = F:\HyperSpin\HyperLaunch\Modules\Snes9x\Snes9x.ahk moduleName = Snes9x modulePath = F:\HyperSpin\HyperLaunch\Modules\Snes9x moduleExtension = ahk moduleExtensionsPath = F:\HyperSpin\HyperLaunch\Module Extensions libPath = F:\HyperSpin\HyperLaunch\Lib 7zEnabled = false 7zPath = F:\HyperSpin\HyperLaunch\Module Extensions\7z.exe 7zDllPath = F:\HyperSpin\HyperLaunch\Module Extensions\7z.dll 7zExtractPath = C:\Users\Garrett\AppData\Local\Temp\HS 7zExtractPathOrig = 7zAttachSystemName = false 7zDelTemp = true 7zSounds = true 7zFormats = .zip,.rar,.7z,.lzh,.gzip,.tar 7zFormatsNoP = zip,rar,7z,lzh,gzip,tar mgEnabled = false mgKey = ~NumpadSub mgBackgroundColor = FF000000 mgSidePadding = 0.2 mgWidthBaseRes = 1920 mgHeightBaseRes = 1080 mgYOffset = 500|800 mgFont = Arial mgText1Options = x10p y250|500 w80p Center cBBFFFFFF r4 s100 BoldItalic mgText1Text = Please select a game mgText2Options = w96p cFFFFFFFF r4 s50 Center BoldItalic mgText2Offset = 100 mgUseSound = true mgSoundfreq = 300 mgExitEffect = none mgSelectedEffect = rotate mgUseGameArt = false mgCandidate = mgValidTypes = (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side mgOnLaunch = false hpEnabled = false hpKey = ~NumpadAdd hpBackToMenuBarKey = X hpZoomInKey = C hpZoomOutKey = V hpScreenshotKey = ~PrintScreen hpHiToTextPath = F:\HyperSpin\HyperLaunch\Module Extensions\HiToText.exe hpSaveStateKeyCodes = {Shift down}{F1 down}{F1 up}{Shift up}|{Shift down}{F2 down}{F2 up}{Shift up}|{Shift down}{F3 down}{F3 up}{Shift up}|{Shift down}{F4 down}{F4 up}{Shift up}|{Shift down}{F5 down}{F5 up}{Shift up}|{Shift down}{F6 down}{F6 up}{Shift up}|{Shift down}{F7 down}{F7 up}{Shift up}|{Shift down}{F8 down}{F8 up}{Shift up}|{Shift down}{F9 down}{F9 up}{Shift up}|{Shift down}{F10 down}{F10 up}{Shift up} hpLoadStateKeyCodes = {F1 down}{F1 up}|{F2 down}{F2 up}|{F3 down}{F3 up}|{F4 down}{F4 up}|{F5 down}{F5 up}|{F6 down}{F6 up}|{F7 down}{F7 up}|{F8 down}{F8 up}|{F9 down}{F9 up}|{F10 down}{F10 up} keymapperEnabled = true keymapperAHKMethod = false keymapper = xpadder xpadderFullPath = F:\HyperSpin\Utilities\Xpadder\Xpadder.exe joyToKeyFullPath = F:\HyperSpin\Utilities\JoyToKey\JoyToKey.exe keymapperProfilePath = F:\HyperSpin\HyperLaunch\Profiles\xpadder keymapperFrontEndProfileName = HyperSpin keymapperFrontEndProfile = Xpadder keymapperHyperLaunchProfileEnabled = false JoyIDsEnabled = false JoyIDsPreferredControllersSystem = use_global JoyIDsPreferredControllersGlobal = Controller (XBOX One For Windows) CustomJoyNamesEnabled = false CustomJoyNames = rotateMethod = false FEProfile = F:\HyperSpin\HyperLaunch\Profiles\xpadder\HyperSpin defaultProfile = F:\HyperSpin\HyperLaunch\Profiles\xpadder\_Default systemProfile = F:\HyperSpin\HyperLaunch\Profiles\xpadder\Super Nintendo Entertainment System xPadderSystemProfile = F:\HyperSpin\HyperLaunch\Profiles\xpadder\Super Nintendo Entertainment System\_Default emuProfile = F:\HyperSpin\HyperLaunch\Profiles\xpadder\Super Nintendo Entertainment System\Snes9x romProfile = F:\HyperSpin\HyperLaunch\Profiles\xpadder\Super Nintendo Entertainment System\ActRaiser 2 (USA) HyperLaunchProfile = F:\HyperSpin\HyperLaunch\Profiles\xpadder\HyperLaunch blankProfile = F:\HyperSpin\HyperLaunch\Profiles\xpadder\_Default\blank ahkFEProfile = F:\HyperSpin\HyperLaunch\Profiles\AHK\HyperSpin ahkDefaultProfile = F:\HyperSpin\HyperLaunch\Profiles\AHK\_Default ahkSystemProfile = F:\HyperSpin\HyperLaunch\Profiles\AHK\Super Nintendo Entertainment System ahkEmuProfile = F:\HyperSpin\HyperLaunch\Profiles\AHK\Super Nintendo Entertainment System\Snes9x ahkRomProfile = F:\HyperSpin\HyperLaunch\Profiles\AHK\Super Nintendo Entertainment System\ActRaiser 2 (USA) ahkHyperLaunchProfile = F:\HyperSpin\HyperLaunch\Profiles\AHK\HyperLaunch bezelEnabled = false bezelICEnabled = false statisticsEnabled = true pressDuration = -1 emuVolume = 1 dxwndIni = F:\HyperSpin\HyperLaunch\Module Extensions\dxwnd\dxwnd.ini dxwndFullPath = F:\HyperSpin\HyperLaunch\Module Extensions\dxwnd\dxwnd.exe mon1O = 0 pacDrivedllFile = F:\HyperSpin\HyperLaunch\Module Extensions\PacDrive32.dll userFadeAnimIniFile = F:\HyperSpin\HyperLaunch\Lib\User Fade Animations.ini 12:30:48:645 | HL | INFO | +0 | BuildScript - Loaded XHotkey Init.ahk scripts 12:30:48:645 | HL | INFO | +0 | BuildScript - Loaded Keymapper Init.ahk scripts 12:30:48:645 | HL | INFO | +0 | BuildScript - Loaded Statistics Init.ahk scripts 12:30:48:645 | HL | WARNING | +0 | BuildScript - "F:\HyperSpin\HyperLaunch\Lib\User Functions Init.ahk" not found 12:30:48:645 | HL | DEBUG1 | +0 | BuildScript - Module starts on line: 2 12:30:48:645 | HL | INFO | +0 | BuildScript - Validating module 12:30:48:648 | HL | INFO | +0 | BuildScript - Validation complete 12:30:48:648 | HL | INFO | +0 | BuildScript - Module: MEmu = Snes9X MEmuV = v1.53 MURL = http://www.snes9x.com/ MAuthor = djvj MVersion = 2.0.1 MCRC = 34FD2149 iCRC = FD5A1CE MID = 635038268923820476 MSystem = "Nintendo Super Famicom","Super Nintendo Entertainment System" ;---------------------------------------------------------------------------- ; Notes: ; Fullscreen is controlled via the variable below ; snes9x adjusts the windowed resolutions in the ini automatically based on the settings you choose below. ; Bezels work, but if you notice a black bar along the bottom, change this option to false in snes9x.conf: ExtendHeight ;---------------------------------------------------------------------------- StartModule() BezelGUI() FadeInStart() settingsFile := modulePath . "\" . moduleName . ".ini" Fullscreen := IniReadCheck(settingsFile, "Settings", "Fullscreen","true",,1) EmulateFullscreen := IniReadCheck(settingsFile, "Settings", "EmulateFullscreen","true",,1) ; This helps fading look better and work better on exit. You cannot use this with a normal fullscreen so one has to be false WindowMaximized := IniReadCheck(settingsFile, "Settings", "WindowMaximized","true",,1) Stretch := IniReadCheck(settingsFile, "Settings", "Stretch","true",,1) MaintainAspectRatio := IniReadCheck(settingsFile, "Settings", "MaintainAspectRatio","true",,1) HideMenu := IniReadCheck(settingsFile, "Settings", "HideMenu","true",,1) FullScreenWidth := IniReadCheck(settingsFile, "Settings", "FullScreenWidth","1024",,1) FullScreenHeight := IniReadCheck(settingsFile, "Settings", "FullScreenHeight","768",,1) snes9xConf := CheckFile(emuPath . "\snes9x.conf") BezelStart() ; Now let's update all our keys if they differ in the ini iniLookup = ( ltrim c Display\Win, Fullscreen:Enabled, %Fullscreen% Display\Win, Fullscreen:EmulateFullscreen, %EmulateFullscreen% Display\Win, Window:Maximized, %WindowMaximized% Display\Win, Stretch:Enabled, %Stretch% Display\Win, Stretch:MaintainAspectRatio, %MaintainAspectRatio% Display\Win, Fullscreen:Width, %FullScreenWidth% Display\Win, Fullscreen:Height, %FullScreenHeight% Display\Win, HideMenu, %HideMenu% ) Loop, Parse, iniLookup, `n { StringSplit, split, A_LoopField, `,, %A_Space%%A_Tab% IniRead, tempVar, %snes9xConf%, %split1%, %split2% If ( tempVar != split3 ) IniWrite, % split3, %snes9xConf%, %split1%, %split2% } 7z(romPath, romName, romExtension, 7zExtractPath) Run(executable . " """ . romPath . "\" . romName . romExtension . """", emuPath) WinWait("Snes9X ahk_class Snes9X: WndClass") WinWaitActive("Snes9X ahk_class Snes9X: WndClass") BezelDraw() FadeInExit() Process("WaitClose", executable) BezelExit() 7zCleanUp() FadeOutExit() ExitModule() CloseProcess: