MydknyteStyrm Posted July 8, 2015 Posted July 8, 2015 I am trying to get retroarch to work with SNES emulation, and I want to use the control panel, not my xbox controller. First, is it possible in RetroArch to use a USB and keyboard inputs simultaneously? Should I use Xpadder with RetroArch? I cant seem to get anything working. I have 4 ultrastiks, and 2 xbox controllers. The other issue I had was every time I started retroarch, it would recognize the two xbox controllers but not the ultrastiks, until i unplugged the x360 pads. Now I can select Ultrastik 1, but I still am nowhere. Any insight that anyone can provide, I would be indebted. Ive spent the better part of two days just trying to get retroarch going. Thanks! Sent from my iPhone using Tapatalk
pofo14 Posted July 8, 2015 Posted July 8, 2015 Is your goal to get the ultrastik working or your control panel / ipac? If it is the control panel / ipac I have a post in the RL forum which explained how to set it up for genesis, but would be pretty much the same for snes. Try that out and I can help if you have any questions along the way. The post is more about setting up RetroArch so it won't matter want your are using (HL or RL) http://www.rlauncher.com/forum/showthread.php?t=1421 I should add that it looks like RetroArch just release v1.2 this week. This was based on the 5/11 nightly build, but I would imagine that not much has changed in these steps.
