Sega M2 games will not load in RL
doyoudesign
I can launch M2 games outside of RL fine...they load very fast.  But in RL they always crash the program?
for 7z option I have it set to True and use global..then in settings I have by Skip checks: rom extension...with out this checked it said the rom extensions were not valid.
Any help?
Ron over at RL said to try:
Click Sega Model 2 on the left.
Click Settings on top and the Main Settings sub-tab.
Set 7z to false.
Set Skip Checks to False.
worked like a charm!!
Also for some reason windows was bringing up an alert in the background if it should trust the emu...so I clicked yes to that...however it was doing all this behind the Fade page art...finally saw what it was doing there via the tool bar.  Once I clicked yes the above fixes worked.
I set up my hyper spin via Simply Austin's YouTube videos...try setting everything up via his tutorials...pretty good.  Had 3 gliches but everything else worked.  If still doesn't work try posting on RocketLauncher forum.  You just post your error log and they try to solve it.
I went back through still not working. I test in rocketlauncher and it loads at best the sega m2 emulator no game... I checked the log and the error is.. ScriptError - You did not supply any valid rom extensions to search for in your compressed roms. Please turn off 7z support or add at least one rom extension to Rom_Extension: "zip". If this archive has no roms with a standard romName inside, you may need to set Skip Checks to "Rom Extension."?
I tired what they said to skip checks.. did not help. The ext is set to zip by default. How the heck to I have hyperspin update the log for it? I have checked but its an old one.. I have it set to TROUBLE SHOOTING.. in RocketlauncherUI. It looks like its a similar issue I had in the past with NON updated syustems in the new rocket launcher... I think I might just wait until I become premium so this issue is done.
Did you put the correct extensions of the roms in?  I know I had the problem of following Austin's tutorial but the prob was the roms I had were a different extenion then what he had.  The other problem I had was the rom set themselves.  The labeling of the roms have to be exact match with hyperspin. At first I downloaded the renaming app and that didn't do much to make things work.   If you search for hyperspin versions that will save a ton of headaches.  Had to learn that one the hard way.  LOL.  So after getting 3-4 bad versions i finally found the set that worked.  Getting HS working was a crazy pain the ass.  But after it works man it's nice!!!  Keep at it...you're close.
Keep posting your logs over in the RL forum they're pretty quick to see the problem.
Thanks.. Well the roms that I have worked before with HL? I will double check. In regards to the extension, I have it set to zip as the roms are zipped, however unzipped the roms have a weird ext.. .01, .02 etc?
I also noticed that the version Austin provides is 1.1a while the module calls for v1.0. Trying that too.
ScriptError - There was an error waiting for the window "ahk_class MYWIN". Please check you have the correct version emulator installed for this module, followed any notes in the module, and have this emulator working outside your Frontend first. Also turn off Fade to see if you are hiding your problem.
That is the error I get. I have double checked and I am not using Sega Model 2 V1.0 as per the module.
I have tried 7z to FALSE and SKIP TO False.. it did not work.
I have checked the paths for roms/emulators they are correct. The roms are .zip and all is set to .zip in the sega model 2 tab.
The emulator opens up but does not play the clicked game.
All the games are listed in green when I check in the games tab.
The emulator works fine outside of RL. I am baffled.
20:21:43:396 | RL | INFO | +N/A | Main - RocketLauncher v1.0.0.1 (www.rlauncher.com)
20:21:43:399 | RL | WARNING | +0 | Main - You have "Logging_Show_Command_Window" enabled. This is only for showing errors being dumped to the command window from an executable. This may cause issues with running some executables and needs to be turned off when you are done.
20:21:43:399 | RL | WARNING | +0 | Main - You have "Logging_Log_Command_Window" enabled. This is only for logging errors being dumped to the command window from an executable. This may cause issues with running some executables and needs to be turned off when you are done.
20:21:43:401 | RL | WARNING | +0 | Main - You cannot use debug console and show/log a console for an emulator simultaneously. Turning off debug console to avoid errors launching.
20:21:43:466 | RL | INFO | +63 | Main - System Specs:
RocketLauncher Dir: E:\Rocketlauncher
RocketLauncher is: 32-bit
OS: Microsoft Windows 7 Professional
SKU: Professional
Total Memory: 8016.31 MB
Free Memory: 4884.85 MB
Used Memory: 3131.465 MB
SystemType: 64-bit
Physical Processors: 1
Logical Processors: 4
GPU 1 Name: Intel® HD Graphics
GPU 1 RAM: -1924.00 MB
GPU 1 Driver Version: 9.17.10.3347
Sound 1 Device: High Definition Audio Device
Sound 1 Status: Enabled
Sound 2 Device: High Definition Audio Device
Sound 2 Status: Enabled
OS Admin Status: Yes
Monitor #1 (\\.\DISPLAY1): 1440x900 (1440x856 work)
Monitor #1 Orientation: Landscape
Current AHK Desktop Width: 1440
Current AHK Desktop Height: 900
AutoHotkey Path:
AHK Version: 1.1.09.04
Unicode: No
20:21:43:466 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\RocketLauncher.exe exists
20:21:43:469 | RL | DEBUG1 | +0 | CheckFile - Attributes:
FileDescription RocketLauncher
FileVersion 1.0.0.1
LegalCopyright ©2015 RocketLauncher
ProductName djvj's one swell guy!
ProductVersion 1.1.9.4
CompanyName Your favorite Front End companion! Visit us @ www.rlauncher.com
File Size: 2084352 bytes
Created: 5/23/2015 - 11:53:13 PM
Modified: 5/30/2015 - 10:19:17 PM
20:21:43:471 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\BinHexRW.ahk exists
20:21:43:479 | RL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library.
20:21:43:486 | RL | DEBUG1 | +0 | CheckFile - Attributes:
File Size: 4961 bytes
Created: 5/24/2015 - 9:27:48 AM
Modified: 6/4/2014 - 11:48:13 PM
20:21:43:486 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\BlockInput.exe exists
20:21:43:489 | RL | DEBUG1 | +16 | CheckFile - Attributes:
FileDescription
FileVersion 1.1.09.04
InternalName
OriginalFilename
ProductName
ProductVersion 1.1.09.04
File Size: 657920 bytes
Created: 5/24/2015 - 9:26:42 AM
Modified: 1/2/2014 - 11:27:34 PM
20:21:43:491 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\CLR.ahk exists
20:21:43:496 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension.
20:21:43:496 | RL | DEBUG1 | +0 | CheckFile - Attributes:
File Size: 10586 bytes
Created: 5/24/2015 - 9:27:29 AM
Modified: 3/5/2013 - 10:21:59 PM
20:21:43:499 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\COM.ahk exists
20:21:43:506 | RL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Extension.
20:21:43:509 | RL | DEBUG1 | +0 | CheckFile - Attributes:
File Size: 26342 bytes
Created: 5/24/2015 - 9:28:19 AM
Modified: 3/5/2013 - 10:22:00 PM
20:21:43:511 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Control_AniGif.ahk exists
20:21:43:516 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension.
20:21:43:519 | RL | DEBUG1 | +0 | CheckFile - Attributes:
File Size: 5716 bytes
Created: 5/24/2015 - 9:26:30 AM
Modified: 4/29/2013 - 2:56:02 PM
20:21:43:521 | RL | INFO | +16 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\gdip.ahk exists
20:21:43:524 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension.
20:21:43:526 | RL | DEBUG1 | +0 | CheckFile - Attributes:
File Size: 88789 bytes
Created: 5/24/2015 - 8:02:39 AM
Modified: 1/13/2013 - 6:07:30 PM
20:21:43:529 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\gdip_alt.ahk exists
20:21:43:536 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library.
20:21:43:539 | RL | DEBUG1 | +0 | CheckFile - Attributes:
File Size: 3394 bytes
Created: 5/24/2015 - 9:25:59 AM
Modified: 1/4/2015 - 8:44:09 PM
20:21:43:541 | RL | DEBUG1 | +0 | gdip_alt.ahk Version: 1.0.1
20:21:43:544 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\gsdll32.dll exists
20:21:43:544 | RL | DEBUG1 | +0 | CheckFile - Attributes:
File Size: 13090816 bytes
Created: 5/24/2015 - 9:25:19 AM
Modified: 1/6/2015 - 10:20:42 PM
20:21:43:546 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\itextsharp.dll exists
20:21:43:549 | RL | DEBUG1 | +0 | CheckFile - Attributes:
FileDescription iTextSharp
FileVersion 5.4.2.0
InternalName itextsharp.dll
LegalCopyright Copyright © 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved.
