rodchan Posted June 15, 2015 Posted June 15, 2015 Ok, so im getting a bit peeved. Maybe its my inability to get this thing to work the way i want it to. So I used Hypersync Cloud to sync up the following systems: NES Famicom Super NES Super Famicom MAME CPS1 CPS2 CPS3 My problem, is that I want these wheels to work! The MAME wheel with all the arcade roms work great, but I want to seperate the arcade systems so I can find things easier (CPS fighters, SNES etc.) I created these wheels, and it looks good, but when I try to launch, iit fails. Rocketlauncher states that I have to set a default emulator for the wheel. So What i do is I setup the default emulator for the CPS1/CPS2/CPS3 and when i go to the default emulator selection, THERE IS NOTHING THERE!!!! FRUSTRATING!! My default emulators list is setup with these emulators, but NONE of them show up. What gives?! Anyway, is there any way I get this seperated? Thanks in advance!
baddeolv Posted June 15, 2015 Posted June 15, 2015 You're overthinking it. Just click on the system in RLHQ click the emulator tab, fill in your Tom path and underneath that, select to launch it with MAME Sent from my iPhone using Tapatalk Instagram : baddeolv Facebook : Brian Addeo
damageinc86 Posted June 15, 2015 Posted June 15, 2015 When I separated all the Arcade Classics (MAME split into different manufacturers) from the main MAME.xml, I went into the Mame settings txt file in the RL settings folder for emulators, and added the system name to the msystem= line. Then it showed up as an available emulator to assign to it in RLHQ
rodchan Posted June 18, 2015 Author Posted June 18, 2015 Thanks guys. I apologize for the rant. I am overthinking it. Ive been working on this system for way too long.
