Rylight Posted January 27, 2013 Posted January 27, 2013 Hello all! First post! Background I have Hyperspin working with MAME, Neo Geo using mame emulator and SNES. My next emulator is Sega Dreamcast. Using NullDC v1.0.4 I have Hyperspin able to open NullDC but it asks to open a rom path Because LoadDefaultImage=0 So I took the advice from other members on this forum to change this to LoadDefaultImage=1 Fullscreen=1 Emulator.AutoStart=1 Since I have turned LoadDefaultImage=1 I now receive this error. Unhandled exeption while Initing Image Reader plugin by drk||Raziel & GiGaHeRz [Aug 21 2011] plugin I know the problem isn't with Hyperspin because I receive this error even when I try and open nullDC separate. The solutions I read about others seeing this error is to update their NullDC, I am running th enewest on their site. nullDC 1.0.4 r136 I am running WIndows 7 64bit. Hope someone has run into thi before and has some advice I am running into a wall with this one. I have seen posts about a Module hyperlauncher, but my concern was would this ruin how I have set up my other emulators? Thanks! Here is my Sega Dreamcast hyperspin.ahk portion: ;*********************************SEGA DREAMCAST******************************** else if (systemName = "Sega Dreamcast" && executable = "nullDC.exe" ) { hideDesktop() SetWorkingDir, %emuPath% Hotkey, %exitEmulatorKey%, CloseProcess Blockinput on SetBatchLines -1 Gui +AlwaysOnTop -Caption +ToolWindow Gui Color, 0 Gui Show, x0 y0 h%A_ScreenHeight% w%A_ScreenWidth%, MouseGetPos X, Y SetDefaultMouseSpeed, 0 MouseMove %A_ScreenWidth%,%A_ScreenHeight% IniWrite, 1, %A_WorkingDir%\nulldc.cfg, nullDC, Emulator.AutoStart IniWrite, 1, %A_WorkingDir%\nulldc.cfg, nullDC, Emulator.NoConsole IniWrite, 1, %A_WorkingDir%\nulldc.cfg, drkpvr, Fullscreen.Enabled IniWrite, 800, %A_WorkingDir%\nulldc.cfg, drkpvr, Fullscreen.Res_X IniWrite, 600, %A_WorkingDir%\nulldc.cfg, drkpvr, Fullscreen.Res_Y IniWrite, %romPath%%romname%%RomExtension%, %A_WorkingDir%\nulldc.cfg, imagereader, defaultimage Run, %executable% Sleep, 8000 Gui Destroy SetDefaultMouseSpeed, 2 Blockinput off ;Process, WaitClose, %executable% Process, WaitClose, nullDC WinActivate, HyperSpin } Here is my Sega Dreamcast.ini [exe info] path=F:\HyperSpin\Emulators\SEGA Dreamcast2\ rompath=F:\HyperSpin\Emulators\RomFiles\Sega Dreamcast Games\ userompath=true exe=nullDC.exe romextension=rar parameters= -config ImageReader:DefaultImage=F:\HyperSpin\Emulators\RomFiles\Sega Dreamcast Games\Soul Calibur.cdi searchsubfolders=true pcgame=false winstate=HIDDEN hyperlaunch=true Per_Game_Modules=false Skipchecks=false Hide_Cursor=use_global Hide_Desktop=use_global Hide_Taskbar=use_global CPWizard_Enabled=use_global CPWizard_Delay=use_global CPWizard_Params=use_global Fade_In=use_global Fade_Out=use_global Fade_Color=use_global Fade_In_Duration=use_global Fade_Out_Duration=use_global Fade_In_Delay=use_global 7z_Enabled=use_global 7z_Extract_Dir=use_global 7z_Delete_Temp=use_global Keymapper_Enabled=use_global Keymapper=use_global MultiGame_Enabled=use_global MultiGame_Background_Color=use_global MultiGame_Side_Padding=use_global MultiGame_Y_Offset=use_global MultiGame_Image_Adjust=use_global MultiGame_Font=use_global MultiGame_Text_1_Options=use_global MultiGame_Text_1_Text=use_global MultiGame_Text_2_Options=use_global MultiGame_Text_2_Offset=use_global MultiGame_Use_Sound=use_global