Colecovision and BlueMSX
matabhaine
All the ini files for BlueMSX are placed in separate folders for each machine in a Machines folder, rom audit in HLHQ, everything is green, BlueMSX and Colecovision works outside HLHQ. Tried MESS but gave up. Any ideas.
Sorry guys but I solved the problem after hours of research and testing.
Be wary of where you download your emulators, as with AAE, the problem I had with BlueMSX was some missing files, including the BlueMSX.ini which i thought was either in the machines folder or generated when you ran the emulator for the first time.
Maybe this post will help someone else with the same problem.
