Retroarch Ipac help
Henderson33
Hi, i have built a bartop arcade and foolishly bought a hard drive with a hyperspin set up on. I regretted it as none of it is configed. I have decided to start a fresh install of hyperspin and i have been following some videos on youtube from simply austin. Im in the process of setting up retroarch but already facing problems, in his video he uses a xbox controller so thats no help to me.
I seen somewhere on this forum that to use a ipac u need to change bind mode from retropad to retrokeyboard. So i did that and then when to assisgn the controls, for up i pressed up on the joystick and it changed the setting to keypad8, pressed down and it changed to keypad2 and so on. The problem is my ipac uses the arrow keys and not the keypad so i dont know why its doing that. Needless to say none of the directions work in game.
Can anyone please help me with this problem?
input_max_users = "16"
input_axis_threshold = "0.500000"
input_remap_binds_enable = "true"
netplay_client_swap_input = "true"
input_descriptor_label_show = "true"
autoconfig_descriptor_label_show = "true"
input_descriptor_hide_unbound = "false"
load_dummy_on_core_shutdown = "true"
fps_show = "false"
ui_menubar_enable = "true"
suspend_screensaver_enable = "true"
fps_monitor_enable = "false"
libretro_path = ":\cores\genesis_plus_gx_libretro.dll"
libretro_directory = ""
libretro_info_path = ""
content_database_path = ""
cheat_database_path = ""
cursor_directory = ""
content_history_dir = ""
rewind_enable = "false"
audio_latency = "64"
audio_sync = "true"
audio_block_frames = "0"
rewind_granularity = "1"
video_shader = ":\shaders\retroarch.cgp"
video_shader_enable = "true"
video_aspect_ratio = "-1.000000"
video_aspect_ratio_auto = "true"
video_windowed_fullscreen = "true"
video_scale = "1.000000"
autosave_interval = "0"
video_crop_overscan = "true"
video_scale_integer = "false"
video_smooth = "true"
video_threaded = "false"
video_shared_context = "false"
video_force_srgb_disable = "false"
video_fullscreen = "true"
video_refresh_rate = "59.950001"
video_monitor_index = "0"
video_fullscreen_x = "0"
video_fullscreen_y = "0"
video_driver = "gl"
menu_driver = "rgui"
menu_pause_libretro = "true"
menu_mouse_enable = "false"
menu_timedate_enable = "true"
menu_wallpaper = ""
video_vsync = "true"
video_hard_sync = "false"
video_hard_sync_frames = "0"
video_frame_delay = "0"
video_black_frame_insertion = "false"
video_disable_composition = "false"
pause_nonactive = "false"
video_swap_interval = "1"
video_gpu_screenshot = "true"
video_rotation = "0"
screenshot_directory = "default"
aspect_ratio_index = "0"
audio_device = ""
video_filter = ""
audio_dsp_plugin = ""
core_management_buildbot_url = "http://buildbot.libretro.com/nightly/win-x86_64/latest/"
camera_device = ""
camera_allow = "false"
audio_rate_control = "true"
audio_rate_control_delta = "0.005000"
audio_max_timing_skew = "0.050000"
audio_volume = "0.000000"
video_context_driver = ""
audio_driver = "dsound"
audio_enable = "true"
audio_mute_enable = "false"
audio_out_rate = "48000"
location_allow = "false"
video_font_size = "48.000000"
video_font_enable = "true"
ups_pref = "false"
bps_pref = "false"
ips_pref = "false"
system_directory = "H:\Hyperspin_Roms\Super Nintendo\"
extraction_directory = ""
input_remapping_directory = ""
input_remapping_path = ""
resampler_directory = ""
audio_resampler = "sinc"
savefile_directory = "default"
savestate_directory = "default"
video_shader_dir = ":\shaders"
video_filter_dir = "default"
audio_filter_dir = "default"
content_directory = "default"
assets_directory = "default"
playlist_directory = "default"
rgui_browser_directory = "default"
rgui_config_directory = ":\configs"
rgui_show_start_screen = "false"
menu_navigation_wraparound_horizontal_enable = "true"
menu_navigation_wraparound_vertical_enable = "true"
menu_navigation_browser_filter_supported_extensions_enable = "true"
game_history_path = ":\configs\retroarch-content-history.txt"
game_history_size = "100"
joypad_autoconfig_dir = ""
input_autodetect_enable = "true"
overlay_directory = "default"
input_overlay = ""
input_overlay_enable = "true"
input_overlay_opacity = "0.700000"
input_overlay_scale = "1.000000"
video_font_path = ""
video_message_pos_x = "0.050000"
video_message_pos_y = "0.050000"
gamma_correction = "false"
soft_filter_enable = "false"
flicker_filter_enable = "false"
flicker_filter_index = "0"
soft_filter_index = "0"
current_resolution_id = "0"
custom_viewport_width = "1024"
custom_viewport_height = "768"
custom_viewport_x = "0"
custom_viewport_y = "0"
block_sram_overwrite = "false"
savestate_auto_index = "false"
savestate_auto_save = "false"
savestate_auto_load = "true"
history_list_enable = "true"
fastforward_ratio = "1.000000"
fastforward_ratio_throttle_enable = "false"
slowmotion_ratio = "3.000000"
config_save_on_exit = "false"
sound_mode = "0"
state_slot = "-1"
netplay_spectator_mode_enable = "false"
netplay_mode = "false"
netplay_ip_address = ""
netplay_ip_port = "0"
netplay_delay_frames = "0"
netplay_nickname = ""
user_language = "0"
custom_bgm_enable = "false"
input_driver = "dinput"
input_joypad_driver = "dinput"
input_keyboard_layout = ""
input_device_p1 = "0"
input_player1_joypad_index = "-1"
input_libretro_device_p1 = "1"
input_player1_analog_dpad_mode = "0"
input_device_p2 = "0"
input_player2_joypad_index = "1"
input_libretro_device_p2 = "1"
input_player2_analog_dpad_mode = "0"
input_device_p3 = "0"
input_player3_joypad_index = "2"
input_libretro_device_p3 = "1"
input_player3_analog_dpad_mode = "0"
input_device_p4 = "0"
input_player4_joypad_index = "3"
input_libretro_device_p4 = "1"
input_player4_analog_dpad_mode = "0"
input_device_p5 = "0"
input_player5_joypad_index = "4"
input_libretro_device_p5 = "1"
input_player5_analog_dpad_mode = "0"
input_device_p6 = "0"
input_player6_joypad_index = "5"
input_libretro_device_p6 = "1"
input_player6_analog_dpad_mode = "0"
input_device_p7 = "0"
input_player7_joypad_index = "6"
input_libretro_device_p7 = "1"
input_player7_analog_dpad_mode = "0"
input_device_p8 = "0"
