  • 1. After syncing the HSM media... the default system theme for every wheel... just breaks.. no inner theme.. no video... The outer wheel loads and the overrides seem to work. But it just freezes the theme... you can still move the wheel and go in and out... but he theme doesnt show anything.
    2. Some main themes are completely broken still.. mugen, touhou, openbor to name a few.
    3. Main Hyperspin theme thats supposed to show when theres no system theme... doesnt work... This is after a sync. Related to point 1.
    4. Platforms tab - Moving things around results in freezing. I had to restore a backup.
    5. Platforms tab - Making changes to the section doesnt save your changes most of the time. Sometimes it has to be reloaded. Sometimes it says the wheel is hidden when its not... still shows up in the main wheel.
    6. Newest HLHQ completely freezes up... doesnt load my wheels. I had to reinstall the old one.
    7. Sometimes pluggins say theres an update but after running the update. It doesnt actually update. Ive tried closing down HLHQ and restarting etc.
    8. If I deleted a folder... and removed the overrides folder. Readding the wheel to HLHQ doesnt actually re-add the override folders... I had to do it manually. (Is this changing? I still have all the Video - Snap 1080p, 240p, 480p etc... From the faq it looks like it just uses video now?
    9. Downloading new themes for many wheels to try and fill spaces since I dont want to use the generic hyperspin theme doesnt work some of the time. I think the themes are bad... as I can get one to show.. but not the other.
    10. When trying to delete the HSM media folder... sometimes a get a folder that wont delete. I need to rename the folder.. And erdownload... the folder is stuck there and wont delete.
    11. The query for Hypertheme needs to be improved immensely.... Searching for items that should show up with partial name searches dont show up at all but if theyre loaded manually, they do show up.
