My Super Nintendo Entertainment System Main Menu theme.
Hard to distinguish from the screen shots but there is a lot of motion in this theme, I'm not sure how to make videos so you will have to give it a try if you are interested.
Mario flies through the air bouncing around on Yoshi beating him in the head (as deserved) while your choice of 1up mushrooms or fruit rains from above.
The background scrolls from the right appearing as though they are moving through the mushroom kingdom, then the video flies in and enlarges while the system title drops from the top and pulses.
This theme was fun to make just because it's enjoyable to watch mario bouncing around, it went through a few iterations along the way with the background but the scrolling artwork made things a little bit problematic as far as a seamless entry, I tinkered for quite a while with scrolling speeds etc.
I've included two themes which are identical aside from one raining 1ups and one raining fruit. Just delete where it says 'fruit' on the one name 'Super Nintendo Entertainment System fruit' and pop it in the 'HyperSpin/Media/Main Menu/Themes' folder.
Thanks to @Mekquake for making the .swf of Mario and Yoshi.
*edit - One important note, you should delete your transition animation file or rename it to something else, because the transitions don't play over the scrolling background so it can make it a little wacky when the theme starts. It's far more seamless when Hyperspin uses one of it's default transitions instead which it should do when it can't find the overide transition file. You will find it in 'HyperSpin/Media/Main Menu/Video/Overide Transitions/Super Nintendo Entertainment System.flv'.
What's New in Version 1.0.1
-Tightened up the timings for the video and header coming in as the delays felt a little long compared to other main menu themes. I've uploaded the theme.xml separately so drag that into the zip
  • Like 4
  • Upvote 1
  • Super Like 3