input_player8_joypad_index = "7"
input_libretro_device_p8 = "1"
input_player8_analog_dpad_mode = "0"
input_device_p9 = "0"
input_player9_joypad_index = "8"
input_libretro_device_p9 = "1"
input_player9_analog_dpad_mode = "0"
input_device_p10 = "0"
input_player10_joypad_index = "9"
input_libretro_device_p10 = "1"
input_player10_analog_dpad_mode = "0"
input_device_p11 = "0"
input_player11_joypad_index = "10"
input_libretro_device_p11 = "1"
input_player11_analog_dpad_mode = "0"
input_device_p12 = "0"
input_player12_joypad_index = "11"
input_libretro_device_p12 = "1"
input_player12_analog_dpad_mode = "0"
input_device_p13 = "0"
input_player13_joypad_index = "12"
input_libretro_device_p13 = "1"
input_player13_analog_dpad_mode = "0"
input_device_p14 = "0"
input_player14_joypad_index = "13"
input_libretro_device_p14 = "1"
input_player14_analog_dpad_mode = "0"
input_device_p15 = "0"
input_player15_joypad_index = "14"
input_libretro_device_p15 = "1"
input_player15_analog_dpad_mode = "0"
input_device_p16 = "0"
input_player16_joypad_index = "15"
input_libretro_device_p16 = "1"
input_player16_analog_dpad_mode = "0"
input_player1_b = "h"
input_player1_b_btn = "nul"
input_player1_b_axis = "nul"
input_player1_y = "z"
input_player1_y_btn = "nul"
input_player1_y_axis = "nul"
input_player1_select = "num5"
input_player1_select_btn = "nul"
input_player1_select_axis = "nul"
input_player1_start = "num1"
input_player1_start_btn = "nul"
input_player1_start_axis = "nul"
input_player1_up = "up"
input_player1_up_btn = "nul"
input_player1_up_axis = "nul"
input_player1_down = "down"
input_player1_down_btn = "nul"
input_player1_down_axis = "nul"
input_player1_left = "left"
input_player1_left_btn = "nul"
input_player1_left_axis = "nul"
input_player1_right = "right"
input_player1_right_btn = "nul"
input_player1_right_axis = "nul"
input_player1_a = "equals"
input_player1_a_btn = "nul"
input_player1_a_axis = "nul"
input_player1_x = "num0"
input_player1_x_btn = "nul"
input_player1_x_axis = "nul"
input_player1_l = "x"
input_player1_l_btn = "nul"
input_player1_l_axis = "nul"
input_player1_r = "num9"
input_player1_r_btn = "nul"
input_player1_r_axis = "nul"
input_player1_l2 = "nul"
input_player1_l2_btn = "nul"
input_player1_l2_axis = "nul"
input_player1_r2 = "nul"
input_player1_r2_btn = "nul"
input_player1_r2_axis = "nul"
input_player1_l3 = "nul"
input_player1_l3_btn = "nul"
input_player1_l3_axis = "nul"
input_player1_r3 = "nul"
input_player1_r3_btn = "nul"
input_player1_r3_axis = "nul"
input_player1_l_x_plus = "nul"
input_player1_l_x_plus_btn = "nul"
input_player1_l_x_plus_axis = "nul"
input_player1_l_x_minus = "nul"
input_player1_l_x_minus_btn = "nul"
input_player1_l_x_minus_axis = "nul"
input_player1_l_y_plus = "nul"
input_player1_l_y_plus_btn = "nul"
input_player1_l_y_plus_axis = "nul"
input_player1_l_y_minus = "nul"
input_player1_l_y_minus_btn = "nul"
input_player1_l_y_minus_axis = "nul"
input_player1_r_x_plus = "nul"
input_player1_r_x_plus_btn = "nul"
input_player1_r_x_plus_axis = "nul"
input_player1_r_x_minus = "nul"
input_player1_r_x_minus_btn = "nul"
input_player1_r_x_minus_axis = "nul"
input_player1_r_y_plus = "nul"
input_player1_r_y_plus_btn = "nul"
input_player1_r_y_plus_axis = "nul"
input_player1_r_y_minus = "nul"
input_player1_r_y_minus_btn = "nul"
input_player1_r_y_minus_axis = "nul"
input_player1_turbo = "nul"
input_player1_turbo_btn = "nul"
input_player1_turbo_axis = "nul"
input_toggle_fast_forward = "nul"
input_toggle_fast_forward_btn = "nul"
input_toggle_fast_forward_axis = "nul"
input_hold_fast_forward = "nul"
input_hold_fast_forward_btn = "nul"
input_hold_fast_forward_axis = "nul"
input_load_state = "f4"
input_load_state_btn = "nul"
input_load_state_axis = "nul"
input_save_state = "f2"
input_save_state_btn = "nul"
input_save_state_axis = "nul"
input_toggle_fullscreen = "nul"
input_toggle_fullscreen_btn = "nul"
input_toggle_fullscreen_axis = "nul"
input_exit_emulator = "escape"
input_exit_emulator_btn = "nul"
input_exit_emulator_axis = "nul"
input_state_slot_increase = "f7"
input_state_slot_increase_btn = "nul"
input_state_slot_increase_axis = "nul"
input_state_slot_decrease = "f6"
input_state_slot_decrease_btn = "nul"
input_state_slot_decrease_axis = "nul"
input_rewind = "nul"
input_rewind_btn = "nul"
input_rewind_axis = "nul"
input_movie_record_toggle = "nul"
input_movie_record_toggle_btn = "nul"
input_movie_record_toggle_axis = "nul"
input_pause_toggle = "nul"
input_pause_toggle_btn = "nul"
input_pause_toggle_axis = "nul"
input_frame_advance = "nul"
input_frame_advance_btn = "nul"
input_frame_advance_axis = "nul"
input_reset = "nul"
input_reset_btn = "nul"
input_reset_axis = "nul"
input_shader_next = "nul"
input_shader_next_btn = "nul"
input_shader_next_axis = "nul"
input_shader_prev = "nul"
input_shader_prev_btn = "nul"
input_shader_prev_axis = "nul"
input_cheat_index_plus = "nul"
input_cheat_index_plus_btn = "nul"
input_cheat_index_plus_axis = "nul"
input_cheat_index_minus = "nul"
input_cheat_index_minus_btn = "nul"
input_cheat_index_minus_axis = "nul"
input_cheat_toggle = "nul"
input_cheat_toggle_btn = "nul"
input_cheat_toggle_axis = "nul"
input_screenshot = "f8"
input_screenshot_btn = "nul"
input_screenshot_axis = "nul"
input_audio_mute = "f9"
input_audio_mute_btn = "nul"
input_audio_mute_axis = "nul"
input_netplay_flip_players = "nul"
input_netplay_flip_players_btn = "nul"
input_netplay_flip_players_axis = "nul"
input_slowmotion = "nul"
input_slowmotion_btn = "nul"
input_slowmotion_axis = "nul"
input_enable_hotkey = "nul"
input_enable_hotkey_btn = "nul"
input_enable_hotkey_axis = "nul"
input_volume_up = "add"
input_volume_up_btn = "nul"
input_volume_up_axis = "nul"
input_volume_down = "subtract"
input_volume_down_btn = "nul"
input_volume_down_axis = "nul"
input_overlay_next = "nul"
input_overlay_next_btn = "nul"
input_overlay_next_axis = "nul"
input_disk_eject_toggle = "nul"
input_disk_eject_toggle_btn = "nul"
input_disk_eject_toggle_axis = "nul"
input_disk_next = "nul"
input_disk_next_btn = "nul"
input_disk_next_axis = "nul"
input_disk_prev = "nul"
input_disk_prev_btn = "nul"
