Lose control of Hyperspin in Mame Menu
dreamerawoken
Hi,
I have been trying to figure this one out on my own, but throwing in the towel.
I am currently running Hyperspin 1.3.
I can control the hyperspin wheel, make selections, and leave the menu wheel on every system installed but on Mame.
As soon as I enter the Mame submenu I lose all controls, and have to lose focus of hyperspin - then go back to focus in order to regain control.
At which point, I lose control all over again if I navigate to any other game selection in the Mame menu. If I leave the Mame menu, all is right with the world.
I have tried disabling Mame themes, Mame Videos, LEDBlinky - and even disconnected my control panel and tested with an ordinary keyboard.
No dice.
I see a thread here that recommends the user upgrade to Hyperspin 1.2 -- I have upgraded to Hyperspin 1.3 and still see the issue.
Any help would be appreciated highly,
Anthony
  • 1 year later...
I know this is an old topic but I can't find any other mentions of this issue.
I'm run into this myself with both v1.3 and v1.3.2.0.
Unfortunately I can't contribute a solution right now, but let me ask: did you ever find a solution?
In my case, the keyboard works fine. Using my Logitech F710 (either with or without Xbox 360 software installed) yields a similar issue to what you described, but emulators other than MAME continuously spin through the list until I use the keyboard.
Hyperspin 1.0 works fine as far as controls go.
I'll test again using my X-Arcade/PS3 controllers with SCPServer and report back if that's OK.
No control at all in HS using the PS3/SCPServer setup, which in theory is just an Xbox 360 controller, on a separate machine. Since I use the PS3 adapter to do the exact same thing on the X-Arcade, I assume it would yield the same result. If you want, I will hook it up and report back.