OriginalFilename itextsharp.dll
ProductName iTextSharp
ProductVersion 5.4.2.0
CompanyName 1T3XT BVBA
File Size: 3743744 bytes
Created: 5/24/2015 - 9:24:07 AM
Modified: 6/14/2013 - 3:06:21 PM
20:21:43:551 | RL | INFO | +15 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Java.ahk exists
20:21:43:554 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library.
20:21:43:556 | RL | DEBUG1 | +0 | CheckFile - Attributes:
File Size: 7841 bytes
Created: 5/24/2015 - 9:27:37 AM
Modified: 12/24/2014 - 12:02:37 AM
20:21:43:559 | RL | DEBUG1 | +0 | Java.ahk Version: 1.0.0
20:21:43:559 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\JSON.ahk exists
20:21:43:564 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension.
20:21:43:566 | RL | DEBUG1 | +0 | CheckFile - Attributes:
File Size: 9203 bytes
Created: 5/24/2015 - 9:26:08 AM
Modified: 5/5/2013 - 3:22:25 PM
20:21:43:566 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Origin.ahk exists
20:21:43:579 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library.
20:21:43:581 | RL | DEBUG1 | +0 | CheckFile - Attributes:
File Size: 4904 bytes
Created: 5/24/2015 - 9:26:27 AM
Modified: 3/22/2015 - 3:51:41 PM
20:21:43:584 | RL | DEBUG1 | +15 | Origin.ahk Version: 1.0.2
20:21:43:586 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\RegRW64.ahk exists
20:21:43:589 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension.
20:21:43:591 | RL | DEBUG1 | +0 | CheckFile - Attributes:
File Size: 6915 bytes
Created: 5/24/2015 - 9:28:09 AM
Modified: 5/8/2014 - 4:06:39 AM
20:21:43:594 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\RIni.ahk exists
20:21:43:599 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Extension.
20:21:43:601 | RL | DEBUG1 | +0 | CheckFile - Attributes:
File Size: 67561 bytes
Created: 5/24/2015 - 9:28:04 AM
Modified: 6/5/2013 - 7:56:23 PM
20:21:43:604 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\SevenZipSharp.dll exists
20:21:43:606 | RL | DEBUG1 | +0 | CheckFile - Attributes:
FileDescription SevenZipSharp
FileVersion 0.64.4841.31212
InternalName SevenZipSharp.dll
LegalCopyright Copyright © Markovtsev Vadim 2009, 2010, licenced under LGPLv3
OriginalFilename SevenZipSharp.dll
ProductName SevenZipSharp
ProductVersion 0.64.4841.31212
CompanyName Markovtsev Vadim
File Size: 165888 bytes
Created: 5/24/2015 - 9:27:30 AM
Modified: 4/21/2013 - 12:08:10 AM
20:21:43:606 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Steam.ahk exists
20:21:43:611 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library.
20:21:43:614 | RL | DEBUG1 | +16 | CheckFile - Attributes:
File Size: 5347 bytes
Created: 5/24/2015 - 9:28:20 AM
Modified: 3/22/2015 - 3:52:25 PM
20:21:43:614 | RL | DEBUG1 | +0 | Steam.ahk Version: 1.0.2
20:21:43:616 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\VA.ahk exists
20:21:43:619 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension.
20:21:43:621 | RL | DEBUG1 | +0 | CheckFile - Attributes:
File Size: 34688 bytes
Created: 5/24/2015 - 9:26:53 AM
Modified: 3/1/2013 - 10:05:47 PM
20:21:43:624 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\VA_Extension.ahk exists
20:21:43:641 | RL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library.
20:21:43:644 | RL | DEBUG1 | +0 | CheckFile - Attributes:
File Size: 3833 bytes
Created: 5/24/2015 - 9:28:38 AM
Modified: 1/13/2015 - 9:16:56 PM
20:21:43:646 | RL | DEBUG1 | +16 | VA_Extension.ahk Version: 1.0.1
20:21:43:646 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\7z.ahk exists
20:21:43:651 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library.
20:21:43:654 | RL | DEBUG1 | +0 | CheckFile - Attributes:
File Size: 29133 bytes
Created: 5/30/2015 - 12:47:30 AM
Modified: 5/30/2015 - 12:47:30 AM
20:21:43:656 | RL | DEBUG1 | +0 | 7z.ahk Version: 1.0.0
20:21:43:659 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Bezel.ahk exists
20:21:43:664 | RL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library.
20:21:43:666 | RL | DEBUG1 | +0 | CheckFile - Attributes:
File Size: 101747 bytes
Created: 5/24/2015 - 9:28:01 AM
Modified: 4/9/2015 - 5:13:13 AM
20:21:43:669 | RL | DEBUG1 | +0 | Bezel.ahk Version: 1.1.0
20:21:43:669 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Fade.ahk exists
20:21:43:674 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library.
20:21:43:676 | RL | DEBUG1 | +16 | CheckFile - Attributes:
File Size: 36786 bytes
Created: 5/24/2015 - 9:26:50 AM
Modified: 5/30/2015 - 10:18:58 PM
20:21:43:679 | RL | DEBUG1 | +0 | Fade.ahk Version: 1.0.10
20:21:43:679 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Fade Init.ahk exists
20:21:43:694 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library.
20:21:43:696 | RL | DEBUG1 | +0 | CheckFile - Attributes:
File Size: 999 bytes
Created: 5/24/2015 - 9:27:38 AM
Modified: 12/24/2014 - 12:21:02 AM
20:21:43:699 | RL | DEBUG1 | +0 | Fade Init.ahk Version: 1.0.1
20:21:43:701 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Fade Animations.ahk exists
20:21:43:706 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library.
20:21:43:706 | RL | DEBUG1 | +0 | CheckFile - Attributes:
File Size: 79822 bytes
Created: 5/24/2015 - 9:27:41 AM
Modified: 5/30/2015 - 10:18:25 PM
20:21:43:709 | RL | DEBUG1 | +15 | Fade Animations.ahk Version: 1.1.6
20:21:43:711 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Pause.ahk exists
20:21:43:721 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library.
20:21:43:724 | RL | DEBUG1 | +16 | CheckFile - Attributes:
File Size: 379298 bytes
Created: 5/24/2015 - 9:26:19 AM
Modified: 5/30/2015 - 10:18:20 PM
20:21:43:726 | RL | DEBUG1 | +0 | Pause.ahk Version: 1.1.0
20:21:43:729 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Pause Init.ahk exists
20:21:43:731 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library.
20:21:43:734 | RL | DEBUG1 | +0 | CheckFile - Attributes:
File Size: 590 bytes
Created: 5/24/2015 - 9:24:21 AM
Modified: 4/9/2015 - 5:13:29 AM
20:21:43:736 | RL | DEBUG1 | +0 | Pause Init.ahk Version: 1.0.2
20:21:43:736 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Keymapper.ahk exists
20:21:43:741 | RL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library.
20:21:43:744 | RL | DEBUG1 | +0 | CheckFile - Attributes:
File Size: 33453 bytes
Created: 5/24/2015 - 9:28:11 AM
Modified: 5/30/2015 - 10:18:27 PM
20:21:43:751 | RL | DEBUG1 | +0 | Keymapper.ahk Version: 1.1.2
20:21:43:751 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Keymapper Init.ahk exists
20:21:43:766 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library.
20:21:43:769 | RL | DEBUG1 | +0 | CheckFile - Attributes:
File Size: 3461 bytes
Created: 5/24/2015 - 9:26:35 AM
Modified: 5/30/2015 - 10:18:57 PM
20:21:43:771 | RL | DEBUG1 | +16 | Keymapper Init.ahk Version: 1.0.4
20:21:43:774 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\MultiGame.ahk exists
20:21:43:779 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library.
20:21:43:779 | RL | DEBUG1 | +0 | CheckFile - Attributes:
File Size: 40639 bytes
Created: 5/24/2015 - 9:24:03 AM
Modified: 4/7/2015 - 3:49:26 PM
20:21:43:781 | RL | DEBUG1 | +0 | MultiGame.ahk Version: 1.0.6
20:21:43:784 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\MultiGame Init.ahk exists
20:21:43:786 | RL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library.
20:21:43:789 | RL | DEBUG1 | +0 | CheckFile - Attributes:
File Size: 161 bytes
Created: 5/24/2015 - 9:28:32 AM
Modified: 4/14/2013 - 2:33:19 PM
20:21:43:791 | RL | DEBUG1 | +0 | MultiGame Init.ahk Version: 1.0.0
20:21:43:791 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\MultiPlayer.ahk exists
20:21:43:796 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library.
