HyperSpin
    1,123
    40
Everything posted by HyperSpin
  1. Version 20101022
    393 downloads
    NES 3D Vector Cart Pack
  2. Version 1.0
    127 downloads
    Nintendo Entertainment System Nintendulator v0.975 Beta by djvj 1.0 Notes: Roms must be unzipped as .nes/.fds/.unif//.unf files, zips are not supported Emulator stores its config in the registry and the rest in C:\Users\%USER%\AppData\Roaming\Nintendulator
  3. Version 1.0
    1,169 downloads
    Nintendo Entertainment System Nestopia 1.39 by BBB 1.0 Info: Some things you might do to make this emulator more cab friendly 1.Since the exit emulator key does nothing you should setup an escape key within the emulator using the input options, the default is alt+x, so change to esc. But since esc is the default key to bring up the fullscreen menu then you should change that to something else such as Alt+M. The exit emulator menu key is disabled to allow for game saving etc... <exit>Esc</exit> <toggle-menu>Alt+M</toggle-menu> 2.You can set this emulator to start in fullscreen using the options, or open the nestopia xml file and change these settings: <start-fullscreen>yes</start-fullscreen> 3.Disable exit confirmation <confirm-exit>no</confirm-exit> 4.Since pressing escape still flashes the upper menu in fullscreen briefly you can minimize the effect by changing the menu's color in fullscreen by going to Options -> Preferences -> FullScreen Menu Color and change it to black or <custom-color>0x00000000</custom-color> <use-custom-color>yes</use-custom-color>
  4. Version 1.1
    128 downloads
    Nintendo Entertainment System Mednafen 0.9.15 by BBB 1.1 Notes: Below are some basic params you can change, there are many other params located in the mednafen documentation that you can add if needed. Some people experience screen flickering and mednafen will not stay in fullscreen, you can changed vDriver below to -vdriver sdl and it will possibly fix the issue. There is no error checking if mednafen fails, so if you try to launch your game and nothing happens, then check the stdout.txt in your mednafen installation directory to see what went wrong. To remap your keys, start a game then press alt + shift + 1 to enter the key configuration. Also see mednafen.cfg to change other keys such as the exit key.
  5. Version 1.1
    247 downloads
    Nintendo Entertainment System Jnes 1.0.2 by Acidnine 1.1 Notes: The main thing this emulator is lacking in is command-line customizability. Which is why I made this... Emulator has no exit bind. So it will use HL built in one. For full-screen settings open Jnes: Options -> Video -> Go full screen when rom is opened
  6. Version 1.0
    396 downloads
    Nintendo Entertainment System Jnes 1.0.2 by Acidnine 1.0 Notes: The only thing this emulator is lacking in is command-line customizability. Which is why I made this... This script will wait for Jnes to be the active window, then send alt+enter to full-screen it. When you press Escape, it will close Jnes and return to Hyperspin.
  7. Version 1.1
    2,020 downloads
    Nintendo Entertainment System HyperBase Database (Official)
  8. Version 20140616
    724 downloads
    Atari 2600 Cart Top Wheel Pack
  9. Version 20150505
    411 downloads
    Atari 2600 Game Wheel Pack
  10. Version 20100101
    283 downloads
    Atari 2600 Main Menu-Unknown
  11. Version 20100403
    1,312 downloads
    Atari 2600 Main Menu Theme-Unknown
  12. Version 1.0
    831 downloads
    Atari 2600 Stella.exe by BBB 1.0 Info:Some things you might do to make this emulator more cab friendly1.Since the exit emulator key does nothing you should setup an escape keywithin the emulator using the input options, the default is alt+x, so changeto esc. But since esc is the default key to bring up the fullscreen menu thenyou should change that to something else such as Alt+M. The exit emulator menukey is disabled to allow for game saving etc...<exit>Esc</exit><toggle-menu>Alt+M</toggle-menu>2.You can set this emulator to start in fullscreen using the options, or open thenestopia xml file and change these settings:<start-fullscreen>yes</start-fullscreen>3.Disable exit confirmation<confirm-exit>no</confirm-exit>4.Since pressing escape still flashes the upper menu in fullscreen brieflyyou can minimize the effect by changing the menu's color in fullscreen bygoing to Options -> Preferences -> FullScreen Menu Color and change it to blackor<custom-color>0x00000000</custom-color><use-custom-color>yes</use-custom-color>
  13. Version 1.1
    3,084 downloads
    Atari 2600 Database (Official)
  14. Version 1.0
    149 downloads
    GX4000 WinAPE v2.0 Alpha 18 by djvj 1.0 Notes: You cannot pass a game name to the emu through CLI, but the emu will autolaunch the game set in its ini file. Run the exe manually and goto Settings->General, check "Disable Automatic Update" On the Display tab, check "Hide Control Panel", "Hide Menus" and "No Right-Click Menu". "Linear Palette" will slightly darken image if you enable it. On the Sound tab, check "44 kHz" and "16 bit". On the Input tab, set your controls and hit OK. Press F10 to turn on fullscreen then ALT+F4 to exit and save your settings. Roms should be zipped
  15. Version 20100206
    281 downloads
    Default Theme for BWhebles 3D Boxart
  16. Version 20111123
    359 downloads
    Amstrad GX4000 Wheel Pack (Official)
  17. Version 1.0.10
    338 downloads
    American Laser Games Daphne Singe v1.0.10 by djvj 1.0 Info: Games must be placed in the ..\emulator\singe\ folder, each under their own subdir emupath should be something like this C:\HyperSpin\Emulators\Actionmax\daphne-singe\ rompath should be something like this C:\HyperSpin\Emulators\Actionmax\daphne-singe\singe\ romextension should be txt A blank txt file should be created for each game name and placed in the rompath folder
  18. Version 1.0
    261 downloads
    AAE AAE .140 by Brian Hoffman 1.0 Info: Nothing Special, uses mame roms and exist via ESC.
  19. Version 20150508
    431 downloads
    Set of 2 Amstrad GX4000 Main Menu Wheels
  20. Version 20100329
    154 downloads
    Default - GX4000 - System Default (4:3)
  21. Version 20100206
    250 downloads
    Default - GX4000 - Main Menu (4:3)
  22. Version 20150508
    1,358 downloads
    221 High Quality Manufacturer Logos for use in Theme Design
  23. Version 20150508
    679 downloads
    Visual Pinball Main Menu Wheel
  24. Version 20150508
    374 downloads
    American Laser Games Wheel Pack (Official)
  25. Version 20150508
    298 downloads
    American Laser Games Pointer