FadeOutStart() WinClose("Snes9X ahk_class Snes9X: WndClass") Return 12:30:48:653 | HL | INFO | +0 | BuildScript - Loaded Multi-Player scripts 12:30:48:655 | HL | INFO | +0 | BuildScript - Loaded Statistics.ahk script 12:30:48:655 | HL | WARNING | +0 | BuildScript - "F:\HyperSpin\HyperLaunch\Lib\User Functions.ahk" not found 12:30:48:655 | HL | INFO | +0 | BuildScript - Finished injecting functions into module 12:30:48:655 | HL | INFO | +0 | Main - Module is built 12:30:48:655 | HL | INFO | +0 | CheckFile - Checking if F:\HyperSpin\HyperLaunch\AutoHotkey.dll exists 12:30:48:683 | HL | DEBUG1 | +31 | CheckFile - Attributes: FileDescription AutoHotkey_H ANSI 32-bit FileVersion 1.1.09.04 InternalName AutoHotkey_H LegalCopyright Copyright (C) 2012 OriginalFilename AutoHotkey.exe ProductName AutoHotkey_H ProductVersion 1.1.09.04 File Size: 785408 bytes Created: 3/20/2015 - 11:06:10 PM Modified: 2/25/2015 - 11:48:51 AM 12:30:48:718 | HL | INFO | +31 | Main - Running module 12:30:48:718 | HL | INFO | +0 | Main - Starting timer to watch if Front End gets displaced and restore it if it does. 12:30:48:818 | MD | INFO | +N/A | Module initialized 12:30:48:818 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Using extended Hotkey method for key(s): "~Esc" to call a group label 12:30:48:818 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Using extended Hotkey method for key(s): "~1joy7&~1joy8" to call a group label 12:30:48:820 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Using extended Hotkey method for key(s): "~2joy7&~2joy8" to call a group label 12:30:48:820 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Using extended Hotkey method for key(s): "~3joy7&~3joy8" to call a group label 12:30:48:820 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Using extended Hotkey method for key(s): "~4joy7&~4joy8" to call a group label 12:30:48:825 | MD | INFO | +0 | CheckFile - Checking if F:\HyperSpin\Utilities\Xpadder\Xpadder.exe exists 12:30:48:825 | MD | DEBUG1 | +0 | CheckFile - Attributes: File Size: 1178624 bytes Created: 3/25/2015 - 8:13:14 PM Modified: 3/25/2015 - 8:13:17 PM 12:30:48:825 | MD | INFO | +0 | Keymapper - Loading xpadder 12:30:48:825 | MD | INFO | +0 | RunKeymapper - Started, using method "load" 12:30:48:825 | MD | INFO | +0 | GetJoystickArray - Started 12:30:48:825 | MD | DEBUG2 | +0 | GetJoystickArray - Joysticks Detected: 0000000000000000 12:30:48:825 | MD | INFO | +0 | GetJoystickArray - Ended 12:30:48:825 | MD | DEBUG2 | +0 | RunKeymapper - Looping through controllers to find xpadder profiles for each one 12:30:48:828 | MD | INFO | +0 | RunXpadder - Started 12:30:48:828 | MD | INFO | +0 | Process - Exist JoyToKey.exe 12:30:48:881 | MD | DEBUG2 | +63 | RunXpadder - Closing xpadder to refresh controllers seen by xpadder 12:30:48:881 | MD | INFO | +0 | Run - Running: F:\HyperSpin\Utilities\Xpadder\Xpadder.exe /C 12:30:48:939 | MD | DEBUG1 | +62 | Run - "Xpadder.exe /C" Process ID: 5080 12:30:48:939 | MD | DEBUG2 | +0 | RunXpadder - Creating an array of connected controllers and profiles to arrange according to the order found in F:\HyperSpin\Utilities\Xpadder\xpadder.ini 12:30:48:939 | MD | INFO | +0 | Process - WaitClose Xpadder.exe 2 12:30:49:159 | MD | DEBUG2 | +218 | RunXpadder - Reading the order in F:\HyperSpin\Utilities\Xpadder\xpadder.ini and arranging profiles found to match that order 12:30:49:159 | MD | DEBUG2 | +0 | RunXpadder - No more controllers to be found 12:30:49:159 | MD | WARNING | +0 | RunXpadder - No profiles found and nothing to tell Xpadder to load 12:30:49:159 | MD | INFO | +0 | RunXpadder - Ended 12:30:49:159 | MD | INFO | +0 | RunKeymapper - Ended 12:30:49:161 | MD | INFO | +0 | StartModule - Started 12:30:49:161 | MD | INFO | +0 | StartModule - MEmu: Snes9X MEmuV: v1.53 MURL: http://www.snes9x.com/ MAuthor: djvj MVersion: 2.0.1 MCRC: 34FD2149 iCRC: FD5A1CE MID: MSystem: "Nintendo Super Famicom","Super Nintendo Entertainment System" 12:30:49:161 | MD | INFO | +0 | StartModule - You have a supported System Name for this module: "Super Nintendo Entertainment System" 12:30:49:164 | MD | INFO | +0 | PluginInit - Started 12:30:49:166 | MD | DEBUG1 | +0 | BuildDatabaseTable - Started - Building Table for: Name|Cloneof|Manufacturer|Year|Genre|Rating 12:30:49:166 | MD | INFO | +0 | CheckFile - Checking if F:\HyperSpin\Databases\Super Nintendo Entertainment System\Super Nintendo Entertainment System.xml exists 12:30:49:166 | MD | DEBUG1 | +0 | CheckFile - Attributes: File Size: 946793 bytes Created: 3/20/2015 - 11:05:34 PM Modified: 4/26/2015 - 12:13:07 AM 12:30:49:169 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching for a "Game Name" in the database 12:30:49:169 | MD | DEBUG1 | +0 | BuildDatabaseTable - Found "Game Name" in the database! 12:30:49:169 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching database for: Name 12:30:49:169 | MD | DEBUG1 | +0 | BuildDatabaseTable - Found "Name" with a value: "ActRaiser 2 (USA)" 12:30:49:169 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching database for: Cloneof 12:30:49:169 | MD | DEBUG1 | +0 | BuildDatabaseTable - Could not find: Cloneof 12:30:49:169 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching database for: Manufacturer 12:30:49:169 | MD | DEBUG1 | +0 | BuildDatabaseTable - Could not find: Manufacturer 12:30:49:171 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching database for: Year 12:30:49:171 | MD | DEBUG1 | +0 | BuildDatabaseTable - Could not find: Year 12:30:49:171 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching database for: Genre 12:30:49:171 | MD | DEBUG1 | +0 | BuildDatabaseTable - Could not find: Genre 12:30:49:171 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching database for: Rating 12:30:49:171 | MD | DEBUG1 | +0 | BuildDatabaseTable - Could not find: Rating 12:30:49:171 | MD | DEBUG2 | +0 | PluginInit - GameInfo: GameInfo Label: Name | GameInfo Value: 12:30:49:171 | MD | DEBUG1 | +0 | BuildDatabaseTable - Ended 12:30:49:171 | MD | DEBUG1 | +0 | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo 12:30:49:194 | MD | DEBUG1 | +32 | BuildAssetsTable - Searching for a Game Logo: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Wheel\ActRaiser 2 (USA).png 12:30:49:194 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a System Logo: F:\HyperSpin\Media\Main Menu\Images\Wheel\Super Nintendo Entertainment System.png 12:30:49:194 | MD | DEBUG2 | +0 | BuildAssetsTable - Media assets found: Asset Label: Game Logo | Asset Path1: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Wheel\ActRaiser 2 (USA).png | Asset Extension1: png | Asset Type1: game Asset Label: System Logo | Asset Path1: F:\HyperSpin\Media\Main Menu\Images\Wheel\Super Nintendo Entertainment System.png | Asset Extension1: png | Asset Type1: system 12:30:49:194 | MD | DEBUG1 | +0 | BuildAssetsTable - Ended 12:30:49:194 | MD | DEBUG1 | +0 | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other 12:30:49:194 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a Artwork1: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Artwork1\ActRaiser 2 (USA).png 12:30:49:194 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a Box Art: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Artwork2\ActRaiser 2 (USA).png 12:30:49:194 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a Cartridge: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Artwork3\ActRaiser 