MultiGame_Sound_Frequency=use_global MultiGame_Exit_Effect=use_global MultiGame_Selected_Effect=use_global MultiGame_Use_Game_Art=use_global MultiGame_Art_Folder=use_global [filters] parents_only=false themes_only=false wheels_only=false [themes] use_parent_vids=true use_parent_themes=false animate_out_default=false reload_backgrounds=false [wheel] alpha=.15 small_alpha = 1 style=normal speed=high pin_center_width=500 horz_wheel_y=512 vert_wheel_position=right y_rotation=center norm_large=360 norm_small=230 vert_large=400 vert_small=240 pin_large=500 pin_small=200 horz_large=240 horz_small=150 letter_wheel_x=800 letter_wheel_y=384 text_width=700 text_font=Style4 small_text_width=260 large_text_width=400 text_stroke_size=6 text_stroke_color=0x000000 text_color1=0x00BFFD text_color2=0xFFFFFF text_color3=0x00BFFD color_ratio=139 shadow_distance=0 shadow_angle=45 shadow_color=0x000000 shadow_alpha=1 shadow_blur=0 [pointer] animated=true x=975 y=384 [video defaults] path=F:\HyperSpin\Media\Sega Dreamcast\Video\ [sounds] game_sounds=true wheel_click=true [navigation] game_jump=50 use_indexes=false jump_timer=400 remove_info_wheel=false remove_info_text=false use_last_game=false last_game=Soul Calibur random_game=false start_on_favorites=false [special Art A] default=false active=true x=512 y=720 in=0.4 out=0.4 length=3 delay=0 type=normal start=bottom [special Art B] default=true active=true x=512 y=740 in=0.4 out=0.4 length=3 delay=0 type=fade start=none [special Art C] active=true x=512 y=384 in=0 out=0 length=3 delay=10 type=fade start=none [Game Text] game_text_active=true show_year=true show_manf=true show_description=true text_color1=0xffffff text_color2=0x0099cc stroke_color=0x000000 text_font=Style1 text1_textsize=26 text1_strokesize=7 text1_x=32 text1_y=610 text2_textsize=36 text2_strokesize=8 text2_x=30 text2_y=640 Here is my nullDC.cfg ;; nullDC config file;; [nullDC] Dynarec.Enabled=1 Dynarec.DoConstantPropagation=1 Dynarec.SafeMode=1 Dynarec.UnderclockFpu=0 Dreamcast.Cable=3 Dreamcast.RTC=1990436719 Dreamcast.Region=3 Dreamcast.Broadcast=4 Emulator.AutoStart=1 Emulator.NoConsole=1 [nullDC_plugins] GUI=nullDC_GUI_Win32.dll Current_PVR=drkPvr_Win32.dll Current_GDR=ImgReader_Win32.dll Current_AICA=nullAICA_Win32.dll Current_ARM=vbaARM_Win32.dll Current_ExtDevice=nullExtDev_Win32.dll Current_maple0_5=PuruPuru_Win32.dll:0 Current_maple0_0=PuruPuru_Win32.dll:1 Current_maple0_1=XMaple_Win32.dll:3 Current_maple1_5=NULL Current_maple2_5=NULL Current_maple3_5=NULL Current_maple0_2=NULL Current_maple0_3=NULL Current_maple0_4=NULL Current_maple1_0=NULL Current_maple1_1=NULL Current_maple1_2=NULL Current_maple1_3=NULL Current_maple1_4=NULL Current_maple2_0=NULL Current_maple2_1=NULL Current_maple2_2=NULL Current_maple2_3=NULL Current_maple2_4=NULL Current_maple3_0=NULL Current_maple3_1=NULL Current_maple3_2=NULL Current_maple3_3=NULL Current_maple3_4=NULL [nullDC_GUI] AutoHideMenu=1 Fullscreen=0 AlwaysOnTop=0 [drkpvr] Emulation.AlphaSortMode=1 Emulation.PaletteMode=1 Emulation.ModVolMode=0 Emulation.ZBufferMode=0 Emulation.TexCacheMode=0 OSD.ShowFPS=0 OSD.ShowStats=0 Video.ResolutionMode=0 Video.VSync=0 Enhancements.MultiSampleCount=0 Enhancements.MultiSampleQuality=0 Enhancements.AspectRatioMode=1 Fullscreen.Enabled=1 Fullscreen.Res_X=800 Fullscreen.Res_Y=600 [imageReader] PatchRegion=0 LoadDefaultImage=1 DefaultImage=F:\HyperSpin\Emulators\RomFiles\Sega Dreamcast