input_disk_prev_axis = "nul"
input_grab_mouse_toggle = "f11"
input_grab_mouse_toggle_btn = "nul"
input_grab_mouse_toggle_axis = "nul"
input_menu_toggle = "f1"
input_menu_toggle_btn = "nul"
input_menu_toggle_axis = "nul"
input_player2_b = "s"
input_player2_b_btn = "nul"
input_player2_b_axis = "nul"
input_player2_y = "i"
input_player2_y_btn = "nul"
input_player2_y_axis = "nul"
input_player2_select = "nul"
input_player2_select_btn = "nul"
input_player2_select_axis = "nul"
input_player2_start = "nul"
input_player2_start_btn = "nul"
input_player2_start_axis = "nul"
input_player2_up = "r"
input_player2_up_btn = "nul"
input_player2_up_axis = "nul"
input_player2_down = "f"
input_player2_down_btn = "nul"
input_player2_down_axis = "nul"
input_player2_left = "d"
input_player2_left_btn = "nul"
input_player2_left_axis = "nul"
input_player2_right = "g"
input_player2_right_btn = "nul"
input_player2_right_axis = "nul"
input_player2_a = "a"
input_player2_a_btn = "nul"
input_player2_a_axis = "nul"
input_player2_x = "w"
input_player2_x_btn = "nul"
input_player2_x_axis = "nul"
input_player2_l = "q"
input_player2_l_btn = "nul"
input_player2_l_axis = "nul"
input_player2_r = "k"
input_player2_r_btn = "nul"
input_player2_r_axis = "nul"
input_player2_l2 = "nul"
input_player2_l2_btn = "nul"
input_player2_l2_axis = "nul"
input_player2_r2 = "nul"
input_player2_r2_btn = "nul"
input_player2_r2_axis = "nul"
input_player2_l3 = "nul"
input_player2_l3_btn = "nul"
input_player2_l3_axis = "nul"
input_player2_r3 = "nul"
input_player2_r3_btn = "nul"
input_player2_r3_axis = "nul"
input_player2_l_x_plus = "nul"
input_player2_l_x_plus_btn = "nul"
input_player2_l_x_plus_axis = "nul"
input_player2_l_x_minus = "nul"
input_player2_l_x_minus_btn = "nul"
input_player2_l_x_minus_axis = "nul"
input_player2_l_y_plus = "nul"
input_player2_l_y_plus_btn = "nul"
input_player2_l_y_plus_axis = "nul"
input_player2_l_y_minus = "nul"
input_player2_l_y_minus_btn = "nul"
input_player2_l_y_minus_axis = "nul"
input_player2_r_x_plus = "nul"
input_player2_r_x_plus_btn = "nul"
input_player2_r_x_plus_axis = "nul"
input_player2_r_x_minus = "nul"
input_player2_r_x_minus_btn = "nul"
input_player2_r_x_minus_axis = "nul"
input_player2_r_y_plus = "nul"
input_player2_r_y_plus_btn = "nul"
input_player2_r_y_plus_axis = "nul"
input_player2_r_y_minus = "nul"
input_player2_r_y_minus_btn = "nul"
input_player2_r_y_minus_axis = "nul"
input_player2_turbo = "nul"
input_player2_turbo_btn = "nul"
input_player2_turbo_axis = "nul"
input_player3_b = "nul"
input_player3_b_btn = "nul"
input_player3_b_axis = "nul"
input_player3_y = "nul"
input_player3_y_btn = "nul"
input_player3_y_axis = "nul"
input_player3_select = "nul"
input_player3_select_btn = "nul"
input_player3_select_axis = "nul"
input_player3_start = "nul"
input_player3_start_btn = "nul"
input_player3_start_axis = "nul"
input_player3_up = "nul"
input_player3_up_btn = "nul"
input_player3_up_axis = "nul"
input_player3_down = "nul"
input_player3_down_btn = "nul"
input_player3_down_axis = "nul"
input_player3_left = "nul"
input_player3_left_btn = "nul"
input_player3_left_axis = "nul"
input_player3_right = "nul"
input_player3_right_btn = "nul"
input_player3_right_axis = "nul"
input_player3_a = "nul"
input_player3_a_btn = "nul"
input_player3_a_axis = "nul"
input_player3_x = "nul"
input_player3_x_btn = "nul"
input_player3_x_axis = "nul"
input_player3_l = "nul"
input_player3_l_btn = "nul"
input_player3_l_axis = "nul"
input_player3_r = "nul"
input_player3_r_btn = "nul"
input_player3_r_axis = "nul"
input_player3_l2 = "nul"
input_player3_l2_btn = "nul"
input_player3_l2_axis = "nul"
input_player3_r2 = "nul"
input_player3_r2_btn = "nul"
input_player3_r2_axis = "nul"
input_player3_l3 = "nul"
input_player3_l3_btn = "nul"
input_player3_l3_axis = "nul"
input_player3_r3 = "nul"
input_player3_r3_btn = "nul"
input_player3_r3_axis = "nul"
input_player3_l_x_plus = "nul"
input_player3_l_x_plus_btn = "nul"
input_player3_l_x_plus_axis = "nul"
input_player3_l_x_minus = "nul"
input_player3_l_x_minus_btn = "nul"
input_player3_l_x_minus_axis = "nul"
input_player3_l_y_plus = "nul"
input_player3_l_y_plus_btn = "nul"
input_player3_l_y_plus_axis = "nul"
input_player3_l_y_minus = "nul"
input_player3_l_y_minus_btn = "nul"
input_player3_l_y_minus_axis = "nul"
input_player3_r_x_plus = "nul"
input_player3_r_x_plus_btn = "nul"
input_player3_r_x_plus_axis = "nul"
input_player3_r_x_minus = "nul"
input_player3_r_x_minus_btn = "nul"
input_player3_r_x_minus_axis = "nul"
input_player3_r_y_plus = "nul"
input_player3_r_y_plus_btn = "nul"
input_player3_r_y_plus_axis = "nul"
input_player3_r_y_minus = "nul"
input_player3_r_y_minus_btn = "nul"
input_player3_r_y_minus_axis = "nul"
input_player3_turbo = "nul"
input_player3_turbo_btn = "nul"
input_player3_turbo_axis = "nul"
input_player4_b = "nul"
input_player4_b_btn = "nul"
input_player4_b_axis = "nul"
input_player4_y = "nul"
input_player4_y_btn = "nul"
input_player4_y_axis = "nul"
input_player4_select = "nul"
input_player4_select_btn = "nul"
input_player4_select_axis = "nul"
input_player4_start = "nul"
input_player4_start_btn = "nul"
input_player4_start_axis = "nul"
input_player4_up = "nul"
input_player4_up_btn = "nul"
input_player4_up_axis = "nul"
input_player4_down = "nul"
input_player4_down_btn = "nul"
input_player4_down_axis = "nul"
input_player4_left = "nul"
input_player4_left_btn = "nul"
input_player4_left_axis = "nul"
input_player4_right = "nul"
input_player4_right_btn = "nul"
input_player4_right_axis = "nul"
input_player4_a = "nul"
input_player4_a_btn = "nul"
input_player4_a_axis = "nul"
input_player4_x = "nul"
input_player4_x_btn = "nul"
input_player4_x_axis = "nul"
input_player4_l = "nul"
input_player4_l_btn = "nul"
input_player4_l_axis = "nul"
input_player4_r = "nul"
input_player4_r_btn = "nul"
input_player4_r_axis = "nul"
input_player4_l2 = "nul"
input_player4_l2_btn = "nul"
input_player4_l2_axis = "nul"
input_player4_r2 = "nul"
input_player4_r2_btn = "nul"
input_player4_r2_axis = "nul"
input_player4_l3 = "nul"
input_player4_l3_btn = "nul"
input_player4_l3_axis = "nul"