2 (USA).png 12:30:49:194 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a Flyers: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Artwork4\ActRaiser 2 (USA).png 12:30:49:196 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a Letters: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters 12:30:49:220 | HL | WARNING | +515 | HyperSpin.exe was displaced to x25 y25 w1440 h760 by Snes9x. It is probably running in true fullscreen mode. 12:30:49:265 | MD | DEBUG1 | +62 | BuildAssetsTable - Searching for a Other: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Other 12:30:49:292 | MD | DEBUG2 | +31 | BuildAssetsTable - Media assets found: Asset Label: Cartridge | Asset Path1: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Artwork3\ActRaiser 2 (USA).png | Asset Extension1: png | Asset Type1: game Asset Label: Flyers | Asset Path1: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Artwork4\ActRaiser 2 (USA).png | Asset Extension1: png | Asset Type1: game Asset Label: Letters | Asset Path1: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters\!.png | Asset Extension1: png | Asset Type1: system Asset Label: Letters | Asset Path2: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters\'.png | Asset Extension2: png | Asset Type2: system Asset Label: Letters | Asset Path3: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters\(.png | Asset Extension3: png | Asset Type3: system Asset Label: Letters | Asset Path4: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters\0.png | Asset Extension4: png | Asset Type4: system Asset Label: Letters | Asset Path5: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters\1.png | Asset Extension5: png | Asset Type5: system Asset Label: Letters | Asset Path6: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters\2.png | Asset Extension6: png | Asset Type6: system Asset Label: Letters | Asset Path7: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters\3.png | Asset Extension7: png | Asset Type7: system Asset Label: Letters | Asset Path8: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters\4.png | Asset Extension8: png | Asset Type8: system Asset Label: Letters | Asset Path9: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters\5.png | Asset Extension9: png | Asset Type9: system Asset Label: Letters | Asset Path10: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters\6.png | Asset Extension10: png | Asset Type10: system Asset Label: Letters | Asset Path11: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters\7.png | Asset Extension11: png | Asset Type11: system Asset Label: Letters | Asset Path12: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters\8.png | Asset Extension12: png | Asset Type12: system Asset Label: Letters | Asset Path13: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters\9.png | Asset Extension13: png | Asset Type13: system Asset Label: Letters | Asset Path14: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters\a.png | Asset Extension14: png | Asset Type14: system Asset Label: Letters | Asset Path15: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters\b.png | Asset Extension15: png | Asset Type15: system Asset Label: Letters | Asset Path16: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters\c.png | Asset Extension16: png | Asset Type16: system Asset Label: Letters | Asset Path17: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters\d.png | Asset Extension17: png | Asset Type17: system Asset Label: Letters | Asset Path18: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters\e.png | Asset Extension18: png | Asset Type18: system Asset Label: Letters | Asset