This will adjust your Master Volume in Windows Vista/7 to any level you wish, after a set amount of idle time. It will also fade the volume down and back up to normal, rather then an abrupt change. All of this is adjustable via the GUI when you run the app. It will create the settings.ini for you automatically on first use.