input_player4_r3 = "nul"
input_player4_r3_btn = "nul"
input_player4_r3_axis = "nul"
input_player4_l_x_plus = "nul"
input_player4_l_x_plus_btn = "nul"
input_player4_l_x_plus_axis = "nul"
input_player4_l_x_minus = "nul"
input_player4_l_x_minus_btn = "nul"
input_player4_l_x_minus_axis = "nul"
input_player4_l_y_plus = "nul"
input_player4_l_y_plus_btn = "nul"
input_player4_l_y_plus_axis = "nul"
input_player4_l_y_minus = "nul"
input_player4_l_y_minus_btn = "nul"
input_player4_l_y_minus_axis = "nul"
input_player4_r_x_plus = "nul"
input_player4_r_x_plus_btn = "nul"
input_player4_r_x_plus_axis = "nul"
input_player4_r_x_minus = "nul"
input_player4_r_x_minus_btn = "nul"
input_player4_r_x_minus_axis = "nul"
input_player4_r_y_plus = "nul"
input_player4_r_y_plus_btn = "nul"
input_player4_r_y_plus_axis = "nul"
input_player4_r_y_minus = "nul"
input_player4_r_y_minus_btn = "nul"
input_player4_r_y_minus_axis = "nul"
input_player4_turbo = "nul"
input_player4_turbo_btn = "nul"
input_player4_turbo_axis = "nul"
input_player5_b = "nul"
input_player5_b_btn = "nul"
input_player5_b_axis = "nul"
input_player5_y = "nul"
input_player5_y_btn = "nul"
input_player5_y_axis = "nul"
input_player5_select = "nul"
input_player5_select_btn = "nul"
input_player5_select_axis = "nul"
input_player5_start = "nul"
input_player5_start_btn = "nul"
input_player5_start_axis = "nul"
input_player5_up = "nul"
input_player5_up_btn = "nul"
input_player5_up_axis = "nul"
input_player5_down = "nul"
input_player5_down_btn = "nul"
input_player5_down_axis = "nul"
input_player5_left = "nul"
input_player5_left_btn = "nul"
input_player5_left_axis = "nul"
input_player5_right = "nul"
input_player5_right_btn = "nul"
input_player5_right_axis = "nul"
input_player5_a = "nul"
input_player5_a_btn = "nul"
input_player5_a_axis = "nul"
input_player5_x = "nul"
input_player5_x_btn = "nul"
input_player5_x_axis = "nul"
input_player5_l = "nul"
input_player5_l_btn = "nul"
input_player5_l_axis = "nul"
input_player5_r = "nul"
input_player5_r_btn = "nul"
input_player5_r_axis = "nul"
input_player5_l2 = "nul"
input_player5_l2_btn = "nul"
input_player5_l2_axis = "nul"
input_player5_r2 = "nul"
input_player5_r2_btn = "nul"
input_player5_r2_axis = "nul"
input_player5_l3 = "nul"
input_player5_l3_btn = "nul"
input_player5_l3_axis = "nul"
input_player5_r3 = "nul"
input_player5_r3_btn = "nul"
input_player5_r3_axis = "nul"
input_player5_l_x_plus = "nul"
input_player5_l_x_plus_btn = "nul"
input_player5_l_x_plus_axis = "nul"
input_player5_l_x_minus = "nul"
input_player5_l_x_minus_btn = "nul"
input_player5_l_x_minus_axis = "nul"
input_player5_l_y_plus = "nul"
input_player5_l_y_plus_btn = "nul"
input_player5_l_y_plus_axis = "nul"
input_player5_l_y_minus = "nul"
input_player5_l_y_minus_btn = "nul"
input_player5_l_y_minus_axis = "nul"
input_player5_r_x_plus = "nul"
input_player5_r_x_plus_btn = "nul"
input_player5_r_x_plus_axis = "nul"
input_player5_r_x_minus = "nul"
input_player5_r_x_minus_btn = "nul"
input_player5_r_x_minus_axis = "nul"
input_player5_r_y_plus = "nul"
input_player5_r_y_plus_btn = "nul"
input_player5_r_y_plus_axis = "nul"
input_player5_r_y_minus = "nul"
input_player5_r_y_minus_btn = "nul"
input_player5_r_y_minus_axis = "nul"
input_player5_turbo = "nul"
input_player5_turbo_btn = "nul"
input_player5_turbo_axis = "nul"
input_player6_b = "nul"
input_player6_b_btn = "nul"
input_player6_b_axis = "nul"
input_player6_y = "nul"
input_player6_y_btn = "nul"
input_player6_y_axis = "nul"
input_player6_select = "nul"
input_player6_select_btn = "nul"
input_player6_select_axis = "nul"
input_player6_start = "nul"
input_player6_start_btn = "nul"
input_player6_start_axis = "nul"
input_player6_up = "nul"
input_player6_up_btn = "nul"
input_player6_up_axis = "nul"
input_player6_down = "nul"
input_player6_down_btn = "nul"
input_player6_down_axis = "nul"
input_player6_left = "nul"
input_player6_left_btn = "nul"
input_player6_left_axis = "nul"
input_player6_right = "nul"
input_player6_right_btn = "nul"
input_player6_right_axis = "nul"
input_player6_a = "nul"
input_player6_a_btn = "nul"
input_player6_a_axis = "nul"
input_player6_x = "nul"
input_player6_x_btn = "nul"
input_player6_x_axis = "nul"
input_player6_l = "nul"
input_player6_l_btn = "nul"
input_player6_l_axis = "nul"
input_player6_r = "nul"
input_player6_r_btn = "nul"
input_player6_r_axis = "nul"
input_player6_l2 = "nul"
input_player6_l2_btn = "nul"
input_player6_l2_axis = "nul"
input_player6_r2 = "nul"
input_player6_r2_btn = "nul"
input_player6_r2_axis = "nul"
input_player6_l3 = "nul"
input_player6_l3_btn = "nul"
input_player6_l3_axis = "nul"
input_player6_r3 = "nul"
input_player6_r3_btn = "nul"
input_player6_r3_axis = "nul"
input_player6_l_x_plus = "nul"
input_player6_l_x_plus_btn = "nul"
input_player6_l_x_plus_axis = "nul"
input_player6_l_x_minus = "nul"
input_player6_l_x_minus_btn = "nul"
input_player6_l_x_minus_axis = "nul"
input_player6_l_y_plus = "nul"
input_player6_l_y_plus_btn = "nul"
input_player6_l_y_plus_axis = "nul"
input_player6_l_y_minus = "nul"
input_player6_l_y_minus_btn = "nul"
input_player6_l_y_minus_axis = "nul"
input_player6_r_x_plus = "nul"
input_player6_r_x_plus_btn = "nul"
input_player6_r_x_plus_axis = "nul"
input_player6_r_x_minus = "nul"
input_player6_r_x_minus_btn = "nul"
input_player6_r_x_minus_axis = "nul"
input_player6_r_y_plus = "nul"
input_player6_r_y_plus_btn = "nul"
input_player6_r_y_plus_axis = "nul"
input_player6_r_y_minus = "nul"
input_player6_r_y_minus_btn = "nul"
input_player6_r_y_minus_axis = "nul"
input_player6_turbo = "nul"
input_player6_turbo_btn = "nul"
input_player6_turbo_axis = "nul"
input_player7_b = "nul"
input_player7_b_btn = "nul"
input_player7_b_axis = "nul"
input_player7_y = "nul"
input_player7_y_btn = "nul"
input_player7_y_axis = "nul"
input_player7_select = "nul"
input_player7_select_btn = "nul"
input_player7_select_axis = "nul"
input_player7_start = "nul"
input_player7_start_btn = "nul"
input_player7_start_axis = "nul"
input_player7_up = "nul"
input_player7_up_btn = "nul"
input_player7_up_axis = "nul"
input_player7_down = "nul"
