FullSinthetik Posted June 13, 2015 Posted June 13, 2015 So this is my first setup and its been interesting. Setting up Rocket Launcher UI to communicate with Hyperspin but the search spinning wheel of death never finds any paths when the magnifying glass is selected. Thx and love the board
rbailey001 Posted June 25, 2015 Posted June 25, 2015 On 6/13/2015 at 11:32 AM, FullSinthetik said: So this is my first setup and its been interesting. Setting up Rocket Launcher UI to communicate with Hyperspin but the search spinning wheel of death never finds any paths when the magnifying glass is selected. Thx and love the board I am new so hopefully this works. But I recently had the same issue and I read that you need to run Rocketlauncher UI as admin. Once I did this it worked perfectly.
rfancella Posted June 25, 2015 Posted June 25, 2015 That did not work for me. I posted about it over at the RL site. They are going to add some additional logging in the next release. I had to select Editable Paths in RLUI to type the paths manually. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