Path19: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters\f.png | Asset Extension19: png | Asset Type19: system Asset Label: Letters | Asset Path20: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters\g.png | Asset Extension20: png | Asset Type20: system Asset Label: Letters | Asset Path21: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters\h.png | Asset Extension21: png | Asset Type21: system Asset Label: Letters | Asset Path22: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters\i.png | Asset Extension22: png | Asset Type22: system Asset Label: Letters | Asset Path23: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters\j.png | Asset Extension23: png | Asset Type23: system Asset Label: Letters | Asset Path24: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters\k.png | Asset Extension24: png | Asset Type24: system Asset Label: Letters | Asset Path25: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters\l.png | Asset Extension25: png | Asset Type25: system Asset Label: Letters | Asset Path26: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters\m.png | Asset Extension26: png | Asset Type26: system Asset Label: Letters | Asset Path27: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters\n.png | Asset Extension27: png | Asset Type27: system Asset Label: Letters | Asset Path28: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters\o.png | Asset Extension28: png | Asset Type28: system Asset Label: Letters | Asset Path29: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters\p.png | Asset Extension29: png | Asset Type29: system Asset Label: Letters | Asset Path30: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters\q.png | Asset Extension30: png | Asset Type30: system Asset Label: Letters | Asset Path31: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters\r.png | Asset Extension31: png | Asset Type31: system Asset Label: Letters | Asset Path32: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters\s.png | Asset Extension32: png | Asset Type32: system Asset Label: Letters | Asset Path33: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters\t.png | Asset Extension33: png | Asset Type33: system Asset Label: Letters | Asset Path34: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters\u.png | Asset Extension34: png | Asset Type34: system Asset Label: Letters | Asset Path35: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters\v.png | Asset Extension35: png | Asset Type35: system Asset Label: Letters | Asset Path36: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters\w.png | Asset Extension36: png | Asset Type36: system Asset Label: Letters | Asset Path37: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters\x.png | Asset Extension37: png | Asset Type37: system Asset Label: Letters | Asset Path38: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters\y.png | Asset Extension38: png | Asset Type38: system Asset Label: Letters | Asset Path39: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Letters\z.png | Asset Extension39: png | Asset Type39: system Asset Label: Other | Asset Path1: F:\HyperSpin\Media\Super Nintendo Entertainment System\Images\Other\Pointer.png | Asset Extension1: png | Asset Type1: system 12:30:49:292 | MD | DEBUG1 | +0 | BuildAssetsTable - Ended 12:30:49:292 | MD | DEBUG1 | +0 | BuildAssetsTable - Started - Building Table for: MP4 Game Video|FLV Game Video|MP4 System Video|FLV System Video 12:30:49:292 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a MP4 Game Video: F:\HyperSpin\Media\Super Nintendo Entertainment System\Video\ActRaiser 2 (USA).* 12:30:49:292 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a MP4 System Video: F:\HyperSpin\Media\Main Menu\Video\Super Nintendo Entertainment System.