input_player7_down_btn = "nul"
input_player7_down_axis = "nul"
input_player7_left = "nul"
input_player7_left_btn = "nul"
input_player7_left_axis = "nul"
input_player7_right = "nul"
input_player7_right_btn = "nul"
input_player7_right_axis = "nul"
input_player7_a = "nul"
input_player7_a_btn = "nul"
input_player7_a_axis = "nul"
input_player7_x = "nul"
input_player7_x_btn = "nul"
input_player7_x_axis = "nul"
input_player7_l = "nul"
input_player7_l_btn = "nul"
input_player7_l_axis = "nul"
input_player7_r = "nul"
input_player7_r_btn = "nul"
input_player7_r_axis = "nul"
input_player7_l2 = "nul"
input_player7_l2_btn = "nul"
input_player7_l2_axis = "nul"
input_player7_r2 = "nul"
input_player7_r2_btn = "nul"
input_player7_r2_axis = "nul"
input_player7_l3 = "nul"
input_player7_l3_btn = "nul"
input_player7_l3_axis = "nul"
input_player7_r3 = "nul"
input_player7_r3_btn = "nul"
input_player7_r3_axis = "nul"
input_player7_l_x_plus = "nul"
input_player7_l_x_plus_btn = "nul"
input_player7_l_x_plus_axis = "nul"
input_player7_l_x_minus = "nul"
input_player7_l_x_minus_btn = "nul"
input_player7_l_x_minus_axis = "nul"
input_player7_l_y_plus = "nul"
input_player7_l_y_plus_btn = "nul"
input_player7_l_y_plus_axis = "nul"
input_player7_l_y_minus = "nul"
input_player7_l_y_minus_btn = "nul"
input_player7_l_y_minus_axis = "nul"
input_player7_r_x_plus = "nul"
input_player7_r_x_plus_btn = "nul"
input_player7_r_x_plus_axis = "nul"
input_player7_r_x_minus = "nul"
input_player7_r_x_minus_btn = "nul"
input_player7_r_x_minus_axis = "nul"
input_player7_r_y_plus = "nul"
input_player7_r_y_plus_btn = "nul"
input_player7_r_y_plus_axis = "nul"
input_player7_r_y_minus = "nul"
input_player7_r_y_minus_btn = "nul"
input_player7_r_y_minus_axis = "nul"
input_player7_turbo = "nul"
input_player7_turbo_btn = "nul"
input_player7_turbo_axis = "nul"
input_player8_b = "nul"
input_player8_b_btn = "nul"
input_player8_b_axis = "nul"
input_player8_y = "nul"
input_player8_y_btn = "nul"
input_player8_y_axis = "nul"
input_player8_select = "nul"
input_player8_select_btn = "nul"
input_player8_select_axis = "nul"
input_player8_start = "nul"
input_player8_start_btn = "nul"
input_player8_start_axis = "nul"
input_player8_up = "nul"
input_player8_up_btn = "nul"
input_player8_up_axis = "nul"
input_player8_down = "nul"
input_player8_down_btn = "nul"
input_player8_down_axis = "nul"
input_player8_left = "nul"
input_player8_left_btn = "nul"
input_player8_left_axis = "nul"
input_player8_right = "nul"
input_player8_right_btn = "nul"
input_player8_right_axis = "nul"
input_player8_a = "nul"
input_player8_a_btn = "nul"
input_player8_a_axis = "nul"
input_player8_x = "nul"
input_player8_x_btn = "nul"
input_player8_x_axis = "nul"
input_player8_l = "nul"
input_player8_l_btn = "nul"
input_player8_l_axis = "nul"
input_player8_r = "nul"
input_player8_r_btn = "nul"
input_player8_r_axis = "nul"
input_player8_l2 = "nul"
input_player8_l2_btn = "nul"
input_player8_l2_axis = "nul"
input_player8_r2 = "nul"
input_player8_r2_btn = "nul"
input_player8_r2_axis = "nul"
input_player8_l3 = "nul"
input_player8_l3_btn = "nul"
input_player8_l3_axis = "nul"
input_player8_r3 = "nul"
input_player8_r3_btn = "nul"
input_player8_r3_axis = "nul"
input_player8_l_x_plus = "nul"
input_player8_l_x_plus_btn = "nul"
input_player8_l_x_plus_axis = "nul"
input_player8_l_x_minus = "nul"
input_player8_l_x_minus_btn = "nul"
input_player8_l_x_minus_axis = "nul"
input_player8_l_y_plus = "nul"
input_player8_l_y_plus_btn = "nul"
input_player8_l_y_plus_axis = "nul"
input_player8_l_y_minus = "nul"
input_player8_l_y_minus_btn = "nul"
input_player8_l_y_minus_axis = "nul"
input_player8_r_x_plus = "nul"
input_player8_r_x_plus_btn = "nul"
input_player8_r_x_plus_axis = "nul"
input_player8_r_x_minus = "nul"
input_player8_r_x_minus_btn = "nul"
input_player8_r_x_minus_axis = "nul"
input_player8_r_y_plus = "nul"
input_player8_r_y_plus_btn = "nul"
input_player8_r_y_plus_axis = "nul"
input_player8_r_y_minus = "nul"
input_player8_r_y_minus_btn = "nul"
input_player8_r_y_minus_axis = "nul"
input_player8_turbo = "nul"
input_player8_turbo_btn = "nul"
input_player8_turbo_axis = "nul"
input_player9_b = "nul"
input_player9_b_btn = "nul"
input_player9_b_axis = "nul"
input_player9_y = "nul"
input_player9_y_btn = "nul"
input_player9_y_axis = "nul"
input_player9_select = "nul"
input_player9_select_btn = "nul"
input_player9_select_axis = "nul"
input_player9_start = "nul"
input_player9_start_btn = "nul"
input_player9_start_axis = "nul"
input_player9_up = "nul"
input_player9_up_btn = "nul"
input_player9_up_axis = "nul"
input_player9_down = "nul"
input_player9_down_btn = "nul"
input_player9_down_axis = "nul"
input_player9_left = "nul"
input_player9_left_btn = "nul"
input_player9_left_axis = "nul"
input_player9_right = "nul"
input_player9_right_btn = "nul"
input_player9_right_axis = "nul"
input_player9_a = "nul"
input_player9_a_btn = "nul"
input_player9_a_axis = "nul"
input_player9_x = "nul"
input_player9_x_btn = "nul"
input_player9_x_axis = "nul"
input_player9_l = "nul"
input_player9_l_btn = "nul"
input_player9_l_axis = "nul"
input_player9_r = "nul"
input_player9_r_btn = "nul"
input_player9_r_axis = "nul"
input_player9_l2 = "nul"
input_player9_l2_btn = "nul"
input_player9_l2_axis = "nul"
input_player9_r2 = "nul"
input_player9_r2_btn = "nul"
input_player9_r2_axis = "nul"
input_player9_l3 = "nul"
input_player9_l3_btn = "nul"
input_player9_l3_axis = "nul"
input_player9_r3 = "nul"
input_player9_r3_btn = "nul"
input_player9_r3_axis = "nul"
input_player9_l_x_plus = "nul"
input_player9_l_x_plus_btn = "nul"
input_player9_l_x_plus_axis = "nul"
input_player9_l_x_minus = "nul"
input_player9_l_x_minus_btn = "nul"
input_player9_l_x_minus_axis = "nul"
input_player9_l_y_plus = "nul"
input_player9_l_y_plus_btn = "nul"
input_player9_l_y_plus_axis = "nul"
input_player9_l_y_minus = "nul"
input_player9_l_y_minus_btn = "nul"
input_player9_l_y_minus_axis = "nul"
input_player9_r_x_plus = "nul"
input_player9_r_x_plus_btn = "nul"
input_player9_r_x_plus_axis = "nul"
input_player9_r_x_minus = "nul"
input_player9_r_x_minus_btn = "nul"
