DESCRIPTION
Volume² is an advanced Windows volume control, a complete replacement for the standard Volume Control. This application lets you easily change the sound volume just by rotating the mouse wheel or by using keyboard hot keys or just mouse move on screen border. It includes an audio mixer with advanced volume controls support, a scheduler, an on-screen display, command line support, the ability to store and recall different unlimited presets via one mouse click or system-wide hot keys. Available languages: Russian, Ukrainian, English, Chinese, Armenian, German, Spanish, Polish, Italian, Arabic, Brazilian, Bulgarian, Byelorussian, Czech, Dutch, French, Greece, Hungarian, Japanese, Korean, Latvian, Portuguese, Romanian, Serbian, Slovak,Slovenian, Swedish, Vietnamese.
CHANGE LOG
*Fixed bug with hang system when connected USB device (on some PCs with Win7 x64)
+Added function disable Volume²
+Added mode OSD "gadget" (OSD always shows)
+Added feature repairing the volume when you start the program (for Win7, when the some users on single PC)
+Added one more DESCRIPTION
Volume² is an advanced Windows volume control, a complete replacement for the standard Volume Control. This application lets you easily change the sound volume just by rotating the mouse wheel or by using keyboard hot keys or just mouse move on screen border. It includes an audio mixer with advanced volume controls support, a scheduler, an on-screen display, command line support, the ability to store and recall different unlimited presets via one mouse click or system-wide hot keys. Available languages: Russian, Ukrainian, English, Chinese, Armenian, German, Spanish, Polish, Italian, Arabic, Brazilian, Bulgarian, Byelorussian, Czech, Dutch, French, Greece, Hungarian, Japanese, Korean, Latvian, Portuguese, Romanian, Serbian, Slovak, Slovenian, Swedish, Vietnamese.
SYSTEM REQUIREMENTS:
Windows XP , Vista , Win7, Win8
INSTALLATION
1. Open the zip file with an unzip tool, such as WinZip or WinRar;
2. Run Setup.exe ;
3. After installation, run Volume2 shortcut on your desktop.
UNINSTALLATION
1. Just run Uninstall.exe in Volume2 folder
CONFIGURATION
On Volume² right click button in System tray icon select "Volume²." place volume control with the wheel: Anywhere on the screen
+In the system tray added option set default device
+Added function Mute all except active application on hotkeys
+Added OSD skin options
+Added new parameter for command string DEBUG (All errors shown on screen)
+Added option auto restart hooks
+Added new function to hotkeys: Set brightness percent
+Added feature Peak Meter on OSD
+Added keys wiche you can set as hotkeys in Volume²: Win+Up, Win+Down, Win+Left, Win+Right
+Add events on hotkey: Power off PC, Reboot PC, Turn off monitor(only for StandBy)
*Fixed bug with volume control in application list(x64)
*Fixed: PeakMeter placement on the second monitor
+Added PeakMeter binding to the device by default (automatic switching)
+Added ability to control the recording devices(Win7/Win8)
INSTALLATION
2. Run Setup.exe ;
What's New in Version 1_1_4_347
- CHANGE LOG
- Full support for Windows 10
- Added a new tag for clues in the system tray / text OSD -% DF - device (sound card)
- Fixed disabling the volume control in full-screen applications
- Added new OSD skin Windows 10 to display the name of the device
- Fixed the default device functions and device management for Windows 10
- Added the task on / off volume in the schedule
- Fixed task start time starts when the end of the big time
- Added option to disable the time range in the Schedule
- Added support for system colors (Windows 7/8/10), to select the System Settings interface
- Fixed: Error creating timetables to fulfill every ...
- Added: Hide Control window at the edge after a specified time
- Fixed: Setting volume Timetable
- Added events Shortcuts, level out the volume for all applications
- Fixed display of information about the personal license
- Fixed volume control on the second tray (on the second monitor) did not work in full-screen applications
- Added a new size for the tray icon 20px
- Fixed horizontal scrolling function KatMouse
- New look of the program settings, as well as updated application icon
- Fixed function vocstanovlenie volume at startup
- Added function control audio devices (tray menu)
- Added the effect of sleep mode Hotkeys
- Added events hotkeys for volume control of the active application
- Added options in the Schedule: Start in the ending (to perform the task in the time range), number of starts
- Removed banner Donate
- Fixed loading skins with an error in the structure (in the log file, which is added to the error)
- Added an expanded list of classes for the function KatMouse (only Config.ini)
- Fixed: Opens the program settings after rebooting the PC on Win8
- Added ability to exclude full-screen program on a mask (or folder)
- Added ability to change the size of the OSD (right mouse button)
- Added option of sticking at the edges of the screen OSD
- Added function disables the middle button, volume control, we at the edge of the screen
- Fixed: reinstall the hook after leaving the sleep mode
- Added: turn off the screen display (OSD), hot key, mouse wheel management and control at the edge of the screen in full-screen applications
- Added a new hotkey combination for: middle mouse button + wheel
- Fixed run applications with the parameters in the schedule and hotkeys
- Schedule adds the ability to set the volume for the device
- Save option Disable Volume² (mouse, keyboard)
- Fixed audio playback on Windows 8
- Fixed the appearance of the Start menu after the change Volume
- Added option Run as Administrator