20:21:43:799 | RL | DEBUG1 | +0 | CheckFile - Attributes:
File Size: 58641 bytes
Created: 5/24/2015 - 9:23:41 AM
Modified: 4/9/2015 - 5:15:25 AM
20:21:43:801 | RL | DEBUG1 | +16 | MultiPlayer.ahk Version: 1.0.5
20:21:43:801 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Password.ahk exists
20:21:43:806 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library.
20:21:43:809 | RL | DEBUG1 | +0 | CheckFile - Attributes:
File Size: 10040 bytes
Created: 5/24/2015 - 9:24:18 AM
Modified: 4/9/2015 - 5:15:55 AM
20:21:43:811 | RL | DEBUG1 | +0 | Password.ahk Version: 1.0.1
20:21:43:811 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Rom Mapping Launch Menu.ahk exists
20:21:43:819 | RL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library.
20:21:43:821 | RL | DEBUG1 | +0 | CheckFile - Attributes:
File Size: 73587 bytes
Modified: 4/9/2015 - 5:16:26 AM
20:21:43:824 | RL | DEBUG1 | +0 | Rom Mapping Launch Menu.ahk Version: 1.0.4
20:21:43:824 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Shared.ahk exists
20:21:43:831 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library.
20:21:43:834 | RL | DEBUG1 | +16 | CheckFile - Attributes:
File Size: 110446 bytes
20:21:43:836 | RL | DEBUG1 | +0 | Shared.ahk Version: 1.2.6
20:21:43:839 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Statistics.ahk exists
20:21:43:844 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library.
20:21:43:844 | RL | DEBUG1 | +0 | CheckFile - Attributes:
File Size: 26143 bytes
Created: 5/24/2015 - 9:26:45 AM
Modified: 4/9/2015 - 5:16:56 AM
20:21:43:849 | RL | DEBUG1 | +16 | Statistics.ahk Version: 1.0.3
20:21:43:849 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Statistics Init.ahk exists
20:21:43:851 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library.
20:21:43:854 | RL | DEBUG1 | +0 | CheckFile - Attributes:
File Size: 33 bytes
Modified: 12/24/2014 - 12:23:48 AM
20:21:43:856 | RL | DEBUG1 | +0 | Statistics Init.ahk Version: 1.0.1
20:21:43:859 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Virtual Drive.ahk exists
20:21:43:861 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library.
20:21:43:864 | RL | DEBUG1 | +15 | CheckFile - Attributes:
File Size: 17072 bytes
Created: 5/30/2015 - 12:47:33 AM
Modified: 5/30/2015 - 12:47:33 AM
20:21:43:866 | RL | DEBUG1 | +0 | Virtual Drive.ahk Version: 1.0.0
20:21:43:866 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\XHotkey.ahk exists
20:21:43:876 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library.
20:21:43:879 | RL | DEBUG1 | +16 | CheckFile - Attributes:
File Size: 29626 bytes
Created: 5/24/2015 - 9:28:26 AM
Modified: 4/9/2015 - 5:17:24 AM
20:21:43:881 | RL | DEBUG1 | +0 | XHotkey.ahk Version: 1.0.3
20:21:43:884 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\XHotkey Init.ahk exists
20:21:43:886 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library.
20:21:43:889 | RL | DEBUG1 | +0 | CheckFile - Attributes:
File Size: 1236 bytes
Created: 5/24/2015 - 9:26:46 AM
Modified: 4/14/2013 - 2:33:16 PM
20:21:43:889 | RL | DEBUG1 | +0 | XHotkey Init.ahk Version: 1.0.0
20:21:43:891 | RL | DEBUG1 | +0 | Main - Using HyperSpin legacy mode for version 1.3.2.0 found at: E:\HyperSpin\HyperSpin.exe
20:21:43:894 | RL | DEBUG1 | +0 | Main - Raw CLI received: "E:\Hyperspin\Emulators\Sega Model 2\roms\daytona.zip, Sega Model 2 -f E:\HyperSpin\HyperSpin.exe -p HyperSpin"
20:21:43:896 | RL | DEBUG1 | +15 | Main - Received a full file path via CLI: "E:\Hyperspin\Emulators\Sega Model 2\roms\daytona.zip"
20:21:43:896 | RL | DEBUG1 | +0 | Main - dbFullName: daytona.zip
20:21:43:899 | RL | DEBUG1 | +0 | Main - dbName: daytona
20:21:43:901 | RL | DEBUG1 | +0 | Main - dbPath: E:\Hyperspin\Emulators\Sega Model 2\roms
20:21:43:901 | RL | DEBUG1 | +0 | Main - dbExt: zip
20:21:43:904 | RL | INFO | +0 | Main - HyperSpin.exe coordinates are x0 y0 w1440 h900
20:21:43:906 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Plugins\HyperSpin.plugin exists
20:21:43:906 | RL | DEBUG1 | +0 | CheckFile - Attributes:
File Size: 8969 bytes
Created: 5/24/2015 - 9:28:44 AM
Modified: 5/30/2015 - 10:18:21 PM
20:21:43:909 | RL | INFO | +0 | Main - Loading Front End Plugin: "HyperSpin"
20:21:43:911 | RL | INFO | +16 | Main - RocketLauncher received "Sega Model 2" and "daytona"
20:21:43:919 | RL | INFO | +0 | Main - Did not find a "E:\Rocketlauncher\Settings\Sega Model 2\Game Options.ini" file, skipping any game-specific options.
20:21:43:919 | RL | INFO | +0 | Main - daytona is using the default emulator: Sega Model 2 Emulator
20:21:43:921 | RL | INFO | +0 | Main - Checking for a [sega Model 2 Emulator] section in E:\Rocketlauncher\Settings\Sega Model 2\Emulators.ini
20:21:43:924 | RL | INFO | +0 | Main - Checking for a [sega Model 2 Emulator] section in E:\Rocketlauncher\Settings\Global Emulators.ini
20:21:43:924 | RL | INFO | +0 | Main - Found [sega Model 2 Emulator] in E:\Rocketlauncher\Settings\Global Emulators.ini
20:21:43:926 | RL | INFO | +16 | CheckFile - Checking if E:\Rocketlauncher\Modules\Sega Model 2 Emulator\Sega Model 2 Emulator.ahk exists
20:21:43:929 | RL | DEBUG1 | +0 | CheckFile - Attributes:
File Size: 12313 bytes
Created: 5/24/2015 - 9:26:55 AM
Modified: 4/4/2015 - 4:19:17 AM
20:21:43:934 | RL | INFO | +0 | Main - CRC Check - CRC matches, this is an official unedited module.
