hyperspin in general
nathan1974au
is there a way to make a single png or swf refresh when the wheel moves. instead of making 1000s of images of the same picture to do the same job. or is there a program that can create one single picture and save over 9000 images to create same picture?.
(Midlife crisis) some have hot rods, some have gold chains, I have arcade machine with hyperspin.
got one image to move back and forth as wheel moves. in the state it's at with one image located in the default locks on screen unless you exit and return
HyperHQ -> wheel settings -> Navigation/Themes
Check Reload backgrounds
Check Animate Out Default Themes
Does this solve your problem with the default theme staying static and not reloading?
it worked thank you very much saved me days!