input_player9_r_x_minus_axis = "nul"
input_player9_r_y_plus = "nul"
input_player9_r_y_plus_btn = "nul"
input_player9_r_y_plus_axis = "nul"
input_player9_r_y_minus = "nul"
input_player9_r_y_minus_btn = "nul"
input_player9_r_y_minus_axis = "nul"
input_player9_turbo = "nul"
input_player9_turbo_btn = "nul"
input_player9_turbo_axis = "nul"
input_player10_b = "nul"
input_player10_b_btn = "nul"
input_player10_b_axis = "nul"
input_player10_y = "nul"
input_player10_y_btn = "nul"
input_player10_y_axis = "nul"
input_player10_select = "nul"
input_player10_select_btn = "nul"
input_player10_select_axis = "nul"
input_player10_start = "nul"
input_player10_start_btn = "nul"
input_player10_start_axis = "nul"
input_player10_up = "nul"
input_player10_up_btn = "nul"
input_player10_up_axis = "nul"
input_player10_down = "nul"
input_player10_down_btn = "nul"
input_player10_down_axis = "nul"
input_player10_left = "nul"
input_player10_left_btn = "nul"
input_player10_left_axis = "nul"
input_player10_right = "nul"
input_player10_right_btn = "nul"
input_player10_right_axis = "nul"
input_player10_a = "nul"
input_player10_a_btn = "nul"
input_player10_a_axis = "nul"
input_player10_x = "nul"
input_player10_x_btn = "nul"
input_player10_x_axis = "nul"
input_player10_l = "nul"
input_player10_l_btn = "nul"
input_player10_l_axis = "nul"
input_player10_r = "nul"
input_player10_r_btn = "nul"
input_player10_r_axis = "nul"
input_player10_l2 = "nul"
input_player10_l2_btn = "nul"
input_player10_l2_axis = "nul"
input_player10_r2 = "nul"
input_player10_r2_btn = "nul"
input_player10_r2_axis = "nul"
input_player10_l3 = "nul"
input_player10_l3_btn = "nul"
input_player10_l3_axis = "nul"
input_player10_r3 = "nul"
input_player10_r3_btn = "nul"
input_player10_r3_axis = "nul"
input_player10_l_x_plus = "nul"
input_player10_l_x_plus_btn = "nul"
input_player10_l_x_plus_axis = "nul"
input_player10_l_x_minus = "nul"
input_player10_l_x_minus_btn = "nul"
input_player10_l_x_minus_axis = "nul"
input_player10_l_y_plus = "nul"
input_player10_l_y_plus_btn = "nul"
input_player10_l_y_plus_axis = "nul"
input_player10_l_y_minus = "nul"
input_player10_l_y_minus_btn = "nul"
input_player10_l_y_minus_axis = "nul"
input_player10_r_x_plus = "nul"
input_player10_r_x_plus_btn = "nul"
input_player10_r_x_plus_axis = "nul"
input_player10_r_x_minus = "nul"
input_player10_r_x_minus_btn = "nul"
input_player10_r_x_minus_axis = "nul"
input_player10_r_y_plus = "nul"
input_player10_r_y_plus_btn = "nul"
input_player10_r_y_plus_axis = "nul"
input_player10_r_y_minus = "nul"
input_player10_r_y_minus_btn = "nul"
input_player10_r_y_minus_axis = "nul"
input_player10_turbo = "nul"
input_player10_turbo_btn = "nul"
input_player10_turbo_axis = "nul"
input_player11_b = "nul"
input_player11_b_btn = "nul"
input_player11_b_axis = "nul"
input_player11_y = "nul"
input_player11_y_btn = "nul"
input_player11_y_axis = "nul"
input_player11_select = "nul"
input_player11_select_btn = "nul"
input_player11_select_axis = "nul"
input_player11_start = "nul"
input_player11_start_btn = "nul"
input_player11_start_axis = "nul"
input_player11_up = "nul"
input_player11_up_btn = "nul"
input_player11_up_axis = "nul"
input_player11_down = "nul"
input_player11_down_btn = "nul"
input_player11_down_axis = "nul"
input_player11_left = "nul"
input_player11_left_btn = "nul"
input_player11_left_axis = "nul"
input_player11_right = "nul"
input_player11_right_btn = "nul"
input_player11_right_axis = "nul"
input_player11_a = "nul"
input_player11_a_btn = "nul"
input_player11_a_axis = "nul"
input_player11_x = "nul"
input_player11_x_btn = "nul"
input_player11_x_axis = "nul"
input_player11_l = "nul"
input_player11_l_btn = "nul"
input_player11_l_axis = "nul"
input_player11_r = "nul"
input_player11_r_btn = "nul"
input_player11_r_axis = "nul"
input_player11_l2 = "nul"
input_player11_l2_btn = "nul"
input_player11_l2_axis = "nul"
input_player11_r2 = "nul"
input_player11_r2_btn = "nul"
input_player11_r2_axis = "nul"
input_player11_l3 = "nul"
input_player11_l3_btn = "nul"
input_player11_l3_axis = "nul"
input_player11_r3 = "nul"
input_player11_r3_btn = "nul"
input_player11_r3_axis = "nul"
input_player11_l_x_plus = "nul"
input_player11_l_x_plus_btn = "nul"
input_player11_l_x_plus_axis = "nul"
input_player11_l_x_minus = "nul"
input_player11_l_x_minus_btn = "nul"
input_player11_l_x_minus_axis = "nul"
input_player11_l_y_plus = "nul"
input_player11_l_y_plus_btn = "nul"
input_player11_l_y_plus_axis = "nul"
input_player11_l_y_minus = "nul"
input_player11_l_y_minus_btn = "nul"
input_player11_l_y_minus_axis = "nul"
input_player11_r_x_plus = "nul"
input_player11_r_x_plus_btn = "nul"
input_player11_r_x_plus_axis = "nul"
input_player11_r_x_minus = "nul"
input_player11_r_x_minus_btn = "nul"
input_player11_r_x_minus_axis = "nul"
input_player11_r_y_plus = "nul"
input_player11_r_y_plus_btn = "nul"
input_player11_r_y_plus_axis = "nul"
input_player11_r_y_minus = "nul"
input_player11_r_y_minus_btn = "nul"
input_player11_r_y_minus_axis = "nul"
input_player11_turbo = "nul"
input_player11_turbo_btn = "nul"
input_player11_turbo_axis = "nul"
input_player12_b = "nul"
input_player12_b_btn = "nul"
input_player12_b_axis = "nul"
input_player12_y = "nul"
input_player12_y_btn = "nul"
input_player12_y_axis = "nul"
input_player12_select = "nul"
input_player12_select_btn = "nul"
input_player12_select_axis = "nul"
input_player12_start = "nul"
input_player12_start_btn = "nul"
input_player12_start_axis = "nul"
input_player12_up = "nul"
input_player12_up_btn = "nul"
input_player12_up_axis = "nul"
input_player12_down = "nul"
input_player12_down_btn = "nul"
input_player12_down_axis = "nul"
input_player12_left = "nul"
input_player12_left_btn = "nul"
input_player12_left_axis = "nul"
input_player12_right = "nul"
input_player12_right_btn = "nul"
input_player12_right_axis = "nul"
input_player12_a = "nul"
input_player12_a_btn = "nul"
input_player12_a_axis = "nul"
input_player12_x = "nul"
input_player12_x_btn = "nul"
input_player12_x_axis = "nul"
input_player12_l = "nul"
input_player12_l_btn = "nul"
input_player12_l_axis = "nul"
input_player12_r = "nul"
