I've re-uploaded the theme to suit 3 different boxart packs available including the newer PAL 3d boxart by NailbombRP and SwedishGojira. See Version notes for details.
This is a modified version of the theme that comes with SupraKarma 's Ultimate SNES pack (now 2.0). No idea the original creator of that theme.
I've modified it for the PAL version of the SNES.
I've also downloaded the PAL cart pack and as i've done with my Mega Drive theme, renamed the artwork to suit the North American lists. As I mentioned with my Mega Drive 2 theme, it's a bigger undertaking than you would expect given there are quite a few titles renamed for Euro release and vice versa. Let me know if that is something that interests you and I can take the hard work out of it for you. I recognise it's not a pure or perfect solution. As with the MD theme i've kept a list of which games are renamed for Euro release with the intention of perhaps editing both names into the xml for display purposes at some point.
You will want the box art from suprakarma's pack as it fits the theme video and I imagine it would look strange if it wasn't just right.
Suprakarma informed me that 'REAL 3D SNES Box' he made with Kondorito contains PAL box art although I'm yet to check it out or verify the box art is the correct size for the theme. I'll be implementing that eventually when I get time and i'll update the theme to suit, but let me know if you give it a try. The video positioning was slightly out on this pack, I've updated the theme. If you want to use the original box art work from version 1.0, I left the theme up as 'default orig'.
As with the original theme the video comes in over the box art after a few seconds. As I recall, the cart art should not need resizing. I've included my cart art here as it does need resizing I believe, at least the few North American carts will if not the rest. You can find the original PAL cart art pack here. Not sure who to credit that to but thanks!
The cart pack I've now included has been renamed to suit the North American preferenced xml found in SupraKarma's pack. So if you are using a Euro first xml, download the original pack I've linked above from emu movies and size the carts as necessary with fotosizer to 275*192. There might be a few missing as I'm yet to update my xml to his latest version.
Boxart is Artwork 1 folder, Cart art is Artwork 3.
As usual here is the Game text settings that go in your 'Super Nintendo Entertainment System.ini' in the 'settings' folder of your Hyperspin directory. Replace with the below if you desire the text as in the image above. My themes don't leave space for special art, so i'll leave that up to you if you want to edit it. You may want to adjust text size to your liking as a few of the long titles are cropped off the screen, not much can be done about that.
[Game Text]
game_text_active=true
show_year=true
show_manf=true
show_description=true
text_color1=0xD70500
text_color2=0xD70500
stroke_color=0xffffff
text_font=Style4
text1_textsize=18
text1_strokesize=20
text1_x=390
text1_y=670
text2_textsize=28
text2_strokesize=20
text2_x=390
text2_y=700
Enjoy!
Edit - Here's the packs that accompany this theme.
What's New in Version 1.1.3
1.1.1 - Updated the video positioning to suit the updated box art in SupraKarma's Ultimate Snes pack. AKA the Real 3D box set.
I've left the original theme here just in case you use the old version of the art work which is a slightly different size.
I've uploaded my resized cart art. Keep in mind it has been renamed to suit the main xml which is NTSC preferential, It's probably the one you are using anyway - but if you are confused why the titles of games are different to the artwork it's because the game was renamed for region when released. If you are using a European first xml to suit European roms, you will need the original cart pack I've linked in the description from emumovies.
I'm yet to update to the newer xml included in the Ultimate snes pack 2.0 and i'm still using the xml from 1.0, so likely there are probably ten or so carts missing in my cart art pack to suit that. A handful of titles either had no PAL release, or I could not find PAL cart art for, they have been left as North American carts.
1.1.2  - Realised i'd uploaded the wrong theme to suit the original box art pack which was someone elses theme I happened to have so deleting that for now. Will see if I can find the proper theme and put it back up later. In the mean time will edit the theme to accommodate the new pal box art pack and include that in the next update.
1.1.3 - Re uploaded all themes.
Default old style -  suit the older default boxart available
Default real3d - suits kondoritos real 3d boxart
Default pal 3d - suits the PAL 3D boxart
  • Like 5