20:21:43:934 | RL | INFO | +0 | Main - daytona will use module: E:\Rocketlauncher\Modules\Sega Model 2 Emulator\Sega Model 2 Emulator.ahk
20:21:43:946 | RL | INFO | +15 | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
20:21:43:949 | RL | INFO | +0 | CheckFile - Checking if E:\Hyperspin\Emulators\Sega Model 2\emulator_multicpu.EXE exists
20:21:43:951 | RL | DEBUG1 | +0 | CheckFile - Attributes:
File Size: 1932288 bytes
Created: 5/31/2015 - 1:54:52 PM
Modified: 3/17/2011 - 5:44:56 AM
20:21:43:954 | RL | INFO | +0 | Main - INI Keys read
20:21:43:954 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\7z.exe exists
20:21:43:956 | RL | DEBUG1 | +0 | CheckFile - Attributes:
FileDescription 7-Zip Console
FileVersion 9.20
InternalName 7z
LegalCopyright Copyright © 1999-2010 Igor Pavlov
OriginalFilename 7z.exe
ProductName 7-Zip
ProductVersion 9.20
CompanyName Igor Pavlov
File Size: 163840 bytes
Created: 5/24/2015 - 9:26:40 AM
Modified: 3/5/2013 - 10:21:50 PM
20:21:43:959 | RL | INFO | +16 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\7z.dll exists
20:21:43:961 | RL | DEBUG1 | +0 | CheckFile - Attributes:
FileDescription 7z Standalone Plugin
FileVersion 9.20
InternalName 7za
OriginalFilename 7za.dll
ProductName 7-Zip
ProductVersion 9.20
File Size: 914432 bytes
Created: 5/24/2015 - 9:28:28 AM
Modified: 3/5/2013 - 10:21:49 PM
20:21:43:961 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\FontReg.exe exists
20:21:43:964 | RL | DEBUG1 | +0 | CheckFile - Attributes:
FileDescription Font Registration Utility (x86-32)
FileVersion 2.1.3.0
OriginalFilename FontReg.exe
File Size: 6144 bytes
Created: 5/24/2015 - 9:27:26 AM
Modified: 3/6/2011 - 1:06:05 AM
20:21:43:969 | RL | INFO | +0 | Main - "daytona" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side
20:21:43:969 | RL | INFO | +0 | CheckPaths - Started
20:21:43:971 | RL | INFO | +0 | CheckPaths - Not scanning to find the rom because a full path was supplied to RocketLauncher via CLI
20:21:43:971 | RL | DEBUG1 | +0 | CheckPaths - Current romName: daytona
20:21:43:974 | RL | DEBUG1 | +15 | CheckPaths - Current romPath: E:\Hyperspin\Emulators\Sega Model 2\roms
20:21:43:974 | RL | DEBUG1 | +0 | CheckPaths - Current romExtension: .zip
20:21:43:976 | RL | INFO | +0 | CheckPaths - Ended
20:21:43:979 | RL | INFO | +0 | BuildScript - User Variables:
; INJECTED VARIABLES
#NoTrayIcon
#InstallKeybdHook
DetectHiddenWindows, ON
SetTitleMatchMode, 2
SendMode, Event
0 = 6
pluginPath = E:\Rocketlauncher\Plugins
pluginName = HyperSpin
pluginExt = .plugin
contextOnExit =
rlMode =
rlTitle = RocketLauncher
rlVersion = 1.0.0.1
rlAuthor = djvj
rlURL = www.rlauncher.com
langFile = E:\Rocketlauncher\Data\Language\Localization.ini
frontendPID = 4696
frontendPath = E:\HyperSpin
frontendExe = HyperSpin.exe
frontendExt = exe
frontendName = HyperSpin
frontendDrive = E:
exitEmulatorKey = ~Esc
exitEmulatorKeyWait = 0
forceHoldKey = ~Esc
restoreFE = false
exitScriptKey = ~q & ~s
toggleCursorKey = ~e & ~t
emuFullPath = E:\Hyperspin\Emulators\Sega Model 2\emulator_multicpu.EXE
emuPath = E:\Hyperspin\Emulators\Sega Model 2
emuName = Sega Model 2 Emulator
emuExt = EXE
romPath = E:\Hyperspin\Emulators\Sega Model 2\roms
romPathFromIni = E:\Hyperspin\Emulators\Sega Model 2\roms
romExtension = .zip
romExtensionOrig = .zip
romExtensions = zip
executable = emulator_multicpu.EXE
systemDbName = Sega Model 2
systemName = Sega Model 2
dbPath = E:\Hyperspin\Emulators\Sega Model 2\roms
dbName = daytona
dbExt = zip
romName = daytona
romMapPath =
romMappingEnabled = false
romMappingMenuWidth = 400
romMappingMenuMargin = 65
romMappingTextMargin = 15
romMappingMenuFlagWidth = 55
altArchiveNameOnly =
altRomNameOnly =
altArchiveAndRomName =
altArchiveAndManyRomNames =
altRomNamesOnly =
romMapScenario =
skipchecks = false
romMatchExt = false
blockInputTime = 0
blockInputFile = E:\Rocketlauncher\Module Extensions\BlockInput.exe
errorLevelReporting = false
lockLaunch = false
lockLaunchGame =
screenRotationAngle = 0
screenRotationAngleGame =
logFile = E:\Rocketlauncher\RocketLauncher.log
logLabel := [" INFO"," WARNING"," ERROR"," DEBUG1"," DEBUG2"]
logLevel = 10
logShowDebugConsole = false
logIncludeModule = true
logShowCommandWindow = true
logCommandWindow = true
rlDebugConsoleStdout =
sysType = 64-bit
navUpKey = Up
navDownKey = Down
navLeftKey = Left
navRightKey = Right
navSelectKey = Enter
navP2UpKey = Numpad8
navP2DownKey = Numpad2
navP2LeftKey = Numpad4
navP2RightKey = Numpad6
navP2SelectKey = NumpadEnter
originalWidth = 1440
originalHeight = 900
vdEnabled = false
vdFullPath =
vdUseSCSI = true
vdDriveLetter =
vdAddDrive = true
servoStikEnabled = false
ledblinkyEnabled = false
ledblinkyFullPath =
ledblinkyProfilePath = E:\Rocketlauncher\Profiles\LEDBlinky
ledblinkyRLProfile = E:\Rocketlauncher\Profiles\LEDBlinky\RocketLauncher
emuIdleShutdown = 0
hideCursor = false
hideEmu = false
hideFE = false
fadeIn = false
fadeInDuration = 500
fadeInDelay = 0
fadeInExitDelay = 0
fadeOutExitDelay = 0
fadeOut = false
fadeOutExtraScreen = false
fadeOutDuration = 500
fadeOutDelay = 0
fadeLyrInterpolation = 7
fadeMuteEmulator = false
fadeUseBackgrounds = false
fadeWidthBaseRes = 1920
fadeHeightBaseRes = 1080
fadeLyr1Color = FF000000
fadeLyr2X = 0
fadeLyr2Y = 0
fadeLyr2W =
fadeLyr2H =
fadeLyr2Adjust = 1
fadeLyr2PicPad = 0
fadeLyr3Pos = Center
fadeLyr3X = 450
fadeLyr3Y = 450
fadeLyr3W =
fadeLyr3H =
fadeLyr3Adjust = 1
fadeLyr3PicPad = 0
fadeLyr3Speed = 750
fadeLyr3Type = imageandbar
fadeLyr3Repeat = 1
fadeLyr3StaticX = 0
fadeLyr3StaticY = 870|1575
fadeLyr3StaticW =
fadeLyr3StaticH =
fadeLyr3StaticAdjust = 1
fadeLyr3StaticPicPad = 0
fadeLyr4Adjust = 1
fadeLyr4X = 1792|952
fadeLyr4Y = 891|1596
fadeLyr4W = 128
fadeLyr4H =
fadeLyr4Pos = No Alignment
fadeLyr4FPS = 50
fadeLyr4PicPad = 0
fadeTranspGifColor = FFFFFF
fadeBarWindow = Image
fadeBarWindowX =
fadeBarWindowY =
fadeBarWindowW = 900
fadeBarWindowH =
fadeBarWindowR = 30
fadeBarWindowM = 30
fadeBarWindowHatchStyle = 8
fadeBar = 7zOnly
fadeBarNon7zProgressTime = 0
fadeBarBack = true
fadeBarBackColor = FF555555
fadeBarH = 30
fadeBarR = 10
fadeBarColor = DD00BFFF
fadeBarHatchStyle = 8
fadeBarPercentageText = true
fadeBarInfoText = true
fadeBarXOffset = 0
fadeBarYOffset = 150
fadeRomInfoSystemName = image
fadeRomInfoManufacturer = text with label
fadeRomInfoGenre = disabled
fadeRomInfoRating = image
fadeRomInfoTextMargin = 7
fadeStatsInfoTextMargin = 7
fadeText1X = 0
fadeText1Y = 0
fadeText1 = Loading Game
fadeText2X = 0
fadeText2Y = 0
fadeText3 = Loading Game
fadeText4 = Loading Complete
fadeFont = Bebas Neue
fadeExtractionTime = disabled
fadeExtractionTimeTextX = 0
fadeExtractionTimeTextY = 0
fadeInterruptKey =
detectFadeErrorEnabled = true
fadeImgPath = E:\Rocketlauncher\Media\Fade
RLDataPath = E:\Rocketlauncher\Data
RLMediaPath = E:\Rocketlauncher\Media
RLErrSoundPath = E:\Rocketlauncher\Media\Sounds\Error
modulesPath = E:\Rocketlauncher\Modules
moduleFullName = E:\Rocketlauncher\Modules\Sega Model 2 Emulator\Sega Model 2 Emulator.ahk
moduleName = Sega Model 2 Emulator
modulePath = E:\Rocketlauncher\Modules\Sega Model 2 Emulator
moduleExtension = ahk
moduleExtensionsPath = E:\Rocketlauncher\Module Extensions
libPath = E:\Rocketlauncher\Lib
7zEnabled = false
7zPath = E:\Rocketlauncher\Module Extensions\7z.exe
