bent98
    239
Everything posted by bent98
  1. Jp is going to release FS with alpha ramps soon. Prob after Congo. Thats the old 4:3 converted to FS
  2. Very exicted with the updates!
  3. BTW With the latest WIP 4 script, when I launch FP tables I see the windows taskbar for a split second.
  4. I only have this issue with b2s tables. All others work fine. Also I am running win xp, why would i need to set win nt sp5 comp mode?
  5. I have issues with WIP 3 and WIP 4 1295 and B2S tables. I am using 182.50 drivers in Win xp 32bit. FPlaunch works great except when launching B2S tables. It looses focus when launch and I have to press my Exit button, which is mapped to Esc key to regain focus. Here is my FPlaunch config [FPLaunch] exitScriptKey = q & s exitEmulatorKey = Esc toggleCursorKey = t pauseVPinball = g hideCursor = true hideDesktop = true hideTaskbar = true useExitScreen = true usePauseKey = true useLoadScreen = true fadespeed = 15 UseExitAsPause = true exitEmulatorKey2= 1 exitEmulatorKey3= Enter pauseFPKey = RButton saveFPTables = true
  6. I have having issue compiling it. Could you put a link to it?
  7. Blur Can you add thast bigscore slamit into latest script and let me test it?
  8. blur Can you please add it?
  9. Blur Did you add big boss slam it big score support?
  10. Thanks again Blur for all your hard work on this.
  11. Blur Works awsome for me also. Thats for adding code to by pass vpinmame error. Thanks for all your hard work on this. I do have a question for you. I still have esc mapped in my ipac and in exit emulator. I am not having any issues. Should I remap it to e or o like you say or just leave well enough alone?
  12. blur Does WIP2 incude pinmame automatic error box removal?
  13. PM Bad Boy Bill. He will know
  14. http://www.hyperspin-fe.com/forum/showthread.php?p=112714#post112714 as per this thread bigboss is fine with you including it in your script.
  15. Blur Can you post a new link with updated script? Also can you add slam tilt support that big boss posted in other thread?
  16. Thank Blur. I assume you will include that in the next build of the script?
  17. I want support added in as sometimes new versions of pinmame cause issue and you have to roll back to an earlier version. Have this error code clear will be helpful.
  18. Thats the error. Can you add support in the script to eliminate this box?
  19. Blur I justed test 1.295 and it works great. No more taskbar when exiting. I still have an issue with it not clearing a error message. There is a table I run called space shuttle. If you run an older version of vpinmame you get an error and then you have to hit enter to clear screen and the it works. I usually just hit the plunger once but isnt the new script support to automatically send an enter commend for error screens?
  20. Its probably good to include an option to turn feature on and off. I for one would want nag screens to close but if I have trying to troubleshoot have them on
  21. I was just asking to see what you guys had in store for us. Thanks for all you effort!
  22. Blur you guys going to make any more script updates?
  23. Is there any way to make FP exit like VP. I know right now we can't have the overlay graphics unless dll workaround is implemented, but just from a button pressing standpoint and the way my cab is set up I prefer to have FP exit like VP. In other words cant you make the FP exit if you hold down esc for 3 secs?and pause mapped to another key? Maybe have a timer so that if esc is held down for 3 secs then send a 1 and pause is just esc or what every you assign it which in my caase would be a g? If this is not possible can you provide an option in the script to just allow VP to use to pause feature but FP acts like it always has when there is not pause and when you hit escape it just exits back to HP? I dont play FP that much and could do with out pause right now. I am concerned someone other then my plays the cabinet and won't know how to exit from FP. BTW, thanks so much for your efforts on this, you guys are doing a wonderful job.