input_player12_r_btn = "nul"
input_player12_r_axis = "nul"
input_player12_l2 = "nul"
input_player12_l2_btn = "nul"
input_player12_l2_axis = "nul"
input_player12_r2 = "nul"
input_player12_r2_btn = "nul"
input_player12_r2_axis = "nul"
input_player12_l3 = "nul"
input_player12_l3_btn = "nul"
input_player12_l3_axis = "nul"
input_player12_r3 = "nul"
input_player12_r3_btn = "nul"
input_player12_r3_axis = "nul"
input_player12_l_x_plus = "nul"
input_player12_l_x_plus_btn = "nul"
input_player12_l_x_plus_axis = "nul"
input_player12_l_x_minus = "nul"
input_player12_l_x_minus_btn = "nul"
input_player12_l_x_minus_axis = "nul"
input_player12_l_y_plus = "nul"
input_player12_l_y_plus_btn = "nul"
input_player12_l_y_plus_axis = "nul"
input_player12_l_y_minus = "nul"
input_player12_l_y_minus_btn = "nul"
input_player12_l_y_minus_axis = "nul"
input_player12_r_x_plus = "nul"
input_player12_r_x_plus_btn = "nul"
input_player12_r_x_plus_axis = "nul"
input_player12_r_x_minus = "nul"
input_player12_r_x_minus_btn = "nul"
input_player12_r_x_minus_axis = "nul"
input_player12_r_y_plus = "nul"
input_player12_r_y_plus_btn = "nul"
input_player12_r_y_plus_axis = "nul"
input_player12_r_y_minus = "nul"
input_player12_r_y_minus_btn = "nul"
input_player12_r_y_minus_axis = "nul"
input_player12_turbo = "nul"
input_player12_turbo_btn = "nul"
input_player12_turbo_axis = "nul"
input_player13_b = "nul"
input_player13_b_btn = "nul"
input_player13_b_axis = "nul"
input_player13_y = "nul"
input_player13_y_btn = "nul"
input_player13_y_axis = "nul"
input_player13_select = "nul"
input_player13_select_btn = "nul"
input_player13_select_axis = "nul"
input_player13_start = "nul"
input_player13_start_btn = "nul"
input_player13_start_axis = "nul"
input_player13_up = "nul"
input_player13_up_btn = "nul"
input_player13_up_axis = "nul"
input_player13_down = "nul"
input_player13_down_btn = "nul"
input_player13_down_axis = "nul"
input_player13_left = "nul"
input_player13_left_btn = "nul"
input_player13_left_axis = "nul"
input_player13_right = "nul"
input_player13_right_btn = "nul"
input_player13_right_axis = "nul"
input_player13_a = "nul"
input_player13_a_btn = "nul"
input_player13_a_axis = "nul"
input_player13_x = "nul"
input_player13_x_btn = "nul"
input_player13_x_axis = "nul"
input_player13_l = "nul"
input_player13_l_btn = "nul"
input_player13_l_axis = "nul"
input_player13_r = "nul"
input_player13_r_btn = "nul"
input_player13_r_axis = "nul"
input_player13_l2 = "nul"
input_player13_l2_btn = "nul"
input_player13_l2_axis = "nul"
input_player13_r2 = "nul"
input_player13_r2_btn = "nul"
input_player13_r2_axis = "nul"
input_player13_l3 = "nul"
input_player13_l3_btn = "nul"
input_player13_l3_axis = "nul"
input_player13_r3 = "nul"
input_player13_r3_btn = "nul"
input_player13_r3_axis = "nul"
input_player13_l_x_plus = "nul"
input_player13_l_x_plus_btn = "nul"
input_player13_l_x_plus_axis = "nul"
input_player13_l_x_minus = "nul"
input_player13_l_x_minus_btn = "nul"
input_player13_l_x_minus_axis = "nul"
input_player13_l_y_plus = "nul"
input_player13_l_y_plus_btn = "nul"
input_player13_l_y_plus_axis = "nul"
input_player13_l_y_minus = "nul"
input_player13_l_y_minus_btn = "nul"
input_player13_l_y_minus_axis = "nul"
input_player13_r_x_plus = "nul"
input_player13_r_x_plus_btn = "nul"
input_player13_r_x_plus_axis = "nul"
input_player13_r_x_minus = "nul"
input_player13_r_x_minus_btn = "nul"
input_player13_r_x_minus_axis = "nul"
input_player13_r_y_plus = "nul"
input_player13_r_y_plus_btn = "nul"
input_player13_r_y_plus_axis = "nul"
input_player13_r_y_minus = "nul"
input_player13_r_y_minus_btn = "nul"
input_player13_r_y_minus_axis = "nul"
input_player13_turbo = "nul"
input_player13_turbo_btn = "nul"
input_player13_turbo_axis = "nul"
input_player14_b = "nul"
input_player14_b_btn = "nul"
input_player14_b_axis = "nul"
input_player14_y = "nul"
input_player14_y_btn = "nul"
input_player14_y_axis = "nul"
input_player14_select = "nul"
input_player14_select_btn = "nul"
input_player14_select_axis = "nul"
input_player14_start = "nul"
input_player14_start_btn = "nul"
input_player14_start_axis = "nul"
input_player14_up = "nul"
input_player14_up_btn = "nul"
input_player14_up_axis = "nul"
input_player14_down = "nul"
input_player14_down_btn = "nul"
input_player14_down_axis = "nul"
input_player14_left = "nul"
input_player14_left_btn = "nul"
input_player14_left_axis = "nul"
input_player14_right = "nul"
input_player14_right_btn = "nul"
input_player14_right_axis = "nul"
input_player14_a = "nul"
input_player14_a_btn = "nul"
input_player14_a_axis = "nul"
input_player14_x = "nul"
input_player14_x_btn = "nul"
input_player14_x_axis = "nul"
input_player14_l = "nul"
input_player14_l_btn = "nul"
input_player14_l_axis = "nul"
input_player14_r = "nul"
input_player14_r_btn = "nul"
input_player14_r_axis = "nul"
input_player14_l2 = "nul"
input_player14_l2_btn = "nul"
input_player14_l2_axis = "nul"
input_player14_r2 = "nul"
input_player14_r2_btn = "nul"
input_player14_r2_axis = "nul"
input_player14_l3 = "nul"
input_player14_l3_btn = "nul"
input_player14_l3_axis = "nul"
input_player14_r3 = "nul"
input_player14_r3_btn = "nul"
input_player14_r3_axis = "nul"
input_player14_l_x_plus = "nul"
input_player14_l_x_plus_btn = "nul"
input_player14_l_x_plus_axis = "nul"
input_player14_l_x_minus = "nul"
input_player14_l_x_minus_btn = "nul"
input_player14_l_x_minus_axis = "nul"
input_player14_l_y_plus = "nul"
input_player14_l_y_plus_btn = "nul"
input_player14_l_y_plus_axis = "nul"
input_player14_l_y_minus = "nul"
input_player14_l_y_minus_btn = "nul"
input_player14_l_y_minus_axis = "nul"
input_player14_r_x_plus = "nul"
input_player14_r_x_plus_btn = "nul"
input_player14_r_x_plus_axis = "nul"
input_player14_r_x_minus = "nul"
input_player14_r_x_minus_btn = "nul"
input_player14_r_x_minus_axis = "nul"
input_player14_r_y_plus = "nul"
input_player14_r_y_plus_btn = "nul"
input_player14_r_y_plus_axis = "nul"
input_player14_r_y_minus = "nul"
input_player14_r_y_minus_btn = "nul"
input_player14_r_y_minus_axis = "nul"
input_player14_turbo = "nul"
input_player14_turbo_btn = "nul"
