Project 64 2.2.0.3
5thWolf
What big changes have i seen? None!!!! I use Retroarch...hahahahahahahaahaha!!!!
I'll have a look at it later. I use it as an alternate emulator for some of the games that won't work in Retroarch.
Don't know if this helps but...
Project64 2.2.0.3
Language: clean up of text
RDB Changes: lots
NRage: ignore raw when mempak set
NRage: Default to mempak
Project64: code clean up
RSP: code clean up
Project64 2.2.0.2
RDB Changes: lots
Glide: fixed memory leak in config window
Glide: Stop assert on non utf8/ansi internal name
Glide: Be able to show errors when in debug mode
Project64: All language files are utf8 instead of ansi
Project64: Upgraded 7zip library to 9.2
Project64: Hacks in rdb are now applied to jabo and glide plugin only
Project64: fixed some bugs in dynamically changing plugins
Rsp: Optimize a few recompiler opcodes
Rsp: Used standard types
Project64 2.2.0.1
Input: dynamic link xinput (should work better in XP)
Update project settings for VS2013 (should work better in XP)
Upated rdb file
update glide.rdb
Updated cheat files
This ^^
(Tapatalk)
Not looking for change log. Just curious how people's experience are running their games compared to 2.1. Several games had issues last release still.
~5thWolf~