Games\Soul Calibur.rar LastImage=c:\game.gdi [nullAica] BufferSize=2048 LimitFPS=1 HW_mixing=0 SoundRenderer=1 GlobalFocus=1 BufferCount=1 CDDAMute=0 GlobalMute=0 DSPEnabled=0 Volume=90 [nullExtDev] mode=0 adapter=0 [ndc_hookjoy] PortA_CONT_C=66 PortA_CONT_B=88 PortA_CONT_A=86 PortA_CONT_START=16 PortA_CONT_DPAD_UP=38 PortA_CONT_DPAD_DOWN=40 PortA_CONT_DPAD_LEFT=37 PortA_CONT_DPAD_RIGHT=39 PortA_CONT_Z=77 PortA_CONT_Y=90 PortA_CONT_X=67 PortA_CONT_DPAD2_UP=0 PortA_CONT_DPAD2_DOWN=0 PortA_CONT_DPAD2_LEFT=0 PortA_CONT_DPAD2_RIGHT=0 PortA_CONT_ANALOG_UP=73 PortA_CONT_ANALOG_DOWN=75 PortA_CONT_ANALOG_LEFT=74 PortA_CONT_ANALOG_RIGHT=76 PortA_CONT_LSLIDER=65 PortA_CONT_RSLIDER=83 PortB_CONT_C=66 PortB_CONT_B=88 PortB_CONT_A=86 PortB_CONT_START=16 PortB_CONT_DPAD_UP=38 PortB_CONT_DPAD_DOWN=40 PortB_CONT_DPAD_LEFT=37 PortB_CONT_DPAD_RIGHT=39 PortB_CONT_Z=77 PortB_CONT_Y=90 PortB_CONT_X=67 PortB_CONT_DPAD2_UP=0 PortB_CONT_DPAD2_DOWN=0 PortB_CONT_DPAD2_LEFT=0 PortB_CONT_DPAD2_RIGHT=0 PortB_CONT_ANALOG_UP=73 PortB_CONT_ANALOG_DOWN=75 PortB_CONT_ANALOG_LEFT=74 PortB_CONT_ANALOG_RIGHT=76 PortB_CONT_LSLIDER=65 PortB_CONT_RSLIDER=83 PortC_CONT_C=66 PortC_CONT_B=88 PortC_CONT_A=86 PortC_CONT_START=16 PortC_CONT_DPAD_UP=38 PortC_CONT_DPAD_DOWN=40 PortC_CONT_DPAD_LEFT=37 PortC_CONT_DPAD_RIGHT=39 PortC_CONT_Z=77 PortC_CONT_Y=90 PortC_CONT_X=67 PortC_CONT_DPAD2_UP=0 PortC_CONT_DPAD2_DOWN=0 PortC_CONT_DPAD2_LEFT=0 PortC_CONT_DPAD2_RIGHT=0 PortC_CONT_ANALOG_UP=73 PortC_CONT_ANALOG_DOWN=75 PortC_CONT_ANALOG_LEFT=74 PortC_CONT_ANALOG_RIGHT=76 PortC_CONT_LSLIDER=65 PortC_CONT_RSLIDER=83 PortD_CONT_C=66 PortD_CONT_B=88 PortD_CONT_A=86 PortD_CONT_START=16 PortD_CONT_DPAD_UP=38 PortD_CONT_DPAD_DOWN=40 PortD_CONT_DPAD_LEFT=37 PortD_CONT_DPAD_RIGHT=39 PortD_CONT_Z=77 PortD_CONT_Y=90 PortD_CONT_X=67 PortD_CONT_DPAD2_UP=0 PortD_CONT_DPAD2_DOWN=0 PortD_CONT_DPAD2_LEFT=0 PortD_CONT_DPAD2_RIGHT=0 PortD_CONT_ANALOG_UP=73 PortD_CONT_ANALOG_DOWN=75 PortD_CONT_ANALOG_LEFT=74 PortD_CONT_ANALOG_RIGHT=76 PortD_CONT_LSLIDER=65 PortD_CONT_RSLIDER=83 local_port=0 server_addr=192.168.1.33 server_port=11122 [drkMaple] VMU.Show=1 Mouse.Sensitivity=100 [PuruPuru_Pad_1] l_shoulder=-1 r_shoulder=-1 a_button=-1 b_button=-1 x_button=-1 y_button=-1 start_button=-1 dpad_up=-1 dpad_down=-1 dpad_left=-1 dpad_right=-1 main_x_left=-1 main_x_right=-1 main_y_up=-1 main_y_down=-1 halfpress=-1 deadzone=24 pakku_intensity=100 pakku_length=175 keyboard=0 joy_id=0 controllertype=0 [PuruPuru_Pad_2] l_shoulder=-1 r_shoulder=-1 a_button=-1 b_button=-1 x_button=-1 y_button=-1 start_button=-1 dpad_up=-1 dpad_down=-1 dpad_left=-1 dpad_right=-1 main_x_left=-1 main_x_right=-1 main_y_up=-1 main_y_down=-1 halfpress=-1 deadzone=24 pakku_intensity=100 pakku_length=175 keyboard=0 joy_id=0 controllertype=0 [PuruPuru_Pad_3] l_shoulder=-1 r_shoulder=-1 a_button=-1 b_button=-1 x_button=-1 y_button=-1 start_button=-1 dpad_up=-1 dpad_down=-1 dpad_left=-1 dpad_right=-1 main_x_left=-1 main_x_right=-1 main_y_up=-1 main_y_down=-1 halfpress=-1 deadzone=24 pakku_intensity=100 pakku_length=175 keyboard=0 joy_id=0 controllertype=0 [PuruPuru_Pad_4] l_shoulder=-1 r_shoulder=-1 a_button=-1 b_button=-1 x_button=-1 y_button=-1 start_button=-1 dpad_up=-1 dpad_down=-1 dpad_left=-1 dpad_right=-1 main_x_left=-1 main_x_right=-1 main_y_up=-1 main_y_down=-1 halfpress=-1 deadzone=24 pakku_intensity=100 pakku_length=175 keyboard=0 joy_id=0 controllertype=0 [Xmaple] Controller.DeadZone=25 PuruPuru.UseRealFrequency=1 PuruPuru.Length=175 PuruPuru.Intensity=100