7zDllPath = E:\Rocketlauncher\Module Extensions\7z.dll
7zExtractPath = C:\Users\Lenovo\AppData\Local\Temp\HS
7zExtractPathOrig =
7zAttachSystemName = false
7zDelTemp = true
7zSounds = true
mgEnabled = false
mgKey = ~NumpadSub
mgBackgroundColor = FF000000
mgSidePadding = 0.2
mgWidthBaseRes = 1920
mgHeightBaseRes = 1080
mgYOffset = 500|800
mgFont = Arial
mgText2Offset = 100
mgUseSound = true
mgSoundfreq = 300
mgExitEffect = none
mgSelectedEffect = rotate
mgUseGameArt = false
mgCandidate =
mgOnLaunch = false
pauseEnabled = false
pauseKey = ~NumpadAdd
pauseBackToMenuBarKey = X
pauseZoomInKey = C
pauseZoomOutKey = V
pauseHiToTextPath = E:\Rocketlauncher\Module Extensions\HiToText.exe
pauseSaveStateKeyCodes =
pauseLoadStateKeyCodes =
keymapperEnabled = false
keymapperAHKMethod = false
keymapper = xpadder
xpadderFullPath = E:\Utilities\Xpadder\xpadder.exe
joyToKeyFullPath = E:\Utilities\JoyToKey\JoyToKey.exe
keymapperProfilePath = E:\Rocketlauncher\Profiles\xpadder
keymapperFrontEndProfileName = RocketLauncherUI
JoyIDsEnabled = false
JoyIDsPreferredControllersSystem = use_global
JoyIDsPreferredControllersGlobal =
CustomJoyNamesEnabled = false
CustomJoyNames =
rotateMethod = false
FEProfile = E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI
defaultProfile = E:\Rocketlauncher\Profiles\xpadder\_Default
systemProfile = E:\Rocketlauncher\Profiles\xpadder\Sega Model 2
xPadderSystemProfile = E:\Rocketlauncher\Profiles\xpadder\Sega Model 2\_Default
emuProfile = E:\Rocketlauncher\Profiles\xpadder\Sega Model 2\Sega Model 2 Emulator
romProfile = E:\Rocketlauncher\Profiles\xpadder\Sega Model 2\daytona
RocketLauncherProfile = E:\Rocketlauncher\Profiles\xpadder\RocketLauncher
blankProfile = E:\Rocketlauncher\Profiles\xpadder\_Default\blank
ahkFEProfile = E:\Rocketlauncher\Profiles\AHK\RocketLauncherUI
ahkDefaultProfile = E:\Rocketlauncher\Profiles\AHK\_Default
ahkSystemProfile = E:\Rocketlauncher\Profiles\AHK\Sega Model 2
ahkEmuProfile = E:\Rocketlauncher\Profiles\AHK\Sega Model 2\Sega Model 2 Emulator
ahkRomProfile = E:\Rocketlauncher\Profiles\AHK\Sega Model 2\daytona
ahkRocketLauncherProfile = E:\Rocketlauncher\Profiles\AHK\RocketLauncher
bezelEnabled = false
bezelICEnabled = false
statisticsEnabled = true
pressDuration = -1
emuVolume = 1
dxwndIni = E:\Rocketlauncher\Module Extensions\dxwnd\dxwnd.ini
dxwndFullPath = E:\Rocketlauncher\Module Extensions\dxwnd\dxwnd.exe
mon1O = 0
pacDrivedllFile = E:\Rocketlauncher\Module Extensions\PacDrive32.dll
userFadeAnimIniFile = E:\Rocketlauncher\Lib\User Fade Animations.ini
20:21:43:981 | RL | INFO | +0 | BuildScript - Loaded XHotkey Init.ahk scripts
20:21:43:989 | RL | INFO | +16 | BuildScript - Loaded Statistics Init.ahk scripts
20:21:43:991 | RL | WARNING | +0 | BuildScript - "E:\Rocketlauncher\Lib\User Functions Init.ahk" not found
20:21:43:994 | RL | DEBUG1 | +0 | BuildScript - Module starts on line: 2
20:21:43:994 | RL | INFO | +0 | BuildScript - Validating module
20:21:43:996 | RL | INFO | +0 | BuildScript - Validation complete
20:21:43:999 | RL | INFO | +0 | BuildScript - Module:
MEmu = Sega Model 2 Emulator
MEmuV = v1.0
MURL = http://nebula.emulatronia.com/
MAuthor = djvj,ghutch92
MVersion = 2.0.8
MCRC = F8CE6B9D
iCRC = C842B2DD
mId = 635175648125374429
MSystem = "Sega Model 2"
; Notes:
; Oustide of Hyperspin, open the Sega Model 2 Emulator.
; Under Video enable "auto switch to fullscreen".
; model2.zip must exist in your rom path which contains the needed bios files for the system.
; Module settings overwrite what you have set in the emulator itself.
; For Multiplayer Support:
; To enable the linked games support, set Link_Enabled to true in the module settings in RocketLauncherUI
; The module has an internal list of games that it will only enable it for. Not all of the games work in this emu. See below for more info.
; 1.) Multiplayer does not work when the emulator is launched using the same executable in the same path.
; 2.) Multiplayer only works if player 1 is set to be in master mode and players 2-4 are set to be in slave mode. (this info is stored in the emupath\NVDATA folder, press F2 to set in game)
; 3.) Singleplayer only works if player 1 is set to be in single mode. (this info is stored in the emupath\NVDATA folder, press F2 to set in game)
; 4.) Only the active window accepts keyboard input.
; Fixed Issue 1 by having folders in the emupath named Player 2, Player 3, and Player 4 and within each of these folsers there are separate installs of sega model 2 emulator.
; Fixed Issue 2 and 3 for Player 1 by having a folder named "Multi" in the NVDATA folder for multiplayer dat files and a folder name "Single" in the NVDATA folder for single player dat files.
; Fixed Issue 4 by activating the first player window so first player always has the keyboard and players 2-4 have to use a joystick(gamepad).
;Games that have a working link:
; daytona,daytonagtx,daytonam,daytonas,daytonat,indy500,indy500d,manxtt,motoraid,skisuprg,srallyc,srallycb,srallyp,stcc,stcce,von,vonj,waverunr
; overrev and sgt24h both look like they can support link but I couldn't get it working, because I think m2emulator uses a linking hack to get these games to work in stand alone mode.
; Still need to see if waverunr, stcc, stcce, von, and vonj can link, I couldn't get these working, I think my processor is the issue here. Saw video of stcc & waverunr link working though.
; von and vonj can only do a 2 player link
StartModule()
BezelGUI()
linkEnabled := IniReadCheck(settingsFile, "Settings|" . romName, "Link_Enabled", "false",,1)
SplitScreen2PlayersMode := IniReadCheck(settingsFile, "Settings", "SplitScreen_2_Players","Vertical",,1) ;horizontal or vertical
SplitScreen3PlayersMode := IniReadCheck(settingsFile, "Settings", "SplitScreen_3_Players","P1top",,1) ; For Player1 screen to be on left: P1left. For Player1 screen to be on top: P1top. For Player1 screen to be on bottom: P1bottom. For Player1 screen to be on right: P1right.
If romName in daytona,daytonagtx,daytonam,daytonas,daytonat,indy500,indy500d,manxtt,motoraid,skisuprg,srallyc,srallycb,srallyp,stcc,stcce,von,vonj,waverunr
If (linkEnabled = "true") {
Log("Module - Link mode enabled")
linkEnabledGame := 1
If linkEnabledGame
If (romName = "von") or (romName = "vonj")
SelectedNumberofPlayers := NumberOfPlayersSelectionMenu(2)
Else
SelectedNumberofPlayers := NumberOfPlayersSelectionMenu(4)
FadeInStart()
fullscreen := IniReadCheck(settingsFile, "Settings", "Fullscreen","true",,1)
fullScreenWidth := IniReadCheck(settingsFile, "Settings", "FullScreenWidth",A_ScreenWidth,,1)
fullScreenHeight := IniReadCheck(settingsFile, "Settings", "FullScreenHeight",A_ScreenHeight,,1)
emupath2 := IniReadCheck(settingsFile, "Settings", "Player2_EmulatorPath",emupath . "\Player 2",,1) ;must be a unique path to same version of the emulator
emupath3 := IniReadCheck(settingsFile, "Settings", "Player3_EmulatorPath",emupath . "\Player 3",,1) ;must be a unique path to same version of the emulator
emupath4 := IniReadCheck(settingsFile, "Settings", "Player4_EmulatorPath",emupath . "\Player 4",,1) ;must be a unique path to same version of the emulator
CheckFile(romPath . "\model2.zip","Could not locate ""model2.zip"" which contains the bios files for this emulator. Please make sure it exists in the same folder as your roms.")
