Everything posted by bent98
Can you post it here?
I am requesting you add 2 additional and important pieces of code the next version of fplaunch. 1)Use custom B2S settings per table in Hyperpin http://www.vpforums.org/index.php?showtopic=20807&hl=%2Bb2s+%2Bfplaunch 2) I don’t have link for it but essentially it allows you to disable ledcontol.ini so people with forcefeedback on their cabs can turn it on and off through the HS menus. I will get permission from Kodiac and Deegor.
Hey blur any progress?
Really? I havent had any issues. Why would UVP stop working?
Ak ok
I am having wierd issue with latest WIP8 launch. I got 2 set ups of Scared Stiff. One of the orginal version and one with GI8 mod. They both work fine except only the ScaredStiff_FS_B2S launches the backglass, the GI8 doesnt. I tried it outside of HS. If I set the GI8 table to launch True it works outside of hS. Once I set it to false and run it from HS it doesnt load the back glass. I checked the spelling of the .exe backflass it references and its correct. Not sure why it doesnt work. <game name="ScaredStiff_FS_B2S_GI8"> <description>Scared Stiff Dark Mod (Bally 1996)</description> <!-- <version>Scared_Stiff_VP9_1.443FS> --> <manufacturer>Bally</manufacturer> <year>1996</year> <type>SS</type> </game> <game name="ScaredStiff_FS_B2S"> <description>Scared Stiff (Bally 1996)</description> <!-- <version>Scared_Stiff_VP9_1.44FS> --> <manufacturer>Bally</manufacturer> <year>1996</year> <type>SS</type> </game>
If your going to ask think bigger, how about a HYPERDMD like function to FPlaunch.
Yes, I do read. I was suggesting you update the main page in the thread with the latest WIP 8 and remove the options not used anymore in settings.ini file to avoid confusion.
ok I removed both pauseVPinball = g and pauseFPKey = RButton and replaced the pauseKey with a g. I also changed speed back to 25. All is well. Thanks. You really should make a post about that as its confusing when going from WIP 5 to the new ones. I was confused about Hi Score intergration because I saw it as implemented in first post on this thread.How long before you get that in there? Thanks again blur for all your hard work. New launcher works great!
I just checked. They are all set to true. It seems like when I press p very lightly it goes to the service menu screen. I assume that is what we are calling pause now? If so how do I map that function to my "g" key? I tried different combinations and nothing works. ITs always set to "P" key. Also you really have to hit "P" ever so lighly otherwise it wants to try and go into the 3.2.1. exit routine.Can you make the delay longer so the Pause key needs to be pressed a few milliseconds longer? I still dont understand why you have a pause.png file in the package. If the service menu screen replaces pause why do we still need it? I also see you have custom loading screen for FP, VP, and bigscore. How do you enable those? Lastly, do you still have plans and integrating pinemhi support? Thanks Blur!!! exitScriptKey = q & s exitEmulatorKey = e toggleCursorKey = t pauseVPinball = g hideCursor = true hideDesktop = true hideTaskbar = true useExitScreen = true usePauseKey = true useLoadScreen = true fadespeed = 15 UseExitAsPause = true exitEmulatorKey2= 1 exitEmulatorKey3= Enter pauseFPKey = RButton saveFPTables = true pauseKey=p editTableKey=!F4 printScreenKey=o pfScreenNum=1 bgScreenNum=2 useExitMenu=true upKey=LShift downKey=RShift instructionsKey=i flyerKey=f hyperScale=0.75 debugMode=false ledwiz=false hyperpinexe=hyperpin.exe [LastLoad]
Ok So issue was this Go.bat needs to look like this. cd C:\slamit bigscore Mine looked like this C:\slamit\bigscore Thanks Blur. By the way, how do i get the Paused screen to come up? I am still not sure I understand. Is Pause gone because i still see the paused screen in the WIP 8 package. Also you say exit is now Pause. Exit is mapped to E on my setup. But if I tap exit it doesnt Pause. I need to hold down exit to escape.
it is. C:\hyperpin hyperpin.exe is in there c:\slamit\ go.bat and bigscore.exe are in there
When I run Slamit from FPlaunck.ahk i browse to Future Pinball and then Biscore. I run it and PF turns black. I Hit t and the have to run it again for the screen to clear up. I could not copy and paste the log file so I print screened it. I have my Bigscore in a folder off my c drive called slamit. I have a bat file which is named go.bat and inside bat file it points to bigscore.exe. IF I launch go.bat in windows it runs bigscore fine. Second question: How do I access pause menu graphic? If i escape it gives me that count down screen.
Blur, Just tried WIP 8, works great except Slamit Bigscore still doesn't work. Screen just stays black when you select it from HP. Also, I just want to confirm, the Pause key doesnt work anymore and to pause you just use the instruction cards menu to pause? I did notice you still have a "pause screen graphic" Do I need to add or change anything in the menu config located in hyperpin.ini? Thanks again for all your hard work.
You know what UW, thats a great idea. I too find certain tables for whatever reason play better with different versions of Pinmame. Blur, you gotta figure this one out.
That sounds reasonable. Maybe you should add the word. Pause/Menu. I have a Pause Button on my cab. Also, I havent been home to test latest WIP. Did you guys add the DMD messages when scrolling in HP? I know there is some much to test and going on with this script but I was just curious about this as that was one feature I was really looking forward to.
Can't wait
http://annystudio.com/software/jpeglosslessrotator/ will that work?
Cant wait for this release. Come on guys.
Sweet! Dont forget the Slam it Bigscore fix Blur
Ok THat triple strike was on my end. I didnt have script set to false.
Yes B2s tables do. But other b2s work fine. Just this one is an issue.
Just tried did the same thing.
http://www.vpforums.org/index.php?automodule=downloads&req=idx&cmd=viewdetail&f_id=5798 You will need 2 monitors to test. Ill let you know today if that helps first.
I am using 1.295 wip 4 and noticed with specifically with TripleStrikeB2S every time I launch it the loading screen maintains focus even after table is loaded. I need to hit ESC or click on mouse to gain focus to the table. I dont have this issue with any other table.