mrfloppy Posted January 28, 2013 Posted January 28, 2013 You really should go to the new hyperlaunch. Yes, it will make your other emulators not work until you download appropriate modules for them. Also, that is the latest compiled version of nullDC, but you need to run the small upgrades to get to the newer versions, or find a pre-compiled newer version elsewhere. In my experience, version .136 does not run as many roms as the version for which the modules support, which I believe is .141 off the top of my head. Does it give you this error when trying multiple roms?
Rylight Posted January 28, 2013 Author Posted January 28, 2013 Solved. Thanks for getting back so quickly. You reminding me to check a differnet file sparked an idea. My SNES roms are all zipped so I had set the extension for my dreamcast games to be zipped as well. Once I changed my ini file to use CDI extension instead of RAR it worked first time. I have a few more emulators I want to add and I do not want to do this again so I will go through the effort to upgrade so I dont run into headaches in the future. Thanks!
foxxhole Posted August 6, 2014 Posted August 6, 2014 I'm actually running into the same problem (same error when i try to launch NullDC). How did you fix it?
Flipzo Posted August 17, 2014 Posted August 17, 2014 I just downloaded HyperSpin+HyperLaunch 2 days ago and I'm having this problem with NullDC as well. E:\HyperSpin\Settings\Sega Dreamcast.ini [exe info] path= rompath= userompath=true exe= romextension= parameters= searchsubfolders=true pcgame=false winstate=HIDDEN hyperlaunch=true [filters] parents_only=false themes_only=false wheels_only=false [themes] use_parent_vids=true use_parent_themes=false animate_out_default=false reload_backgrounds=false [wheel] alpha=.15 small_alpha = 1 style=normal speed=high pin_center_width=500 horz_wheel_y=512 vert_wheel_position=right y_rotation=center norm_large=360 norm_small=230 vert_large=400 vert_small=240 pin_large=500 pin_small=200 horz_large=240 horz_small=150 letter_wheel_x=800 letter_wheel_y=384 text_width=700 text_font=Style4 small_text_width=260 large_text_width=400 text_stroke_size=6 text_stroke_color=0x000000 text_color1=0x00BFFD text_color2=0xFFFFFF text_color3=0x00BFFD color_ratio=139 shadow_distance=0 shadow_angle=45 shadow_color=0x000000 shadow_alpha=1 shadow_blur=0 [pointer] animated=true x=975 y=384 [video defaults] path=C:\HyperSpin\Media\Sega Dreamcast\Video\ [sounds] game_sounds=true wheel_click=true [navigation] game_jump=50 use_indexes=false jump_timer=400 remove_info_wheel=false remove_info_text=false use_last_game=false last_game=Bust-A-Move 4 (USA) random_game=false start_on_favorites=false [special Art A] default=false active=true x=512 y=720 in=0.4 out=0.4 length=3 delay=0 type=normal start=bottom [special Art B] default=true active=true x=512 y=740 in=0.4 out=0.4 length=3 delay=0 type=fade start=none [special Art C] active=true x=512 y=384 in=0 out=0 length=3 delay=10 type=fade start=none [Game Text] game_text_active=true show_year=true show_manf=true show_description=true text_color1=0xffffff text_color2=0x0099cc stroke_color=0x000000 text_font=Style1 text1_textsize=26 text1_strokesize=7 text1_x=32 text1_y=610 text2_textsize=36 text2_strokesize=8 text2_x=30 text2_y=640 Anybody? I want to get this working..