m2Ini := CheckFile(emuPath . "\EMULATOR.INI")
m2RomDir1 := IniReadCheck(m2Ini, "RomDirs", "Dir1",,,1)
If (m2RomDir1 != romPath)
IniWrite, %romPath%, %m2Ini%, RomDirs, Dir1 ; write the correct romPath to the emu's ini so the user does not need to define this
If SelectedNumberofPlayers > 1
BezelStart(SelectedNumberofPlayers)
Else
BezelStart()
hideEmuObj := Object("AHK_class MYWIN",1) ; Hide_Emu will hide these windows. 0 = will never unhide, 1 = will unhide later
; Write settings to m2's ini file - this needs to change also
IniWrite, % (If fullscreen = "true" ? 1 : 0), %m2Ini%, Renderer, AutoFull
IniWrite, %fullScreenWidth%, %m2Ini%, Renderer, FullScreenWidth
IniWrite, %fullScreenHeight%, %m2Ini%, Renderer, FullScreenHeight
If (SelectedNumberofPlayers = 1 || !linkEnabledGame) {
; Changing Cabinent Settings for player 1 this is because we will need to switch between master controller mode and single mode
; this info is stored in the NVDATA folder
; store single player settings in the NVDATA\Single folder and the Multiplayer Settings in the NVDATA\Multi folder
If (FileExist(emupath . "\NVDATA\Single\" . romName . ".DAT") && linkEnabledGame) {
Log("Overwriting " . emupath . "\NVDATA\" . romName . ".DAT with " . emupath . "\NVDATA\Single\" . romName . ".DAT")
FileCopy,%emupath%\NVDATA\Single\%romName%.DAT,%emupath%\NVDATA,1
HideEmuStart() ; This fully ensures windows are completely hidden even faster than winwait
Run(executable . A_Space . romName, emuPath, "Hide") ; Hides the emulator on launch. When bezel is enabled, this helps not show the emu before the rom is loaded
WinWait("ahk_class MYWIN",,,"Model 2 Emulator")
;WinWaitActive("ahk_class MYWIN",,,"Model 2 Emulator") ;this line only works if fade in is enabled
Sleep, 1000 ; Increase if Hyperspin is getting a quick flash in before the game loads
} Else {
;screen positions
If (SelectedNumberofPlayers = 2)
If SplitScreen2PlayersMode = Vertical
X1 := 0 , Y1 := 0 , W1 := A_ScreenWidth//2 , H1 := A_ScreenHeight , X2 := A_ScreenWidth//2 , Y2 := 0 , W2 := A_ScreenWidth//2 , H2 := A_ScreenHeight
Else
X1 := 0 , Y1 := 0 , W1 := A_ScreenWidth , H1 := A_ScreenHeight//2 , X2 := 0 , Y2 := A_ScreenHeight//2 , W2 := A_ScreenWidth , H2 := A_ScreenHeight//2
Else If (SelectedNumberofPlayers = 3)
If SplitScreen3PlayersMode = P1left
X1 := 0 , Y1 := 0 , W1 := A_ScreenWidth//2 , H1 := A_ScreenHeight , X2 := A_ScreenWidth//2 , Y2 := 0 , W2 := A_ScreenWidth//2 , H2 := A_ScreenHeight//2 , X3 := A_ScreenWidth//2 , Y3 := A_ScreenHeight//2 , W3 := A_ScreenWidth//2 , H3 := A_ScreenHeight//2
Else If SplitScreen3PlayersMode = P1bottom
X1 := 0 , Y1 := A_ScreenHeight//2 , W1 := A_ScreenWidth , H1 := A_ScreenHeight//2 , X2 := 0 , Y2 := 0 , W2 := A_ScreenWidth//2 , H2 := A_ScreenHeight//2 , X3 := A_ScreenWidth//2 , Y3 := 0 , W3 := A_ScreenWidth//2 , H3 := A_ScreenHeight//2
Else If SplitScreen3PlayersMode = P1right
X1 := A_ScreenWidth//2 , Y1 := 0 , W1 := A_ScreenWidth//2 , H1 := A_ScreenHeight , X2 := 0 , Y2 := 0 , W2 := A_ScreenWidth//2 , H2 := A_ScreenHeight//2 , X3 := 0 , Y3 := A_ScreenHeight//2 , W3 := A_ScreenWidth//2 , H3 := A_ScreenHeight//2
Else ; top
X1 := 0 , Y1 := 0 , W1 := A_ScreenWidth , H1 := A_ScreenHeight//2, X2 := 0 , Y2 := A_ScreenHeight//2 , W2 := A_ScreenWidth//2 , H2 := A_ScreenHeight//2, X3 := A_ScreenWidth//2 , Y3 := A_ScreenHeight//2 , W3 := A_ScreenWidth//2 , H3 := A_ScreenHeight//2
Else
X1 := 0 , Y1 := 0 , W1 := A_ScreenWidth//2 , H1 := A_ScreenHeight//2 , X2 := A_ScreenWidth//2 , Y2 := 0 , W2 := A_ScreenWidth//2 , H2 := A_ScreenHeight//2 , X3 := 0 , Y3 := A_ScreenHeight//2 , W3 := A_ScreenWidth//2 , H3 := A_ScreenHeight//2 , X4 := A_ScreenWidth//2 , Y4 := A_ScreenHeight//2 , W4 := A_ScreenWidth//2 , H4 := A_ScreenHeight//2
;this loop is for error checking since this emulator needs multiple instances of the emulator starting from different locations to run
Loop, %SelectedNumberofPlayers%
LinkedEmuPath := (A_Index = 1) ? (emupath) : (emupath%A_Index%)
CheckFile(LinkedEmuPath . "\" . executable)
CheckFile(LinkedEmuPath . "\EMULATOR.INI")
If FileExist(emupath . "\NVDATA\Multi\" . romName . ".DAT") {
Log("Overwriting " . emupath . "\NVDATA\" . romName . ".DAT with " . emupath . "\NVDATA\Multi\" . romName . ".DAT")
FileCopy,%emupath%\NVDATA\Multi\%romName%.DAT,%emupath%\NVDATA,1
m2ini := LinkedEmuPath . "\EMULATOR.INI" ;no need to checkfile it here since it's already been done
; Removing Fullscreen
IniWrite, 0, %m2Ini%, Renderer, AutoFull
; Creating the link
IniWrite,127.0.0.1,%LinkedEmuPath%\m2network.ini,network,NextIp ;127.0.0.1 is local address
IniWrite,% (1978 + A_Index - 1),%LinkedEmuPath%\m2network.ini,network,RxPort ;Recieving port
;the last player sends information to the first player completing the circle
IniWrite,% (If (A_Index = SelectedNumberofPlayers) ? 1978 : (1978 + A_Index)),%LinkedEmuPath%\m2network.ini,network,NextPort ;Sending Port
Run(executable . A_Space . romName, LinkedEmuPath, "Hide",Screen%A_Index%PID)
WinWait("ahk_pid " . Screen%A_Index%PID)
WinGet, Screen%A_Index%ID, ID, % "ahk_pid " . Screen%A_Index%PID
If Fullscreen = true
{ WinSet, Style, -0xC00000, % "ahk_id " . Screen%A_Index%ID
ToggleMenu(Screen%A_Index%ID)
WinSet, Style, -0xC40000, % "ahk_id " . Screen%A_Index%ID
currentScreen := A_Index
Log("Moving window " . currentScreen . " to " . X%currentScreen% . "`," . Y%currentScreen% . " with W" . W%currentScreen% . " H" . H%currentScreen%)
WinMove, % "ahk_id " . Screen%currentScreen%ID, , % X%currentScreen%, % Y%currentScreen%, % W%currentScreen%, % H%currentScreen%
;check If window moved
timeout := A_TickCount
Loop
{ WinGetPos, X, Y, W, H, % "ahk_id " . Screen%currentScreen%ID
If (X=X%currentScreen%) and (Y=Y%currentScreen%) and (W=W%currentScreen%) and (H=H%currentScreen%)
break
If (timeout<A_TickCount-2000)
Break
Sleep, 50
Sleep, 50
BezelDraw()
HideEmuEnd()
WinShow, ahk_class MYWIN ; Show the emulator
} Else {
Loop %SelectedNumberofPlayers%
WinShow, % "ahk_id " . Screen%a_index%ID ; Show the emulator
WinActivate, ahk_id %Screen1ID% ; activate first player window so that first player can use keyboard instead of last player
;I find that the fade in exit looks better after the winshow lines
FadeInExit()
BezelExit()
FadeOutExit()
ExitModule()
CloseProcess:
FadeOutStart()
If (SelectedNumberofPlayers>1) {
{ WinClose("ahk_id " . Screen%A_Index%ID)
WinWaitClose("ahk_id " . Screen%A_Index%ID)
} Else
WinClose("AHK_class MYWIN")
Return
20:21:43:009 | RL | INFO | +16 | BuildScript - Loaded Multi-Player scripts
20:21:44:011 | RL | INFO | +0 | BuildScript - Loaded Statistics.ahk script
20:21:44:011 | RL | WARNING | +0 | BuildScript - "E:\Rocketlauncher\Lib\User Functions.ahk" not found
20:21:44:014 | RL | INFO | +0 | BuildScript - Finished injecting functions into module
20:21:44:016 | RL | INFO | +0 | Main - Module is built
20:21:44:016 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\AutoHotkey.dll exists
20:21:44:021 | RL | DEBUG1 | +15 | CheckFile - Attributes:
FileDescription AutoHotkey_H ANSI 32-bit
InternalName AutoHotkey_H
LegalCopyright Copyright © 2012
OriginalFilename AutoHotkey.exe
ProductName AutoHotkey_H
File Size: 785408 bytes
Modified: 4/19/2013 - 7:16:32 PM
20:21:44:024 | RL | INFO | +0 | Main - Running module
20:21:44:024 | RL | INFO | +0 | Main - Starting timer to watch if Front End gets displaced and restore it if it does.