* 12:30:49:292 | MD | DEBUG2 | +0 | BuildAssetsTable - Media assets found: Asset Label: MP4 Game Video | Asset Path1: F:\HyperSpin\Media\Super Nintendo Entertainment System\Video\ActRaiser 2 (USA).mp4 | Asset Extension1: mp4 | Asset Type1: game Asset Label: MP4 System Video | Asset Path1: F:\HyperSpin\Media\Main Menu\Video\Super Nintendo Entertainment System.mp4 | Asset Extension1: mp4 | Asset Type1: system 12:30:49:292 | MD | DEBUG1 | +0 | BuildAssetsTable - Ended 12:30:49:292 | MD | INFO | +0 | PluginInit - Ended 12:30:49:295 | MD | DEBUG1 | +0 | StartModule - Setting romName to the dbName sent to HyperLaunch: ActRaiser 2 (USA) 12:30:49:295 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~e & ~t" to call label: "ToggleCursor" 12:30:49:295 | MD | INFO | +0 | StartModule - Ended 12:30:49:295 | MD | INFO | +0 | Module Setting - [Settings] - Fullscreen: true 12:30:49:295 | MD | INFO | +0 | Module Setting - [Settings] - EmulateFullscreen: true 12:30:49:295 | MD | INFO | +0 | Module Setting - [Settings] - WindowMaximized: true 12:30:49:295 | MD | INFO | +0 | Module Setting - [Settings] - Stretch: true 12:30:49:295 | MD | INFO | +0 | Module Setting - [Settings] - MaintainAspectRatio: true 12:30:49:295 | MD | INFO | +0 | Module Setting - [Settings] - HideMenu: true 12:30:49:295 | MD | INFO | +0 | Module Setting - [Settings] - FullScreenWidth: 1024 12:30:49:312 | MD | INFO | +31 | Module Setting - [Settings] - FullScreenHeight: 768 12:30:49:312 | MD | INFO | +0 | CheckFile - Checking if F:\HyperSpin\Emulators\Super Nintendo Entertainment System\Snes9x\snes9x.conf exists 12:30:49:360 | MD | DEBUG1 | +47 | CheckFile - Attributes: File Size: 26797 bytes Created: 4/18/2015 - 12:10:40 PM Modified: 4/29/2015 - 11:23:31 AM 12:30:49:363 | MD | INFO | +0 | Run - Running: F:\HyperSpin\Emulators\Super Nintendo Entertainment System\Snes9x\snes9x-x64.exe "F:\HyperSpin\Emulators\Super Nintendo Entertainment System\roms\ActRaiser 2 (USA).zip" 12:30:49:473 | MD | DEBUG1 | +109 | Run - "snes9x-x64.exe "F:\HyperSpin\Emulators\Super Nintendo Entertainment System\roms\ActRaiser 2 (USA).zip"" Process ID: 3776 12:30:49:473 | MD | DEBUG1 | +0 | GetActiveWindowStatus - Title: HyperSpin | Class: ThunderRT6FormDC | State: 0 | X: 0 | Y: 0 | Width: 1920 | Height: 1080 | Window HWND: 0x3a0586 | Process ID: 5540 | Process Path: F:\Hyperspin\HyperSpin.exe 12:30:49:473 | MD | INFO | +0 | WinWait - Waiting for "Snes9X ahk_class Snes9X: WndClass" 12:30:49:892 | MD | DEBUG1 | +422 | GetActiveWindowStatus - Title: Snes9X v1.53 for Windows | Class: Snes9X: WndClass | State: 0 | X: 0 | Y: 0 | Width: 1920 | Height: 1080 | Window HWND: 0x20600 | Process ID: 3776 | Process Path: F:\HyperSpin\Emulators\Super Nintendo Entertainment System\Snes9x\snes9x-x64.exe 12:30:49:892 | MD | DEBUG1 | +0 | GetActiveWindowStatus - Title: Snes9X v1.53 for Windows | Class: Snes9X: WndClass | State: 0 | X: 0 | Y: 0 | Width: 1920 | Height: 1080 | Window HWND: 0x20600 | Process ID: 3776 | Process Path: F:\HyperSpin\Emulators\Super Nintendo Entertainment System\Snes9x\snes9x-x64.exe 12:30:49:892 | MD | INFO | +0 | WinWaitActive - Waiting for "Snes9X ahk_class Snes9X: WndClass" 12:30:49:999 | MD | DEBUG1 | +109 | GetActiveWindowStatus - Title: Snes9X v1.53 for Windows | Class: Snes9X: WndClass | State: 0 | X: 0 | Y: 0 | Width: 1920 | Height: 1080 | Window HWND: 0x20600 | Process ID: 3776 | Process Path: F:\HyperSpin\Emulators\Super Nintendo Entertainment System\Snes9x\snes9x-x64.exe 12:30:49:999 | MD | INFO | +0 | Process - WaitClose snes9x-x64.exe 12:31:11:904 | MD | ERROR | +21902 | 1 12:31:11:904 | MD | DEBUG1 | +0 | CloseProcess - Started, user requested