Emu54 Posted August 17, 2014 Posted August 17, 2014 I have been working on this u have to not work in hyperspin try the emu first in null dc options go to gd rom untick use default image and press select image find your game works great what trying to find out is does null dc work with 7zip games and can null dc have a folder rather then sub game folders
Emu54 Posted August 17, 2014 Posted August 17, 2014 Got mine working with hyperhq controller set up works great be happy to help got to go to work for a few hours send me message
craiganderson Posted August 19, 2014 Posted August 19, 2014 I get this sort of error it seems like every time I come back to Dreamcast after not playing for a while and then it takes forever to figure it out again from scratch. And I am not smart enough to understand the fancy module that is supplied for nullDC....so I put my own together. Seems to load .cdi and gdi (inside zipped files) fine so far. A few dont work but they dont work outside of hyperspin/hyperlaunch so thats probably a bad .cdi file issue or something....... no fullscreen support because I am using a bezel and this emulator seems to remember its fullscreen status...so open it outside hyperspin .... fullscreen it....then close it...viola it has a blockinput command which on my system requires hyperspin and xpadder to be run as administrators....just fyi MEmu = NullDC MEmuV = r141 MURL = https://code.google.com/p/nulldc/ MAuthor = MVersion = MCRC = iCRC = MID = MSystem = "Sega Dreamcast" BlockInput, On StartModule() BezelGUI() FadeInStart() settingsFile := modulePath . "\" . moduleName . ".ini" Fullscreen := IniReadCheck(settingsFile, "Settings", "Fullscreen","true",,1) BezelStart() 7z(romPath, romName, romExtension, 7zExtractPath) Run(executable, emuPath) WinWait("nullDC ahk_class ndc_main_window") WinWaitActive("nullDC ahk_class ndc_main_window") Sleep, 500 WinMenuSelectItem,nullDC ahk_class ndc_main_window,,File,Normal Boot WinWait("Select Image File ahk_class #32770") WinWaitActive("Select Image File ahk_class #32770") Sleep, 1111 Loop { ControlGetText, edit1Text, Edit1, Select Image File ahk_class #32770 If ( edit1Text = romPath . "\" . romName . romExtension ) Break Sleep, 100 ControlSetText, Edit1, %romPath%\%romName%%romExtension%, Select Image File ahk_class #32770 } Sleep, 1000 ControlSend, Button1, {Enter}, Select Image File ahk_class #32770 Sleep, 500 WinMinimize, nullDC ahk_class ConsoleWindowClass BlockInput, Off FadeInExit() BezelDraw() Process("WaitClose", executable) 7zCleanUp() BezelExit() FadeOutExit() ExitModule() CloseProcess: FadeOutStart() WinClose("nullDC ahk_class ndc_main_window") Process, Close, nullDC_Win32_Release-NoTrace.exe Return Under Options > GDRom ---> I have everything unchecked...... and in task manager my nulldc is listed as "nullDC_Win32_Release-NoTrace.exe"....I use a process, close command in the .ahk file and i also made my nulldc.cfg file "read only"...not sure if that is necessary but emulator SEEMs like it forgets setting...dunno here it is in action (with fade turned off) ZuN5hITty3M http://craigandersonthemes.weebly.com/