input_player14_turbo_axis = "nul"
input_player15_b = "nul"
input_player15_b_btn = "nul"
input_player15_b_axis = "nul"
input_player15_y = "nul"
input_player15_y_btn = "nul"
input_player15_y_axis = "nul"
input_player15_select = "nul"
input_player15_select_btn = "nul"
input_player15_select_axis = "nul"
input_player15_start = "nul"
input_player15_start_btn = "nul"
input_player15_start_axis = "nul"
input_player15_up = "nul"
input_player15_up_btn = "nul"
input_player15_up_axis = "nul"
input_player15_down = "nul"
input_player15_down_btn = "nul"
input_player15_down_axis = "nul"
input_player15_left = "nul"
input_player15_left_btn = "nul"
input_player15_left_axis = "nul"
input_player15_right = "nul"
input_player15_right_btn = "nul"
input_player15_right_axis = "nul"
input_player15_a = "nul"
input_player15_a_btn = "nul"
input_player15_a_axis = "nul"
input_player15_x = "nul"
input_player15_x_btn = "nul"
input_player15_x_axis = "nul"
input_player15_l = "nul"
input_player15_l_btn = "nul"
input_player15_l_axis = "nul"
input_player15_r = "nul"
input_player15_r_btn = "nul"
input_player15_r_axis = "nul"
input_player15_l2 = "nul"
input_player15_l2_btn = "nul"
input_player15_l2_axis = "nul"
input_player15_r2 = "nul"
input_player15_r2_btn = "nul"
input_player15_r2_axis = "nul"
input_player15_l3 = "nul"
input_player15_l3_btn = "nul"
input_player15_l3_axis = "nul"
input_player15_r3 = "nul"
input_player15_r3_btn = "nul"
input_player15_r3_axis = "nul"
input_player15_l_x_plus = "nul"
input_player15_l_x_plus_btn = "nul"
input_player15_l_x_plus_axis = "nul"
input_player15_l_x_minus = "nul"
input_player15_l_x_minus_btn = "nul"
input_player15_l_x_minus_axis = "nul"
input_player15_l_y_plus = "nul"
input_player15_l_y_plus_btn = "nul"
input_player15_l_y_plus_axis = "nul"
input_player15_l_y_minus = "nul"
input_player15_l_y_minus_btn = "nul"
input_player15_l_y_minus_axis = "nul"
input_player15_r_x_plus = "nul"
input_player15_r_x_plus_btn = "nul"
input_player15_r_x_plus_axis = "nul"
input_player15_r_x_minus = "nul"
input_player15_r_x_minus_btn = "nul"
input_player15_r_x_minus_axis = "nul"
input_player15_r_y_plus = "nul"
input_player15_r_y_plus_btn = "nul"
input_player15_r_y_plus_axis = "nul"
input_player15_r_y_minus = "nul"
input_player15_r_y_minus_btn = "nul"
input_player15_r_y_minus_axis = "nul"
input_player15_turbo = "nul"
input_player15_turbo_btn = "nul"
input_player15_turbo_axis = "nul"
input_player16_b = "nul"
input_player16_b_btn = "nul"
input_player16_b_axis = "nul"
input_player16_y = "nul"
input_player16_y_btn = "nul"
input_player16_y_axis = "nul"
input_player16_select = "nul"
input_player16_select_btn = "nul"
input_player16_select_axis = "nul"
input_player16_start = "nul"
input_player16_start_btn = "nul"
input_player16_start_axis = "nul"
input_player16_up = "nul"
input_player16_up_btn = "nul"
input_player16_up_axis = "nul"
input_player16_down = "nul"
input_player16_down_btn = "nul"
input_player16_down_axis = "nul"
input_player16_left = "nul"
input_player16_left_btn = "nul"
input_player16_left_axis = "nul"
input_player16_right = "nul"
input_player16_right_btn = "nul"
input_player16_right_axis = "nul"
input_player16_a = "nul"
input_player16_a_btn = "nul"
input_player16_a_axis = "nul"
input_player16_x = "nul"
input_player16_x_btn = "nul"
input_player16_x_axis = "nul"
input_player16_l = "nul"
input_player16_l_btn = "nul"
input_player16_l_axis = "nul"
input_player16_r = "nul"
input_player16_r_btn = "nul"
input_player16_r_axis = "nul"
input_player16_l2 = "nul"
input_player16_l2_btn = "nul"
input_player16_l2_axis = "nul"
input_player16_r2 = "nul"
input_player16_r2_btn = "nul"
input_player16_r2_axis = "nul"
input_player16_l3 = "nul"
input_player16_l3_btn = "nul"
input_player16_l3_axis = "nul"
input_player16_r3 = "nul"
input_player16_r3_btn = "nul"
input_player16_r3_axis = "nul"
input_player16_l_x_plus = "nul"
input_player16_l_x_plus_btn = "nul"
input_player16_l_x_plus_axis = "nul"
input_player16_l_x_minus = "nul"
input_player16_l_x_minus_btn = "nul"
input_player16_l_x_minus_axis = "nul"
input_player16_l_y_plus = "nul"
input_player16_l_y_plus_btn = "nul"
input_player16_l_y_plus_axis = "nul"
input_player16_l_y_minus = "nul"
input_player16_l_y_minus_btn = "nul"
input_player16_l_y_minus_axis = "nul"
input_player16_r_x_plus = "nul"
input_player16_r_x_plus_btn = "nul"
input_player16_r_x_plus_axis = "nul"
input_player16_r_x_minus = "nul"
input_player16_r_x_minus_btn = "nul"
input_player16_r_x_minus_axis = "nul"
input_player16_r_y_plus = "nul"
input_player16_r_y_plus_btn = "nul"
input_player16_r_y_plus_axis = "nul"
input_player16_r_y_minus = "nul"
input_player16_r_y_minus_btn = "nul"
input_player16_r_y_minus_axis = "nul"
input_player16_turbo = "nul"
input_player16_turbo_btn = "nul"
input_player16_turbo_axis = "nul"
core_specific_config = "false"
libretro_log_level = "0"
log_verbosity = "false"
perfcnt_enable = "false"
archive_mode = "0"
I have retroarch with ipac4 and genesis setup fine.  I am using retropad.  See my Sega Genesis.cfg.  Now I am using direction keys for player 1 as you are.  My buttons are configured differently but pretty much all I do with retro arch is get 1 system working and copy the config to the next system, test and move on.  Hope this helps you out.  Good luck.
As a side note I am sure there is a way to load back to default settings in retro arch if you have not gotten any systems going, there are just so many options and if you start mucking around and don't remember what you did it will be hard to figure out what is wrong so starting over from the default config may be best as well at this point depending on how many input settings or other settings you have been playing with.  Good luck.
WOW thank you, i used a retroache pack provided by simply austin, i guess all the settings in there were configed ready for a xbox pad (i really dont know), all i did was copy your .cfg set up and changed to suit my ipac and works great. I have tried that already but wasnt having none of it, i bet i had them doubled up as hot keys too and was causing problems.
Anyway thanks again, i can crack on :)