to end launched application 12:31:11:905 | MD | INFO | +0 | WinClose - Closing: Snes9X ahk_class Snes9X: WndClass 12:31:12:138 | MD | DEBUG1 | +234 | CloseProcess - Ended 12:31:12:140 | MD | INFO | +0 | ExitModule - Started 12:31:12:141 | MD | INFO | +0 | Starting Updating Statistics: 12:31:12:141 | MD | DEBUG2 | +0 | Total Elapsed Time in Pause in seconds: 0 12:31:12:141 | MD | DEBUG2 | +0 | gameSectionStartTime:3505997 12:31:12:141 | MD | DEBUG2 | +0 | ElapsedTime:22 12:31:12:142 | MD | DEBUG2 | +0 | Statistics cleared game name: ActRaiser 2 12:31:12:255 | MD | DEBUG2 | +110 | Loaded game statistics from ini files: Number_of_Times_Played: 2 Last_Time_Played: Wednesday April 29, 2015 11:22:53 AM Average_Time_Played: 38 Total_Time_Played: 75 System_Total_Played_Time: 4048 Total_Global_Played_Time: 45224 12:31:12:255 | MD | DEBUG2 | +0 | Updated Statistics: Number_of_Times_Played: 3 Last_Time_Played: Wednesday April 29, 2015 12:30:49 PM Average_Time_Played: 32 Total_Time_Played: 97 System_Total_Played_Time: 4070 Total_Global_Played_Time: 45246 12:31:12:307 | MD | INFO | +62 | Game section statistics updated. 12:31:12:307 | MD | INFO | +0 | RunKeymapper - Started, using method "unload" 12:31:12:307 | MD | INFO | +0 | GetJoystickArray - Started 12:31:12:310 | MD | DEBUG2 | +0 | GetJoystickArray - Joysticks Detected: 0000000000000000 12:31:12:310 | MD | INFO | +0 | GetJoystickArray - Ended 12:31:12:310 | MD | DEBUG2 | +0 | RunKeymapper - Looping through controllers to find xpadder profiles for each one 12:31:12:310 | MD | INFO | +0 | RunXpadder - Started 12:31:12:310 | MD | INFO | +0 | Process - Exist JoyToKey.exe 12:31:12:312 | MD | DEBUG2 | +0 | RunXpadder - Closing xpadder to refresh controllers seen by xpadder 12:31:12:312 | MD | INFO | +0 | Run - Running: F:\HyperSpin\Utilities\Xpadder\Xpadder.exe /C 12:31:12:355 | MD | DEBUG1 | +47 | Run - "Xpadder.exe /C" Process ID: 8824 12:31:12:355 | MD | DEBUG2 | +0 | RunXpadder - Creating an array of connected controllers and profiles to arrange according to the order found in F:\HyperSpin\Utilities\Xpadder\xpadder.ini 12:31:12:355 | MD | INFO | +0 | Process - WaitClose Xpadder.exe 2 12:31:12:583 | MD | DEBUG2 | +218 | RunXpadder - Reading the order in F:\HyperSpin\Utilities\Xpadder\xpadder.ini and arranging profiles found to match that order 12:31:12:583 | MD | DEBUG2 | +0 | RunXpadder - No more controllers to be found 12:31:12:583 | MD | WARNING | +0 | RunXpadder - No profiles found and nothing to tell Xpadder to load 12:31:12:583 | MD | INFO | +0 | RunXpadder - Ended 12:31:12:583 | MD | INFO | +0 | RunKeymapper - Ended 12:31:12:608 | MD | INFO | +31 | ExitModule - Ended 12:31:12:608 | MD | INFO | +0 | End of Module Logs 12:31:12:717 | HL | INFO | +23494 | Main - Module ended, exiting HyperLaunch normally 12:31:12:717 | HL | INFO | +0 | ExitScript - Started 12:31:12:722 | HL | DEBUG1 | +0 | ExitScript - Restoring HyperSpin.exe to x0 y0 w1920 h1080 12:31:12:852 | HL | DEBUG1 | +140 | ExitScript - Clicking HyperSpin.exe to attempt to put it into focus 12:31:12:852 | HL | DEBUG1 | +0 | ExitScript - Checking what application is currently in focus. 12:31:12:860 | HL | INFO | +0 | SystemCursor - Restoring mouse cursor 12:31:12:867 | HL | INFO | +0 | ExitScript - Ended [/code]
Traeyu Posted April 30, 2015 Author Posted April 30, 2015 Well, I have no idea what I did but it is working now. I ran Xpadder in compatibility mode and seemed to work after that but turned compatability mode off and still works so I have no idea what happened that it started finding controllers again.
Traeyu Posted April 30, 2015 Author Posted April 30, 2015 Weird stuff. Get AntiMicro Never heard of it, I'll check it out. Thanks