20:21:44:119 | MD | INFO | +N/A | Module initialized
20:21:44:121 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess"
20:21:44:126 | MD | INFO | +0 | StartModule - Started
20:21:44:144 | MD | INFO | +31 | StartModule - MEmu: Sega Model 2 Emulator
MEmuV: v1.0
MURL: http://nebula.emulatronia.com/
MAuthor: djvj,ghutch92
MVersion: 2.0.8
MCRC: F8CE6B9D
iCRC: C842B2DD
MID:
MSystem: "Sega Model 2"
20:21:44:144 | MD | INFO | +0 | StartModule - You have a supported System Name for this module: "Sega Model 2"
20:21:44:146 | MD | INFO | +0 | PluginInit - Started
20:21:44:149 | MD | DEBUG1 | +0 | BuildDatabaseTable - Started - Building Table for: Name|Cloneof|Manufacturer|Year|Genre|Rating
20:21:44:149 | MD | INFO | +0 | CheckFile - Checking if E:\HyperSpin\Databases\Sega Model 2\Sega Model 2.xml exists
20:21:44:151 | MD | DEBUG1 | +0 | CheckFile - Attributes:
File Size: 17934 bytes
Created: 5/29/2015 - 9:39:48 PM
Modified: 4/8/2014 - 5:50:38 AM
20:21:44:154 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching for a "Game Name" in the database
20:21:44:156 | MD | DEBUG1 | +0 | BuildDatabaseTable - Found "Game Name" in the database!
20:21:44:156 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching database for: Name
20:21:44:159 | MD | DEBUG1 | +0 | BuildDatabaseTable - Found "Name" with a value: "Daytona USA"
20:21:44:176 | MD | DEBUG1 | +31 | BuildDatabaseTable - Searching database for: Cloneof
20:21:44:186 | MD | DEBUG1 | +0 | BuildDatabaseTable - Could not find: Cloneof
20:21:44:189 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching database for: Manufacturer
20:21:44:211 | MD | DEBUG1 | +31 | BuildDatabaseTable - Found "Manufacturer" with a value: "Sega"
20:21:44:244 | MD | DEBUG1 | +32 | BuildDatabaseTable - Searching database for: Year
20:21:44:246 | MD | DEBUG1 | +0 | BuildDatabaseTable - Found "Year" with a value: "1994"
20:21:44:246 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching database for: Genre
20:21:44:249 | MD | DEBUG1 | +0 | BuildDatabaseTable - Found "Genre" with a value: "Driving"
20:21:44:251 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching database for: Rating
20:21:44:274 | MD | DEBUG1 | +31 | BuildDatabaseTable - Found "Rating" with a value: "AAMA - Green (Suitable For All Ages)"
20:21:44:274 | MD | DEBUG2 | +0 | PluginInit - GameInfo:
GameInfo Label: Genre | GameInfo Value:
GameInfo Label: Manufacturer | GameInfo Value:
GameInfo Label: Name | GameInfo Value:
GameInfo Label: Rating | GameInfo Value:
GameInfo Label: Year | GameInfo Value:
20:21:44:276 | MD | DEBUG1 | +0 | BuildDatabaseTable - Ended
20:21:44:279 | MD | DEBUG1 | +0 | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo
20:21:44:281 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a Game Logo: E:\HyperSpin\Media\Sega Model 2\Images\Wheel\daytona.png
20:21:44:281 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a System Logo: E:\HyperSpin\Media\Main Menu\Images\Wheel\Sega Model 2.png
20:21:44:284 | MD | DEBUG2 | +0 | BuildAssetsTable - Media assets found:
Asset Label: System Logo | Asset Path1: E:\HyperSpin\Media\Main Menu\Images\Wheel\Sega Model 2.png | Asset Extension1: png | Asset Type1: system
20:21:44:306 | MD | DEBUG1 | +31 | BuildAssetsTable - Ended
20:21:44:306 | MD | DEBUG1 | +0 | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other
20:21:44:309 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a Artwork1: E:\HyperSpin\Media\Sega Model 2\Images\Artwork1\daytona.png
20:21:44:311 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a Box Art: E:\HyperSpin\Media\Sega Model 2\Images\Artwork2\daytona.png
20:21:44:314 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a Cartridge: E:\HyperSpin\Media\Sega Model 2\Images\Artwork3\daytona.png
20:21:44:336 | MD | DEBUG1 | +31 | BuildAssetsTable - Searching for a Flyers: E:\HyperSpin\Media\Sega Model 2\Images\Artwork4\daytona.png
20:21:44:379 | MD | DEBUG1 | +47 | BuildAssetsTable - Searching for a Letters: E:\HyperSpin\Media\Sega Model 2\Images\Letters
20:21:44:416 | MD | DEBUG1 | +31 | BuildAssetsTable - Searching for a Other: E:\HyperSpin\Media\Sega Model 2\Images\Other
20:21:44:421 | MD | DEBUG2 | +0 | BuildAssetsTable - Media assets found:
Asset Label: Letters | Asset Path1: E:\Hyperspin\Media\Sega Model 2\Images\Letters\!.png | Asset Extension1: png | Asset Type1: system
Asset Label: Letters | Asset Path2: E:\Hyperspin\Media\Sega Model 2\Images\Letters\'.png | Asset Extension2: png | Asset Type2: system
Asset Label: Letters | Asset Path3: E:\Hyperspin\Media\Sega Model 2\Images\Letters\(.png | Asset Extension3: png | Asset Type3: system
Asset Label: Letters | Asset Path4: E:\Hyperspin\Media\Sega Model 2\Images\Letters\0.png | Asset Extension4: png | Asset Type4: system
Asset Label: Letters | Asset Path5: E:\Hyperspin\Media\Sega Model 2\Images\Letters\1.png | Asset Extension5: png | Asset Type5: system
Asset Label: Letters | Asset Path6: E:\Hyperspin\Media\Sega Model 2\Images\Letters\2.png | Asset Extension6: png | Asset Type6: system
Asset Label: Letters | Asset Path7: E:\Hyperspin\Media\Sega Model 2\Images\Letters\3.png | Asset Extension7: png | Asset Type7: system
Asset Label: Letters | Asset Path8: E:\Hyperspin\Media\Sega Model 2\Images\Letters\4.png | Asset Extension8: png | Asset Type8: system
Asset Label: Letters | Asset Path9: E:\Hyperspin\Media\Sega Model 2\Images\Letters\5.png | Asset Extension9: png | Asset Type9: system
Asset Label: Letters | Asset Path10: E:\Hyperspin\Media\Sega Model 2\Images\Letters\6.png | Asset Extension10: png | Asset Type10: system
Asset Label: Letters | Asset Path11: E:\Hyperspin\Media\Sega Model 2\Images\Letters\7.png | Asset Extension11: png | Asset Type11: system
Asset Label: Letters | Asset Path12: E:\Hyperspin\Media\Sega Model 2\Images\Letters\8.png | Asset Extension12: png | Asset Type12: system
Asset Label: Letters | Asset Path13: E:\Hyperspin\Media\Sega Model 2\Images\Letters\9.png | Asset Extension13: png | Asset Type13: system
Asset Label: Letters | Asset Path14: E:\Hyperspin\Media\Sega Model 2\Images\Letters\a.png | Asset Extension14: png | Asset Type14: system
Asset Label: Letters | Asset Path15: E:\Hyperspin\Media\Sega Model 2\Images\Letters\b.png | Asset Extension15: png | Asset Type15: system
Asset Label: Letters | Asset Path16: E:\Hyperspin\Media\Sega Model 2\Images\Letters\c.png | Asset Extension16: png | Asset Type16: system
Asset Label: Letters | Asset Path17: E:\Hyperspin\Media\Sega Model 2\Images\Letters\d.png | Asset Extension17: png | Asset Type17: system
Asset Label: Letters | Asset Path18: E:\Hyperspin\Media\Sega Model 2\Images\Letters\e.png | Asset Extension18: png | Asset Type18: system
