Check if the CRC data in a selected XML Hyperspin Database match your rom files.
Files must be named correctly... and match the database already.
Can be used to check if your files are the correct ones or if the CRC data in a database is correct :)
What's New in Version 0.0.0.3
  • 0.0.0.3: C# Version with GUI, You will need .net Framework 4.5
  • 0.0.0.2: First release
