	This is an XML (Unfinished) for fruit machines as i have been searching the net and found very little to do with this emulation aspect of it .Any Media would be gratefully put to use and more help with the emulation using MFME V2 V3 V5.1 V9.4 V10.1a emulators,the biggest problem is having it maintain the desktop screen size when the machine is loaded through rocketlauncher,Anyway i hope this helps the people who like the fruit machines
Additional
each machine must be in its own folder unzipped then Rename fruit machine folder and the .gam file inside the folder to machine name in the xml
example rename" magnificent7sWDX" to "Magnificent 7's (Barcrest) and the .gam file inside the folder the same as machine folder name
hope this helps