Asset Label: Letters | Asset Path19: E:\Hyperspin\Media\Sega Model 2\Images\Letters\f.png | Asset Extension19: png | Asset Type19: system
Asset Label: Letters | Asset Path20: E:\Hyperspin\Media\Sega Model 2\Images\Letters\g.png | Asset Extension20: png | Asset Type20: system
Asset Label: Letters | Asset Path21: E:\Hyperspin\Media\Sega Model 2\Images\Letters\h.png | Asset Extension21: png | Asset Type21: system
Asset Label: Letters | Asset Path22: E:\Hyperspin\Media\Sega Model 2\Images\Letters\i.png | Asset Extension22: png | Asset Type22: system
Asset Label: Letters | Asset Path23: E:\Hyperspin\Media\Sega Model 2\Images\Letters\j.png | Asset Extension23: png | Asset Type23: system
Asset Label: Letters | Asset Path24: E:\Hyperspin\Media\Sega Model 2\Images\Letters\k.png | Asset Extension24: png | Asset Type24: system
Asset Label: Letters | Asset Path25: E:\Hyperspin\Media\Sega Model 2\Images\Letters\l.png | Asset Extension25: png | Asset Type25: system
Asset Label: Letters | Asset Path26: E:\Hyperspin\Media\Sega Model 2\Images\Letters\m.png | Asset Extension26: png | Asset Type26: system
Asset Label: Letters | Asset Path27: E:\Hyperspin\Media\Sega Model 2\Images\Letters\n.png | Asset Extension27: png | Asset Type27: system
Asset Label: Letters | Asset Path28: E:\Hyperspin\Media\Sega Model 2\Images\Letters\o.png | Asset Extension28: png | Asset Type28: system
Asset Label: Letters | Asset Path29: E:\Hyperspin\Media\Sega Model 2\Images\Letters\p.png | Asset Extension29: png | Asset Type29: system
Asset Label: Letters | Asset Path30: E:\Hyperspin\Media\Sega Model 2\Images\Letters\q.png | Asset Extension30: png | Asset Type30: system
Asset Label: Letters | Asset Path31: E:\Hyperspin\Media\Sega Model 2\Images\Letters\r.png | Asset Extension31: png | Asset Type31: system
Asset Label: Letters | Asset Path32: E:\Hyperspin\Media\Sega Model 2\Images\Letters\s.png | Asset Extension32: png | Asset Type32: system
Asset Label: Letters | Asset Path33: E:\Hyperspin\Media\Sega Model 2\Images\Letters\t.png | Asset Extension33: png | Asset Type33: system
Asset Label: Letters | Asset Path34: E:\Hyperspin\Media\Sega Model 2\Images\Letters\u.png | Asset Extension34: png | Asset Type34: system
Asset Label: Letters | Asset Path35: E:\Hyperspin\Media\Sega Model 2\Images\Letters\v.png | Asset Extension35: png | Asset Type35: system
Asset Label: Letters | Asset Path36: E:\Hyperspin\Media\Sega Model 2\Images\Letters\w.png | Asset Extension36: png | Asset Type36: system
Asset Label: Letters | Asset Path37: E:\Hyperspin\Media\Sega Model 2\Images\Letters\x.png | Asset Extension37: png | Asset Type37: system
Asset Label: Letters | Asset Path38: E:\Hyperspin\Media\Sega Model 2\Images\Letters\y.png | Asset Extension38: png | Asset Type38: system
Asset Label: Letters | Asset Path39: E:\Hyperspin\Media\Sega Model 2\Images\Letters\z.png | Asset Extension39: png | Asset Type39: system
Asset Label: Other | Asset Path1: E:\Hyperspin\Media\Sega Model 2\Images\Other\Pointer.png | Asset Extension1: png | Asset Type1: system
20:21:44:424 | MD | DEBUG1 | +0 | BuildAssetsTable - Ended
20:21:44:446 | MD | DEBUG1 | +31 | BuildAssetsTable - Started - Building Table for: Game Video|System Video
20:21:44:449 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a Game Video: E:\HyperSpin\Media\Sega Model 2\Video\daytona.*
20:21:44:449 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a System Video: E:\HyperSpin\Media\Main Menu\Video\Sega Model 2.*
20:21:44:451 | MD | DEBUG2 | +0 | BuildAssetsTable - Media assets found:
Asset Label: System Video | Asset Path1: E:\HyperSpin\Media\Main Menu\Video\Sega Model 2.mp4 | Asset Extension1: mp4 | Asset Type1: system
20:21:44:454 | MD | DEBUG1 | +0 | BuildAssetsTable - Ended
20:21:44:476 | MD | INFO | +32 | PluginInit - Ended
20:21:44:476 | MD | DEBUG1 | +0 | StartModule - Setting romName to the dbName sent to RocketLauncher: daytona
20:21:44:479 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~e & ~t" to call label: "ToggleCursor"
20:21:44:481 | MD | INFO | +0 | StartModule - Ended
20:21:44:484 | MD | INFO | +0 | Module Setting - [settings] - Link_Enabled: false
20:21:44:484 | MD | INFO | +0 | Module Setting - [daytona] - Link_Enabled: false
20:21:44:486 | MD | INFO | +0 | Module Setting - [settings] - SplitScreen_2_Players: Vertical
20:21:44:509 | MD | INFO | +31 | Module Setting - [settings] - SplitScreen_3_Players: P1top
20:21:44:511 | MD | INFO | +0 | Module Setting - [settings] - Fullscreen: true
20:21:44:511 | MD | INFO | +0 | Module Setting - [settings] - FullScreenWidth: 1440
20:21:44:514 | MD | INFO | +0 | Module Setting - [settings] - FullScreenHeight: 900
20:21:44:516 | MD | INFO | +0 | Module Setting - [settings] - Player2_EmulatorPath: E:\Hyperspin\Emulators\Sega Model 2\Player 2
20:21:44:516 | MD | INFO | +0 | Module Setting - [settings] - Player3_EmulatorPath: E:\Hyperspin\Emulators\Sega Model 2\Player 3
20:21:44:539 | MD | INFO | +31 | Module Setting - [settings] - Player4_EmulatorPath: E:\Hyperspin\Emulators\Sega Model 2\Player 4
20:21:44:539 | MD | INFO | +0 | CheckFile - Checking if E:\Hyperspin\Emulators\Sega Model 2\roms\model2.zip exists
20:21:44:541 | MD | DEBUG1 | +0 | CheckFile - Attributes:
File Size: 435154 bytes
Created: 5/31/2015 - 1:55:14 PM
Modified: 3/17/2011 - 11:41:58 PM
20:21:44:544 | MD | INFO | +0 | CheckFile - Checking if E:\Hyperspin\Emulators\Sega Model 2\EMULATOR.INI exists
20:21:44:546 | MD | DEBUG1 | +0 | CheckFile - Attributes:
File Size: 2335 bytes
Modified: 5/31/2015 - 8:20:50 PM
20:21:44:549 | MD | INFO | +0 | Module Setting - [RomDirs] - Dir1: E:\Hyperspin\Emulators\Sega Model 2\roms
20:21:44:574 | MD | INFO | +31 | Run - Running: E:\Hyperspin\Emulators\Sega Model 2\emulator_multicpu.EXE daytona
20:21:44:691 | MD | INFO | +125 | Run - Showing Command Window to troubleshoot launching. ProcessID: 1140
20:21:45:694 | MD | DEBUG1 | +998 | Run - "emulator_multicpu.EXE daytona" Process ID: 1140
20:21:45:696 | MD | DEBUG1 | +0 | GetActiveWindowStatus - Title: Administrator: C:\Windows\system32\cmd.exe - emulator_multicpu.EXE daytona | Class: ConsoleWindowClass | State: 0 | X: 198 | Y: 198 | Width: 668 | Height: 331 | Window HWND: 0x340240 | Process ID: 1140 | Process Path: C:\Windows\SysWOW64\cmd.exe
20:21:45:699 | MD | INFO | +0 | WinWait - Waiting for "ahk_class MYWIN"
20:21:54:279 | MD | DEBUG1 | +8580 | CloseProcess - Started, user requested to end launched application
20:21:54:306 | MD | INFO | +32 | WinClose - Closing: AHK_class MYWIN
20:21:54:541 | MD | DEBUG1 | +234 | CloseProcess - Ended
20:21:58:249 | RL | WARNING | +14227 | HyperSpin.exe was displaced to x y w h by Sega Model 2 Emulator. It is probably running in true fullscreen mode.
