RocketLaunch and UI run games fine, Just not in Hyperspin. Can't Start a game...Please help!!!
Flynn's
Hi there,
       I have been following Simply Austin's Tutorials for setting up the hyperspin, hyperlaunch and rocketlaunch applications. I have it so that I can get to the Roms in the hyperspin programarrow-10x10.png...but if I try to start one, it will not run. The ROMS works great in the Rocketlauncher UI programarrow-10x10.png and also RocketLauncher.
      It does not  NOT launch in the Hyperlaunch program either.
      And recently whilst trying to fix the issues I've been having, i have been receiving the Start Module error. Just trying to get it so that i can get the front end working good with the rest of the stuff. anything that any of you guys can help me out with would be most appreciated.
       Thanks.
I like rocketlauncher, but for some reason everything is gearing to hyperlaunch I think and not working, otherwise it would work because rocketlaunch works. right? is there standard things i need to make sure to change for rocketlaunch to be accepted over hyperlaunch.  Thanks again
I've gotten it to work. but now the issue is that hyperlaunch stays on in the background after one game and wont allow you to star another in hyperspin. suggestions?
Hi, I would try a clean install of RL (in an x:\RocketLauncher folder rather than inside x:\HyperSpin) and use the RL Transition Tool and the "Convert Hyperspin Only" button to fix up HS settings to point to RL and not HL
